Re: [PATCH] doc: ti: Add switch setting for boot modes on AM62 SK
On 1/10/23 3:25 PM, Judith Mendez wrote:
List some common boot modes and their corresponding switch settings for AM62 SK.
Signed-off-by: Judith Mendez jm@ti.com
Acked-by: Andrew Davis afd@ti.com
doc/board/ti/am62x_sk.rst | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst index b1b7d99befb..40d58ea8bfa 100644 --- a/doc/board/ti/am62x_sk.rst +++ b/doc/board/ti/am62x_sk.rst @@ -229,3 +229,32 @@ Image formats: | | SPL DTB 1...N | | | +-------------------+ | +-----------------------+
+Switch Setting for Boot Mode +----------------------------
+Boot Mode pins provide means to select the boot mode and options before the +device is powered up. After every POR, they are the main source to populate +the Boot Parameter Tables.
+The following table shows some common boot modes used on AM62 platform. More +details can be found in the Technical Reference Manual: +https://www.ti.com/lit/pdf/spruiv7 under the `Boot Mode Pins` section.
++--------------+------------+------------+ +|*Boot Mode* | *SW2* | *SW1* | ++--------------+------------+------------+ +| Switch label | 12345678 | 12345678 | ++==============+============+============+ +| SD | 01000000 | 11000010 | ++--------------+------------+------------+ +| OSPI | 00000000 | 11001110 | ++--------------+------------+------------+ +| EMMC | 00000000 | 11010010 | ++--------------+------------+------------+ +| UART | 00000000 | 11011100 | ++--------------+------------+------------+ +| USB DFU | 00000000 | 11001010 | ++--------------+------------+------------+
+For SW2 and SW1, the switch state in the "ON" position = 1.
Hi Judith
Wild... I'm not seeing this on the list? did you get a bounce?
On January 10, 2023 thus sayeth Andrew Davis:
Reviewed-by: Bryan Brattlof bb@ti.com
Andrew Davis
Bryan Brattlof
