[PATCH] net: ftgmac100: Fixed NC-SI PHY device cannot get
The NC-SI interface does not need the MDIO bus and the NC-SI PHY device cannot get from dm_eth_phy_connect. Therefore, use phy_connect directly here.
Signed-off-by: Jacky Chou jacky_chou@aspeedtech.com --- drivers/net/ftgmac100.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 9b536fd5ab..256a519020 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -223,7 +223,7 @@ static int ftgmac100_phy_init(struct udevice *dev) struct phy_device *phydev; int ret;
- if (IS_ENABLED(CONFIG_DM_MDIO)) + if (IS_ENABLED(CONFIG_DM_MDIO) && priv->phy_mode != PHY_INTERFACE_MODE_NCSI) phydev = dm_eth_phy_connect(dev); else phydev = phy_connect(priv->bus, priv->phy_addr, dev, priv->phy_mode);
Acked-by: Leo Yu-Chi Liang ycliang@andestech.com
Jacky Chou
Leo Liang
