[PATCH 1/3] arch: arm: dts: phyboard-electra-uboot.dtsi: Add bootph props to i2c
Add bootph-all properties to I2C0 nodes to ensure the bus and EEPROM are accessible across all stages. This enables reading the SoM configuration at any point during the boot process.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- arch/arm/dts/k3-am642-phyboard-electra-rdk-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/k3-am642-phyboard-electra-rdk-u-boot.dtsi b/arch/arm/dts/k3-am642-phyboard-electra-rdk-u-boot.dtsi index 8f3c3a185ae..c68a48678a2 100644 --- a/arch/arm/dts/k3-am642-phyboard-electra-rdk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-phyboard-electra-rdk-u-boot.dtsi @@ -72,6 +72,14 @@ bootph-all; };
+&main_i2c0 { + bootph-all; +}; + +&main_i2c0_pins_default { + bootph-all; +}; + &main_mmc1_pins_default { bootph-all; };
Detect RAM size via EEPROM and adjust DDR size and banks accordingly. Include necessary fixups to handle ECC-enabled configurations.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- board/phytec/phycore_am64x/Kconfig | 25 +++++ board/phytec/phycore_am64x/phycore-am64x.c | 105 ++++++++++++++++++++- 2 files changed, 128 insertions(+), 2 deletions(-)
diff --git a/board/phytec/phycore_am64x/Kconfig b/board/phytec/phycore_am64x/Kconfig index 829526c3295..a709b71ba4d 100644 --- a/board/phytec/phycore_am64x/Kconfig +++ b/board/phytec/phycore_am64x/Kconfig @@ -35,3 +35,28 @@ config SYS_CONFIG_NAME source "board/phytec/common/Kconfig"
endif + +config PHYCORE_AM64X_RAM_SIZE_FIX + bool "Set phyCORE-AM64x RAM size fix instead of detecting" + default false + help + RAM size is automatic being detected with the help of + the EEPROM introspection data. Set RAM size to a fix value + instead. + +choice + prompt "phyCORE-AM64x RAM size" + depends on PHYCORE_AM64X_RAM_SIZE_FIX + default PHYCORE_AM64X_RAM_SIZE_2GB + +config PHYCORE_AM64X_RAM_SIZE_1GB + bool "1GB RAM" + help + Set RAM size fix to 1GB for phyCORE-AM64x. + +config PHYCORE_AM64X_RAM_SIZE_2GB + bool "2GB RAM" + help + Set RAM size fix to 2GB for phyCORE-AM64x. + +endchoice diff --git a/board/phytec/phycore_am64x/phycore-am64x.c b/board/phytec/phycore_am64x/phycore-am64x.c index 8f3b22657c7..f14c87f5c72 100644 --- a/board/phytec/phycore_am64x/phycore-am64x.c +++ b/board/phytec/phycore_am64x/phycore-am64x.c @@ -11,9 +11,12 @@ #include <env.h> #include <env_internal.h> #include <spl.h> +#include <asm/arch/k3-ddr.h> #include <fdt_support.h> #include <asm/arch/hardware.h>
+#include "../common/am6_som_detection.h" + DECLARE_GLOBAL_DATA_PTR;
int board_init(void) @@ -21,15 +24,113 @@ int board_init(void) return 0; }
+static u8 phytec_get_am64_ddr_size_default(void) +{ + int ret; + struct phytec_eeprom_data data; + + if (IS_ENABLED(CONFIG_PHYCORE_AM64X_RAM_SIZE_FIX)) { + if (IS_ENABLED(CONFIG_PHYCORE_AM64X_RAM_SIZE_1GB)) + return EEPROM_RAM_SIZE_1GB; + else if (IS_ENABLED(CONFIG_PHYCORE_AM64X_RAM_SIZE_2GB)) + return EEPROM_RAM_SIZE_2GB; + } + + ret = phytec_eeprom_data_setup(&data, 0, EEPROM_ADDR); + if (!ret && data.valid) + return phytec_get_am6_ddr_size(&data); + + /* Default DDR size is 2GB */ + return EEPROM_RAM_SIZE_2GB; +} + int dram_init(void) { - return fdtdec_setup_mem_size_base(); + u8 ram_size; + + if (!IS_ENABLED(CONFIG_CPU_V7R)) + return fdtdec_setup_mem_size_base(); + + ram_size = phytec_get_am64_ddr_size_default(); + + switch (ram_size) { + case EEPROM_RAM_SIZE_1GB: + gd->ram_size = 0x40000000; + break; + case EEPROM_RAM_SIZE_2GB: + gd->ram_size = 0x80000000; + break; + default: + gd->ram_size = 0x80000000; + } + + return 0; }
int dram_init_banksize(void) { - return fdtdec_setup_memory_banksize(); + u8 ram_size; + + memset(gd->bd->bi_dram, 0, sizeof(gd->bd->bi_dram[0]) * CONFIG_NR_DRAM_BANKS); + + if (!IS_ENABLED(CONFIG_CPU_V7R)) + return fdtdec_setup_memory_banksize(); + + ram_size = phytec_get_am64_ddr_size_default(); + switch (ram_size) { + case EEPROM_RAM_SIZE_1GB: + gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x40000000; + gd->ram_size = 0x40000000; + break; + + case EEPROM_RAM_SIZE_2GB: + gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x80000000; + gd->ram_size = 0x80000000; + break; + + default: + /* Continue with default 2GB setup */ + gd->bd->bi_dram[0].start = CFG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x80000000; + gd->ram_size = 0x80000000; + printf("DDR size %d is not supported\n", ram_size); + } + + return 0; +} + +#if defined(CONFIG_K3_DDRSS) +int do_board_detect(void) +{ + void *fdt = (void *)gd->fdt_blob; + int bank; + + u64 start[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + dram_init(); + dram_init_banksize(); + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + start[bank] = gd->bd->bi_dram[bank].start; + size[bank] = gd->bd->bi_dram[bank].size; + } + + return fdt_fixup_memory_banks(fdt, start, size, CONFIG_NR_DRAM_BANKS); +} +#endif + +#if IS_ENABLED(CONFIG_XPL_BUILD) +void spl_perform_fixups(struct spl_image_info *spl_image) +{ + if (IS_ENABLED(CONFIG_K3_DDRSS) && IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + else + fixup_memory_node(spl_image); } +#endif
#define CTRLMMR_USB0_PHY_CTRL 0x43004008 #define CORE_VOLTAGE 0x80000000
Enable configs required for detecting and fixing up for different RAM variants. Also resync after savedefconfig.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- configs/phycore_am64x_r5_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/phycore_am64x_r5_defconfig b/configs/phycore_am64x_r5_defconfig index 2d9ff95d781..a764298b186 100644 --- a/configs/phycore_am64x_r5_defconfig +++ b/configs/phycore_am64x_r5_defconfig @@ -5,9 +5,9 @@ CONFIG_SYS_MALLOC_F_LEN=0x80000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM642=y CONFIG_TARGET_PHYCORE_AM64X_R5=y +CONFIG_PHYTEC_SOM_DETECTION=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x7019b800 CONFIG_SF_DEFAULT_SPEED=25000000 @@ -16,6 +16,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-am642-r5-phycore-som-2gb" +CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -34,6 +35,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y
Hi Wadim,
+&main_i2c0 {
- bootph-all;
- bootph-all;
Can we not add the bootph-all property in the kernel DT nodes for this? Also, I don't see main_i2c0 in the kernel DTS file for this[1] platform. Is there a particular reason to not put it there?
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch...
Hi Dhruva,
Am 27.01.25 um 13:22 schrieb Dhruva Gole:
Hi Wadim,
+&main_i2c0 {
- bootph-all;
- bootph-all;
Yes, adding bootph-props to the Kernel device tree is on my todo.
It is defined in the som.dtsi file
Regards, Wadim
Dhruva Gole
Wadim Egorov
