[PATCH v2 0/3] stm32mp1: board: add support of CONFIG_ENV_IS_IN_MMC
Rebased serie [1] with minor modification for avenger96 board (as SD card is no more used for environment, replaced by SPI-NOR)
This serie depends on ENV patches [2] (RESEND of [3])
[1] http://patchwork.ozlabs.org/project/uboot/list/?series=165333 [2] http://patchwork.ozlabs.org/project/uboot/list/?series=183363 [3] http://patchwork.ozlabs.org/project/uboot/list/?series=165325
Patrick
Changes in v2: - remove impact on avenger96 board as ENV is saved in NOR for DHCOR SOM (CONFIG_ENV_IS_IN_SPI_FLASH in stm32mp15_dhcor_basic_defconfig)
Patrick Delaunay (3): stm32mp1: board: add support of CONFIG_ENV_IS_IN_MMC stm32mp1: use a specific SD/eMMC partition for U-Boot enviromnent configs:stm32mp1: activate env config in SPL
arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 1 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 1 + board/st/stm32mp1/stm32mp1.c | 20 +++++++++++++++++--- configs/stm32mp15_basic_defconfig | 8 ++++---- configs/stm32mp15_trusted_defconfig | 5 +---- 5 files changed, 24 insertions(+), 11 deletions(-)
Add support of CONFIG_ENV_IS_IN_MMC in env_get_location, used for all mmc device (SD card and eMMC). The 2 configs CONFIG_ENV_IS_IN_MMC and CONFIG_ENV_IS_IN_EXT4 are incompatible.
Add the weak function mmc_get_env_dev to select the mmc boot instance.
Reviewed-by: Patrice Chotard patrice.chotard@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
(no changes since v1)
board/st/stm32mp1/stm32mp1.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 4553329b25..b695e8bc6b 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -833,6 +833,11 @@ enum env_location env_get_location(enum env_operation op, int prio) return ENVL_UNKNOWN;
switch (bootmode & TAMP_BOOT_DEVICE_MASK) { +#ifdef CONFIG_ENV_IS_IN_MMC + case BOOT_FLASH_SD: + case BOOT_FLASH_EMMC: + return ENVL_MMC; +#endif #ifdef CONFIG_ENV_IS_IN_EXT4 case BOOT_FLASH_SD: case BOOT_FLASH_EMMC: @@ -875,6 +880,15 @@ const char *env_ext4_get_dev_part(void) } #endif
+#if defined(CONFIG_ENV_IS_IN_MMC) +int mmc_get_env_dev(void) +{ + u32 bootmode = get_bootmode(); + + return (bootmode & TAMP_BOOT_INSTANCE_MASK) - 1; +} +#endif + #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, bd_t *bd) {
- case BOOT_FLASH_SD:
- case BOOT_FLASH_EMMC:
return ENVL_MMC;
- u32 bootmode = get_bootmode();
- return (bootmode & TAMP_BOOT_INSTANCE_MASK) - 1;
+} +#endif
Applied to u-boot-stm/master
Thanks
Patrice
Save the environment at the end of the U-Boot partition, the GPT partition named "ssbl" in SD card or eMMC and avoid requirements on the "bootfs" file system generated via specific raw tools (like wic and genimage).
With the previous configuration of the U-Boot environment saved in ext4 file, U-Boot need to create/modify the file uenv.txt in the ext4 file system; so this EXT4 file system need to be generated without some functionality, like metadata_csum and dir_index, because they are not supported by U-Boot.
arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 1 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 1 + configs/stm32mp15_basic_defconfig | 5 +---- configs/stm32mp15_trusted_defconfig | 5 +---- 4 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi index c52abeb1e7..3635965ca4 100644 --- a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi @@ -16,6 +16,7 @@ config { u-boot,boot-led = "heartbeat"; u-boot,error-led = "error"; + u-boot,mmc-env-partition = "ssbl"; st,adc_usb_pd = <&adc1 18>, <&adc1 19>; st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; diff --git a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi index 84af7fa47b..d3ca5d1e58 100644 --- a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi @@ -17,6 +17,7 @@ config { u-boot,boot-led = "heartbeat"; u-boot,error-led = "error"; + u-boot,mmc-env-partition = "ssbl"; st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; }; diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index c7dd2926c9..acf9331b4b 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -53,13 +53,10 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_EXT4_INTERFACE="mmc" -CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" -CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index ca4a10813b..b7ff4b2aec 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -40,13 +40,10 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_EXT4_INTERFACE="mmc" -CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" -CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r"
Changes in v2:
st,adc_usb_pd = <&adc1 18>, <&adc1 19>; st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>;u-boot,mmc-env-partition = "ssbl";
st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; };u-boot,mmc-env-partition = "ssbl";
Thanks
Patrice
Activate env config in SPL with CONFIG_SPL_ENV_SUPPORT and use CONFIG_IS_ENABLED macro to test the activated CONFIG_$(SPL_)ENV_IS_IN_... in env_get_location.
board/st/stm32mp1/stm32mp1.c | 8 ++++---- configs/stm32mp15_basic_defconfig | 3 +++ 2 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index b695e8bc6b..7abb90d1d4 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -833,22 +833,22 @@ enum env_location env_get_location(enum env_operation op, int prio) return ENVL_UNKNOWN;
switch (bootmode & TAMP_BOOT_DEVICE_MASK) { -#ifdef CONFIG_ENV_IS_IN_MMC +#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) case BOOT_FLASH_SD: case BOOT_FLASH_EMMC: return ENVL_MMC; #endif -#ifdef CONFIG_ENV_IS_IN_EXT4 +#if CONFIG_IS_ENABLED(ENV_IS_IN_EXT4) case BOOT_FLASH_SD: case BOOT_FLASH_EMMC: return ENVL_EXT4; #endif -#ifdef CONFIG_ENV_IS_IN_UBI +#if CONFIG_IS_ENABLED(ENV_IS_IN_UBI) case BOOT_FLASH_NAND: case BOOT_FLASH_SPINAND: return ENVL_UBI; #endif -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#if CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH) case BOOT_FLASH_NOR: return ENVL_SPI_FLASH; #endif diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index acf9331b4b..31597dbc40 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y @@ -61,6 +62,8 @@ CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_SPL_ENV_IS_NOWHERE is not set +# CONFIG_SPL_ENV_IS_IN_SPI_FLASH is not set CONFIG_STM32_ADC=y CONFIG_SET_DFU_ALT_INFO=y CONFIG_USB_FUNCTION_FASTBOOT=y
Thanks
Patrice
Patrice CHOTARD
Patrick Delaunay
