[U-Boot] [u-boot-imx] Pull request for u-boot-imx tree
Hello Stefano,
I have prepared a branch with the patches I got acked on the mailing list while you were in VAC.
The following changes since commit baff308162c3980e7616b624e19889a4d757aae8:
i.MX28: Avoid redefining serial_put[cs]() (2012-05-09 12:49:14 +0200)
git://github.com/otavio/u-boot.git pending
for you to fetch changes up to e54fdc58c639a94e2c4805612a4d69613eaa9586:
m28evk: use same notation to alloc the 128kB stack (2012-06-11 11:30:01 -0300)
---------------------------------------------------------------- Otavio Salvador (6): i.MX28: Fix a typo in mx28_reg_8 macro m28evk: fix board config include guardian macro name mx28evk: ensure command definition is in alphabetic order mx28evk: fix board config include guardian macro name m28evk: drop duplicated definition of CONFIG_OF_LIBFDT m28evk: use same notation to alloc the 128kB stack
arch/arm/include/asm/arch-mx28/regs-common.h | 2 +- include/configs/m28evk.h | 10 ++++------ include/configs/mx28evk.h | 8 ++++---- 3 files changed, 9 insertions(+), 11 deletions(-)
On 11/06/2012 16:31, Otavio Salvador wrote:
Hello Stefano,
Hello Otavio,
git://github.com/otavio/u-boot.git http://github.com/otavio/u-boot.git pending
Thanks - I am starting to work all i.MX patches I received in the time I was in vacation. It can take a while until I will come at the end of the list ;-)
Best regards, Stefano Babic
Yes; that's why I prepared the branch. It makes easy since those are the patches that got acked. Mine you can check directly on this branch. The other changes I have pending I will send after you catch up :-)
Otavio Salvador
Stefano Babic
