[U-Boot] [PATCH] include: net: Simplify the usage of __always_inline
Since commit de4d2e9e7ce0f9 (" bitops: Add fls_long and __ffs64") <linux/compiler.h> is included in include/linux/bitops.h, which allows us to marking a function as 'always_inline' in a simpler format.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/net.h | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/include/net.h b/include/net.h index ebed29a..ac44d61 100644 --- a/include/net.h +++ b/include/net.h @@ -181,8 +181,7 @@ int eth_unregister(struct eth_device *dev);/* Remove network device */
extern struct eth_device *eth_current;
-static inline __attribute__((always_inline)) -struct eth_device *eth_get_dev(void) +static __always_inline struct eth_device *eth_get_dev(void) { return eth_current; } @@ -200,14 +199,14 @@ static inline unsigned char *eth_get_ethaddr(void) /* Used only when NetConsole is enabled */ int eth_is_active(struct eth_device *dev); /* Test device for active state */ /* Set active state */ -static inline __attribute__((always_inline)) int eth_init_state_only(void) +static __always_inline int eth_init_state_only(void) { eth_get_dev()->state = ETH_STATE_ACTIVE;
return 0; } /* Set passive state */ -static inline __attribute__((always_inline)) void eth_halt_state_only(void) +static __always_inline void eth_halt_state_only(void) { eth_get_dev()->state = ETH_STATE_PASSIVE; } @@ -657,7 +656,7 @@ int nc_input_packet(uchar *pkt, struct in_addr src_ip, unsigned dest_port, unsigned src_port, unsigned len); #endif
-static inline __attribute__((always_inline)) int eth_is_on_demand_init(void) +static __always_inline int eth_is_on_demand_init(void) { #ifdef CONFIG_NETCONSOLE extern enum proto_t net_loop_last_protocol;
Hi Fabio,
Applied to u-boot-net/master, thanks! -Joe
Fabio Estevam
Joe Hershberger
