[PATCH 1/1] riscv: separate .data and .text sections of EFI binaries
EFI binaries should not contain sections that are both writable and executable. Separate the RX .text section from the RW .data section
Adjust the section alignment to 4096 bytes.
Fix conflicting SPDX license information in linker scripts introduced by commit 7215787c4ea4 ("SPDX: Convert single license tags to Linux Kernel style").
Fixes: 7215787c4ea4 ("SPDX: Convert single license tags to Linux Kernel style") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- arch/riscv/lib/crt0_riscv_efi.S | 39 ++++++++++++++++++++++-------- arch/riscv/lib/elf_riscv32_efi.lds | 26 ++++++++++++-------- arch/riscv/lib/elf_riscv64_efi.lds | 26 ++++++++++++-------- 3 files changed, 61 insertions(+), 30 deletions(-)
diff --git a/arch/riscv/lib/crt0_riscv_efi.S b/arch/riscv/lib/crt0_riscv_efi.S index 793eefdd883..46b08552371 100644 --- a/arch/riscv/lib/crt0_riscv_efi.S +++ b/arch/riscv/lib/crt0_riscv_efi.S @@ -53,7 +53,7 @@ pe_header: .long IMAGE_NT_SIGNATURE /* 'PE' */ coff_header: .short PE_MACHINE /* RISC-V 64/32-bit */ - .short 2 /* nr_sections */ + .short 3 /* nr_sections */ .long 0 /* TimeDateStamp */ .long 0 /* PointerToSymbolTable */ .long 0 /* NumberOfSymbols */ @@ -144,18 +144,37 @@ section_table: .byte 0 .byte 0 .byte 0 /* end of 0 padding of section name */ - .long _edata - _start /* VirtualSize */ + .long _etext - _start /* VirtualSize */ .long _start - ImageBase /* VirtualAddress */ - .long _edata - _start /* SizeOfRawData */ + .long _etext - _start /* SizeOfRawData */ .long _start - ImageBase /* PointerToRawData */ + .long 0 /* PointerToRelocations (0 for executables) */ + .long 0 /* PointerToLineNumbers (0 for executables) */ + .short 0 /* NumberOfRelocations (0 for executables) */ + .short 0 /* NumberOfLineNumbers (0 for executables) */ + /* Characteristics (section flags) */ + .long (IMAGE_SCN_MEM_READ | \ + IMAGE_SCN_MEM_EXECUTE | \ + IMAGE_SCN_CNT_CODE) + + .ascii ".data" + .byte 0 + .byte 0 + .byte 0 /* end of 0 padding of section name */ + .long _edata - _data /* VirtualSize */ + .long _data - ImageBase /* VirtualAddress */ + .long _edata - _data /* SizeOfRawData */ + .long _data - ImageBase /* PointerToRawData */ + .long 0 /* PointerToRelocations */ + .long 0 /* PointerToLineNumbers */ + .short 0 /* NumberOfRelocations */ + .short 0 /* NumberOfLineNumbers */ + /* Characteristics (section flags) */ + .long (IMAGE_SCN_MEM_WRITE | \ + IMAGE_SCN_MEM_READ | \ + IMAGE_SCN_CNT_INITIALIZED_DATA)
- .long 0 /* PointerToRelocations (0 for executables) */ - .long 0 /* PointerToLineNumbers (0 for executables) */ - .short 0 /* NumberOfRelocations (0 for executables) */ - .short 0 /* NumberOfLineNumbers (0 for executables) */ - .long 0xe0500020 /* Characteristics (section flags) */ - - .align 9 + .align 12 _start: addi sp, sp, -(SIZE_LONG * 3) SAVE_LONG(a0, 0) diff --git a/arch/riscv/lib/elf_riscv32_efi.lds b/arch/riscv/lib/elf_riscv32_efi.lds index c3e0d20d577..7b9bd7b7f15 100644 --- a/arch/riscv/lib/elf_riscv32_efi.lds +++ b/arch/riscv/lib/elf_riscv32_efi.lds @@ -1,14 +1,18 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: BSD-2-Clause */ /* * U-Boot riscv32 EFI linker script * - * SPDX-License-Identifier: BSD-2-Clause - * * Modified from arch/arm/lib/elf_aarch64_efi.lds */
OUTPUT_FORMAT("elf32-littleriscv", "elf32-littleriscv", "elf32-littleriscv") OUTPUT_ARCH(riscv) + +PHDRS +{ + data PT_LOAD FLAGS(3); /* SHF_WRITE | SHF_ALLOC */ +} + ENTRY(_start) SECTIONS { @@ -20,11 +24,17 @@ SECTIONS *(.gnu.linkonce.t.*) *(.srodata) *(.rodata*) + . = ALIGN(16); + *(.dynamic); . = ALIGN(512); } + .rela.dyn : { *(.rela.dyn) } + .rela.plt : { *(.rela.plt) } + .rela.got : { *(.rela.got) } + .rela.data : { *(.rela.data) *(.rela.data*) } _etext = .; _text_size = . - _text; - .dynamic : { *(.dynamic) } + . = ALIGN(4096); .data : { _data = .; *(.sdata) @@ -49,12 +59,8 @@ SECTIONS . = ALIGN(512); _bss_end = .; _edata = .; - } - .rela.dyn : { *(.rela.dyn) } - .rela.plt : { *(.rela.plt) } - .rela.got : { *(.rela.got) } - .rela.data : { *(.rela.data) *(.rela.data*) } - _data_size = . - _etext; + } :data + _data_size = _edata - _data;
. = ALIGN(4096); .dynsym : { *(.dynsym) } diff --git a/arch/riscv/lib/elf_riscv64_efi.lds b/arch/riscv/lib/elf_riscv64_efi.lds index ecb91395486..d0b4f3d1d64 100644 --- a/arch/riscv/lib/elf_riscv64_efi.lds +++ b/arch/riscv/lib/elf_riscv64_efi.lds @@ -1,14 +1,18 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: BSD-2-Clause */ /* * U-Boot riscv64 EFI linker script * - * SPDX-License-Identifier: BSD-2-Clause - * * Modified from arch/arm/lib/elf_aarch64_efi.lds */
OUTPUT_FORMAT("elf64-littleriscv", "elf64-littleriscv", "elf64-littleriscv") OUTPUT_ARCH(riscv) + +PHDRS +{ + data PT_LOAD FLAGS(3); /* SHF_WRITE | SHF_ALLOC */ +} + ENTRY(_start) SECTIONS { @@ -20,11 +24,17 @@ SECTIONS *(.gnu.linkonce.t.*) *(.srodata) *(.rodata*) + . = ALIGN(16); + *(.dynamic); . = ALIGN(512); } + .rela.dyn : { *(.rela.dyn) } + .rela.plt : { *(.rela.plt) } + .rela.got : { *(.rela.got) } + .rela.data : { *(.rela.data) *(.rela.data*) } _etext = .; _text_size = . - _text; - .dynamic : { *(.dynamic) } + . = ALIGN(4096); .data : { _data = .; *(.sdata) @@ -49,12 +59,8 @@ SECTIONS . = ALIGN(512); _bss_end = .; _edata = .; - } - .rela.dyn : { *(.rela.dyn) } - .rela.plt : { *(.rela.plt) } - .rela.got : { *(.rela.got) } - .rela.data : { *(.rela.data) *(.rela.data*) } - _data_size = . - _etext; + } :data + _data_size = _edata - _data;
Lets not do two distinct changes like this in a single commit, thanks.
