[U-Boot] please pull u-boot-samsung master
Dear Tom,
The following changes since commit fa8883a1e39a20e72aaa5093af0c80062cb95757:
Merge branch 'master' of git://git.denx.de/u-boot-i2c (2015-11-27 08:41:03 -0500)
http://git.denx.de/u-boot-samsung
for you to fetch changes up to 225f5eeccd6c0d376a20c15897edd8c69500d8cc:
arm: s5pc1xx: move SoC to mach-s5pc1xx (2015-11-30 17:17:01 +0900)
---------------------------------------------------------------- Minkyu Kang (1): arm: s5pc1xx: move SoC to mach-s5pc1xx
MAINTAINERS | 6 ++---- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 1 - arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/Kconfig | 0 arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/Makefile | 0 arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/cache.c | 0 arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/clock.c | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/clk.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/clock.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/cpu.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/gpio.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/mmc.h | 0 .../asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/periph.h | 0 .../asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/pinmux.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/power.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/pwm.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/sromc.h | 0 .../asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/sys_proto.h | 0 .../{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/uart.h | 0 .../asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/watchdog.h | 0 arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/reset.S | 0 22 files changed, 4 insertions(+), 6 deletions(-) rename arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/Kconfig (100%) rename arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/Makefile (100%) rename arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/cache.c (100%) rename arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/clock.c (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/clk.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/clock.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/cpu.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/gpio.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/mmc.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/periph.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/pinmux.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/power.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/pwm.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/sromc.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/sys_proto.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/uart.h (100%) rename arch/arm/{include/asm/arch-s5pc1xx => mach-s5pc1xx/include/mach}/watchdog.h (100%) rename arch/arm/{cpu/armv7/s5pc1xx => mach-s5pc1xx}/reset.S (100%)
On Mon, Nov 30, 2015 at 05:33:14PM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
