[PATCH] env: Fix invalid env handling in env_init()
29 May
2020
29 May
'20
7:51 p.m.
In case the env storage driver marks environment as ENV_INVALID, we must reset the $ret return value to -ENOENT to let the env init code reset the environment to the default one a bit further down.
Signed-off-by: Marek Vasut marex@denx.de --- env/env.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/env/env.c b/env/env.c index dcc25c030b..024d36fdbe 100644 --- a/env/env.c +++ b/env/env.c @@ -300,6 +300,9 @@ int env_init(void)
debug("%s: Environment %s init done (ret=%d)\n", __func__, drv->name, ret); + + if (gd->env_valid == ENV_INVALID) + ret = -ENOENT; }
if (!prio)
2.25.1
1812
