[U-Boot] [PATCH] test/py/tests/test_sleep.py: Add check for CONFIG_CMD_MISC
We can only run this command if the sleep command is enabled and that depends on CONFIG_CMD_MISC
Signed-off-by: Tom Rini trini@konsulko.com --- test/py/tests/test_sleep.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/py/tests/test_sleep.py b/test/py/tests/test_sleep.py index 5c1a2623fefa..b59a4cfc0fc2 100644 --- a/test/py/tests/test_sleep.py +++ b/test/py/tests/test_sleep.py @@ -9,6 +9,8 @@ def test_sleep(u_boot_console): """Test the sleep command, and validate that it sleeps for approximately the correct amount of time."""
+ if u_boot_console.config.buildconfig.get('config_cmd_misc', 'n') != 'y': + pytest.skip('sleep command not supported') # 3s isn't too long, but is enough to cross a few second boundaries. sleep_time = 3 tstart = time.time()
