[U-Boot] [PATCH] mmc: Improve tinification
Drop all the extra content from the MMC core, so that tiny MMC support is really tiny, no fancy anything. That means the tiny MMC support does only 1-bit transfers at default speed settings. Moreover, this patch drops duplicate instance of struct mmc mmc_static, which wasted about 360 bytes. Furthermore, since MMC tiny supports only one controller at all times, get rid of mallocating the ext csd backup and replace it with static array. All in all, this patch saves ~4 kiB of bloat from the MMC core, which on platforms with severe limitations can be beneficial.
Signed-off-by: Marek Vasut marek.vasut@gmail.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Tom Rini trini@konsulko.com --- drivers/mmc/mmc.c | 66 +++++++++++++++++++++++++++++------------------- drivers/mmc/mmc_legacy.c | 23 ++++++++++++++++- 2 files changed, 62 insertions(+), 27 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index f72b80c704..961bd49db0 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -24,29 +24,8 @@
static int mmc_set_signal_voltage(struct mmc *mmc, uint signal_voltage); static int mmc_power_cycle(struct mmc *mmc); +#if !CONFIG_IS_ENABLED(MMC_TINY) static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps); - -#if CONFIG_IS_ENABLED(MMC_TINY) -static struct mmc mmc_static; -struct mmc *find_mmc_device(int dev_num) -{ - return &mmc_static; -} - -void mmc_do_preinit(void) -{ - struct mmc *m = &mmc_static; -#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT - mmc_set_preinit(m, 1); -#endif - if (m->preinit) - mmc_start_init(m); -} - -struct blk_desc *mmc_get_blk_desc(struct mmc *mmc) -{ - return &mmc->block_dev; -} #endif
#if !CONFIG_IS_ENABLED(DM_MMC) @@ -772,7 +751,7 @@ int mmc_switch(struct mmc *mmc, u8 set, u8 index, u8 value) return ret;
} - +#if !CONFIG_IS_ENABLED(MMC_TINY) static int mmc_set_card_speed(struct mmc *mmc, enum bus_mode mode) { int err; @@ -856,6 +835,7 @@ static int mmc_get_capabilities(struct mmc *mmc)
return 0; } +#endif
static int mmc_set_capacity(struct mmc *mmc, int part_num) { @@ -1155,6 +1135,7 @@ int mmc_getcd(struct mmc *mmc) } #endif
+#if !CONFIG_IS_ENABLED(MMC_TINY) static int sd_switch(struct mmc *mmc, int mode, int group, u8 value, u8 *resp) { struct mmc_cmd cmd; @@ -1175,7 +1156,6 @@ static int sd_switch(struct mmc *mmc, int mode, int group, u8 value, u8 *resp) return mmc_send_cmd(mmc, &cmd, &data); }
- static int sd_get_capabilities(struct mmc *mmc) { int err; @@ -1362,6 +1342,7 @@ static int sd_select_bus_width(struct mmc *mmc, int w)
return 0; } +#endif
#if CONFIG_IS_ENABLED(MMC_WRITE) static int sd_read_ssr(struct mmc *mmc) @@ -1583,6 +1564,7 @@ static inline int mmc_set_signal_voltage(struct mmc *mmc, uint signal_voltage) } #endif
+#if !CONFIG_IS_ENABLED(MMC_TINY) static const struct mode_width_tuning sd_modes_by_pref[] = { #if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) #ifdef MMC_SUPPORTS_TUNING @@ -1933,9 +1915,15 @@ error:
return -ENOTSUPP; } +#endif + +#if CONFIG_IS_ENABLED(MMC_TINY) +DEFINE_CACHE_ALIGN_BUFFER(u8, ext_csd_bkup, MMC_MAX_BLOCK_LEN); +#endif
static int mmc_startup_v4(struct mmc *mmc) { + int err, i; u64 capacity; bool has_parts = false; @@ -1952,6 +1940,23 @@ static int mmc_startup_v4(struct mmc *mmc) MMC_VERSION_5_1 };
+#if CONFIG_IS_ENABLED(MMC_TINY) + u8 *ext_csd = ext_csd_bkup; + + if (IS_SD(mmc) || (mmc->version < MMC_VERSION_4)) + return 0; + + if (!mmc->ext_csd) + memset(ext_csd_bkup, 0, sizeof(ext_csd_bkup)); + + err = mmc_send_ext_csd(mmc, ext_csd); + if (err) + goto error; + + /* store the ext csd for future reference */ + if (!mmc->ext_csd) + mmc->ext_csd = ext_csd; +#else ALLOC_CACHE_ALIGN_BUFFER(u8, ext_csd, MMC_MAX_BLOCK_LEN);
if (IS_SD(mmc) || (mmc->version < MMC_VERSION_4)) @@ -1968,7 +1973,7 @@ static int mmc_startup_v4(struct mmc *mmc) if (!mmc->ext_csd) return -ENOMEM; memcpy(mmc->ext_csd, ext_csd, MMC_MAX_BLOCK_LEN); - +#endif if (ext_csd[EXT_CSD_REV] >= ARRAY_SIZE(mmc_versions)) return -EINVAL;
@@ -2107,7 +2112,9 @@ static int mmc_startup_v4(struct mmc *mmc) return 0; error: if (mmc->ext_csd) { +#if !CONFIG_IS_ENABLED(MMC_TINY) free(mmc->ext_csd); +#endif mmc->ext_csd = NULL; } return err; @@ -2296,6 +2303,13 @@ static int mmc_startup(struct mmc *mmc) if (err) return err;
+ + +#if CONFIG_IS_ENABLED(MMC_TINY) + mmc_set_clock(mmc, mmc->legacy_speed, false); + mmc_select_mode(mmc, IS_SD(mmc) ? SD_LEGACY : MMC_LEGACY); + mmc_set_bus_width(mmc, 1); +#else if (IS_SD(mmc)) { err = sd_get_capabilities(mmc); if (err) @@ -2307,7 +2321,7 @@ static int mmc_startup(struct mmc *mmc) return err; mmc_select_mode_and_width(mmc, mmc->card_caps); } - +#endif if (err) return err;
diff --git a/drivers/mmc/mmc_legacy.c b/drivers/mmc/mmc_legacy.c index 100b931e5b..8d62440f15 100644 --- a/drivers/mmc/mmc_legacy.c +++ b/drivers/mmc/mmc_legacy.c @@ -13,7 +13,28 @@ static struct list_head mmc_devices; static int cur_dev_num = -1;
-#if !CONFIG_IS_ENABLED(MMC_TINY) +#if CONFIG_IS_ENABLED(MMC_TINY) +static struct mmc mmc_static; +struct mmc *find_mmc_device(int dev_num) +{ + return &mmc_static; +} + +void mmc_do_preinit(void) +{ + struct mmc *m = &mmc_static; +#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT + mmc_set_preinit(m, 1); +#endif + if (m->preinit) + mmc_start_init(m); +} + +struct blk_desc *mmc_get_blk_desc(struct mmc *mmc) +{ + return &mmc->block_dev; +} +#else struct mmc *find_mmc_device(int dev_num) { struct mmc *m;
