[PATCH v7 0/3] Introduce mtdblock device
Hello!
This series adds support for the mtdblock device, which allows to read/write data block by block. For example, it can now be used for BCB or Android AB command:
$ bcb load mtd 0 part_name
Tested only on SPI NAND, so bind is made only for SPI NAND drivers.
Changes V1 -> V2 [1]:
- Drop patch [2]. - Add warning if bind NAND mtdblock device. - Move documentation of mtdblock implementation from commit message to the source code. - Remove __maybe_unused from mtd partition functions description. - Use blk_enabled() instead of #ifdefs.
Changes V2 -> V3 [2]:
- Rebased over [3]. - Rename mtd_bread/bwrite -> mtd_blk_read/write. - Fix GPL-2.0 license short name definiton in headers. - Add empty line after MTD_ENTRY_NUMBERS define.
Changes V3 -> V4 [4]:
- Fix build warnings: use LBAF printf format string for lbaint_t types.
Changes V4 -> V5 [5]:
- Rebased over u-boot/master. - Fix build errors and warnings if CONFIG_BLK isn't enabled. - Fix failed tests in cases is mtdblock device isn't binded.
Changes V5 -> V6 [6]:
- Rebased over u-boot/master. - Fix build errors when CONFIG_MTD isn't enabled. - Use auto blk device devnum generation when call blk_create_devicef (pass -1 parameter instead of dev_seq(dev)).
Changes V6 -> V7 [7]:
- Rebased over u-boot/master. - Introduce CONFIG_MTD_BLOCK which is disabled by default.
Links:
- [1] https://lore.kernel.org/all/20240227100441.1811047-1-avromanov@salutedevices... - [2] https://lore.kernel.org/all/20240227100441.1811047-5-avromanov@salutedevices... - [3] https://lore.kernel.org/u-boot/20240403114047.84030-1-heinrich.schuchardt@ca... - [4] https://lore.kernel.org/all/20240404105813.1520732-1-avromanov@salutedevices... - [5] https://lore.kernel.org/all/20240524102920.2631731-1-avromanov@salutedevices... - [6] https://lore.kernel.org/all/20240603155702.1840464-1-avromanov@salutedevices... - [7] https://lore.kernel.org/all/20240626104440.2811686-1-avromanov@salutedevices...
Alexey Romanov (3): disk: support MTD partitions drivers: introduce mtdblock abstraction spinand: bind mtdblock
disk/part.c | 3 +- drivers/block/blk-uclass.c | 1 + drivers/mtd/Kconfig | 9 ++ drivers/mtd/Makefile | 1 + drivers/mtd/mtdblock.c | 227 ++++++++++++++++++++++++++++++++++++ drivers/mtd/mtdpart.c | 76 ++++++++++++ drivers/mtd/nand/spi/core.c | 21 ++++ include/linux/mtd/mtd.h | 25 ++++ include/part.h | 3 + 9 files changed, 365 insertions(+), 1 deletion(-) create mode 100644 drivers/mtd/mtdblock.c
Add new MTD partition driver, which can be useful with mtdblock driver combination.
Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- disk/part.c | 3 +- drivers/mtd/Kconfig | 1 + drivers/mtd/mtdpart.c | 76 +++++++++++++++++++++++++++++++++++++++++++ include/part.h | 3 ++ 4 files changed, 82 insertions(+), 1 deletion(-)
diff --git a/disk/part.c b/disk/part.c index bc932526f9..86f669926e 100644 --- a/disk/part.c +++ b/disk/part.c @@ -304,7 +304,8 @@ static void print_part_header(const char *type, struct blk_desc *desc) CONFIG_IS_ENABLED(DOS_PARTITION) || \ CONFIG_IS_ENABLED(ISO_PARTITION) || \ CONFIG_IS_ENABLED(AMIGA_PARTITION) || \ - CONFIG_IS_ENABLED(EFI_PARTITION) + CONFIG_IS_ENABLED(EFI_PARTITION) || \ + CONFIG_IS_ENABLED(MTD_PARTITIONS) printf("\nPartition Map for %s device %d -- Partition Type: %s\n\n", uclass_get_name(desc->uclass_id), desc->devnum, type); #endif /* any CONFIG_..._PARTITION */ diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 4fdc9645d0..e4e29e0a3c 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -2,6 +2,7 @@ menu "MTD Support"
config MTD_PARTITIONS bool + select PARTITIONS
config MTD bool "Enable MTD layer" diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index be1d19b4ff..88094b81e7 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -20,6 +20,8 @@ #endif
#include <malloc.h> +#include <memalign.h> +#include <part.h> #include <linux/bug.h> #include <linux/errno.h> #include <linux/compat.h> @@ -1054,3 +1056,77 @@ uint64_t mtd_get_device_size(const struct mtd_info *mtd) return mtd->size; } EXPORT_SYMBOL_GPL(mtd_get_device_size); + +static struct mtd_info *mtd_get_partition_by_index(struct mtd_info *mtd, int index) +{ + struct mtd_info *part; + int i = 0; + + list_for_each_entry(part, &mtd->partitions, node) + if (i++ == index) + return part; + + debug("Partition with idx=%d not found on MTD device %s\n", index, mtd->name); + return NULL; +} + +static int __maybe_unused part_get_info_mtd(struct blk_desc *dev_desc, int part_idx, + struct disk_partition *info) +{ + struct mtd_info *master = blk_desc_to_mtd(dev_desc); + struct mtd_info *part; + + if (!master) { + debug("MTD device is NULL\n"); + return -EINVAL; + } + + part = mtd_get_partition_by_index(master, part_idx); + if (!part) { + debug("Failed to find partition with idx=%d\n", part_idx); + return -EINVAL; + } + + snprintf(info->name, PART_NAME_LEN, part->name); + info->start = part->offset / dev_desc->blksz; + info->size = part->size / dev_desc->blksz; + info->blksz = dev_desc->blksz; + + return 0; +} + +static void __maybe_unused part_print_mtd(struct blk_desc *dev_desc) +{ + struct mtd_info *master = blk_desc_to_mtd(dev_desc); + struct mtd_info *part; + + if (!master) + return; + + list_for_each_entry(part, &master->partitions, node) + printf("- 0x%012llx-0x%012llx : "%s"\n", + part->offset, part->offset + part->size, part->name); +} + +static int part_test_mtd(struct blk_desc *dev_desc) +{ + struct mtd_info *master = blk_desc_to_mtd(dev_desc); + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz); + + if (!master) + return -1; + + if (blk_dread(dev_desc, 0, 1, (ulong *)buffer) != 1) + return -1; + + return 0; +} + +U_BOOT_PART_TYPE(mtd) = { + .name = "MTD", + .part_type = PART_TYPE_MTD, + .max_entries = MTD_ENTRY_NUMBERS, + .get_info = part_get_info_ptr(part_get_info_mtd), + .print = part_print_ptr(part_print_mtd), + .test = part_test_mtd, +}; diff --git a/include/part.h b/include/part.h index 32ee404885..40419fdf2f 100644 --- a/include/part.h +++ b/include/part.h @@ -30,12 +30,15 @@ struct block_drvr { #define PART_TYPE_ISO 0x03 #define PART_TYPE_AMIGA 0x04 #define PART_TYPE_EFI 0x05 +#define PART_TYPE_MTD 0x06
/* maximum number of partition entries supported by search */ #define DOS_ENTRY_NUMBERS 8 #define ISO_ENTRY_NUMBERS 64 #define MAC_ENTRY_NUMBERS 64 #define AMIGA_ENTRY_NUMBERS 8 +#define MTD_ENTRY_NUMBERS 64 + /* * Type string for U-Boot bootable partitions */
MTD block - abstraction over MTD subsystem, allowing to read and write in blocks using BLK UCLASS.
Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- drivers/block/blk-uclass.c | 1 + drivers/mtd/Kconfig | 8 ++ drivers/mtd/Makefile | 1 + drivers/mtd/mtdblock.c | 227 +++++++++++++++++++++++++++++++++++++ include/linux/mtd/mtd.h | 25 ++++ 5 files changed, 262 insertions(+) create mode 100644 drivers/mtd/mtdblock.c
diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 512c952f4d..9b8aa45667 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -36,6 +36,7 @@ static struct { { UCLASS_PVBLOCK, "pvblock" }, { UCLASS_BLKMAP, "blkmap" }, { UCLASS_RKMTD, "rkmtd" }, + { UCLASS_MTD, "mtd" }, };
static enum uclass_id uclass_name_to_iftype(const char *uclass_idname) diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index e4e29e0a3c..ce74ef31d7 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -32,6 +32,14 @@ config MTD_CONCAT into a single logical device. The larger logical device can then be partitioned.
+config MTD_BLOCK + bool "Enable block device access to MTD devices" + depends on BLK + default n + help + Enable support for block device access to MTD devices + using blk_ops abstraction. + config SYS_MTDPARTS_RUNTIME bool "Allow MTDPARTS to be configured at runtime" help diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index c2fc80b10f..10d575e9f9 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -26,6 +26,7 @@ obj-y += onenand/ obj-y += spi/ obj-$(CONFIG_MTD_UBI) += ubi/ obj-$(CONFIG_NVMXIP) += nvmxip/ +obj-$(CONFIG_MTD_BLOCK) += mtdblock.o
#SPL/TPL build else diff --git a/drivers/mtd/mtdblock.c b/drivers/mtd/mtdblock.c new file mode 100644 index 0000000000..66a79b8c56 --- /dev/null +++ b/drivers/mtd/mtdblock.c @@ -0,0 +1,227 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * MTD block - abstraction over MTD subsystem, allowing + * to read and write in blocks using BLK UCLASS. + * + * - Read algorithm: + * + * 1. Convert start block number to start address. + * 2. Read block_dev->blksz bytes using mtd_read() and + * add to start address pointer block_dev->blksz bytes, + * until the requested number of blocks have been read. + * + * - Write algorithm: + * + * 1. Convert start block number to start address. + * 2. Round this address down by mtd->erasesize. + * + * Erase addr Start addr + * | | + * v v + * +----------------+----------------+----------------+ + * | blksz | blksz | blksz | + * +----------------+----------------+----------------+ + * + * 3. Calculate offset between this two addresses. + * 4. Read mtd->erasesize bytes using mtd_read() into + * temporary buffer from erase address. + * + * Erase addr Start addr + * | | + * v v + * +----------------+----------------+----------------+ + * | blksz | blksz | blksz | + * +----------------+----------------+----------------+ + * ^ + * | + * | + * mtd_read() + * from here + * + * 5. Copy data from user buffer to temporary buffer with offset, + * calculated at step 3. + * 6. Erase and write mtd->erasesize bytes at erase address + * pointer using mtd_erase/mtd_write(). + * 7. Add to erase address pointer mtd->erasesize bytes. + * 8. goto 1 until the requested number of blocks have + * been written. + * + * (C) Copyright 2024 SaluteDevices, Inc. + * + * Author: Alexey Romanov avromanov@salutedevices.com + */ + +#include <blk.h> +#include <part.h> +#include <dm/device.h> +#include <dm/device-internal.h> +#include <linux/mtd/mtd.h> + +int mtd_bind(struct udevice *dev, struct mtd_info **mtd) +{ + struct blk_desc *bdesc; + struct udevice *bdev; + int ret; + + ret = blk_create_devicef(dev, "mtd_blk", "blk", UCLASS_MTD, + -1, 512, 0, &bdev); + if (ret) { + pr_err("Cannot create block device\n"); + return ret; + } + + bdesc = dev_get_uclass_plat(bdev); + dev_set_priv(bdev, mtd); + bdesc->bdev = bdev; + bdesc->part_type = PART_TYPE_MTD; + + return 0; +} + +static ulong mtd_blk_read(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, + void *dst) +{ + struct blk_desc *block_dev = dev_get_uclass_plat(dev); + struct mtd_info *mtd = blk_desc_to_mtd(block_dev); + unsigned int sect_size = block_dev->blksz; + lbaint_t cur = start; + ulong read_cnt = 0; + + while (read_cnt < blkcnt) { + int ret; + loff_t sect_start = cur * sect_size; + size_t retlen; + + ret = mtd_read(mtd, sect_start, sect_size, &retlen, dst); + if (ret) + return ret; + + if (retlen != sect_size) { + pr_err("mtdblock: failed to read block 0x" LBAF "\n", cur); + return -EIO; + } + + cur++; + dst += sect_size; + read_cnt++; + } + + return read_cnt; +} + +static int mtd_erase_write(struct mtd_info *mtd, uint64_t start, const void *src) +{ + int ret; + size_t retlen; + struct erase_info erase = { 0 }; + + erase.mtd = mtd; + erase.addr = start; + erase.len = mtd->erasesize; + + ret = mtd_erase(mtd, &erase); + if (ret) + return ret; + + ret = mtd_write(mtd, start, mtd->erasesize, &retlen, src); + if (ret) + return ret; + + if (retlen != mtd->erasesize) { + pr_err("mtdblock: failed to read block at 0x%llx\n", start); + return -EIO; + } + + return 0; +} + +static ulong mtd_blk_write(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, + const void *src) +{ + struct blk_desc *block_dev = dev_get_uclass_plat(dev); + struct mtd_info *mtd = blk_desc_to_mtd(block_dev); + unsigned int sect_size = block_dev->blksz; + lbaint_t cur = start, blocks_todo = blkcnt; + ulong write_cnt = 0; + u8 *buf; + int ret = 0; + + buf = malloc(mtd->erasesize); + if (!buf) + return -ENOMEM; + + while (blocks_todo > 0) { + loff_t sect_start = cur * sect_size; + loff_t erase_start = ALIGN_DOWN(sect_start, mtd->erasesize); + u32 offset = sect_start - erase_start; + size_t cur_size = min_t(size_t, mtd->erasesize - offset, + blocks_todo * sect_size); + size_t retlen; + lbaint_t written; + + ret = mtd_read(mtd, erase_start, mtd->erasesize, &retlen, buf); + if (ret) + goto out; + + if (retlen != mtd->erasesize) { + pr_err("mtdblock: failed to read block 0x" LBAF "\n", cur); + ret = -EIO; + goto out; + } + + memcpy(buf + offset, src, cur_size); + + ret = mtd_erase_write(mtd, erase_start, buf); + if (ret) + goto out; + + written = cur_size / sect_size; + + blocks_todo -= written; + cur += written; + src += cur_size; + write_cnt += written; + } + +out: + free(buf); + + if (ret) + return ret; + + return write_cnt; +} + +static int mtd_blk_probe(struct udevice *dev) +{ + struct blk_desc *bdesc; + struct mtd_info *mtd; + int ret; + + ret = device_probe(dev); + if (ret) { + pr_err("Probing %s failed (err=%d)\n", dev->name, ret); + return ret; + } + + bdesc = dev_get_uclass_plat(dev); + mtd = blk_desc_to_mtd(bdesc); + + if (mtd_type_is_nand(mtd)) + pr_warn("MTD device '%s' is NAND, please use UBI devices instead\n", + mtd->name); + + return 0; +} + +static const struct blk_ops mtd_blk_ops = { + .read = mtd_blk_read, + .write = mtd_blk_write, +}; + +U_BOOT_DRIVER(mtd_blk) = { + .name = "mtd_blk", + .id = UCLASS_BLK, + .ops = &mtd_blk_ops, + .probe = mtd_blk_probe, +}; diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index ee18a63e46..3f66ea17c1 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -26,6 +26,7 @@ #include <dm/device.h> #endif #include <dm/ofnode.h> +#include <blk.h>
#define MAX_MTD_DEVICES 32 #endif @@ -412,6 +413,30 @@ int mtd_write(struct mtd_info *mtd, loff_t to, size_t len, size_t *retlen, int mtd_panic_write(struct mtd_info *mtd, loff_t to, size_t len, size_t *retlen, const u_char *buf);
+#if CONFIG_IS_ENABLED(MTD_BLOCK) +static inline struct mtd_info *blk_desc_to_mtd(struct blk_desc *bdesc) +{ + void *priv = dev_get_priv(bdesc->bdev); + + if (!priv) + return NULL; + + return *((struct mtd_info **)priv); +} + +int mtd_bind(struct udevice *dev, struct mtd_info **mtd); +#else +static inline struct mtd_info *blk_desc_to_mtd(struct blk_desc *bdesc) +{ + return NULL; +} + +static inline int mtd_bind(struct udevice *dev, struct mtd_info **mtd) +{ + return -EOPNOTSUPP; +} +#endif + int mtd_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops); int mtd_write_oob(struct mtd_info *mtd, loff_t to, struct mtd_oob_ops *ops);
Bind SPI-NAND driver to MTD block driver.
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- drivers/mtd/nand/spi/core.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index ef50237f10..54a90ff295 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -33,6 +33,10 @@ #include <linux/printk.h> #endif
+struct spinand_plat { + struct mtd_info *mtd; +}; + /* SPI NAND index visible in MTD names */ static int spi_nand_idx;
@@ -1172,12 +1176,25 @@ static void spinand_cleanup(struct spinand_device *spinand) kfree(spinand->scratchbuf); }
+static int spinand_bind(struct udevice *dev) +{ + if (blk_enabled()) { + struct spinand_plat *plat = dev_get_plat(dev); + + if (CONFIG_IS_ENABLED(MTD_BLOCK)) + return mtd_bind(dev, &plat->mtd); + } + + return 0; +} + static int spinand_probe(struct udevice *dev) { struct spinand_device *spinand = dev_get_priv(dev); struct spi_slave *slave = dev_get_parent_priv(dev); struct mtd_info *mtd = dev_get_uclass_priv(dev); struct nand_device *nand = spinand_to_nand(spinand); + struct spinand_plat *plat = dev_get_plat(dev); int ret;
#ifndef __UBOOT__ @@ -1217,6 +1234,8 @@ static int spinand_probe(struct udevice *dev) if (ret) goto err_spinand_cleanup;
+ plat->mtd = mtd; + return 0;
err_spinand_cleanup: @@ -1286,4 +1305,6 @@ U_BOOT_DRIVER(spinand) = { .of_match = spinand_ids, .priv_auto = sizeof(struct spinand_device), .probe = spinand_probe, + .bind = spinand_bind, + .plat_auto = sizeof(struct spinand_plat), };
If tried to test this with the SPI NOR framework but I couldn't get it to work. The SPI NOR flash didn't register with/was found by the mtdblock subsystem. I guess that is probably because the SPI NOR flash has it's own UCLASS_SPI_FLASH. There is some kind of compatibility layer (drivers/mtd/spi/sf_mtd.c) but it doesn't register a UCLASS_MTD.
Do you have any idea how to get this to work?
-michael
Hi Michael,
Sorry for the late reply.
I think you have to try bind driver via mtd_bind(), just like I do for SPI-NAND in patch "spinand: bind mtdblock".
I see what in file drivers/mtd/spi/sf_probe.c there is struct mtd_info and also you have U_BOOT_DRIVER. Maybe try to bind there?
-michael
Alexey Romanov
Michael Walle
