[U-Boot] [PATCH v2] sun5i: a13: Add Olimex SOM board support
Add support for Olimex A13-512-SOM board, and this particular design is like A13-SOM-WIFI can mount on-top of A13-SOM.
https://www.olimex.com/Products/SOM/A13/A13-SOM-512/ https://www.olimex.com/Products/SOM/A13/A13-SOM-WIFI/open-source-hardware
Boot Log: -------- U-Boot SPL 2017.05-00660-gabc3491 (May 23 2017 - 18:03:09) DRAM: 512 MiB CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1
U-Boot 2017.05-00660-gabc3491 (May 23 2017 - 18:03:09 +0530) Allwinner Technology
CPU: Allwinner A13 (SUN5I) Model: Olimex A13-Olinuxino SOM I2C: ready DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0
Cc: Maxime Ripard maxime.ripard@free-electrons.com Signed-off-by: Jagan Teki jagan@openedev.com --- Changes for v2: - Rebase on master - Drop sufix 'wifi' on dts and defconfig files since SOM comes with wifi module by default.
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun5i-a13-olinuxino-som.dts | 174 +++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/A13-OLinuXino-SOM_defconfig | 18 ++++ 4 files changed, 198 insertions(+) create mode 100644 arch/arm/dts/sun5i-a13-olinuxino-som.dts create mode 100644 configs/A13-OLinuXino-SOM_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e2c2584..31ada74 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -231,6 +231,7 @@ dtb-$(CONFIG_MACH_SUN5I) += \ sun5i-a13-inet-98v-rev2.dtb \ sun5i-a13-olinuxino.dtb \ sun5i-a13-olinuxino-micro.dtb \ + sun5i-a13-olinuxino-som.dtb \ sun5i-a13-q8-tablet.dtb \ sun5i-a13-utoo-p66.dtb \ sun5i-gr8-chip-pro.dtb \ diff --git a/arch/arm/dts/sun5i-a13-olinuxino-som.dts b/arch/arm/dts/sun5i-a13-olinuxino-som.dts new file mode 100644 index 0000000..3bb3b7d --- /dev/null +++ b/arch/arm/dts/sun5i-a13-olinuxino-som.dts @@ -0,0 +1,174 @@ +/* + * Copyright 2012 Maxime Ripard maxime.ripard@free-electrons.com + * Copyright 2013 Hans de Goede hdegoede@redhat.com + * Copyright 2017 Jagan Teki jagan@openedev.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun5i-a13.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Olimex A13-Olinuxino SOM"; + compatible = "olimex,a13-olinuxino-som", "allwinner,sun5i-a13"; + + aliases { + serial0 = &uart1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_olinuxinom>; + + power { + label = "a13-olinuxino-micro:green:power"; + gpios = <&pio 6 9 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_olinuxinom>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 6 0 GPIO_ACTIVE_HIGH>; /* PG0 */ + cd-inverted; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +&pio { + mmc0_cd_pin_olinuxinom: mmc0_cd_pin@0 { + allwinner,pins = "PG0"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + led_pins_olinuxinom: led_pins@0 { + allwinner,pins = "PG9"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_20_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PG2"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PG1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; + + usb0_vbus_pin_olinuxinom: usb0_vbus_pin@0 { + allwinner,pins = "PG12"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb1_vbus_pin_olinuxinom: usb1_vbus_pin@0 { + allwinner,pins = "PG11"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_usb0_vbus { + pinctrl-0 = <&usb0_vbus_pin_olinuxinom>; + gpio = <&pio 6 12 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +®_usb1_vbus { + pinctrl-0 = <&usb1_vbus_pin_olinuxinom>; + gpio = <&pio 6 11 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins_b>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 6 2 GPIO_ACTIVE_HIGH>; /* PG2 */ + usb0_vbus_det-gpio = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index a512a20..55d7590 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -73,6 +73,11 @@ F: include/configs/sun9i.h F: configs/Merrii_A80_Optimus_defconfig F: include/configs/sun50i.h
+A13-OLIMEX-SOM-WIFI BOARD +M: Jagan Teki jagan@openedev.com +S: Maintained +F: configs/A13-OLinuXino-SOM_defconfig + A20-OLIMEX-SOM-EVB BOARD M: Marcus Cooper codekipper@gmail.com S: Maintained diff --git a/configs/A13-OLinuXino-SOM_defconfig b/configs/A13-OLinuXino-SOM_defconfig new file mode 100644 index 0000000..da43157 --- /dev/null +++ b/configs/A13-OLinuXino-SOM_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN5I=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_EMR1=0 +CONFIG_MMC0_CD_PIN="PG0" +CONFIG_USB1_VBUS_PIN="PG11" +CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-som" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUNXI_NO_PMIC=y +CONFIG_USB_EHCI_HCD=y
Boot Log:
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
Jagan Teki
Maxime Ripard
