[U-Boot] Problem booting linux kernel due to garbled available machine support
Hello All,
I'm having a problem booting a linux kernel built with Marvell buildroot-sdk-6.0 for an Armada XP development board (DB-78460-BP). The kernel messages indicate that the machine id is not recognized or not supported, but I believe this is because the available machine support is all junk.
Marvell>> bootm 0x2000000 ## Booting kernel from Legacy Image at 02000000 ... Image Name: linux-3.0 Created: 2012-08-02 14:04:49 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3303200 Bytes = 3.2 MB Load Address: 02008000 Entry Point: 02008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Using machid 0xbdc from environment
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Error: unrecognized/unsupported machine ID (r1 = 0x00000bdc).
Available machine support:
ID (hex) NAME 00000000 (null) c000e150 (null) À á0Ø-é°LââßMâMëP1å ã c000e234 ¬õÀ À á0Ø-é°Lâ
Please check your kernel config and/or bootloader.
These are the machine types in my kernel config which should be showing up in the available machine support, but for some reason is garbled.
[dallasc /development/dallasc/TS-3400/buildroot-2011.05-sdk6.0/output/build/linux-3.0.6] grep '^CONFIG_MACH' .config CONFIG_MACH_ARMADA_XP_DB=y CONFIG_MACH_ARMADA_XP_RDSRV=y CONFIG_MACH_ARMADA_XP_RD_NAS=y
[dallasc /development/dallasc/TS-3400/buildroot-2011.05-sdk6.0/output/build/linux-3.0.6] grep MACH_ARMADA arch/arm/tools/mach-types armada_xp_fpga MACH_ARMADA_XP_FPGA ARMADA_XP_FPGA 528 armada_xp_db MACH_ARMADA_XP_DB ARMADA_XP_DB 3036 armada_xp_rd_nas MACH_ARMADA_XP_RD_NAS ARMADA_XP_RD_NAS 3500 armada_xp_rdsrv MACH_ARMADA_XP_RDSRV ARMADA_XP_RDSRV 3037
It looks like the DB-78460-BP board is identifying itself as 0x00000bdc = 3036, which corresponds to the armada_xp_db.
Does anyone have any suggestions on how to debug the cause of the garbling?
Thanks,
Dallas
Dallas Clement
