[PATCH v5 1/3] arm: mvebu: dts: sync DTS
Update the uDPU DTS to the version that is pending upstream [1][2][3][4].
[1] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [2] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [3] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4... [4] https://patchwork.kernel.org/project/linux-arm-kernel/patch/20220516124828.4...
Signed-off-by: Robert Marko robert.marko@sartura.hr --- arch/arm/dts/armada-3720-uDPU.dts | 23 ++++++++++------------- 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/armada-3720-uDPU.dts b/arch/arm/dts/armada-3720-uDPU.dts index 1f534c0c65..f21a855fc6 100644 --- a/arch/arm/dts/armada-3720-uDPU.dts +++ b/arch/arm/dts/armada-3720-uDPU.dts @@ -16,7 +16,7 @@
/ { model = "Methode uDPU Board"; - compatible = "methode,udpu", "marvell,armada3720"; + compatible = "methode,udpu", "marvell,armada3720", "marvell,armada3710";
chosen { stdout-path = "serial0:115200n8"; @@ -28,35 +28,34 @@ };
leds { - pinctrl-names = "default"; compatible = "gpio-leds";
- power1 { + led-power1 { label = "udpu:green:power"; gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; };
- power2 { + led-power2 { label = "udpu:red:power"; gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; };
- network1 { + led-network1 { label = "udpu:green:network"; gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; };
- network2 { + led-network2 { label = "udpu:red:network"; gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; };
- alarm1 { + led-alarm1 { label = "udpu:green:alarm"; gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; };
- alarm2 { + led-alarm2 { label = "udpu:red:alarm"; gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; }; @@ -99,7 +98,7 @@ pinctrl-names = "default"; pinctrl-0 = <&spi_quad_pins>;
- spi-flash@0 { + flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <54000000>; @@ -153,14 +152,12 @@ scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
- nct375@48 { - status = "okay"; + temp-sensor@48 { compatible = "ti,tmp75c"; reg = <0x48>; };
- nct375@49 { - status = "okay"; + temp-sensor@49 { compatible = "ti,tmp75c"; reg = <0x49>; };
Methode eDPU is an Armada 3720 power board based on the Methode uDPU.
They feature the same CPU, RAM, and storage as well as the form factor.
However, eDPU only has one SFP slot plus a copper G.hn port which does not work under U-boot.
In order to reduce duplication, split the uDPU DTS into a common one.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- Changes in v4: * Remove CMD_PCI as PCI is disabled anyway
Changes in v3: * Use DTS-es pending merge upstream * Re-enable SCSI as the Armada 37xx BOOT_TARGET_DEVICES defines SCSI device as one of the bootable ones. We dont have space constraints, so just re-enable SCSI rather than making one more config header
Changes in v2: * Correct the PHY mode to 2500Base-X * Add the DTB to Makefile * Remove SCSI/SATA, PCI and E1000 from defconfig as they are not present --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-eDPU-u-boot.dtsi | 45 ++++++ arch/arm/dts/armada-3720-eDPU.dts | 14 ++ arch/arm/dts/armada-3720-uDPU.dts | 150 +------------------- arch/arm/dts/armada-3720-uDPU.dtsi | 160 ++++++++++++++++++++++ configs/eDPU_defconfig | 95 +++++++++++++ 6 files changed, 316 insertions(+), 149 deletions(-) create mode 100644 arch/arm/dts/armada-3720-eDPU-u-boot.dtsi create mode 100644 arch/arm/dts/armada-3720-eDPU.dts create mode 100644 arch/arm/dts/armada-3720-uDPU.dtsi create mode 100644 configs/eDPU_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 83630af4f6..c484875585 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -236,6 +236,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ armada-3720-turris-mox.dtb \ + armada-3720-eDPU.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ armada-385-atl-x530.dtb \ diff --git a/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi b/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi new file mode 100644 index 0000000000..1b2648f64d --- /dev/null +++ b/arch/arm/dts/armada-3720-eDPU-u-boot.dtsi @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + smbios { + compatible = "u-boot,sysinfo-smbios"; + + smbios { + system { + product = "eDPU"; + }; + + baseboard { + product = "eDPU"; + }; + + chassis { + product = "eDPU"; + }; + }; + }; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; +}; + +ð0 { + /* G.hn does not work without additional configuration */ + status = "disabled"; +}; + +ð1 { + fixed-link { + speed = <1000>; + full-duplex; + }; +}; diff --git a/arch/arm/dts/armada-3720-eDPU.dts b/arch/arm/dts/armada-3720-eDPU.dts new file mode 100644 index 0000000000..57fc698e55 --- /dev/null +++ b/arch/arm/dts/armada-3720-eDPU.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; + +#include "armada-3720-uDPU.dtsi" + +/ { + model = "Methode eDPU Board"; + compatible = "methode,edpu", "marvell,armada3720", "marvell,armada3710"; +}; + +ð0 { + phy-mode = "2500base-x"; +}; diff --git a/arch/arm/dts/armada-3720-uDPU.dts b/arch/arm/dts/armada-3720-uDPU.dts index f21a855fc6..a75734d88a 100644 --- a/arch/arm/dts/armada-3720-uDPU.dts +++ b/arch/arm/dts/armada-3720-uDPU.dts @@ -1,66 +1,13 @@ // SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Device tree for the uDPU board. - * Based on Marvell Armada 3720 development board (DB-88F3720-DDR3) - * Copyright (C) 2016 Marvell - * Copyright (C) 2019 Methode Electronics - * Copyright (C) 2019 Telus - * - * Vladimir Vid vladimir.vid@sartura.hr - */
/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include "armada-372x.dtsi" +#include "armada-3720-uDPU.dtsi"
/ { model = "Methode uDPU Board"; compatible = "methode,udpu", "marvell,armada3720", "marvell,armada3710";
- chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x00000000 0x00000000 0x00000000 0x20000000>; - }; - - leds { - compatible = "gpio-leds"; - - led-power1 { - label = "udpu:green:power"; - gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; - }; - - led-power2 { - label = "udpu:red:power"; - gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; - }; - - led-network1 { - label = "udpu:green:network"; - gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; - }; - - led-network2 { - label = "udpu:red:network"; - gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; - }; - - led-alarm1 { - label = "udpu:green:alarm"; - gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; - }; - - led-alarm2 { - label = "udpu:red:alarm"; - gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; - }; - }; - sfp_eth0: sfp-eth0 { compatible = "sff,sfp"; i2c-bus = <&i2c0>; @@ -70,55 +17,6 @@ tx-fault-gpio = <&gpiosb 5 GPIO_ACTIVE_HIGH>; maximum-power-milliwatt = <3000>; }; - - sfp_eth1: sfp-eth1 { - compatible = "sff,sfp"; - i2c-bus = <&i2c1>; - los-gpio = <&gpiosb 7 GPIO_ACTIVE_HIGH>; - mod-def0-gpio = <&gpiosb 8 GPIO_ACTIVE_LOW>; - tx-disable-gpio = <&gpiosb 9 GPIO_ACTIVE_HIGH>; - tx-fault-gpio = <&gpiosb 10 GPIO_ACTIVE_HIGH>; - maximum-power-milliwatt = <3000>; - }; -}; - -&sdhci0 { - status = "okay"; - bus-width = <8>; - mmc-ddr-1_8v; - mmc-hs400-1_8v; - marvell,pad-type = "fixed-1-8v"; - non-removable; - no-sd; - no-sdio; -}; - -&spi0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&spi_quad_pins>; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <54000000>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "firmware"; - reg = <0x0 0x180000>; - }; - - partition@180000 { - label = "u-boot-env"; - reg = <0x180000 0x10000>; - }; - }; - }; };
&pinctrl_nb { @@ -126,11 +24,6 @@ groups = "i2c1"; function = "gpio"; }; - - i2c2_recovery_pins: i2c2-recovery-pins { - groups = "i2c2"; - function = "gpio"; - }; };
&i2c0 { @@ -143,48 +36,7 @@ sda-gpios = <&gpionb 1 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; };
-&i2c1 { - status = "okay"; - pinctrl-names = "default", "recovery"; - pinctrl-0 = <&i2c2_pins>; - pinctrl-1 = <&i2c2_recovery_pins>; - /delete-property/mrvl,i2c-fast-mode; - scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; - - temp-sensor@48 { - compatible = "ti,tmp75c"; - reg = <0x48>; - }; - - temp-sensor@49 { - compatible = "ti,tmp75c"; - reg = <0x49>; - }; -}; - ð0 { phy-mode = "sgmii"; - status = "okay"; - managed = "in-band-status"; - phys = <&comphy1 0>; sfp = <&sfp_eth0>; }; - -ð1 { - phy-mode = "sgmii"; - status = "okay"; - managed = "in-band-status"; - phys = <&comphy0 1>; - sfp = <&sfp_eth1>; -}; - -&usb3 { - status = "okay"; - phys = <&usb2_utmi_otg_phy>; - phy-names = "usb2-utmi-otg-phy"; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/dts/armada-3720-uDPU.dtsi b/arch/arm/dts/armada-3720-uDPU.dtsi new file mode 100644 index 0000000000..3f79923376 --- /dev/null +++ b/arch/arm/dts/armada-3720-uDPU.dtsi @@ -0,0 +1,160 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device tree for the uDPU board. + * Based on Marvell Armada 3720 development board (DB-88F3720-DDR3) + * Copyright (C) 2016 Marvell + * Copyright (C) 2019 Methode Electronics + * Copyright (C) 2019 Telus + * + * Vladimir Vid vladimir.vid@sartura.hr + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "armada-372x.dtsi" + +/ { + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x00000000 0x00000000 0x00000000 0x20000000>; + }; + + leds { + compatible = "gpio-leds"; + + led-power1 { + label = "udpu:green:power"; + gpios = <&gpionb 11 GPIO_ACTIVE_LOW>; + }; + + led-power2 { + label = "udpu:red:power"; + gpios = <&gpionb 12 GPIO_ACTIVE_LOW>; + }; + + led-network1 { + label = "udpu:green:network"; + gpios = <&gpionb 13 GPIO_ACTIVE_LOW>; + }; + + led-network2 { + label = "udpu:red:network"; + gpios = <&gpionb 14 GPIO_ACTIVE_LOW>; + }; + + led-alarm1 { + label = "udpu:green:alarm"; + gpios = <&gpionb 15 GPIO_ACTIVE_LOW>; + }; + + led-alarm2 { + label = "udpu:red:alarm"; + gpios = <&gpionb 16 GPIO_ACTIVE_LOW>; + }; + }; + + sfp_eth1: sfp-eth1 { + compatible = "sff,sfp"; + i2c-bus = <&i2c1>; + los-gpio = <&gpiosb 7 GPIO_ACTIVE_HIGH>; + mod-def0-gpio = <&gpiosb 8 GPIO_ACTIVE_LOW>; + tx-disable-gpio = <&gpiosb 9 GPIO_ACTIVE_HIGH>; + tx-fault-gpio = <&gpiosb 10 GPIO_ACTIVE_HIGH>; + maximum-power-milliwatt = <3000>; + }; +}; + +&sdhci0 { + status = "okay"; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + marvell,pad-type = "fixed-1-8v"; + non-removable; + no-sd; + no-sdio; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi_quad_pins>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <54000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "firmware"; + reg = <0x0 0x180000>; + }; + + partition@180000 { + label = "u-boot-env"; + reg = <0x180000 0x10000>; + }; + }; + }; +}; + +&pinctrl_nb { + i2c2_recovery_pins: i2c2-recovery-pins { + groups = "i2c2"; + function = "gpio"; + }; +}; + +&i2c1 { + status = "okay"; + pinctrl-names = "default", "recovery"; + pinctrl-0 = <&i2c2_pins>; + pinctrl-1 = <&i2c2_recovery_pins>; + /delete-property/mrvl,i2c-fast-mode; + scl-gpios = <&gpionb 2 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + sda-gpios = <&gpionb 3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; + + temp-sensor@48 { + compatible = "ti,tmp75c"; + reg = <0x48>; + }; + + temp-sensor@49 { + compatible = "ti,tmp75c"; + reg = <0x49>; + }; +}; + +ð0 { + status = "okay"; + managed = "in-band-status"; + phys = <&comphy1 0>; +}; + +ð1 { + phy-mode = "sgmii"; + status = "okay"; + managed = "in-band-status"; + phys = <&comphy0 1>; + sfp = <&sfp_eth1>; +}; + +&usb3 { + status = "okay"; + phys = <&usb2_utmi_otg_phy>; + phy-names = "usb2-utmi-otg-phy"; +}; + +&uart0 { + status = "okay"; +}; diff --git a/configs/eDPU_defconfig b/configs/eDPU_defconfig new file mode 100644 index 0000000000..e2e593ad21 --- /dev/null +++ b/configs/eDPU_defconfig @@ -0,0 +1,95 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_MVEBU_EFUSE=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x180000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="armada-3720-eDPU" +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_SYS_LOAD_ADDR=0x6000000 +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_USE_PREBOOT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="eDPU>> " +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +# CONFIG_CMD_SCSI is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ARP_TIMEOUT=200 +CONFIG_NET_RETRY_COUNT=50 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_I2C=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_MV=y +CONFIG_MISC=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB_10G=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_FIXED=y +CONFIG_PHY_GIGE=y +CONFIG_MVNETA=y +CONFIG_MVMDIO=y +CONFIG_PHY=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_37XX=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SCSI=y +CONFIG_MVEBU_A3700_UART=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SMBIOS=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_LZO=y +CONFIG_SPL_LZO=y
Thanks, Stefan
Changes in v4:
- Remove CMD_PCI as PCI is disabled anyway
Changes in v3:
- Use DTS-es pending merge upstream
- Re-enable SCSI as the Armada 37xx BOOT_TARGET_DEVICES defines SCSI device
Changes in v2:
- Correct the PHY mode to 2500Base-X
- Add the DTB to Makefile
- Remove SCSI/SATA, PCI and E1000 from defconfig as they are not present
- armada-3720-eDPU.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ armada-385-atl-x530.dtb \
- smbios {
smbios {
system {
product = "eDPU";
baseboard {
product = "eDPU";
chassis {
product = "eDPU";
+&spi0 {
- u-boot,dm-pre-reloc;
- spi-flash@0 {
+&sdhci0 {
+ð0 {
- /* G.hn does not work without additional configuration */
- status = "disabled";
+ð1 {
- fixed-link {
speed = <1000>;
full-duplex;
+/dts-v1/;
- model = "Methode eDPU Board";
- compatible = "methode,edpu", "marvell,armada3720", "marvell,armada3710";
+ð0 {
- phy-mode = "2500base-x";
- Device tree for the uDPU board.
- Based on Marvell Armada 3720 development board (DB-88F3720-DDR3)
- Copyright (C) 2016 Marvell
- Copyright (C) 2019 Methode Electronics
- Copyright (C) 2019 Telus
- Vladimir Vid vladimir.vid@sartura.hr
/dts-v1/;
- chosen {
- memory@0 {
- leds {
led-power1 {
led-power2 {
led-network1 {
led-network2 {
led-alarm1 {
led-alarm2 {
i2c-bus = <&i2c1>;
-&sdhci0 {
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
- non-removable;
- no-sd;
- no-sdio;
-&spi0 {
status = "okay";
flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "firmware";
partition@180000 {
&pinctrl_nb {
groups = "i2c2";
function = "gpio";
&i2c0 {
-&i2c1 {
- status = "okay";
- temp-sensor@48 {
reg = <0x48>;
- temp-sensor@49 {
reg = <0x49>;
- status = "okay";
-ð1 {
- status = "okay";
-&usb3 {
- status = "okay";
-&uart0 {
- status = "okay";
+/dts-v1/;
- chosen {
- memory@0 {
- leds {
led-power1 {
led-power2 {
led-network1 {
led-network2 {
led-alarm1 {
led-alarm2 {
i2c-bus = <&i2c1>;
+&sdhci0 {
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
- non-removable;
- no-sd;
- no-sdio;
+&spi0 {
- status = "okay";
- flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "firmware";
partition@180000 {
+&pinctrl_nb {
groups = "i2c2";
function = "gpio";
+&i2c1 {
- status = "okay";
- temp-sensor@48 {
reg = <0x48>;
- temp-sensor@49 {
reg = <0x49>;
+ð0 {
- status = "okay";
+ð1 {
- status = "okay";
+&usb3 {
- status = "okay";
+&uart0 {
- status = "okay";
Viele Grüße, Stefan Roese
On Friday 20 May 2022 13:46:32 Robert Marko wrote:
Changes in v4:
Changes in v3:
Hello! Is this SCSI error related to distroboot as for NVMe here? https://patchwork.ozlabs.org/comment/2896154/
Changes in v2:
Changes in v4:
Changes in v3:
Hi Pali, its the same type of error, just for SCSI. I see that you posted a possible solution for cases where boards dont have one of the listed media enabled.
Regards, Robert
Changes in v2:
Changes in v4:
Changes in v3:
Ok! I added guard in new patch for all boot targets, including SCSI, so it should fix also issue for *DPU boards.
Regards, Robert
Changes in v2:
-- Robert Marko Staff Embedded Linux Engineer Sartura Ltd. Lendavska ulica 16a 10000 Zagreb, Croatia Email: robert.marko@sartura.hr Web: www.sartura.hr
Changes in v4:
Changes in v3:
Hello! Patch "Set BOOT_TARGET_DEVICES list to enabled peripherals" is now in u-boot-marvell tree, so you could send a patch which disables those unused peripherals in eDPU defconfig file. https://source.denx.de/u-boot/custodians/u-boot-marvell/-/commits/master/
Regards, Robert
Changes in v2:
Changes in v4:
Changes in v3:
Just to clarify: I originally wanted to push those changes in "master" upstream beginning of this week. But decided to defer this until the next merge window open, as most of them are not bug fixes.
Still Pali's comment is correct. You could already work on a patch using these groundwork patches as basis.
Thanks, Stefan
Regards, Robert
Changes in v2:
Changes in v4:
Changes in v3:
No issues, I was waiting for them to be picked into your tree. I will whip up a patch to disable SCSI now that it's not required anymore.
Regards, Robert
Thanks, Stefan
Regards, Robert
Changes in v2:
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v4:
Changes in v3:
Changes in v2:
- smbios {
smbios {
system {
product = "eDPU";
baseboard {
product = "eDPU";
chassis {
product = "eDPU";
+&spi0 {
- spi-flash@0 {
+&sdhci0 {
+ð0 {
+ð1 {
- fixed-link {
speed = <1000>;
full-duplex;
+/dts-v1/;
+ð0 {
/dts-v1/;
- chosen {
- memory@0 {
- leds {
led-power1 {
led-power2 {
led-network1 {
led-network2 {
led-alarm1 {
led-alarm2 {
i2c-bus = <&i2c1>;
-&sdhci0 {
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
- non-removable;
- no-sd;
- no-sdio;
-&spi0 {
status = "okay";
flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "firmware";
partition@180000 {
&pinctrl_nb {
groups = "i2c2";
function = "gpio";
&i2c0 {
-&i2c1 {
- status = "okay";
- temp-sensor@48 {
reg = <0x48>;
- temp-sensor@49 {
reg = <0x49>;
- status = "okay";
-ð1 {
- status = "okay";
-&usb3 {
- status = "okay";
-&uart0 {
- status = "okay";
+/dts-v1/;
- chosen {
- memory@0 {
- leds {
led-power1 {
led-power2 {
led-network1 {
led-network2 {
led-alarm1 {
led-alarm2 {
i2c-bus = <&i2c1>;
+&sdhci0 {
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
- non-removable;
- no-sd;
- no-sdio;
+&spi0 {
- status = "okay";
- flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "firmware";
partition@180000 {
+&pinctrl_nb {
groups = "i2c2";
function = "gpio";
+&i2c1 {
- status = "okay";
- temp-sensor@48 {
reg = <0x48>;
- temp-sensor@49 {
reg = <0x49>;
+ð0 {
- status = "okay";
+ð1 {
- status = "okay";
+&usb3 {
- status = "okay";
+&uart0 {
- status = "okay";
I am currently maintaing the Methode uDPU and eDPU boards so add myself as the maintainer for them.
Remove the old entry from board/Marvell/mvebu_armada-37xx/MAINTAINERS.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- Changes in v5: * Remove entry from the board/Marvell/mvebu_armada-37xx/MAINTAINERS --- MAINTAINERS | 8 ++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 5 ----- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 56be0bfad0..3d72b0c11f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -344,6 +344,14 @@ F: tools/mtk_image.c F: tools/mtk_image.h N: mediatek
+ARM METHODE SUPPORT +M: Robert Marko robert.marko@sartura.hr +S: Maintained +F: arch/arm/dts/armada-3720-eDPU* +F: arch/arm/dts/armada-3720-uDPU* +F: configs/eDPU_defconfig +F: configs/uDPU_defconfig + ARM MICROCHIP/ATMEL AT91 M: Eugen Hristev eugen.hristev@microchip.com S: Maintained diff --git a/board/Marvell/mvebu_armada-37xx/MAINTAINERS b/board/Marvell/mvebu_armada-37xx/MAINTAINERS index f2c0a582d7..9b0afeef10 100644 --- a/board/Marvell/mvebu_armada-37xx/MAINTAINERS +++ b/board/Marvell/mvebu_armada-37xx/MAINTAINERS @@ -9,8 +9,3 @@ ESPRESSOBin BOARD M: Konstantin Porotchkin kostap@marvell.com S: Maintained F: configs/mvebu_espressobin-88f3720_defconfig - -uDPU BOARD -M: Vladimir Vid vladimir.vid@sartura.hr -S: Maintained -F: configs/uDPU_defconfig
Thanks, Stefan
Changes in v5:
- Remove entry from the board/Marvell/mvebu_armada-37xx/MAINTAINERS
- ARM MICROCHIP/ATMEL AT91 M: Eugen Hristev eugen.hristev@microchip.com S: Maintained
Thanks, Stefan
Changes in v5:
Thanks, Stefan
leds {
power1 {
};led-power1 { label = "udpu:green:power"; gpios = <&gpionb 11 GPIO_ACTIVE_LOW>;
power2 {
};led-power2 { label = "udpu:red:power"; gpios = <&gpionb 12 GPIO_ACTIVE_LOW>;
network1 {
};led-network1 { label = "udpu:green:network"; gpios = <&gpionb 13 GPIO_ACTIVE_LOW>;
network2 {
};led-network2 { label = "udpu:red:network"; gpios = <&gpionb 14 GPIO_ACTIVE_LOW>;
alarm1 {
};led-alarm1 { label = "udpu:green:alarm"; gpios = <&gpionb 15 GPIO_ACTIVE_LOW>;
alarm2 {
};led-alarm2 { label = "udpu:red:alarm"; gpios = <&gpionb 16 GPIO_ACTIVE_LOW>;
- spi-flash@0 {
- flash@0 { compatible = "jedec,spi-nor"; reg = <0>; spi-max-frequency = <54000000>;
- nct375@48 {
status = "okay";
- temp-sensor@48 { compatible = "ti,tmp75c"; reg = <0x48>; };
- nct375@49 {
status = "okay";
- temp-sensor@49 { compatible = "ti,tmp75c"; reg = <0x49>; };
Thanks, Stefan
leds {
power1 {
power2 {
network1 {
network2 {
alarm1 {
alarm2 {
- spi-flash@0 {
- nct375@48 {
status = "okay";
- nct375@49 {
status = "okay";
Pali Rohár
Robert Marko
Stefan Roese
