[U-Boot] unassigned-patches/51: [PATCH] S5PC100: Moved the #defines for PLLs to common header file
The get_pll_clk(int) API returns the PLL frequency based on the (int) argument which is defined locally in clock.c
Moving that #define to common header file (clk.h) would be helpful when using the API from other files.
Signed-off-by: Naveen Krishna Ch ch.naveen@samsung.com
--- Added to GNATS database as unassigned-patches/51
Responsible: patch-coord Message-Id: 1265200544-26547-1-git-send-email-ch.naveen@samsung.com In-Reply-To: References: Patch-Date: Wed Feb 03 13:35:44 +0100 2010
--- cpu/arm_cortexa8/s5pc1xx/clock.c | 7 +------ include/asm-arm/arch-s5pc1xx/clk.h | 6 ++++++ 2 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/cpu/arm_cortexa8/s5pc1xx/clock.c b/cpu/arm_cortexa8/s5pc1xx/clock.c index a9e78dd..19619f9 100644 --- a/cpu/arm_cortexa8/s5pc1xx/clock.c +++ b/cpu/arm_cortexa8/s5pc1xx/clock.c @@ -25,12 +25,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> - -#define APLL 0 -#define MPLL 1 -#define EPLL 2 -#define HPLL 3 -#define VPLL 4 +#include <asm/arch/clk.h>
#define CLK_M 0 #define CLK_D 1 diff --git a/include/asm-arm/arch-s5pc1xx/clk.h b/include/asm-arm/arch-s5pc1xx/clk.h index f1aa44f..3e59abe 100644 --- a/include/asm-arm/arch-s5pc1xx/clk.h +++ b/include/asm-arm/arch-s5pc1xx/clk.h @@ -23,6 +23,12 @@ #ifndef __ASM_ARM_ARCH_CLK_H_ #define __ASM_ARM_ARCH_CLK_H_
+#define APLL 0 +#define MPLL 1 +#define EPLL 2 +#define HPLL 3 +#define VPLL 4 + void s5pc1xx_clock_init(void);
extern unsigned long (*get_pll_clk)(int pllreg);
u-boot@bugs.denx.de
