[U-Boot] [PATCH 3/3] dm: dts: ls2085a: Add dts files for LS2085AQDS and LS2085ARDB
Add dts source files for LS2085AQDS and LS2085ARDB boards.
Signed-off-by: Haikun Wang haikun.wang@freescale.com --- arch/arm/dts/Makefile | 2 ++ arch/arm/dts/fsl-ls2085a-qds.dts | 53 ++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/fsl-ls2085a-rdb.dts | 35 ++++++++++++++++++++++++++ 3 files changed, 90 insertions(+) create mode 100644 arch/arm/dts/fsl-ls2085a-qds.dts create mode 100644 arch/arm/dts/fsl-ls2085a-rdb.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 15d60b9..2b64851 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -56,6 +56,8 @@ dtb-$(CONFIG_SOCFPGA) += \
dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ ls1021a-twr.dtb +dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2085a-qds.dtb \ + fsl-ls2085a-rdb.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/fsl-ls2085a-qds.dts b/arch/arm/dts/fsl-ls2085a-qds.dts new file mode 100644 index 0000000..4477e54 --- /dev/null +++ b/arch/arm/dts/fsl-ls2085a-qds.dts @@ -0,0 +1,53 @@ +/* + * Freescale ls2085a QDS board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls2085a.dtsi" + +/ { + model = "Freescale Layerscape 2085a QDS Board"; + compatible = "fsl,ls2085a-qds", "fsl,ls2085a"; + + aliases { + spi1 = &dspi; + }; +}; + +&dspi { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <1>; + }; + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <2>; + }; +}; diff --git a/arch/arm/dts/fsl-ls2085a-rdb.dts b/arch/arm/dts/fsl-ls2085a-rdb.dts new file mode 100644 index 0000000..25278df --- /dev/null +++ b/arch/arm/dts/fsl-ls2085a-rdb.dts @@ -0,0 +1,35 @@ +/* + * Freescale ls2085a RDB board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "fsl-ls2085a.dtsi" + +/ { + model = "Freescale Layerscape 2085a RDB Board"; + compatible = "fsl,ls2085a-rdb", "fsl,ls2085a"; + + aliases { + spi1 = &dspi; + }; +}; + +&dspi { + bus-num = <0>; + status = "okay"; + + dflash0: n25q512a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <3000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; +};
Haikun Wang
