[U-Boot] [PATCH v3 0/2] efi_loader: provide new doc/README.efi
Provides information about
- usage of the bootefi command - overview of UEFI - interaction between U-Boot and EFI drivers
--- v3 rename README.efi to README.uefi use UEFI instead of EFI where applicable v2 split the patch in two: one deleteing all old lines, the other adding the new ones update README contents ---
Heinrich Schuchardt (2): efi_loader: delete doc/README.efi efi_loader: provide new doc/README.uefi
doc/README.efi | 86 --------------- doc/README.uefi | 332 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 332 insertions(+), 86 deletions(-) delete mode 100644 doc/README.efi create mode 100644 doc/README.uefi
Delete README.efi. It is replaced by a further patch.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 no change v2 delete all lines instead of complete file --- doc/README.efi | 86 ---------------------------------------------------------- 1 file changed, 86 deletions(-)
diff --git a/doc/README.efi b/doc/README.efi index 956f5bfa0c6..e69de29bb2d 100644 --- a/doc/README.efi +++ b/doc/README.efi @@ -1,86 +0,0 @@ -# -# Copyright (C) 2015 Google, Inc -# -# SPDX-License-Identifier: GPL-2.0+ -# - -EFI on U-Boot -============= -This document provides information about the implementation of the UEFI API [1] -in U-Boot. - - -=========== Table of Contents =========== - -Motivation -How do I get it? -Status -Future work - - -Motivation ----------- - -With this API support in place, you can run any UEFI payload (such as the Linux -kernel, grub2 or gummiboot) on U-Boot. This dramatically simplifies boot loader -configuration, as U-Boot based systems now look and feel (almost) the same way -as TianoCore based systems. - -How do I get it? ----------------- - -EFI support for 32bit ARM and AArch64 is already included in U-Boot. All you -need to do is enable - - CONFIG_CMD_BOOTEFI=y - CONFIG_EFI_LOADER=y - -in your .config file and you will automatically get a bootefi command to run -an efi application as well as snippet in the default distro boot script that -scans for removable media efi binaries as fallback. - -Status ------- - -I am successfully able to run grub2 and Linux EFI binaries with this code on -ARMv7 as well as AArch64 systems. - -When enabled, the resulting U-Boot binary only grows by ~10KB, so it's very -light weight. - -All storage devices are directly accessible from the uEFI payload - -Removable media booting (search for /efi/boot/boota{a64,arm}.efi) is supported. - -Simple use cases like "Plug this SD card into my ARM device and it just -boots into grub which boots into Linux", work very well. - - -Running HelloWord.efi ---------------------- - -You can run a simple 'hello world' EFI program in U-Boot. -Enable the option CONFIG_CMD_BOOTEFI_HELLO. - -Then you can boot into U-Boot and type: - - > bootefi hello - -The 'hello world EFI' program will then run, print a message and exit. - - -Future work ------------ - -Of course, there are still a few things one could do on top: - - - Improve disk media detection (don't scan, use what information we -have) - - Add EFI variable support using NVRAM - - Add GFX support - - Make EFI Shell work - - Network device support - - Support for payload exit - - Payload Watchdog support - -[1] http://uefi.org/
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 rename README.efi to README.uefi use UEFI instead of EFI where applicable v2 split the patch in two: one deleteing all old lines, the other adding the new ones update README contents --- MAINTAINERS | 2 +- doc/README.efi | 0 doc/README.uefi | 332 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 333 insertions(+), 1 deletion(-) delete mode 100644 doc/README.efi create mode 100644 doc/README.uefi
diff --git a/MAINTAINERS b/MAINTAINERS index 077828cf1d4..da799b551d9 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -290,7 +290,7 @@ EFI PAYLOAD M: Alexander Graf agraf@suse.de S: Maintained T: git git://github.com/agraf/u-boot.git -F: doc/README.efi +F: doc/README.uefi F: doc/README.iscsi F: include/efi* F: include/pe.h diff --git a/doc/README.efi b/doc/README.efi deleted file mode 100644 index e69de29bb2d..00000000000 diff --git a/doc/README.uefi b/doc/README.uefi new file mode 100644 index 00000000000..7403be36146 --- /dev/null +++ b/doc/README.uefi @@ -0,0 +1,332 @@ +<!-- + Copyright (c) 2018 Heinrich Schuchardt + + SPDX-License-Identifier: GPL-2.0+ +--> + +# UEFI on U-Boot + +The Unified Extensible Firmware Interface Specification (UEFI) [1] has become +the default for booting on AArch64 and x86 systems. It provides a stable API for +the interaction of drivers and applications with the firmware. The API comprises +access to block storage, network, and console to name a few. The Linux kernel +and boot loaders like GRUB or the FreeBSD loader can be executed. + +## Building for UEFI + +The UEFI standard supports only little endian systems. The UEFI support can be +activated for ARM and x86 by specifying + + CONFIG_CMD_BOOTEFI=y + CONFIG_EFI_LOADER=y + +in the .config file. + +Support for attaching virtual block devices, e.g. iSCSI drives connected by the +loaded UEFI application [3], requires + + CONFIG_BLK=y + CONFIG_PARTITIONS=y + +### Executing a UEFI binary + +The bootefi command is used to start UEFI applications or to install UEFI +drivers. It takes two parameters + + bootefi <image address> [fdt address] + +* image address - the memory address of the UEFI binary +* fdt address - the memory address of the flattened device tree + +Below you find the output of an example session starting GRUB. + + => load mmc 0:2 ${fdt_addr_r} boot/dtb + 29830 bytes read in 14 ms (2 MiB/s) + => load mmc 0:1 ${kernel_addr_r} efi/debian/grubaa64.efi + reading efi/debian/grubaa64.efi + 120832 bytes read in 7 ms (16.5 MiB/s) + => bootefi ${kernel_addr_r} ${fdt_addr_r} + +The environment variable 'bootargs' is passed as load options in the UEFI system +table. The Linux kernel EFI stub uses the load options as command line +arguments. + +### Executing the boot manager + +The UEFI specfication foresees to define boot entries and boot sequence via UEFI +variables. Booting according to these variables is possible via + + bootefi bootmgr [fdt address] + +As of U-Boot v2018.03 UEFI variables are not persisted and cannot be set at +runtime. + +### Executing the built in hello world application + +A hello world UEFI application can be built with + + CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y + +It can be embedded into the U-Boot binary with + + CONFIG_CMD_BOOTEFI_HELLO=y + +The bootefi command is used to start the embedded hello world application. + + bootefi hello [fdt address] + +Below you find the output of an example session. + + => bootefi hello ${fdtcontroladdr} + ## Starting EFI application at 01000000 ... + WARNING: using memory device/image path, this may confuse some payloads! + Hello, world! + Running on UEFI 2.7 + Have SMBIOS table + Have device tree + Load options: root=/dev/sdb3 init=/sbin/init rootwait ro + ## Application terminated, r = 0 + +The environment variable fdtcontroladdr points to U-Boot's internal device tree +(if available). + +### Executing the built-in selftest + +An UEFI selftest suite can be embedded in U-Boot by building with + + CONFIG_CMD_BOOTEFI_SELFTEST=y + +For testing the UEFI implementation the bootefi command can be used to start the +selftest. + + bootefi selftest [fdt address] + +The environment variable 'efi_selftest' can be used to select a single test. If +it is not provided all tests are executed except those marked as 'on request'. +If the environment variable is set to 'list' a list of all tests is shown. + +Below you can find the output of an example session. + + => setenv efi_selftest simple network protocol + => bootefi selftest + Testing EFI API implementation + Selected test: 'simple network protocol' + Setting up 'simple network protocol' + Setting up 'simple network protocol' succeeded + Executing 'simple network protocol' + DHCP Discover + DHCP reply received from 192.168.76.2 (52:55:c0:a8:4c:02) + as broadcast message. + Executing 'simple network protocol' succeeded + Tearing down 'simple network protocol' + Tearing down 'simple network protocol' succeeded + Boot services terminated + Summary: 0 failures + Preparing for reset. Press any key. + +## The UEFI life cycle + +After the U-Boot platform has been initialized the UEFI API provides two kinds +of services + +* boot services and +* runtime services. + +The API can be extended by loading UEFI drivers which come in two variants + +* boot drivers and +* runtime drivers. + +UEFI drivers are installed with U-Boot's bootefi command. With the same command +UEFI applications can be executed. + +Loaded images of UEFI drivers stay in memory after returning to U-Boot while +loaded images of applications are removed from memory. + +An UEFI application (e.g. an operating system) that wants to take full control +of the system calls ExitBootServices. After a UEFI application calls +ExitBootServices + +* boot services are not available anymore +* timer events are stopped +* the memory used by U-Boot except for runtime services is released +* the memory used by boot time drivers is released + +So this is a point of no return. Afterwards the UEFI application can only return +to U-Boot by rebooting. + +## The UEFI object model + +UEFI offers a flexible and expandable object model. The objects in the UEFI API +are devices, drivers, and loaded images. These objects are referenced by +handles. + +The interfaces implemented by the objects are referred to as protocols. These +are identified by GUIDs. They can be installed and uninstalled by calling the +appropriate boot services. + +Handles are created by the InstallProtocolInterface or the +InstallMultipleProtocolinterfaces service if NULL is passed as handle. + +Handles are deleted when the last protocol has been removed with the +UninstallProtocolInterface or the UninstallMultipleProtocolInterfaces service. + +Devices offer the EFI_DEVICE_PATH_PROTOCOL. A device path is the concatenation +of device nodes. By their device paths all devices of a system are arranged in a +tree. + +Drivers offer the EFI_DRIVER_BINDING_PROTOCOL. This protocol is used to connect +a driver to devices (which are referenced as controllers in this context). + +Loaded images offer the EFI_LOADED_IMAGE_PROTOCOL. This protocol provides meta +information about the image and a pointer to the unload callback function. + +## The UEFI events + +In the UEFI terminology an event is a data object referencing a notification +function which is queued for calling when the event is signaled. The following +types of events exist: + +* periodic and single shot timer events +* exit boot services events, triggered by calling the ExitBootServices() service +* virtual address change events +* memory map change events +* read to boot events +* reset system events +* system table events +* events that are only triggered programmatically + +Events can be created with the CreateEvent service and deleted with CloseEvent +service. + +Events can be assigned to an event group. If any of the events in a group is +signaled, all other events in the group are also set to the signaled state. + +## The UEFI driver model + +A driver is specific for a single protocol installed on a device. To install a +driver on a device the ConnectController service is called. In this context +controller refers to the device for which the driver is installed. + +The relevant drivers are identified using the EFI_DRIVER_BINDING_PROTOCOL. This +protocol has has three functions: + +* supported - determines if the driver is compatible with the device +* start - installs the driver by opening the relevant protocol with + attribute EFI_OPEN_PROTOCOL_BY_DRIVER +* stop - uninstalls the driver + +The driver may create child controllers (child devices). E.g. a driver for block +IO devices will create the device handles for the partitions. The child +controllers will open the supported protocol with the attribute +EFI_OPEN_PROTOCOL_BY_CHILD_CONTROLLER. + +A driver can be detached from a device using the DisconnectController service. + +## U-Boot devices mapped as UEFI devices + +Some of the U-Boot devices are mapped as UEFI devices + +* block IO devices +* console +* graphical output +* network adapter + +As of U-Boot 2018.03 the logic for doing this is hard coded. + +The development target is to integrate the setup of these UEFI devices with the +U-Boot driver model. So when a U-Boot device is discovered a handle should be +created and the device path protocol and the relevant IO protocol should be +installed. The UEFI driver then would be attached by calling ConnectController. +When a U-Boot device is removed DisconnectController should be called. + +## UEFI devices mapped as U-Boot devices + +UEFI drivers binaries and applications may create new (virtual) devices, install +a protocol and call the ConnectController service. Now the matching UEFI driver +is determined by iterating over the implementations of the +EFI_DRIVER_BINDING_PROTOCOL. + +It is the task of the UEFI driver to create a corresponding U-Boot device and to +proxy calls for this U-Boot device to the controller. + +In U-Boot 2018.03 this has only been implemented for block IO devices. + +### UEFI uclass + +An UEFI uclass driver (lib/efi_driver/efi_uclass.c) has been created that +takes care of initializing the UEFI drivers and providing the +EFI_DRIVER_BINDING_PROTOCOL implementation for the UEFI drivers. + +A linker created list is used to keep track of the UEFI drivers. To create an +entry in the list the UEFI driver uses the U_BOOT_DRIVER macro specifying +UCLASS_EFI as the ID of its uclass, e.g. + + /* Identify as UEFI driver */ + U_BOOT_DRIVER(efi_block) = { + .name = "EFI block driver", + .id = UCLASS_EFI, + .ops = &driver_ops, + }; + +The available operations are defined via the structure struct efi_driver_ops. + + struct efi_driver_ops { + const efi_guid_t *protocol; + const efi_guid_t *child_protocol; + int (*bind)(efi_handle_t handle, void *interface); + }; + +When the supported() function of the EFI_DRIVER_BINDING_PROTOCOL is called the +uclass checks if the protocol GUID matches the protocol GUID of the UEFI driver. +In the start() function the bind() function of the UEFI driver is called after +checking the GUID. +The stop() function of the EFI_DRIVER_BINDING_PROTOCOL disconnects the child +controllers created by the UEFI driver and the UEFI driver. (In U-Boot v2013.03 +this is not yet completely implemented.) + +### UEFI block IO driver + +The UEFI block IO driver supports devices exposing the EFI_BLOCK_IO_PROTOCOL. + +When connected it creates a new U-Boot block IO device with interface type +IF_TYPE_EFI, adds child controllers mapping the partitions, and installs the +EFI_SIMPLE_FILE_SYSTEM_PROTOCOL on these. This can be used together with the +software iPXE to boot from iSCSI network drives [3]. + +This driver is only available if U-Boot is configured with + + CONFIG_BLK=y + CONFIG_PARTITIONS=y + +## TODOs as of U-Boot 2018.03 + +* unimplemented or incompletely implemented boot services + * Exit - call unload function, unload applications only + * ReinstallProtocolInterface + * UnloadImage + +* unimplemented events + * EVT_RUNTIME + * EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE + * event groups + +* data model + * manage events in a linked list + * manage configuration tables in a linked list + +* UEFI drivers + * support DisconnectController for UEFI block devices. + +* support for CONFIG_EFI_LOADER in the sandbox (CONFIG_SANDBOX=y) + +* UEFI variables + * persistence + * runtime support + +## Links + +* [1](http://uefi.org/specifications) + http://uefi.org/specifications - UEFI specifications +* [2](./driver-model/README.txt) doc/driver-model/README.txt - Driver model +* [3](./README.iscsi) doc/README.iscsi - iSCSI booting with U-Boot and iPXE
- overview of UEFI
Well, from my point of view: Reviewed-by: Leif Lindholm leif.lindholm@linaro.org or Acked-by: Leif Lindholm leif.lindholm@linaro.org (whichever makes more sense).
Many thanks!
/ Leif
- Copyright (c) 2018 Heinrich Schuchardt
+# UEFI on U-Boot
- CONFIG_BLK=y
- CONFIG_PARTITIONS=y
- bootefi <image address> [fdt address]
- => load mmc 0:2 ${fdt_addr_r} boot/dtb
- 29830 bytes read in 14 ms (2 MiB/s)
- => load mmc 0:1 ${kernel_addr_r} efi/debian/grubaa64.efi
- reading efi/debian/grubaa64.efi
- 120832 bytes read in 7 ms (16.5 MiB/s)
- => bootefi ${kernel_addr_r} ${fdt_addr_r}
- bootefi bootmgr [fdt address]
- CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
- CONFIG_CMD_BOOTEFI_HELLO=y
- bootefi hello [fdt address]
- => bootefi hello ${fdtcontroladdr}
- ## Starting EFI application at 01000000 ...
- WARNING: using memory device/image path, this may confuse some payloads!
- Hello, world!
- Running on UEFI 2.7
- Have SMBIOS table
- Have device tree
- Load options: root=/dev/sdb3 init=/sbin/init rootwait ro
- ## Application terminated, r = 0
- CONFIG_CMD_BOOTEFI_SELFTEST=y
- bootefi selftest [fdt address]
- => setenv efi_selftest simple network protocol
- => bootefi selftest
- Testing EFI API implementation
- Selected test: 'simple network protocol'
- Setting up 'simple network protocol'
- Setting up 'simple network protocol' succeeded
- Executing 'simple network protocol'
- DHCP Discover
- DHCP reply received from 192.168.76.2 (52:55:c0:a8:4c:02)
- Executing 'simple network protocol' succeeded
- Tearing down 'simple network protocol'
- Tearing down 'simple network protocol' succeeded
- Boot services terminated
- Summary: 0 failures
- Preparing for reset. Press any key.
+## The UEFI events
- attribute EFI_OPEN_PROTOCOL_BY_DRIVER
+### UEFI uclass
- /* Identify as UEFI driver */
- U_BOOT_DRIVER(efi_block) = {
.id = UCLASS_EFI,
.ops = &driver_ops,
- struct efi_driver_ops {
- CONFIG_BLK=y
- Exit - call unload function, unload applications only
- ReinstallProtocolInterface
- UnloadImage
- EVT_RUNTIME
- EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE
- event groups
+* data model
- manage events in a linked list
- manage configuration tables in a linked list
+* UEFI drivers
- support DisconnectController for UEFI block devices.
+* UEFI variables
- persistence
- runtime support
+## Links
- http://uefi.org/specifications - UEFI specifications
2.16.1
Leif Lindholm
