[PATCH] MAINTAINERS: Fix ANDROID AB unknown file entry
Commit 19a91f2464a8 ("Create a new boot/ directory") moved the android_ab.c code under boot/android_ab but did not update the MAINTAINERS entry.
Update it so that the maintainer will get cc'ed again.
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- MAINTAINERS | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 7c1cb2dc4dc0..f6de883a7d8f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -60,8 +60,8 @@ ANDROID AB M: Igor Opaniuk igor.opaniuk@gmail.com R: Sam Protsenko semen.protsenko@linaro.org S: Maintained +F: boot/android_ab.c F: cmd/ab_select.c -F: common/android_ab.c F: doc/android/ab.rst F: include/android_ab.h F: test/py/tests/test_android/test_ab.py
--- base-commit: 9e53e45292ee2f1d9d2ccc59914b161bef9b10d7 change-id: 20231220-maintainers-fix-ab-2afa7cee97bd
Hi Mattijs,
On Wed, Dec 20, 2023 at 10:43 AM Mattijs Korpershoek mkorpershoek@baylibre.com wrote:
Thanks for the patch! Would you mind adding corresponding "Fixes" tag below your Signed-off?
Other than that LGTM:
Reviewed-by: Sam Protsenko semen.protsenko@linaro.org
Hi Sam,
Thank you for your review.
On Thu, Dec 21, 2023 at 08:15, Sam Protsenko semen.protsenko@linaro.org wrote:
Hi Mattijs,
I don't mind, will send a v2.
Mattijs Korpershoek
Sam Protsenko
