[U-Boot] [PATCH 1/2] powerpc/85xx: CONFIG_ENABLE_36BIT_PHYS does not depend on CONFIG_PHYS_64BIT
The macro CONFIG_ENABLE_36BIT_PHYS is used to indicate that the given SOC is capable of 36-bit physical addresses, even if such large addresses are not used. On two boards, this macro was enabled only when building a 36-bit image.
Signed-off-by: Timur Tabi timur@freescale.com --- include/configs/P1022DS.h | 3 ++- include/configs/p1_p2_rdb_pc.h | 3 +-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index a3cccf4..28848bd 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -43,8 +43,9 @@ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */
-#ifdef CONFIG_PHYS_64BIT #define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT #define CONFIG_ADDR_MAP #define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index b9b89cf..df1925f 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -204,9 +204,8 @@ #define CONFIG_BTB
#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ -#ifdef CONFIG_PHYS_64BIT + #define CONFIG_ENABLE_36BIT_PHYS -#endif
#ifdef CONFIG_PHYS_64BIT #define CONFIG_ADDR_MAP 1
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication.
So if a given SOC can support 36-bit addresses, display one of these two messages during boot:
ADDR: 32-bit address map
or
ADDR: 36-bit address map
Also delete the board-specific code that does this.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 12 ++++++++++++ board/freescale/corenet_ds/corenet_ds.c | 4 ---- board/freescale/mpc8536ds/mpc8536ds.c | 7 +------ board/freescale/mpc8572ds/mpc8572ds.c | 6 +----- board/freescale/p1010rdb/p1010rdb.c | 6 +----- board/freescale/p1022ds/p1022ds.c | 8 ++------ board/freescale/p1_p2_rdb/p1_p2_rdb.c | 4 +--- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 8 +------- board/freescale/p2020ds/p2020ds.c | 8 ++------ board/freescale/p2041rdb/p2041rdb.c | 4 ---- 10 files changed, 21 insertions(+), 46 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 27f836c..d691726 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -302,6 +302,18 @@ int cpu_init_r(void) sync(); #endif
+ /* + * If we support 36-bit addressing, then display whether this is a + * 32-bit build or a 36-bit build. + */ +#ifdef CONFIG_ENABLE_36BIT_PHYS +#ifdef CONFIG_PHYS_64BIT + puts("ADDR: 36-bit address map\n"); +#else + puts("ADDR: 32-bit address map\n"); +#endif +#endif + puts ("L2: ");
#if defined(CONFIG_L2_CACHE) diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index b1eecc4..a33c936 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -62,10 +62,6 @@ int checkboard (void) else printf("invalid setting of SW%u\n", PIXIS_LBMAP_SWITCH);
-#ifdef CONFIG_PHYS_64BIT - puts("36-bit Addressing\n"); -#endif - /* Display the RCW, so that no one gets confused as to what RCW * we're actually using for this boot. */ diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index b292e13..b407f1d 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -62,12 +62,7 @@ int checkboard (void) u8 vboot; u8 *pixis_base = (u8 *)PIXIS_BASE;
- puts("Board: MPC8536DS "); -#ifdef CONFIG_PHYS_64BIT - puts("(36-bit addrmap) "); -#endif - - printf ("Sys ID: 0x%02x, " + printf ("Board: MPC8536DS Sys ID: 0x%02x, " "Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", in_8(pixis_base + PIXIS_ID), in_8(pixis_base + PIXIS_VER), in_8(pixis_base + PIXIS_PVER)); diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index b20299e..38eafe0 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -45,11 +45,7 @@ int checkboard (void) u8 vboot; u8 *pixis_base = (u8 *)PIXIS_BASE;
- puts ("Board: MPC8572DS "); -#ifdef CONFIG_PHYS_64BIT - puts ("(36-bit addrmap) "); -#endif - printf ("Sys ID: 0x%02x, " + printf ("Board: MPC8572DS Sys ID: 0x%02x, " "Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", in_8(pixis_base + PIXIS_ID), in_8(pixis_base + PIXIS_VER), in_8(pixis_base + PIXIS_PVER)); diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 03e9da1..7aa2117 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -165,11 +165,7 @@ int checkboard(void) struct cpu_type *cpu;
cpu = gd->cpu; - printf("Board: %sRDB ", cpu->name); -#ifdef CONFIG_PHYS_64BIT - puts("(36-bit addrmap)"); -#endif - puts("\n"); + printf("Board: %sRDB\n", cpu->name);
return 0; } diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 456d9b0..aca30f3 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -56,12 +56,8 @@ int checkboard(void) { u8 sw;
- puts("Board: P1022DS "); -#ifdef CONFIG_PHYS_64BIT - puts("(36-bit addrmap) "); -#endif - - printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", + printf("Board: P1022DS Sys ID: 0x%02x, " + "Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", in_8(&pixis->id), in_8(&pixis->arch), in_8(&pixis->scver));
sw = in_8(&PIXIS_SW(PIXIS_LBMAP_SWITCH)); diff --git a/board/freescale/p1_p2_rdb/p1_p2_rdb.c b/board/freescale/p1_p2_rdb/p1_p2_rdb.c index 864b3ce..6418710 100644 --- a/board/freescale/p1_p2_rdb/p1_p2_rdb.c +++ b/board/freescale/p1_p2_rdb/p1_p2_rdb.c @@ -110,9 +110,7 @@ int checkboard (void)
cpu = gd->cpu; printf ("Board: %sRDB Rev%c\n", cpu->name, board_rev); -#ifdef CONFIG_PHYS_64BIT - puts ("(36-bit addrmap) \n"); -#endif + setbits_be32(&pgpio->gpdir, GPIO_DIR);
/* diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 4671128..abe087b 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -225,13 +225,7 @@ int checkboard(void) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); u8 in, out, io_config, val;
- printf("Board: %s ", CONFIG_BOARDNAME); - -#ifdef CONFIG_PHYS_64BIT - puts("(36-bit addrmap) "); -#endif - - printf("CPLD: V%d.%d PCBA: V%d.0\n", + printf("Board: %s CPLD: V%d.%d PCBA: V%d.0\n", CONFIG_BOARDNAME, in_8(&cpld_data->cpld_rev_major) & 0x0F, in_8(&cpld_data->cpld_rev_minor) & 0x0F, in_8(&cpld_data->pcba_rev) & 0x0F); diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index d3af6cf..e8d31a4 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -61,12 +61,8 @@ int checkboard(void) { u8 sw;
- puts("Board: P2020DS "); -#ifdef CONFIG_PHYS_64BIT - puts("(36-bit addrmap) "); -#endif - - printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", + printf("Board: P2020DS Sys ID: 0x%02x, " + "Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", in_8(&pixis->id), in_8(&pixis->arch), in_8(&pixis->scver));
sw = in_8(&PIXIS_SW(PIXIS_LBMAP_SWITCH)); diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index 6ed404f..6e47204 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -54,10 +54,6 @@ int checkboard(void) sw = CPLD_READ(fbank_sel); printf("vBank: %d\n", sw & 0x1);
-#ifdef CONFIG_PHYS_64BIT - puts("36-bit Addressing\n"); -#endif - /* * Display the RCW, so that no one gets confused as to what RCW * we're actually using for this boot.
or
#if defined(A) && defined(B)
- puts("ADDR: 36-bit address map\n");
+#else
- puts("ADDR: 32-bit address map\n");
+#endif +#endif
- puts ("L2: ");
Wolfgang's being making comments about reducing the boot info we've been outputting so would like his 2 cents on this.
- k
That's not what I want to do. Look at the code more closely.
I understand that, but the patch description explains why this is important.
Dear Kumar Gala,
In message CA7ACAD5-C754-4F8A-BE2E-97E04DD005B2@freescale.com you wrote:
Wolfgang's being making comments about reducing the boot info we've been = outputting so would like his 2 cents on this.
I understand that this is just replacing the implementation, i. e. not adding new output.
But you are right - I'd much rather see this printed for example as part of the "bdinfo" command than with the regular boot messages.
Recently, we've been adding boards that have CONFIG_PCI_SCAN_SHOW defined. Are you saying that we should not be doing that? That adds a lot more text than my patch does.
Examples: http://patchwork.ozlabs.org/patch/108682/ http://patchwork.ozlabs.org/patch/108533/
Kumar, are you okay with not displaying the address map size at all during boot time? If we bury this information in the 'bdinfo' command, we're going to have even more confusion as to which U-Boot we're booting.
Dear Timur Tabi,
Yes, that's what I'm sayin. All this "useful" information should be available easily to everybody who is interested in it - no boubt of that. But it shoudld NOT be printed on each and every boot.
What sort of "confusion" do you have? I see two situations: in 99.99% of all cases U-Boot is just a means to boot an OS, and nobody cares a bit about the actual U-Boot output, as long as the OS is runnign after a few seconds, and rather sooner than later. For a few use cases where developers are working on a board, they might wonder which state a board is in - then itis very useful to have a command to display this information any time they are interested in it - even without having to reboot the system.
It is actually pretty silly to print certain interesting information only at boot time.
The confusion stems mostly from the fact that we've been displaying this information for years. If suddenly we stop displaying it, people are going to think that something is wrong. Also, you need to know which U-Boot you're running before you boot the kernel, because the device tree needs to match. No one is going to think to use the 'bdinfo' command to find it.
Many board configurations come in 32-bit and 36-bit versions. E.g.
make P1022DS_config vs. make P1022DS_36BIT_config
The problem is that this isn't standard. "make P1022DS" builds a 32-bit U-Boot. But "make P4080DS" builds a 36-bit U-Boot. So we've been displaying the address map size at boot time in some situations, but not all. My patch makes this standard.
I agree with adding that information to the bdinfo command. I'm just worried about having it available only there.
Dear Timur Tabi,
Software changes, output changes. Document your changes if you want to make sure your users happy. Feel free to send them detailled changed logs.
But it's not you who defines what the standard looks like.
You will get used to it, and so will your users.
On Sep 1, 2011, at 4:59 PM, Wolfgang Denk wrote:
Dear Timur Tabi,
I agree with this, however I think it should be left to the board config/port to decide if it wants to print and enable this info on boot. The FSL PPC board ports are not the typical use case. I view our board ports having a few different purposes: * Examples for people building their own boards * Used for customer evaluation and support
Having the additional information printed on boot is extremely useful to FSL for our board ports for supporting customers. So my take is the following:
1. We reduce the amount printed in the "default" case 2. First choice should always be to have a command the print status info 3. Allow a board port to makes its own decision if it wants to do something like enable CONFIG_PCI_SCAN_SHOW
Any concerns w/that proposal?
- k
Kumar Gala wrote:
- We reduce the amount printed in the "default" case
- First choice should always be to have a command the print status info
- Allow a board port to makes its own decision if it wants to do something like enable CONFIG_PCI_SCAN_SHOW
Are you talking about my patch, or about CONFIG_PCI_SCAN_SHOW?
The reason I like my patch as-is is because it completely eliminates the board from the decision. It's only one line, and it's CONSISTENT. That's the key part. We have not been consistent about this, and it seems silly for each board to implement the same feature.
Both. I'm think for your patch we'd add some general config option for extra print info.
- k
So you want to see this instead:
/* * Display whether this is a 32-bit build or a 36-bit build. */ #ifdef CONFIG_DISPLAY_ADDR_SIZE #ifdef CONFIG_PHYS_64BIT puts("ADDR: 36-bit address map\n"); #else puts("ADDR: 32-bit address map\n"); #endif #endif
I still like my way better. It eliminates the need to think about another CONFIG option. I think adding another CONFIG option is worse than adding another line of text.
It think it's silly to complain about adding one line of text that is only displayed on e500 systems that support 36-bit addressing, especially since we display this information on most of our boards anyway. Surely we can find some other line of text that we can shorten or eliminate to make up for it.
For instance, we can combine these two lines into one:
CPU0: P1022E, Version: 1.0, (0x80ee0010) Core: E500, Version: 5.0, (0x80211050)
or these two lines:
L1: D-cache 32 kB enabled I-cache 32 kB enabled
- Display whether this is a 32-bit build or a 36-bit build.
I think we could introduce kernel style "printk" levels that would allow more control over something like this.
- k
Or we could implement Kconfig and defconfigs. But neither of these options is going to help me now.
Dear Kumar Gala,
In message A324986C-C4BF-459A-83AC-2B753FED7A1F@kernel.crashing.org you wrote:
I think we could introduce kernel style "printk" levels that would allow = more control over something like this.
We can invent many things, or we can keep the code lean and simple.
Let's just move this to where it belongs - to some command that prints that information upon explicit request of the user. "bdinfo" comes to mind here. Feel free to run such a command as "preboot" sequence then.
Dear Timur Tabi,
Please dump this completely.
Dear Kumar Gala,
- Examples for people building their own boards
Especially of this you have additional responsibility not to set bad examples.
"extremely useful" is a really big statement. I don't buy it.
I want to clean this up, and I'm extremely unhappy if there are "examples for people building their own boards" that use excessively verbose boot messages.
participants (5)
Kumar Gala
Kumar Gala
Tabi Timur-B04825
Timur Tabi
