[U-Boot] [PATCH] setenv: do console redirection even if previously unset
If "stdout" is not previously set, doing "setenv stdout lcd" had no effect, since console redirection only worked if the environment variable was already set; the second time you run setenv it worked. Most default environments lack stdin/out/err definitions, so I'm sure I'm not alone with this problem.
This patch simply moves a block of code out of a conditional, to do the same work even if the variable was previously unset.
Signed-off-by: Alessandro Rubini rubini@unipv.it Acked-by: Andrea Gallo andrea.gallo@stericsson.com --- common/cmd_nvedit.c | 62 +++++++++++++++++++++++++------------------------- 1 files changed, 31 insertions(+), 31 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 2186205..9f8d531 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -202,6 +202,37 @@ int _do_setenv (int flag, int argc, char *argv[]) break; }
+ /* Check for console redirection */ + if (strcmp(name,"stdin") == 0) { + console = stdin; + } else if (strcmp(name,"stdout") == 0) { + console = stdout; + } else if (strcmp(name,"stderr") == 0) { + console = stderr; + } + + if (console != -1) { + if (argc < 3) { /* Cannot delete it! */ + printf("Can't delete "%s"\n", name); + return 1; + } + +#ifdef CONFIG_CONSOLE_MUX + i = iomux_doenv(console, argv[2]); + if (i) + return i; +#else + /* Try assigning specified device */ + if (console_assign (console, argv[2]) < 0) + return 1; + +#ifdef CONFIG_SERIAL_MULTI + if (serial_assign (argv[2]) < 0) + return 1; +#endif +#endif /* CONFIG_CONSOLE_MUX */ + } + /* * Delete any existing definition */ @@ -229,37 +260,6 @@ int _do_setenv (int flag, int argc, char *argv[]) } #endif
- /* Check for console redirection */ - if (strcmp(name,"stdin") == 0) { - console = stdin; - } else if (strcmp(name,"stdout") == 0) { - console = stdout; - } else if (strcmp(name,"stderr") == 0) { - console = stderr; - } - - if (console != -1) { - if (argc < 3) { /* Cannot delete it! */ - printf("Can't delete "%s"\n", name); - return 1; - } - -#ifdef CONFIG_CONSOLE_MUX - i = iomux_doenv(console, argv[2]); - if (i) - return i; -#else - /* Try assigning specified device */ - if (console_assign (console, argv[2]) < 0) - return 1; - -#ifdef CONFIG_SERIAL_MULTI - if (serial_assign (argv[2]) < 0) - return 1; -#endif -#endif /* CONFIG_CONSOLE_MUX */ - } - /* * Switch to new baudrate if new baudrate is supported */
Dear Alessandro Rubini,
Applied, thanks.
Alessandro Rubini
