[U-Boot] [RFC PATCH 0/2] Add support for two modules from Laird
Hi These patches add basic support for two cpu modules from Laird. These boards are based on the at91sam9x5ek and the sama5d3xek and have been updated from old versions. I believe I have captured the KConfig moves and adjustents but if there are better solutions now I should look into please let me know.
Kind regards, Ben Whitten (2): board: laird: add WB45N CPU module board: laird: add WB50N CPU module
arch/arm/mach-at91/Kconfig | 14 +++ arch/arm/mach-at91/include/mach/gpio.h | 2 + board/laird/wb45n/Kconfig | 12 ++ board/laird/wb45n/MAINTAINERS | 6 + board/laird/wb45n/Makefile | 6 + board/laird/wb45n/wb45n.c | 199 +++++++++++++++++++++++++++++++ board/laird/wb50n/Kconfig | 12 ++ board/laird/wb50n/MAINTAINERS | 6 + board/laird/wb50n/Makefile | 6 + board/laird/wb50n/wb50n.c | 206 +++++++++++++++++++++++++++++++++ configs/wb45n_defconfig | 27 +++++ configs/wb50n_defconfig | 26 +++++ include/configs/wb45n.h | 163 ++++++++++++++++++++++++++ include/configs/wb50n.h | 143 +++++++++++++++++++++++ 14 files changed, 828 insertions(+) create mode 100644 board/laird/wb45n/Kconfig create mode 100644 board/laird/wb45n/MAINTAINERS create mode 100644 board/laird/wb45n/Makefile create mode 100644 board/laird/wb45n/wb45n.c create mode 100644 board/laird/wb50n/Kconfig create mode 100644 board/laird/wb50n/MAINTAINERS create mode 100644 board/laird/wb50n/Makefile create mode 100644 board/laird/wb50n/wb50n.c create mode 100644 configs/wb45n_defconfig create mode 100644 configs/wb50n_defconfig create mode 100644 include/configs/wb45n.h create mode 100644 include/configs/wb50n.h
This board is based on the Atmel 9x5 eval board. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL
Signed-off-by: Ben Whitten ben.whitten@lairdtech.com Signed-off-by: Dan Kephart dan.kephart@lairdtech.com --- arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/include/mach/gpio.h | 2 + board/laird/wb45n/Kconfig | 12 ++ board/laird/wb45n/MAINTAINERS | 6 + board/laird/wb45n/Makefile | 6 + board/laird/wb45n/wb45n.c | 199 +++++++++++++++++++++++++++++++++ configs/wb45n_defconfig | 27 +++++ include/configs/wb45n.h | 163 +++++++++++++++++++++++++++ 8 files changed, 421 insertions(+) create mode 100644 board/laird/wb45n/Kconfig create mode 100644 board/laird/wb45n/MAINTAINERS create mode 100644 board/laird/wb45n/Makefile create mode 100644 board/laird/wb45n/wb45n.c create mode 100644 configs/wb45n_defconfig create mode 100644 include/configs/wb45n.h
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 99b88d1..e4d9690 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -164,6 +164,11 @@ config TARGET_VINCO select CPU_V7 select SUPPORT_SPL
+config TARGET_WB45N + bool "Support Laird WB45N" + select CPU_ARM926EJS + select SUPPORT_SPL + endchoice
config SYS_SOC @@ -197,5 +202,6 @@ source "board/ronetix/pm9g45/Kconfig" source "board/siemens/corvus/Kconfig" source "board/siemens/taurus/Kconfig" source "board/siemens/smartweb/Kconfig" +source "board/laird/wb45n/Kconfig"
endif diff --git a/arch/arm/mach-at91/include/mach/gpio.h b/arch/arm/mach-at91/include/mach/gpio.h index df0f719..e206316 100644 --- a/arch/arm/mach-at91/include/mach/gpio.h +++ b/arch/arm/mach-at91/include/mach/gpio.h @@ -219,6 +219,8 @@ static inline unsigned pin_to_mask(unsigned pin) at91_set_a_periph((x - PIN_BASE) / 32,(x % 32), y) #define at91_set_B_periph(x, y) \ at91_set_b_periph((x - PIN_BASE) / 32,(x % 32), y) +#define at91_set_gpio_deglitch(x, y) \ + at91_set_pio_deglitch((x - PIN_BASE) / 32,(x % 32), y) #define at91_set_gpio_output(x, y) \ at91_set_pio_output((x - PIN_BASE) / 32,(x % 32), y) #define at91_set_gpio_input(x, y) \ diff --git a/board/laird/wb45n/Kconfig b/board/laird/wb45n/Kconfig new file mode 100644 index 0000000..2a67337 --- /dev/null +++ b/board/laird/wb45n/Kconfig @@ -0,0 +1,12 @@ +if TARGET_WB45N + +config SYS_BOARD + default "wb45n" + +config SYS_VENDOR + default "laird" + +config SYS_CONFIG_NAME + default "wb45n" + +endif diff --git a/board/laird/wb45n/MAINTAINERS b/board/laird/wb45n/MAINTAINERS new file mode 100644 index 0000000..60bb563 --- /dev/null +++ b/board/laird/wb45n/MAINTAINERS @@ -0,0 +1,6 @@ +WB45N CPU MODULE +M: Ben Whitten ben.whitten@lairdtech.com +S: Maintained +F: board/laird/wb45n/ +F: include/configs/wb45n.h +F: configs/wb45n_defconfig diff --git a/board/laird/wb45n/Makefile b/board/laird/wb45n/Makefile new file mode 100644 index 0000000..fc645dd --- /dev/null +++ b/board/laird/wb45n/Makefile @@ -0,0 +1,6 @@ +# +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += wb45n.o diff --git a/board/laird/wb45n/wb45n.c b/board/laird/wb45n/wb45n.c new file mode 100644 index 0000000..5914071 --- /dev/null +++ b/board/laird/wb45n/wb45n.c @@ -0,0 +1,199 @@ +/* + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9x5_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <net.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ +static void wb45n_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + csa = readl(&matrix->ebicsa); + /* Enable CS3 */ + csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; + /* NAND flash on D0 */ + csa &= ~AT91_MATRIX_NFD0_ON_D16; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(1), &smc->cs[3].mode); + + at91_periph_clk_enable(ATMEL_ID_PIOCD); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); + /* Disable Flash Write Protect Line */ + at91_set_gpio_output(AT91_PIN_PD10, 1); + + at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */ + at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */ + at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* NAND ALE */ + at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* NAND CLE */ +} + +static void wb45n_gpio_hw_init(void) +{ + + /* Configure wifi gpio CHIP_PWD_L */ + at91_set_gpio_output(AT91_PIN_PA28, 0); + + /* Setup USB pins */ + at91_set_gpio_input(AT91_PIN_PB11, 0); + at91_set_gpio_output(AT91_PIN_PB12, 0); + + /* IRQ pin, pullup, deglitch */ + at91_set_gpio_input(AT91_PIN_PB18, 1); + at91_set_gpio_deglitch(AT91_PIN_PB18, 1); +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; + + if (has_emac0()) + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); + + return rc; +} + +int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + wb45n_gpio_hw_init(); + + wb45n_nand_hw_init(); + + at91_macb_hw_init(); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> + +void at91_spl_board_init(void) +{ + /* Setup GPIO first */ + wb45n_gpio_hw_init(); + + /* Bring up NAND */ + wb45n_nand_hw_init(); +} + +void matrix_init(void) +{ + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + csa = readl(&matrix->ebicsa); + /* Pull ups on D0 - D16 */ + csa &= ~AT91_MATRIX_EBI_DBPU_OFF; + csa |= AT91_MATRIX_EBI_DBPD_OFF; + /* Normal drive strength */ + csa |= AT91_MATRIX_EBI_EBI_IOSR_NORMAL; + /* Multi-port off */ + csa &= ~AT91_MATRIX_MP_ON; + writel(csa, &matrix->ebicsa); +} + +#include <asm/arch/atmel_mpddrc.h> +static void ddr2_conf(struct atmel_mpddrc_config *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_LPDDR_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_DQMS_SHARED); + + ddr2->rtr = 0x411; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 19 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 18 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 3 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct atmel_mpddrc_config ddr2; + unsigned long csa; + + ddr2_conf(&ddr2); + + /* enable DDR2 clock */ + at91_system_clk_enable(AT91_PMC_DDR); + + /* Chip select 1 is for DDR2/SDRAM */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_EBI_CS1A_SDRAMC; + writel(csa, &matrix->ebicsa); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_DDRSDRC, ATMEL_BASE_CS1, &ddr2); +} +#endif diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig new file mode 100644 index 0000000..4ba0088 --- /dev/null +++ b/configs/wb45n_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TARGET_WB45N=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_LZMA=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h new file mode 100644 index 0000000..fd714dd --- /dev/null +++ b/include/configs/wb45n.h @@ -0,0 +1,163 @@ +/* + * Configuation settings for the WB45N CPU Module. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H__ +#define __CONFIG_H__ + +#include <asm/hardware.h> + +#define CONFIG_SYS_TEXT_BASE 0x23f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) + +/* NAND flash */ +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD4 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5 + +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC 1 +#define CONFIG_ATMEL_NAND_HW_PMECC 1 +#define CONFIG_PMECC_CAP 4 +#define CONFIG_PMECC_SECTOR_SIZE 512 + +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_MACB_SEARCH_PHY +#define CONFIG_ETHADDR C0:EE:40:00:00:00 +#define CONFIG_ENV_OVERWRITE 1 + +/* System */ +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +#ifdef CONFIG_SYS_USE_NANDFLASH +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xa0000 +#define CONFIG_ENV_OFFSET_REDUND 0xc0000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 block = 128 kB */ + +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xe0000 0x280000; " \ + "run _mtd; bootm" + +#define MTDIDS_DEFAULT "nand0=atmel_nand" +#define MTDPARTS_DEFAULT "mtdparts=atmel_nand:" \ + "128K(at91bs)," \ + "512K(u-boot)," \ + "128K(u-boot-env)," \ + "128K(redund-env)," \ + "2560K(kernel-a)," \ + "2560K(kernel-b)," \ + "38912K(rootfs-a)," \ + "38912K(rootfs-b)," \ + "46208K(user)," \ + "512K(logs)" + +#else +#error No boot method selected, please select 'CONFIG_SYS_USE_NANDFLASH' +#endif + +#define CONFIG_BOOTARGS "console=ttyS0,115200 earlyprintk " \ + "rw noinitrd mem=64M " \ + "rootfstype=ubifs root=ubi0:rootfs ubi.mtd=6" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "_mtd=mtdparts default; set bootargs ${bootargs} ${mtdparts}\0" \ + "autoload=no\0" \ + "autostart=no\0" \ + "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ + "\0" + +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024 + 0x1000) + +/* SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x6000 +#define CONFIG_SPL_STACK 0x308000 + +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SYS_MONITOR_LEN (512 << 10) + +#define CONFIG_SYS_MASTER_CLOCK 132096000 +#define CONFIG_SYS_AT91_PLLA 0x20c73f03 +#define CONFIG_SYS_MCKR 0x1301 +#define CONFIG_SYS_MCKR_CSS 0x1302 + +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0 +#define CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER + +#endif /* __CONFIG_H__ */
- Ethernet
- FIT
- SPL
- Ethernet
- FIT
- SPL
Patch is assigned to me. However, this is Atmel, now orphaned. I haven't work with AT-91 since a very long time, so I cannot say more about patches, but it is a pity if the patches will be lost. Tom, should I merge them even if they are not i.MX related ? Or do you pick them yourself ?
Regards, Stefano
- bool "Support Laird WB45N"
- select CPU_ARM926EJS
- select SUPPORT_SPL
endchoice
- at91_set_pio_deglitch((x - PIN_BASE) / 32,(x % 32), y)
+config SYS_BOARD
- default "wb45n"
+config SYS_VENDOR
- default "laird"
- default "wb45n"
- Miscelaneous platform dependent initialisations
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- unsigned long csa;
- csa = readl(&matrix->ebicsa);
- /* Enable CS3 */
- csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA;
- /* NAND flash on D0 */
- csa &= ~AT91_MATRIX_NFD0_ON_D16;
- writel(csa, &matrix->ebicsa);
- /* Configure SMC CS3 for NAND/SmartMedia */
- writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6),
&smc->cs[3].cycle);
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
- at91_periph_clk_enable(ATMEL_ID_PIOCD);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
- /* Disable Flash Write Protect Line */
- at91_set_gpio_output(AT91_PIN_PD10, 1);
- at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* NAND OE */
- at91_set_a_periph(AT91_PIO_PORTD, 1, 1); /* NAND WE */
- at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* NAND ALE */
- at91_set_a_periph(AT91_PIO_PORTD, 3, 1); /* NAND CLE */
- /* Configure wifi gpio CHIP_PWD_L */
- at91_set_gpio_output(AT91_PIN_PA28, 0);
- /* Setup USB pins */
- at91_set_gpio_input(AT91_PIN_PB11, 0);
- at91_set_gpio_output(AT91_PIN_PB12, 0);
- /* IRQ pin, pullup, deglitch */
- at91_set_gpio_input(AT91_PIN_PB18, 1);
- at91_set_gpio_deglitch(AT91_PIN_PB18, 1);
- int rc = 0;
- if (has_emac0())
- return rc;
- at91_seriald_hw_init();
- /* address of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- wb45n_gpio_hw_init();
- wb45n_nand_hw_init();
- at91_macb_hw_init();
- gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE,
- /* Setup GPIO first */
- /* Bring up NAND */
- /* Pull ups on D0 - D16 */
- csa &= ~AT91_MATRIX_EBI_DBPU_OFF;
- csa |= AT91_MATRIX_EBI_DBPD_OFF;
- /* Normal drive strength */
- csa |= AT91_MATRIX_EBI_EBI_IOSR_NORMAL;
- /* Multi-port off */
- csa &= ~AT91_MATRIX_MP_ON;
- ddr2->md = (ATMEL_MPDDRC_MD_DBW_16_BITS | ATMEL_MPDDRC_MD_LPDDR_SDRAM);
- ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_10 |
- ddr2->rtr = 0x411;
- ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET |
- ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET |
- ddr2->tpr2 = (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET |
- struct atmel_mpddrc_config ddr2;
- ddr2_conf(&ddr2);
- /* enable DDR2 clock */
- at91_system_clk_enable(AT91_PMC_DDR);
- /* Chip select 1 is for DDR2/SDRAM */
- csa |= AT91_MATRIX_EBI_CS1A_SDRAMC;
- /* DDRAM2 Controller initialize */
- ddr2_init(ATMEL_BASE_DDRSDRC, ATMEL_BASE_CS1, &ddr2);
- Configuation settings for the WB45N CPU Module.
- BOOTP options
- (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
- "run _mtd; bootm"
"128K(at91bs)," \
"512K(u-boot)," \
"46208K(user)," \
"512K(logs)"
- "_mtd=mtdparts default; set bootargs ${bootargs} ${mtdparts}\0" \
- "autoload=no\0" \
- "autostart=no\0" \
- "ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \
- "\0"
- Size of malloc() pool
- Ethernet
- FIT
- SPL
Ah, sorry, I saw laird, had the WiFi modules they do for i.MX series platforms in mind and went "oh, must be an i.MX system". Please toss them back to me, thanks!
- Ethernet
- FIT
- SPL
Hi Tom, Any comments on these boards? Whilst I was at ELCE I bumped into Marek and had a talk about adding new boards, he had mentioned new boards should be using DM. As this is the direction things are moving let me know and I can convert them.
Thanks, Ben
- Ethernet
- FIT
- SPL
Sorry. Can you please re-test and re-post against top of tree and I'll make sure it gets in, assuming no other problems show up. Thanks!
This board is based on the Atmel sama5d3 eval boards. Supporting the following features: - Boot from NAND Flash - Ethernet - FIT - SPL
Signed-off-by: Ben Whitten ben.whitten@lairdtech.com Signed-off-by: Dan Kephart dan.kephart@lairdtech.com --- arch/arm/mach-at91/Kconfig | 8 ++ board/laird/wb50n/Kconfig | 12 +++ board/laird/wb50n/MAINTAINERS | 6 ++ board/laird/wb50n/Makefile | 6 ++ board/laird/wb50n/wb50n.c | 206 ++++++++++++++++++++++++++++++++++++++++++ configs/wb50n_defconfig | 26 ++++++ include/configs/wb50n.h | 143 +++++++++++++++++++++++++++++ 7 files changed, 407 insertions(+) create mode 100644 board/laird/wb50n/Kconfig create mode 100644 board/laird/wb50n/MAINTAINERS create mode 100644 board/laird/wb50n/Makefile create mode 100644 board/laird/wb50n/wb50n.c create mode 100644 configs/wb50n_defconfig create mode 100644 include/configs/wb50n.h
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index e4d9690..d89c53b 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -169,6 +169,13 @@ config TARGET_WB45N select CPU_ARM926EJS select SUPPORT_SPL
+config TARGET_WB50N + bool "Support Laird WB50N" + select BOARD_LATE_INIT + select CPU_V7 + select SUPPORT_SPL + select BOARD_EARLY_INIT_F + endchoice
config SYS_SOC @@ -203,5 +210,6 @@ source "board/siemens/corvus/Kconfig" source "board/siemens/taurus/Kconfig" source "board/siemens/smartweb/Kconfig" source "board/laird/wb45n/Kconfig" +source "board/laird/wb50n/Kconfig"
endif diff --git a/board/laird/wb50n/Kconfig b/board/laird/wb50n/Kconfig new file mode 100644 index 0000000..2e7090e --- /dev/null +++ b/board/laird/wb50n/Kconfig @@ -0,0 +1,12 @@ +if TARGET_WB50N + +config SYS_BOARD + default "wb50n" + +config SYS_VENDOR + default "laird" + +config SYS_CONFIG_NAME + default "wb50n" + +endif diff --git a/board/laird/wb50n/MAINTAINERS b/board/laird/wb50n/MAINTAINERS new file mode 100644 index 0000000..3d38fc4 --- /dev/null +++ b/board/laird/wb50n/MAINTAINERS @@ -0,0 +1,6 @@ +WB50N CPU MODULE +M: Ben Whitten ben.whitten@lairdtech.com +S: Maintained +F: board/laird/wb50n/ +F: include/configs/wb50n.h +F: configs/wb50n_defconfig diff --git a/board/laird/wb50n/Makefile b/board/laird/wb50n/Makefile new file mode 100644 index 0000000..d1b6cfa --- /dev/null +++ b/board/laird/wb50n/Makefile @@ -0,0 +1,6 @@ +# +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += wb50n.o diff --git a/board/laird/wb50n/wb50n.c b/board/laird/wb50n/wb50n.c new file mode 100644 index 0000000..354cecf --- /dev/null +++ b/board/laird/wb50n/wb50n.c @@ -0,0 +1,206 @@ +/* + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sama5_sfr.h> +#include <asm/arch/sama5d3_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clk.h> +#include <micrel.h> +#include <net.h> +#include <netdev.h> +#include <spl.h> +#include <asm/arch/atmel_mpddrc.h> +#include <asm/arch/at91_wdt.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +void wb50n_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + + at91_periph_clk_enable(ATMEL_ID_SMC); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(1) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(1), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(5), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(8) | AT91_SMC_CYCLE_NRD(8), + &smc->cs[3].cycle); + writel(AT91_SMC_TIMINGS_TCLR(3) | AT91_SMC_TIMINGS_TADL(10) | + AT91_SMC_TIMINGS_TAR(3) | AT91_SMC_TIMINGS_TRR(4) | + AT91_SMC_TIMINGS_TWB(5) | AT91_SMC_TIMINGS_RBNSEL(3) | + AT91_SMC_TIMINGS_NFSEL(1), &smc->cs[3].timings); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode); + + /* Disable Flash Write Protect Line */ + at91_set_pio_output(AT91_PIO_PORTE, 14, 1); +} + +int board_early_init_f(void) +{ + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + at91_periph_clk_enable(ATMEL_ID_PIOD); + at91_periph_clk_enable(ATMEL_ID_PIOE); + + at91_seriald_hw_init(); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + wb50n_nand_hw_init(); + + at91_macb_hw_init(); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* rx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x2222); + /* tx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x2222); + /* rx/tx clock delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf2f4); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; + + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); + + return rc; +} + +#ifdef CONFIG_BOARD_LATE_INIT +#include <linux/ctype.h> +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + const char *LAIRD_NAME = "lrd_name"; + char name[32], *p; + + strcpy(name, get_cpu_name()); + for (p = name; *p != '\0'; *p = tolower(*p), p++) + ; + strcat(name, "-wb50n"); + setenv(LAIRD_NAME, name); + +#endif + + return 0; +} +#endif + +/* SPL */ +#ifdef CONFIG_SPL_BUILD +void spl_board_init(void) +{ + wb50n_nand_hw_init(); +} + +static void ddr2_conf(struct atmel_mpddrc_config *ddr2) +{ + ddr2->md = (ATMEL_MPDDRC_MD_DBW_32_BITS | ATMEL_MPDDRC_MD_LPDDR_SDRAM); + + ddr2->cr = (ATMEL_MPDDRC_CR_NC_COL_9 | + ATMEL_MPDDRC_CR_NR_ROW_13 | + ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | + ATMEL_MPDDRC_CR_NDQS_DISABLED | + ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | + ATMEL_MPDDRC_CR_UNAL_SUPPORTED); + + ddr2->rtr = 0x411; + + ddr2->tpr0 = (6 << ATMEL_MPDDRC_TPR0_TRAS_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRCD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWR_OFFSET | + 8 << ATMEL_MPDDRC_TPR0_TRC_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRP_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TRRD_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TWTR_OFFSET | + 2 << ATMEL_MPDDRC_TPR0_TMRD_OFFSET); + + ddr2->tpr1 = (2 << ATMEL_MPDDRC_TPR1_TXP_OFFSET | + 200 << ATMEL_MPDDRC_TPR1_TXSRD_OFFSET | + 19 << ATMEL_MPDDRC_TPR1_TXSNR_OFFSET | + 18 << ATMEL_MPDDRC_TPR1_TRFC_OFFSET); + + ddr2->tpr2 = (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TRTP_OFFSET | + 3 << ATMEL_MPDDRC_TPR2_TRPA_OFFSET | + 7 << ATMEL_MPDDRC_TPR2_TXARDS_OFFSET | + 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); +} + +void mem_init(void) +{ + struct atmel_sfr *sfr = (struct atmel_sfr *)ATMEL_BASE_SFR; + struct atmel_mpddrc_config ddr2; + + ddr2_conf(&ddr2); + + writel(ATMEL_SFR_DDRCFG_FDQIEN | ATMEL_SFR_DDRCFG_FDQSIEN, + &sfr->ddrcfg); + + /* enable MPDDR clock */ + at91_periph_clk_enable(ATMEL_ID_MPDDRC); + at91_system_clk_enable(AT91_PMC_DDR); + + /* DDRAM2 Controller initialize */ + ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); +} + +void at91_pmc_init(void) +{ + u32 tmp; + + tmp = AT91_PMC_PLLAR_29 | + AT91_PMC_PLLXR_PLLCOUNT(0x3f) | + AT91_PMC_PLLXR_MUL(43) | AT91_PMC_PLLXR_DIV(1); + at91_plla_init(tmp); + + at91_pllicpr_init(AT91_PMC_IPLL_PLLA(0x3)); + + tmp = AT91_PMC_MCKR_MDIV_4 | AT91_PMC_MCKR_CSS_PLLA; + at91_mck_init(tmp); +} +#endif diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig new file mode 100644 index 0000000..e03a5d3 --- /dev/null +++ b/configs/wb50n_defconfig @@ -0,0 +1,26 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TARGET_WB50N=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" +CONFIG_BOOTDELAY=3 +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y +CONFIG_CMD_NAND_TRIMFFS=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_LZMA=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h new file mode 100644 index 0000000..ba66daa --- /dev/null +++ b/include/configs/wb50n.h @@ -0,0 +1,143 @@ +/* + * Configuation settings for the WB50N CPU Module. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/hardware.h> + +#define CONFIG_SYS_TEXT_BASE 0x23f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ + +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define CONFIG_IMAGE_FORMAT_LEGACY + +/* general purpose I/O */ +#define CONFIG_AT91_GPIO + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_DBGU + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_DDRCS +#define CONFIG_SYS_SDRAM_SIZE 0x04000000 + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR 0x310000 +#else +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) +#endif + +#define CONFIG_SYS_MEMTEST_START 0x21000000 +#define CONFIG_SYS_MEMTEST_END 0x22000000 +#define CONFIG_SYS_ALT_MEMTEST + +/* NAND flash */ +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ONFI_DETECTION +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC +#define CONFIG_ATMEL_NAND_HW_PMECC +#define CONFIG_PMECC_CAP 8 +#define CONFIG_PMECC_SECTOR_SIZE 512 + +/* Ethernet Hardware */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_MACB_SEARCH_PHY +#define CONFIG_RGMII +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 +#define CONFIG_ETHADDR C0:EE:40:00:00:00 +#define CONFIG_ENV_OVERWRITE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "autoload=no\0" \ + "autostart=no\0" + +/* bootstrap + u-boot + env in nandflash */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0xA0000 +#define CONFIG_ENV_OFFSET_REDUND 0xC0000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_BOOTCOMMAND \ + "nand read 0x22000000 0x000e0000 0x500000; " \ + "bootm" + +#define CONFIG_BOOTARGS \ + "rw rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (2 * 1024 * 1024) + +/* SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x300000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_BSS_START_ADDR 0x20000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20080000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 + +#define CONFIG_SYS_MONITOR_LEN (512 << 10) + +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE 0x20000 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0x0 +#define CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER + +#endif
- Ethernet
- FIT
- SPL
Ben Whitten
Ben Whitten
Stefano Babic
