[U-Boot-Users] jffs2 view u-boot/linux
Hi all,
I'm wondering why linux and u-boot are seeing different files when I use a jjfs2 image on my nand flash.
This is what I've done. I partitioned my nand flash with 3 partitions (u-boot, jffs2, user) Then I flashed the jffs2 image with nand write.jffs2 booted the uImage from my jffs2 with fsload That all worked fine (although fsload is extreamly slow) and I can use my linux. Then I created a new file in my root. A "ls" from linux displays that file. With a "ls" from u-boot the file is not visible... So what went wrong? Who is cheating on me?
Thanks for your help. Jonas
Jonas Dietsche wrote on 05/17/05 10:39:
Hi all,
Some additional info: I use the mtd stuff from mtd-snapshot-20050524.tar.bz2 with a 2.6.11 kernel. I executed patchkernel.sh from the mtd package. I created a jffs2 image with mkfs.jffs2 -e 16384 -qnd my_rootfs -o jffs2.img Then I flashed the image with nand write.jffs2 (or from linux with nandwrite). A "ls" shows me the contents of the image as expected. Scanning JFFS2 FS: .. done. drwxr-xr-x 0 Mon May 30 10:09:25 2005 bin drwxr-xr-x 0 Mon May 30 10:09:25 2005 dev drwxr-xr-x 0 Mon May 30 10:09:25 2005 etc drwxr-xr-x 0 Mon May 30 10:09:25 2005 initrd drwxr-xr-x 0 Mon May 30 10:09:25 2005 lib drwxr-xr-x 0 Mon May 30 10:09:25 2005 mnt drwxr-xr-x 0 Mon May 30 10:09:25 2005 nfs drwxr-xr-x 0 Mon May 30 10:09:25 2005 proc drwxr-xr-x 0 Mon May 30 10:09:25 2005 ram drwxr-xr-x 0 Mon May 30 10:09:25 2005 sbin drwxr-xr-x 0 Mon May 30 10:09:25 2005 sys lrwxrwxrwx 4 Mon May 30 10:09:25 2005 tmp -> -rw-r--r-- 1330220 Mon May 30 10:09:24 2005 uImage drwxr-xr-x 0 Mon May 30 10:09:25 2005 usr lrwxrwxrwx 4 Mon May 30 10:09:25 2005 var -> drwxr-xr-x 0 Mon May 30 10:09:25 2005 www
Then I boot linux and mount my jffs2 partiton. I deleted the uImage from it. A "ls" from linux shows me that it is deleted. Then I rebooted and did a "ls" from u-boot. Scanning JFFS2 FS: .. done. drwxr-xr-x 0 Mon May 30 10:09:25 2005 bin drwxr-xr-x 0 Mon May 30 10:09:25 2005 dev drwxr-xr-x 0 Thu Aug 26 08:34:34 2004 etc drwxr-xr-x 0 Mon May 30 10:09:25 2005 initrd drwxr-xr-x 0 Mon May 30 10:09:25 2005 lib drwxr-xr-x 0 Mon May 30 10:09:25 2005 mnt drwxr-xr-x 0 Mon May 30 10:09:25 2005 nfs drwxr-xr-x 0 Mon May 30 10:09:25 2005 proc drwxr-xr-x 0 Mon May 30 10:09:25 2005 ram drwxr-xr-x 0 Mon May 30 10:09:25 2005 sbin drwxr-xr-x 0 Mon May 30 10:09:25 2005 sys lrwxrwxrwx 4 Mon May 30 10:09:25 2005 tmp -> -rw-r--r-- 1330220 Mon May 30 10:09:24 2005 uImage drwxr-xr-x 0 Mon May 30 10:09:25 2005 usr lrwxrwxrwx 4 Mon May 30 10:09:25 2005 var -> drwxr-xr-x 0 Mon May 30 10:09:25 2005 www drwxr-xr-x 0 Mon May 30 10:09:25 2005 bin drwxr-xr-x 0 Mon May 30 10:09:25 2005 dev drwxr-xr-x 0 Thu Aug 26 08:34:34 2004 etc drwxr-xr-x 0 Mon May 30 10:09:25 2005 initrd drwxr-xr-x 0 Mon May 30 10:09:25 2005 lib
The uImage is still there. And "bin, dev, etc, initrd, lib" are listed twice. Then I deleted the "www directory" and the ls of u-boot gives me Scanning JFFS2 FS: ... done. drwxr-xr-x 0 Mon May 30 10:09:25 2005 bin drwxr-xr-x 0 Mon May 30 10:09:25 2005 dev drwxr-xr-x 0 Thu Aug 26 08:34:34 2004 etc drwxr-xr-x 0 Mon May 30 10:09:25 2005 initrd drwxr-xr-x 0 Mon May 30 10:09:25 2005 lib drwxr-xr-x 0 Mon May 30 10:09:25 2005 mnt drwxr-xr-x 0 Mon May 30 10:09:25 2005 nfs drwxr-xr-x 0 Mon May 30 10:09:25 2005 proc drwxr-xr-x 0 Mon May 30 10:09:25 2005 ram drwxr-xr-x 0 Mon May 30 10:09:25 2005 sbin drwxr-xr-x 0 Mon May 30 10:09:25 2005 sys lrwxrwxrwx 4 Mon May 30 10:09:25 2005 tmp -> -rw-r--r-- 1330220 Mon May 30 10:09:24 2005 uImage drwxr-xr-x 0 Mon May 30 10:09:25 2005 usr lrwxrwxrwx 4 Mon May 30 10:09:25 2005 var -> drwxr-xr-x 0 Mon May 30 10:09:25 2005 www drwxr-xr-x 0 Mon May 30 10:09:25 2005 bin drwxr-xr-x 0 Mon May 30 10:09:25 2005 dev drwxr-xr-x 0 Thu Aug 26 08:34:34 2004 etc drwxr-xr-x 0 Mon May 30 10:09:25 2005 initrd drwxr-xr-x 0 Mon May 30 10:09:25 2005 lib drwxr-xr-x 0 Mon May 30 10:09:25 2005 usr lrwxrwxrwx 4 Mon May 30 10:09:25 2005 var ->
"bin, dev, etc, initrd, lib, usr var" are listed twice.
What I'm doing wrong?
Jonas
Dear Jonas,
We use a snapshot from MTD CVS of March 13, 2005 in our 2.4.25 kernel tree, and this is what U-Boot was tested against.
Are you absolutely sure that 16 kB is the correct erase block size for your hardware?
And when booting Linux again the state is again as expected?
Can you try the March 13 MTD snapshot?
Hello Wolfgang,
thanks for your reply.
can you send it or give me a link?
Yes, it is a Samsung K9F1208U0B.
Yes, it looks as expected.
Jonas
Send what? Our kernel tree? It's the linuxppc_2_4_devel module on our CVS server; see http://www.denx.de/re/linux.html
But it should be sufficient to check out the MTD code as of March 13.
Ok, bad question... ;-)
I tested it with the MTD code of march 13 with the same result. Files I deleted are still there.
Regards, Jonas
I created a 1MB partition to speed up the testing. Maybe someone can do the same tests and tell me if he sees the same results...
* under linux I erased the partition with flash_eraseall -j /dev/mtd/2 * then I mounted it with mount -t jffs2 /dev/mtdblock/2 /mnt * and created a file on the partition cd /mnt/ echo test >testfile * reboot linux * under u-boot I did a ls and got the following (DEBUG_DIRENT and DEBUG_FRAGMENTS in jffs2_1pass.c are enabled) Scanning JFFS2 FS: . done.
******The directory Entries******
testfile build_list: magic = 00001985 build_list: nodetype = 0000e001 build_list: hdr_crc = fa3ebe78 build_list: pino = 00000001 build_list: version = 00000001 build_list: ino = 00000002 build_list: mctime = 00000074 build_list: nsize = 00000008 build_list: type = 00000008 build_list: node_crc = c489d275 build_list: name_crc = ddab2c44 build_list: offset = 004f8044
******The fragment Entries******
build_list: FLASH_OFFSET = 004f8000 build_list: totlen = 00000044 build_list: inode = 00000002 build_list: version = 00000001 build_list: isize = 00000000 build_list: atime = 00000074 build_list: offset = 00000000 build_list: csize = 00000000 build_list: dsize = 00000000 build_list: compr = 00000000 build_list: usercompr = 00000000 build_list: flags = 00000000 build_list: offset = 004f8000
build_list: FLASH_OFFSET = 004f8074 build_list: totlen = 00000049 build_list: inode = 00000002 build_list: version = 00000002 build_list: isize = 00000005 build_list: atime = 00000074 build_list: offset = 00000000 build_list: csize = 00000005 build_list: dsize = 00000005 build_list: compr = 00000000 build_list: usercompr = 00000000 build_list: flags = 00000000 build_list: offset = 004f8074 -rw-r--r-- 5 Thu Jan 01 00:01:56 1970 testfile
* then I booted linux, mounted the jffs2 partition, deleted the file and rebooted * ls in u-boot displays Scanning JFFS2 FS: . done.
testfile build_list: magic = 00001985 build_list: nodetype = 0000e001 build_list: hdr_crc = fa3ebe78 build_list: pino = 00000001 build_list: version = 00000002 build_list: ino = 00000000 build_list: mctime = 00000023 build_list: nsize = 00000008 build_list: type = 00000000 build_list: node_crc = 508a537f build_list: name_crc = ddab2c44 build_list: offset = 004f8200
How can I manage it that the deleted testfile isn't displayed anymore? Is this a NAND specific problem?
Thanks. Jonas
Did you verify that your partition definitions in Linux and in U-Boot (CONFIG_JFFS2_NAND_OFF, CONFIG_JFFS2_NAND_SIZE) are exactly the same?
Jonas Dietsche
