Back to the discussion from August I have refactored the LL TEMAC driver. Just in version V4 it is ready to next review.
Note: To use the driver on Microblaze, you will need additional platform patches by Michal Simek: - http://patchwork.ozlabs.org/patch/112535/ - http://patchwork.ozlabs.org/patch/112534/ - http://patchwork.ozlabs.org/patch/112532/
I will collect all related patches on a public bundle: - http://patchwork.ozlabs.org/user/bundle/2339/
br, Stephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used.
The driver uses and requires MII and PHYLIB.
Signed-off-by: Stephan Linz linz@li-pro.net --- v4: Separate fifo and sdma code from driver core Split sdma code into separate DCR and XPS bus access code Add extensive register struct definitions and enumerations Add new callbacks into fifo an sdma code Prepare CDMAC buffer handling to be unique for every instance Separate Xilinx specific indirect DCR access, so we can move to arch Remove useless 'emac' parameter from indirect access helper functions Correct MDIO clock setup. Remove endless loops Common code beautifying
v3: Use helper functions for fifo mode Use helper functions for indirect accesses Code cleanup Add comments for MAGIC values Simplify code in fifo mode
v2: Remove helper function for access to temac Remove SDMA/FIFO/DCR macros and configure it in board Setup mac by write_hwaddr --- drivers/net/Makefile | 2 + drivers/net/xilinx_ll_temac.c | 399 ++++++++++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac.h | 305 ++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac_fifo.c | 93 ++++++++ drivers/net/xilinx_ll_temac_fifo.h | 112 ++++++++++ drivers/net/xilinx_ll_temac_sdma.c | 413 ++++++++++++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac_sdma.h | 280 ++++++++++++++++++++++++ include/netdev.h | 2 + 8 files changed, 1606 insertions(+), 0 deletions(-) create mode 100644 drivers/net/xilinx_ll_temac.c create mode 100644 drivers/net/xilinx_ll_temac.h create mode 100644 drivers/net/xilinx_ll_temac_fifo.c create mode 100644 drivers/net/xilinx_ll_temac_fifo.h create mode 100644 drivers/net/xilinx_ll_temac_sdma.c create mode 100644 drivers/net/xilinx_ll_temac_sdma.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d3df82e..14d71a7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -76,6 +76,8 @@ COBJS-$(CONFIG_ULI526X) += uli526x.o COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o COBJS-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +COBJS-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o \ + xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c new file mode 100644 index 0000000..39f3a8b --- /dev/null +++ b/drivers/net/xilinx_ll_temac.c @@ -0,0 +1,399 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * supports SDMA or FIFO access + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ + +#include <config.h> +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <asm/io.h> +#include <phy.h> +#include <miiphy.h> + +#include "xilinx_ll_temac.h" + +#undef ETH_HALTING + +#if !defined(CONFIG_MII) || !defined(CONFIG_CMD_MII) +# error "LL_TEMAC requires MII -- CONFIG_MII has to be defined!" +#endif + +#if !defined(CONFIG_PHYLIB) +# error "LL_TEMAC requires PHYLIB -- CONFIG_PHYLIB has to be defined!" +#endif + +/* + * Prior to PHY access, the MDIO clock must be setup. This driver will set a + * safe default that should work with PLB bus speeds of up to 150 MHz and keep + * the MDIO clock below 2.5 MHz. If the user wishes faster access to the PHY + * then the clock divisor can be set to a different value by setting the + * correct bus speed value with CONFIG_XILINX_LL_TEMAC_CLK. + */ +#if !defined(CONFIG_XILINX_LL_TEMAC_CLK) +#define MDIO_CLOCK_DIV MC_CLKDIV_10(150000000) +#else +#define MDIO_CLOCK_DIV MC_CLKDIV_25(CONFIG_XILINX_LL_TEMAC_CLK) +#endif + + +/* Data buffer for LL TEMAC Rx and Tx direction */ +static unsigned char rx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); +static unsigned char tx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); + + +/* CDMAC buffer descriptor for LL TEMAC Rx and Tx buffer handling */ +static struct cdmac_bd rx_descr __attribute((aligned(DMAALIGN))); +static struct cdmac_bd tx_descr __attribute((aligned(DMAALIGN))); + + +static inline void xps_ll_temac_check_status(struct temac_reg *regs, u32 mask) +{ + unsigned timeout = 2000; + while (timeout && (!(in_be32(®s->rdy) & mask))) + timeout--; + if (!timeout) + printf("%s: Timeout\n", __func__); +} + +/* + * Undirect hostif write to ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 67, Using the MII Management to Access PHY Registers + */ +static void xps_ll_temac_hostif_set(struct eth_device *dev, u8 phy_addr, + u8 reg_addr, u16 phy_data) +{ + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + out_be32(®s->lsw, (phy_data & LSW_REGDAT_MASK)); + out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMWD); + out_be32(®s->lsw, + ((phy_addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | + (reg_addr & LSW_REGAD_MASK)); + out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMAI); + xps_ll_temac_check_status(regs, RSE_MIIM_WR); +} + +/* + * Undirect hostif read to ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 67, Using the MII Management to Access PHY Registers + */ +static u16 xps_ll_temac_hostif_get(struct eth_device *dev, u8 phy_addr, + u8 reg_addr) +{ + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + out_be32(®s->lsw, + ((phy_addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | + (reg_addr & LSW_REGAD_MASK)); + out_be32(®s->ctl, TEMAC_MIIMAI); + xps_ll_temac_check_status(regs, RSE_MIIM_RR); + return in_be32(®s->lsw) & LSW_REGDAT_MASK; +} + +/* + * Undirect write to ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +static void xps_ll_temac_indirect_set(struct eth_device *dev, u16 regn, + u32 reg_data) +{ + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + out_be32(®s->lsw, (reg_data & MLSW_MASK)); + out_be32(®s->ctl, CTL_WEN | (regn & CTL_ADDR_MASK)); + xps_ll_temac_check_status(regs, RSE_CFG_WR); +} + +/* + * Undirect read from ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +static u32 xps_ll_temac_indirect_get(struct eth_device *dev, u16 regn) +{ + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + out_be32(®s->ctl, (regn & CTL_ADDR_MASK)); + xps_ll_temac_check_status(regs, RSE_CFG_RR); + return in_be32(®s->lsw) & MLSW_MASK; +} + +#ifdef DEBUG +static inline void read_phy_reg(struct eth_device *dev, u8 phy_addr) +{ + int j, result; + debug("phy%d ", phy_addr); + for (j = 0; j < 32; j++) { + result = xps_ll_temac_hostif_get(dev, phy_addr, j); + debug("%d: 0x%x ", j, result); + } + debug("\n"); +} +#endif + +/* setting ll_temac and phy to proper setting */ +static int xps_ll_temac_phy_ctrl(struct eth_device *dev) +{ + int i; + unsigned int temp, speed; + struct ll_temac *ll_temac = dev->priv; + struct phy_device *phydev; + + u32 supported = SUPPORTED_10baseT_Half | + SUPPORTED_10baseT_Full | + SUPPORTED_100baseT_Half | + SUPPORTED_100baseT_Full | + SUPPORTED_1000baseT_Half | + SUPPORTED_1000baseT_Full; + + if (ll_temac->phyaddr == -1) { + for (i = 31; i >= 0; i--) { + temp = xps_ll_temac_hostif_get(dev, i, 1); + if ((temp & 0x0ffff) != 0x0ffff) { + debug("phy %x result %x\n", i, temp); + ll_temac->phyaddr = i; + break; + } + } + } + + /* interface - look at tsec */ + phydev = phy_connect(ll_temac->bus, ll_temac->phyaddr, dev, 0); + + phydev->supported &= supported; + phydev->advertising = phydev->supported; + ll_temac->phydev = phydev; + phy_config(phydev); + phy_startup(phydev); + + switch (phydev->speed) { + case 1000: + speed = EMMC_LSPD_1000; + break; + case 100: + speed = EMMC_LSPD_100; + break; + case 10: + speed = EMMC_LSPD_10; + break; + default: + return 0; + } + temp = xps_ll_temac_indirect_get(dev, TEMAC_EMMC); + temp &= ~EMMC_LSPD_MASK; + temp |= speed; + xps_ll_temac_indirect_set(dev, TEMAC_EMMC, temp); + + return 1; +} + +/* setup mac addr */ +static int ll_temac_addr_setup(struct eth_device *dev) +{ + u32 val; + + /* set up unicast MAC address filter */ + val = ((dev->enetaddr[3] << 24) | (dev->enetaddr[2] << 16) | + (dev->enetaddr[1] << 8) | (dev->enetaddr[0])); + val &= UAW0_UADDR_MASK; + xps_ll_temac_indirect_set(dev, TEMAC_UAW0, val); + + val = ((dev->enetaddr[5] << 8) | dev->enetaddr[4]); + val &= UAW1_UADDR_MASK; + xps_ll_temac_indirect_set(dev, TEMAC_UAW1, val); + + return 0; +} + +static int xps_ll_temac_init(struct eth_device *dev, bd_t *bis) +{ + struct ll_temac *ll_temac = dev->priv; + + if (ll_temac->ctrlreset) + if (ll_temac->ctrlreset(dev)) + return -1; + + if (ll_temac->ctrlinit) + ll_temac->ctrlinit(dev); + + xps_ll_temac_indirect_set(dev, TEMAC_MC, + MC_MDIOEN | (MDIO_CLOCK_DIV & MC_CLKDIV_MASK)); + + /* Promiscuous mode disable */ + xps_ll_temac_indirect_set(dev, TEMAC_AFM, 0); + + /* Enable Receiver - RX bit */ + xps_ll_temac_indirect_set(dev, TEMAC_RCW1, RCW1_RX); + + /* Enable Transmitter - TX bit */ + xps_ll_temac_indirect_set(dev, TEMAC_TC, TC_TX); + + return 0; +} + +/* halt device */ +static void ll_temac_halt(struct eth_device *dev) +{ +#ifdef ETH_HALTING + struct ll_temac *ll_temac = dev->priv; + + /* Disable Receiver */ + xps_ll_temac_indirect_set(dev, TEMAC_RCW0, 0); + + /* Disable Transmitter */ + xps_ll_temac_indirect_set(dev, TEMAC_TC, 0); + + if (ll_temac->ctrlhalt) + ll_temac->ctrlhalt(dev); +#endif +} + +static int ll_temac_init(struct eth_device *dev, bd_t *bis) +{ +#if DEBUG + int i; +#endif + xps_ll_temac_init(dev, bis); + + printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\n", + dev->name, 0, dev->iobase); + +#if DEBUG + for (i = 0; i < 32; i++) + read_phy_reg(dev, i); +#endif + + if (!xps_ll_temac_phy_ctrl(dev)) { + ll_temac_halt(dev); + return -1; + } + + return 0; +} + +static int ll_temac_miiphy_read(const char *devname, unsigned char addr, + unsigned char reg, unsigned short *value) +{ + struct eth_device *dev = eth_get_dev(); + + *value = xps_ll_temac_hostif_get(dev, addr, reg); + + debug("%s 0x%x, 0x%x, 0x%x\n", __func__, addr, reg, *value); + return 0; +} + +static int ll_temac_miiphy_write(const char *devname, unsigned char addr, + unsigned char reg, unsigned short value) +{ + struct eth_device *dev = eth_get_dev(); + debug("%s 0x%x, 0x%x, 0x%x\n", __func__, addr, reg, value); + + xps_ll_temac_hostif_set(dev, addr, reg, value); + + return 0; +} + +static int ll_temac_bus_reset(struct mii_dev *bus) +{ + debug("Just bus reset\n"); + return 0; +} + +/* + * bis: board information + * base_addr: LL TEMAC register bank + * ctrl_addr: LL TEMAC sub-controller register bank (FIFO or SDMA) + * mode: driver mode bit flags (see xilinx_ll_temac.h) + */ +int xilinx_ll_temac_initialize(bd_t *bis, unsigned long base_addr, + int mode, unsigned long ctrl_addr) +{ + struct eth_device *dev; + struct ll_temac *ll_temac; + + dev = calloc(1, sizeof(*dev)); + if (dev == NULL) + return -1; + + dev->priv = calloc(1, sizeof(struct ll_temac)); + if (dev->priv == NULL) { + free(dev); + return -1; + } + + ll_temac = dev->priv; + + sprintf(dev->name, "Xlltem.%lx", base_addr); + + dev->iobase = base_addr; + ll_temac->ctrladdr = ctrl_addr; + ll_temac->rx_bp = rx_buffer; + ll_temac->tx_bp = tx_buffer; + ll_temac->rx_dp = &rx_descr; + ll_temac->tx_dp = &tx_descr; + +#ifdef CONFIG_PHY_ADDR + ll_temac->phyaddr = CONFIG_PHY_ADDR; +#else + ll_temac->phyaddr = -1; +#endif + + dev->init = ll_temac_init; + dev->halt = ll_temac_halt; + dev->write_hwaddr = ll_temac_addr_setup; + + if (mode & M_SDMA) { +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + if (mode & M_DCR) { + ll_temac->ctrlinit = ll_temac_init_dmac; + ll_temac->ctrlhalt = ll_temac_halt_dmac; + ll_temac->ctrlreset = ll_temac_reset_dmac; + dev->recv = ll_temac_recv_dmac; + dev->send = ll_temac_send_dmac; + } else +#endif + { + ll_temac->ctrlinit = ll_temac_init_sdma; + ll_temac->ctrlhalt = ll_temac_halt_sdma; + ll_temac->ctrlreset = ll_temac_reset_sdma; + dev->recv = ll_temac_recv_sdma; + dev->send = ll_temac_send_sdma; + } + } else { + ll_temac->ctrlinit = NULL; + ll_temac->ctrlhalt = NULL; + ll_temac->ctrlreset = ll_temac_reset_fifo; + dev->recv = ll_temac_recv_fifo; + dev->send = ll_temac_send_fifo; + } + + eth_register(dev); + + miiphy_register(dev->name, ll_temac_miiphy_read, ll_temac_miiphy_write); + ll_temac->bus = miiphy_get_dev_by_name(dev->name); + ll_temac->bus->reset = ll_temac_bus_reset; + return 1; +} diff --git a/drivers/net/xilinx_ll_temac.h b/drivers/net/xilinx_ll_temac.h new file mode 100644 index 0000000..03dbb29 --- /dev/null +++ b/drivers/net/xilinx_ll_temac.h @@ -0,0 +1,305 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * private interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ +#ifndef _XILINX_LL_TEMAC_ +#define _XILINX_LL_TEMAC_ + +#include <net.h> +#include <phy.h> +#include <miiphy.h> +#include <asm/byteorder.h> + +#include "xilinx_ll_temac_fifo.h" +#include "xilinx_ll_temac_sdma.h" + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +struct ll_temac { + int ctrladdr; + void (*ctrlinit) (struct eth_device*); + int (*ctrlhalt) (struct eth_device*); + int (*ctrlreset) (struct eth_device*); + + unsigned char *rx_bp; + unsigned char *tx_bp; + + struct cdmac_bd *rx_dp; + struct cdmac_bd *tx_dp; + + int phyaddr; + struct phy_device *phydev; + struct mii_dev *bus; +}; + +/* + * Driver mode bit flags + * + * FIXME: this should going up to include -- but where? + */ +#define M_FIFO (0) /* use FIFO Ctrl */ +#define M_SDMA (1 << 0) /* use SDMA Ctrl */ +#define M_DCR (1 << 1) /* use DCR Bus */ + + +/* + * TEMAC Memory and Register Definition + * + * [1]: http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 19, Memory and Register Descriptions + */ +struct temac_reg { + /* direct soft registers (low part) */ + u32 raf; /* Reset and Address Filter */ + u32 tpf; /* Transmit Pause Frame */ + u32 ifgp; /* Transmit Inter Frame Gap Adjustment */ + u32 is; /* Interrupt Status */ + u32 ip; /* Interrupt Pending */ + u32 ie; /* Interrupt Enable */ + u32 ttag; /* Transmit VLAN Tag */ + u32 rtag; /* Receive VLAN Tag */ + /* hard TEMAC registers */ + u32 msw; /* Most Significant Word Data */ + u32 lsw; /* Least Significant Word Data */ + u32 ctl; /* Control */ + u32 rdy; /* Ready Status */ + /* direct soft registers (high part) */ + u32 uawl; /* Unicast Address Word Lower */ + u32 uawu; /* Unicast Address Word Upper */ + u32 tpid0; /* VLAN TPID Word 0 */ + u32 tpid1; /* VLAN TPID Word 1 */ +}; + +/* Reset and Address Filter Registers (raf), [1] p25 */ +#define RAF_SR (1 << 13) +#define RAF_EMFE (1 << 12) +#define RAF_NFE (1 << 11) +#define RAF_RVSTM_POS (9) +#define RAF_RVSTM_MASK (3 << RAF_RVSTM_POS) +#define RAF_TVSTM_POS (7) +#define RAF_TVSTM_MASK (3 << RAF_TVSTM_POS) +#define RAF_RVTM_POS (5) +#define RAF_RVTM_MASK (3 << RAF_RVTM_POS) +#define RAF_TVTM_POS (3) +#define RAF_TVTM_MASK (3 << RAF_TVTM_POS) +#define RAF_BCREJ (1 << 2) +#define RAF_MCREJ (1 << 1) +#define RAF_HTRST (1 << 0) + +/* Transmit Pause Frame Registers (tpf), [1] p28 */ +#define TPF_TPFV_POS (0) +#define TPF_TPFV_MASK (0xFFFF << TPF_TPFV_POS) + +/* Transmit Inter Frame Gap Adjustment Registers (ifgp), [1] p28 */ +#define IFGP_POS (0) +#define IFGP_MASK (0xFF << IFGP_POS) + +/* Interrupt Status, Pending, Enable Registers (is, ip, ie), [1] p29-33 */ +#define ISPE_MR (1 << 7) +#define ISPE_RDL (1 << 6) +#define ISPE_TC (1 << 5) +#define ISPE_RFO (1 << 4) +#define ISPE_RR (1 << 3) +#define ISPE_RC (1 << 2) +#define ISPE_AN (1 << 1) +#define ISPE_HAC (1 << 0) + +/* Transmit, Receive VLAN Tag Registers (ttag, rtag), [1] p34-35 */ +#define TRTAG_TPID_POS (16) +#define TRTAG_TPID_MASK (0xFFFF << TRTAG_TPID_POS) +#define TRTAG_PRIO_POS (13) +#define TRTAG_PRIO_MASK (7 << TRTAG_PRIO_POS) +#define TRTAG_CFI (1 << 12) +#define TRTAG_VID_POS (0) +#define TRTAG_VID_MASK (0xFFF << TRTAG_VID_POS) + +/* Most, Least Significant Word Data Register (msw, lsw), [1] p46 */ +#define MLSW_POS (0) +#define MLSW_MASK (~0UL << MLSW_POS) + +/* LSW Data Register for PHY addresses (lsw), [1] p66 */ +#define LSW_REGAD_POS (0) +#define LSW_REGAD_MASK (0x1F << LSW_REGAD_POS) +#define LSW_PHYAD_POS (5) +#define LSW_PHYAD_MASK (0x1F << LSW_PHYAD_POS) + +/* LSW Data Register for PHY data (lsw), [1] p66 */ +#define LSW_REGDAT_POS (0) +#define LSW_REGDAT_MASK (0xFFFF << LSW_REGDAT_POS) + +/* Control Register (ctl), [1] p47 */ +#define CTL_WEN (1 << 15) +#define CTL_ADDR_POS (0) +#define CTL_ADDR_MASK (0x3FF << CTL_ADDR_POS) + +/* Ready Status Register Ethernet (rdy), [1] p48 */ +#define RSE_HACS_RDY (1 << 14) +#define RSE_CFG_WR (1 << 6) +#define RSE_CFG_RR (1 << 5) +#define RSE_AF_WR (1 << 4) +#define RSE_AF_RR (1 << 3) +#define RSE_MIIM_WR (1 << 2) +#define RSE_MIIM_RR (1 << 1) +#define RSE_FABR_RR (1 << 0) + +/* Unicast Address Word Lower, Upper Registers (uawl, uawu), [1] p35-36 */ +#define UAWL_UADDR_POS (0) +#define UAWL_UADDR_MASK (~0UL << UAWL_UADDR_POS) +#define UAWU_UADDR_POS (0) +#define UAWU_UADDR_MASK (0xFFFF << UAWU_UADDR_POS) + +/* VLAN TPID Word 0, 1 Registers (tpid0, tpid1), [1] p37 */ +#define TPID0_V0_POS (0) +#define TPID0_V0_MASK (0xFFFF << TPID0_V0_POS) +#define TPID0_V1_POS (16) +#define TPID0_V1_MASK (0xFFFF << TPID0_V1_POS) +#define TPID1_V2_POS (0) +#define TPID1_V2_MASK (0xFFFF << TPID1_V2_POS) +#define TPID1_V3_POS (16) +#define TPID1_V3_MASK (0xFFFF << TPID1_V3_POS) + + +/* + * TEMAC Indirectly Addressable Register Index Enumeration + * + * [1]: http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 23, PLB Indirectly Addressable TEMAC Registers + */ +enum temac_ctrl { + TEMAC_RCW0 = 0x200, + TEMAC_RCW1 = 0x240, + TEMAC_TC = 0x280, + TEMAC_FCC = 0x2C0, + TEMAC_EMMC = 0x300, + TEMAC_PHYC = 0x320, + TEMAC_MC = 0x340, + TEMAC_UAW0 = 0x380, + TEMAC_UAW1 = 0x384, + TEMAC_MAW0 = 0x388, + TEMAC_MAW1 = 0x38C, + TEMAC_AFM = 0x390, + TEMAC_TIS = 0x3A0, + TEMAC_TIE = 0x3A4, + TEMAC_MIIMWD = 0x3B0, + TEMAC_MIIMAI = 0x3B4 +}; + +/* Receive Configuration Word 0, 1 Registers (RCW0, RCW1), [1] p50-51 */ +#define RCW0_PADDR_POS (0) +#define RCW0_PADDR_MASK (~0UL << RCW_PADDR_POS) +#define RCW1_RST (1 << 31) +#define RCW1_JUM (1 << 30) +#define RCW1_FCS (1 << 29) +#define RCW1_RX (1 << 28) +#define RCW1_VLAN (1 << 27) +#define RCW1_HD (1 << 26) +#define RCW1_LT_DIS (1 << 25) +#define RCW1_PADDR_POS (0) +#define RCW1_PADDR_MASK (0xFFFF << RCW_PADDR_POS) + +/* Transmit Configuration Registers (TC), [1] p52 */ +#define TC_RST (1 << 31) +#define TC_JUM (1 << 30) +#define TC_FCS (1 << 29) +#define TC_TX (1 << 28) +#define TC_VLAN (1 << 27) +#define TC_HD (1 << 26) +#define TC_IFG (1 << 25) + +/* Flow Control Configuration Registers (FCC), [1] p54 */ +#define FCC_FCTX (1 << 30) +#define FCC_FCRX (1 << 29) + +/* Ethernet MAC Mode Configuration Registers (EMMC), [1] p54 */ +#define EMMC_LSPD_POS (30) +#define EMMC_LSPD_MASK (3 << EMMC_LSPD_POS) +#define EMMC_LSPD_1000 (2 << EMMC_LSPD_POS) +#define EMMC_LSPD_100 (1 << EMMC_LSPD_POS) +#define EMMC_LSPD_10 (0) +#define EMMC_RGMII (1 << 29) +#define EMMC_SGMII (1 << 28) +#define EMMC_GPCS (1 << 27) +#define EMMC_HOST (1 << 26) +#define EMMC_TX16 (1 << 25) +#define EMMC_RX16 (1 << 24) + +/* RGMII/SGMII Configuration Registers (PHYC), [1] p56 */ +#define PHYC_SLSPD_POS (30) +#define PHYC_SLSPD_MASK (3 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_1000 (2 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_100 (1 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_10 (0) +#define PHYC_RLSPD_POS (2) +#define PHYC_RLSPD_MASK (3 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_1000 (2 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_100 (1 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_10 (0) +#define PHYC_RGMII_HD (1 << 1) +#define PHYC_RGMII_LINK (1 << 0) + +/* Management Configuration Registers (MC), [1] p57 */ +#define MC_MDIOEN (1 << 6) +#define MC_CLKDIV_POS (0) +#define MC_CLKDIV_MASK (0x3F << MC_CLKDIV_POS) + +/* + * fHOSTCLK fMDC = fHOSTCLK + * fMDC = ------------------- ---------> MC_CLKDIV = -------- - 1 + * (1 + MC_CLKDIV) * 2 2.5 MHz 5MHz + */ +#define MC_CLKDIV(f,m) ((f / (2 * m)) - 1) +#define MC_CLKDIV_25(f) MC_CLKDIV(f, 2500000) +#define MC_CLKDIV_20(f) MC_CLKDIV(f, 2000000) +#define MC_CLKDIV_15(f) MC_CLKDIV(f, 1500000) +#define MC_CLKDIV_10(f) MC_CLKDIV(f, 1000000) + +/* Unicast Address Word 0, 1 Registers (UAW0, UAW1), [1] p58-59 */ +#define UAW0_UADDR_POS (0) +#define UAW0_UADDR_MASK (~0UL << UAW0_UADDR_POS) +#define UAW1_UADDR_POS (0) +#define UAW1_UADDR_MASK (0xFFFF << UAW1_UADDR_POS) + +/* Multicast Address Word 0, 1 Registers (MAW0, MAW1), [1] p60 */ +#define MAW0_MADDR_POS (0) +#define MAW0_MADDR_MASK (~0UL << MAW0_MADDR_POS) +#define MAW1_RNW (1 << 23) +#define MAW1_MAIDX_POS (16) +#define MAW1_MAIDX_MASK (3 << MAW1_MAIDX_POS) +#define MAW1_MADDR_POS (0) +#define MAW1_MADDR_MASK (0xFFFF << MAW1_MADDR_POS) + +/* Address Filter Mode Registers (AFM), [1] p63 */ +#define AFM_PM (1 << 31) + +/* Interrupt Status, Enable Registers (TIS, TIE), [1] p63-65 */ +#define TISE_CFG_W (1 << 6) +#define TISE_CFG_R (1 << 5) +#define TISE_AF_W (1 << 4) +#define TISE_AF_R (1 << 3) +#define TISE_MIIM_W (1 << 2) +#define TISE_MIIM_R (1 << 1) +#define TISE_FABR_R (1 << 0) + +/* MII Management Write Data Registers (MIIMWD), [1] p66 */ +#define MIIMWD_DATA_POS (0) +#define MIIMWD_DATA_MASK (0xFFFF << MIIMWD_DATA_POS) + + +#endif /* _XILINX_LL_TEMAC_ */ diff --git a/drivers/net/xilinx_ll_temac_fifo.c b/drivers/net/xilinx_ll_temac_fifo.c new file mode 100644 index 0000000..02800d5 --- /dev/null +++ b/drivers/net/xilinx_ll_temac_fifo.c @@ -0,0 +1,93 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * FIFO interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ + +#include <config.h> +#include <common.h> +#include <net.h> + +#include <asm/types.h> +#include <asm/io.h> + +#include "xilinx_ll_temac.h" + +#ifdef DEBUG +static void debugll(struct eth_device *dev, int count) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + printf("FIFO: %d isr 0x%08x, ier 0x%08x, rdfr 0x%08x, " + "rdfo 0x%08x rlr 0x%08x\n", count, + in_be32(&fifo_ctrl->isr), in_be32(&fifo_ctrl->ier), + in_be32(&fifo_ctrl->rdfr), in_be32(&fifo_ctrl->rdfo), + in_be32(&fifo_ctrl->rlf)); +} +#endif + +int ll_temac_reset_fifo(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + + out_be32(&fifo_ctrl->tdfr, LL_FIFO_TDFR_KEY); + out_be32(&fifo_ctrl->rdfr, LL_FIFO_RDFR_KEY); + out_be32(&fifo_ctrl->isr, ~0UL); + out_be32(&fifo_ctrl->ier, 0); + + return 0; +} + +int ll_temac_recv_fifo(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + u32 i, len = 0; + u32 *buf = (u32 *)&(ll_temac->rx_bp); + + if (in_be32(&fifo_ctrl->isr) & LL_FIFO_ISR_RC) { + out_be32(&fifo_ctrl->isr, ~0UL); /* reset isr */ + + /* while (fifo_ctrl->isr); */ + len = in_be32(&fifo_ctrl->rlf) & LL_FIFO_RLF_MASK; + + for (i = 0; i < len; i += 4) + *buf++ = in_be32(&fifo_ctrl->rdfd); + +#ifdef DEBUG + debugll(dev, 1); +#endif + NetReceive((uchar *)&(ll_temac->rx_bp), len); + } + return len; +} + +int ll_temac_send_fifo(struct eth_device *dev, + volatile void *buffer, int length) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + u32 *buf = (u32 *)buffer; + u32 i; + + for (i = 0; i < length; i += 4) + out_be32(&fifo_ctrl->tdfd, *buf++); + + out_be32(&fifo_ctrl->tlf, length); + return 0; +} diff --git a/drivers/net/xilinx_ll_temac_fifo.h b/drivers/net/xilinx_ll_temac_fifo.h new file mode 100644 index 0000000..c8fcd96 --- /dev/null +++ b/drivers/net/xilinx_ll_temac_fifo.h @@ -0,0 +1,112 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * FIFO interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ +#ifndef _XILINX_LL_TEMAC_FIFO_ +#define _XILINX_LL_TEMAC_FIFO_ + +#include <net.h> +#include <asm/types.h> +#include <asm/byteorder.h> + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +/* + * FIFO Register Definition + * + * Used for memory mapped access from and to (Rd/Td) the LocalLink (LL) TEMAC via + * the 2 kb full duplex FIFO Controller -- one for each. + * + * [1]: http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_fifo.pdf + * page 10, Registers Definition + */ +struct fifo_ctrl { + u32 isr; /* Interrupt Status Register (RW) */ + u32 ier; /* Interrupt Enable Register (RW) */ + u32 tdfr; /* Transmit Data FIFO Reset (WO) */ + u32 tdfv; /* Transmit Data FIFO Vacancy (RO) */ + u32 tdfd; /* Transmit Data FIFO 32bit wide Data write port (WO) */ + u32 tlf; /* Transmit Length FIFO (WO) */ + u32 rdfr; /* Receive Data FIFO Reset (WO) */ + u32 rdfo; /* Receive Data FIFO Occupancy (RO) */ + u32 rdfd; /* Receive Data FIFO 32bit wide Data read port (RO) */ + u32 rlf; /* Receive Length FIFO (RO) */ + u32 llr; /* LocalLink Reset (WO) */ +}; + +/* Interrupt Status Register (ISR), [1] p11 */ +#define LL_FIFO_ISR_RPURE (1 << 31) /* Receive Packet Underrun Read Error */ +#define LL_FIFO_ISR_RPORE (1 << 30) /* Receive Packet Overrun Read Error */ +#define LL_FIFO_ISR_RPUE (1 << 29) /* Receive Packet Underrun Error */ +#define LL_FIFO_ISR_TPOE (1 << 28) /* Transmit Packet Overrun Error */ +#define LL_FIFO_ISR_TC (1 << 27) /* Transmit Complete */ +#define LL_FIFO_ISR_RC (1 << 26) /* Receive Complete */ +#define LL_FIFO_ISR_TSE (1 << 25) /* Transmit Size Error */ +#define LL_FIFO_ISR_TRC (1 << 24) /* Transmit Reset Complete */ +#define LL_FIFO_ISR_RRC (1 << 23) /* Receive Reset Complete */ + +/* Interrupt Enable Register (IER), [1] p12/p13 */ +#define LL_FIFO_IER_RPURE (1 << 31) /* Receive Packet Underrun Read Error */ +#define LL_FIFO_IER_RPORE (1 << 30) /* Receive Packet Overrun Read Error */ +#define LL_FIFO_IER_RPUE (1 << 29) /* Receive Packet Underrun Error */ +#define LL_FIFO_IER_TPOE (1 << 28) /* Transmit Packet Overrun Error */ +#define LL_FIFO_IER_TC (1 << 27) /* Transmit Complete */ +#define LL_FIFO_IER_RC (1 << 26) /* Receive Complete */ +#define LL_FIFO_IER_TSE (1 << 25) /* Transmit Size Error */ +#define LL_FIFO_IER_TRC (1 << 24) /* Transmit Reset Complete */ +#define LL_FIFO_IER_RRC (1 << 23) /* Receive Reset Complete */ + +/* Transmit Data FIFO Reset (TDFR), [1] p13/p14 */ +#define LL_FIFO_TDFR_KEY (0x000000A5UL) + +/* Transmit Data FIFO Vacancy (TDFV), [1] p14 */ +#define LL_FIFO_TDFV_POS (0) +#define LL_FIFO_TDFV_MASK (0x000001FFUL << LL_FIFO_TDFV_POS) + +/* Transmit Length FIFO (TLF), [1] p16/p17 */ +#define LL_FIFO_TLF_POS (0) +#define LL_FIFO_TLF_MASK (0x000007FFUL << LL_FIFO_TLF_POS) + +/* Receive Data FIFO Reset (RDFR), [1] p15 */ +#define LL_FIFO_RDFR_KEY (0x000000A5UL) + +/* Receive Data FIFO Occupancy (RDFO), [1] p16 */ +#define LL_FIFO_RDFO_POS (0) +#define LL_FIFO_RDFO_MASK (0x000001FFUL << LL_FIFO_RDFO_POS) + +/* Receive Length FIFO (TLF), [1] p17/p18 */ +#define LL_FIFO_RLF_POS (0) +#define LL_FIFO_RLF_MASK (0x000007FFUL << LL_FIFO_RLF_POS) + +/* LocalLink Reset (LLR), [1] p18 */ +#define LL_FIFO_LLR_KEY (0x000000A5UL) + + +/* reset FIFO and IRQ, disable interrupts */ +int ll_temac_reset_fifo(struct eth_device *dev); + +/* receive buffered data from FIFO (polling ISR) */ +int ll_temac_recv_fifo(struct eth_device *dev); + +/* send buffered data to FIFO */ +int ll_temac_send_fifo(struct eth_device *dev, + volatile void *buffer, int length); + +#endif /* _XILINX_LL_TEMAC_FIFO_ */ diff --git a/drivers/net/xilinx_ll_temac_sdma.c b/drivers/net/xilinx_ll_temac_sdma.c new file mode 100644 index 0000000..6a7f2ca --- /dev/null +++ b/drivers/net/xilinx_ll_temac_sdma.c @@ -0,0 +1,413 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * SDMA interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ + +#include <config.h> +#include <common.h> +#include <net.h> + +#include <asm/types.h> +#include <asm/io.h> + +#include "xilinx_ll_temac.h" + + +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) +/* + * Indirect DCR access operations mi{ft}dcr_xilinx() espacialy + * for Xilinx PowerPC implementations on FPGA. + * + * FIXME: This part should going up to arch/powerpc -- but where? + */ +#include <asm/processor.h> +#define XILINX_INDIRECT_DCR_ADDRESS_REG 0 +#define XILINX_INDIRECT_DCR_ACCESS_REG 1 +unsigned mifdcr_xilinx(const unsigned dcrn) +{ + mtdcr(XILINX_INDIRECT_DCR_ADDRESS_REG, dcrn); + return mfdcr(XILINX_INDIRECT_DCR_ACCESS_REG); +} +unsigned mitdcr_xilinx(const unsigned dcrn, int val) +{ + mtdcr(XILINX_INDIRECT_DCR_ADDRESS_REG, dcrn); + mtdcr(XILINX_INDIRECT_DCR_ACCESS_REG, val); +} +#endif + + +/* Check for TX and RX channel errrors. */ +static inline int ll_temac_dma_error(struct eth_device *dev) +{ + int err; + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + + err = in_be32(&sdma_ctrl->tx_chnl_sts) & CHNL_STS_ERROR; + err |= in_be32(&sdma_ctrl->rx_chnl_sts) & CHNL_STS_ERROR; + return err; +} + + +void ll_temac_init_sdma(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + + memset(tx_dp, 0, sizeof(*tx_dp)); + memset(rx_dp, 0, sizeof(*rx_dp)); + + /* from LL TEMAC (Rx) */ + rx_dp->phys_buf_p = ll_temac->rx_bp; + + rx_dp->next_p = rx_dp; + rx_dp->buf_len = PKTSIZE_ALIGN; + flush_cache((u32)rx_dp, sizeof(*tx_dp)); + flush_cache((u32)rx_dp->phys_buf_p, PKTSIZE_ALIGN); + + out_be32(&sdma_ctrl->rx_curdesc_ptr, (u32)rx_dp); + out_be32(&sdma_ctrl->rx_taildesc_ptr, (u32)rx_dp); + out_be32(&sdma_ctrl->rx_nxtdesc_ptr, (u32)rx_dp); /* setup first fd */ + + /* to LL TEMAC (Tx) */ + tx_dp->phys_buf_p = ll_temac->tx_bp; + tx_dp->next_p = tx_dp; + + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + out_be32(&sdma_ctrl->tx_curdesc_ptr, (u32)tx_dp); +} + +int ll_temac_halt_sdma(struct eth_device *dev) +{ + u32 timeout = 2000; + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + + /* + * Soft reset the DMA + * + * Quote from MPMC documentation: Writing a 1 to this field + * forces the DMA engine to shutdown and reset itself. After + * setting this bit, software must poll it until the bit is + * cleared by the DMA. This indicates that the reset process + * is done and the pipeline has been flushed. + */ + out_be32(&sdma_ctrl->dma_control_reg, DMA_CONTROL_RESET); + while (timeout && (in_be32(&sdma_ctrl->dma_control_reg) + & DMA_CONTROL_RESET)) + timeout--; + + if (!timeout) { + printf("%s: Timeout\n", __func__); + return 1; + } + + return 0; +} + +int ll_temac_reset_sdma(struct eth_device *dev) +{ + u32 r; + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + + /* Soft reset the DMA. */ + if (ll_temac_halt_sdma(dev)) + return 1; + + /* Now clear the interrupts. */ + r = in_be32(&sdma_ctrl->tx_chnl_ctrl); + r &= ~CHNL_CTRL_IRQ_MASK; + out_be32(&sdma_ctrl->tx_chnl_ctrl, r); + + r = in_be32(&sdma_ctrl->rx_chnl_ctrl); + r &= ~CHNL_CTRL_IRQ_MASK; + out_be32(&sdma_ctrl->rx_chnl_ctrl, r); + + /* Now ACK pending IRQs. */ + out_be32(&sdma_ctrl->tx_irq_reg, IRQ_REG_IRQ_MASK); + out_be32(&sdma_ctrl->rx_irq_reg, IRQ_REG_IRQ_MASK); + + /* Set tail-ptr mode, disable errors for both channels. */ + out_be32(&sdma_ctrl->dma_control_reg, + /* Enable use of tail pointer register */ + DMA_CONTROL_TPE | + /* Disable error when 2 or 4 bit coalesce counter overflows */ + DMA_CONTROL_RXOCEID | + /* Disable error when 2 or 4 bit coalesce counter overflows */ + DMA_CONTROL_TXOCEID); + + return 0; +} + +int ll_temac_recv_sdma(struct eth_device *dev) +{ + int length; + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + + if (ll_temac_dma_error(dev)) { + if (ll_temac_reset_sdma(dev)) + return -1; + ll_temac_init_sdma(dev); + } + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + + if (!(rx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)) + return 0; + + /* + * Read out the packet info and start the DMA + * onto the second buffer to enable the ethernet rx + * path to run in parallel with sw processing + * packets. + */ + length = rx_dp->sca.app[4] & CDMAC_BD_APP4_RXBYTECNT_MASK; + if (length > 0) + NetReceive(rx_dp->phys_buf_p, length); + + /* flip the buffer and re-enable the DMA. */ + flush_cache((u32)rx_dp->phys_buf_p, length); + + rx_dp->buf_len = PKTSIZE_ALIGN; + rx_dp->sca.stctrl = 0; + rx_dp->sca.app[4] = 0; + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + out_be32(&sdma_ctrl->rx_taildesc_ptr, (u32)rx_dp); + + return length; +} + +int ll_temac_send_sdma(struct eth_device *dev, + volatile void *buffer, int length) +{ + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + + if (ll_temac_dma_error(dev)) { + if (ll_temac_reset_sdma(dev)) + return -1; + ll_temac_init_sdma(dev); + } + + memcpy(ll_temac->tx_bp, (void *)buffer, length); + flush_cache((u32)ll_temac->tx_bp, length); + + tx_dp->sca.stctrl = CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP | + CDMAC_BD_STCTRL_STOP_ON_END; + tx_dp->buf_len = length; + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + + out_be32(&sdma_ctrl->tx_curdesc_ptr, (u32)tx_dp); + out_be32(&sdma_ctrl->tx_taildesc_ptr, (u32)tx_dp); /* DMA start */ + + do { + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + } while (!(tx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)); + + return 0; +} + + +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + +/* Check for TX and RX channel errrors. */ +static inline int ll_temac_dmac_error(struct eth_device *dev) +{ + int err; + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + + err = mifdcr_xilinx(dmac_ctrl + TX_CHNL_STS) & CHNL_STS_ERROR; + err |= mifdcr_xilinx(dmac_ctrl + RX_CHNL_STS) & CHNL_STS_ERROR; + return err; +} + + +void ll_temac_init_dmac(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + + memset(tx_dp, 0, sizeof(*tx_dp)); + memset(rx_dp, 0, sizeof(*rx_dp)); + + /* from LL TEMAC (Rx) */ + rx_dp->phys_buf_p = ll_temac->rx_bp; + + rx_dp->next_p = rx_dp; + rx_dp->buf_len = PKTSIZE_ALIGN; + flush_cache((u32)rx_dp, sizeof(*tx_dp)); + flush_cache((u32)rx_dp->phys_buf_p, PKTSIZE_ALIGN); + + mitdcr_xilinx(dmac_ctrl + RX_CURDESC_PTR, (u32)rx_dp); + mitdcr_xilinx(dmac_ctrl + RX_TAILDESC_PTR, (u32)rx_dp); + mitdcr_xilinx(dmac_ctrl + RX_NXTDESC_PTR, (u32)rx_dp); /* setup first fd */ + + /* to LL TEMAC (Tx) */ + tx_dp->phys_buf_p = ll_temac->tx_bp; + tx_dp->next_p = tx_dp; + + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + mitdcr_xilinx(dmac_ctrl + TX_CURDESC_PTR, (u32)rx_dp); +} + +int ll_temac_halt_dmac(struct eth_device *dev) +{ + u32 timeout = 2000; + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + + /* + * Soft reset the DMA + * + * Quote from MPMC documentation: Writing a 1 to this field + * forces the DMA engine to shutdown and reset itself. After + * setting this bit, software must poll it until the bit is + * cleared by the DMA. This indicates that the reset process + * is done and the pipeline has been flushed. + */ + mitdcr_xilinx(dmac_ctrl + DMA_CONTROL_REG, DMA_CONTROL_RESET); + while (timeout && (mifdcr_xilinx(dmac_ctrl + DMA_CONTROL_REG) + & DMA_CONTROL_RESET)) + timeout--; + + if (!timeout) { + printf("%s: Timeout\n", __func__); + return 1; + } + + return 0; +} + +int ll_temac_reset_dmac(struct eth_device *dev) +{ + u32 r; + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + + /* Soft reset the DMA. */ + if (ll_temac_halt_dmac(dev)) + return 1; + + /* Now clear the interrupts. */ + r = mifdcr_xilinx(dmac_ctrl + TX_CHNL_CTRL); + r &= ~CHNL_CTRL_IRQ_MASK; + mitdcr_xilinx(dmac_ctrl + TX_CHNL_CTRL, r); + + r = mifdcr_xilinx(dmac_ctrl + RX_CHNL_CTRL); + r &= ~CHNL_CTRL_IRQ_MASK; + mitdcr_xilinx(dmac_ctrl + RX_CHNL_CTRL, r); + + /* Now ACK pending IRQs. */ + mitdcr_xilinx(dmac_ctrl + TX_IRQ_REG, IRQ_REG_IRQ_MASK); + mitdcr_xilinx(dmac_ctrl + RX_IRQ_REG, IRQ_REG_IRQ_MASK); + + /* Set tail-ptr mode, disable errors for both channels. */ + mitdcr_xilinx(dmac_ctrl + DMA_CONTROL_REG, + /* Enable use of tail pointer register */ + DMA_CONTROL_TPE | + /* Disable error when 2 or 4 bit coalesce counter overflows */ + DMA_CONTROL_RXOCEID | + /* Disable error when 2 or 4 bit coalesce counter overflows */ + DMA_CONTROL_TXOCEID); + + return 0; +} + +int ll_temac_recv_dmac(struct eth_device *dev) +{ + int length; + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + + if (ll_temac_dmac_error(dev)) { + if (ll_temac_reset_dmac(dev)) + return -1; + ll_temac_init_dmac(dev); + } + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + + if (!(rx_dp.sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)) + return 0; + + /* + * Read out the packet info and start the DMA + * onto the second buffer to enable the ethernet rx + * path to run in parallel with sw processing + * packets. + */ + length = rx_dp->sca.app[4] & CDMAC_BD_APP4_RXBYTECNT_MASK; + if (length > 0) + NetReceive(rx_dp->phys_buf_p, length); + + /* flip the buffer and re-enable the DMA. */ + flush_cache((u32)rx_dp->phys_buf_p, length); + + rx_dp->buf_len = PKTSIZE_ALIGN; + rx_dp->sca.stctrl = 0; + rx_dp->sca.app[4] = 0; + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + mitdcr_xilinx(dmac_ctrl + RX_TAILDESC_PTR, (u32)rx_dp); + + return length; +} + +int ll_temac_send_dmac(struct eth_device *dev, + volatile void *buffer, int length) +{ + struct ll_temac *ll_temac = dev->priv; + unsigned dmac_ctrl = ll_temac->ctrladdr; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + + if (ll_temac_dmac_error(dev)) { + if (ll_temac_reset_dmac(dev)) + return -1; + ll_temac_init_dmac(dev); + } + + memcpy(ll_temac->tx_bp, (void *)buffer, length); + flush_cache((u32)ll_temac->tx_bp, length); + + tx_dp->sca.stctrl = CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP | + CDMAC_BD_STCTRL_STOP_ON_END; + tx_dp->buf_len = length; + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + + mitdcr_xilinx(dmac_ctrl + TX_CURDESC_PTR, (u32)tx_dp); + mitdcr_xilinx(dmac_ctrl + TX_TAILDESC_PTR, (u32)tx_dp); /* DMA start */ + + do { + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + } while (!(tx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)); + + return 0; +} + +#endif /* CONFIG_XILINX_440 || CONFIG_XILINX_405 */ diff --git a/drivers/net/xilinx_ll_temac_sdma.h b/drivers/net/xilinx_ll_temac_sdma.h new file mode 100644 index 0000000..45e63f6 --- /dev/null +++ b/drivers/net/xilinx_ll_temac_sdma.h @@ -0,0 +1,280 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * SDMA interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 Stepahn Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ +#ifndef _XILINX_LL_TEMAC_SDMA_ +#define _XILINX_LL_TEMAC_SDMA_ + +#include <net.h> +#include <asm/types.h> +#include <asm/byteorder.h> + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +#if defined(CONFIG_SYS_CACHELINE_SIZE) +#define DMAALIGN CONFIG_SYS_CACHELINE_SIZE +#else +/* we expact to live in a 32 bit processor environment */ +#define DMAALIGN 32 +#endif + + +/* + * DMA Buffer Descriptor for CDMAC + * + * Used for data connection from and to (Rx/Tx) the LocalLink (LL) TEMAC via + * the Communications Direct Memory Access Controller (CDMAC) -- one for each. + * + * overview: + * ftp://ftp.xilinx.com/pub/documentation/misc/mpmc_getting_started.pdf + * + * [1]: http://www.xilinx.com/support/documentation/ip_documentation/mpmc.pdf + * page 140, DMA Operation Descriptors + * + * [2]: http://www.xilinx.com/support/documentation/user_guides/ug200.pdf + * page 229, DMA Controller -- Descriptor Format + * + * [3]: http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 72, Transmit LocalLink Frame Format + * page 73, Receive LocalLink Frame Format + */ +struct cdmac_bd { + struct cdmac_bd *next_p; /* Next Descriptor Pointer */ + u8 *phys_buf_p; /* Buffer Address */ + u32 buf_len; /* Buffer Length */ + union { + u8 stctrl; /* Status/Control the DMA transfer */ + u32 app[5]; /* application specific data */ + } __attribute__ ((packed, aligned(1))) sca; +}; + +/* CDMAC Descriptor Status and Control (stctrl), [1] p140, [2] p230 */ +#define CDMAC_BD_STCTRL_ERROR (1 << 7) +#define CDMAC_BD_STCTRL_IRQ_ON_END (1 << 6) +#define CDMAC_BD_STCTRL_STOP_ON_END (1 << 5) +#define CDMAC_BD_STCTRL_COMPLETED (1 << 4) +#define CDMAC_BD_STCTRL_SOP (1 << 3) +#define CDMAC_BD_STCTRL_EOP (1 << 2) +#define CDMAC_BD_STCTRL_DMACHBUSY (1 << 1) + +/* CDMAC Descriptor APP0: Transmit LocalLink Footer Word 3, [3] p72 */ +#define CDMAC_BD_APP0_TXCSCNTRL (1 << 0) + +/* CDMAC Descriptor APP1: Transmit LocalLink Footer Word 4, [3] p73 */ +#define CDMAC_BD_APP1_TXCSBEGIN_POS (16) +#define CDMAC_BD_APP1_TXCSBEGIN_MASK (0xFFFF << CDMAC_BD_APP1_TXCSBEGIN_POS) +#define CDMAC_BD_APP1_TXCSINSERT_POS (0) +#define CDMAC_BD_APP1_TXCSINSERT_MASK (0xFFFF << CDMAC_BD_APP1_TXCSINSERT_POS) + +/* CDMAC Descriptor APP2: Transmit LocalLink Footer Word 5, [3] p73 */ +#define CDMAC_BD_APP2_TXCSINIT_POS (0) +#define CDMAC_BD_APP2_TXCSINIT_MASK (0xFFFF << CDMAC_BD_APP2_TXCSINIT_POS) + +/* CDMAC Descriptor APP0: Receive LocalLink Footer Word 3, [3] p73 */ +#define CDMAC_BD_APP0_MADDRU_POS (0) +#define CDMAC_BD_APP0_MADDRU_MASK (0xFFFF << CDMAC_BD_APP0_MADDRU_POS) + +/* CDMAC Descriptor APP1: Receive LocalLink Footer Word 4, [3] p74 */ +#define CDMAC_BD_APP1_MADDRL_POS (0) +#define CDMAC_BD_APP1_MADDRL_MASK (~0UL << CDMAC_BD_APP1_MADDRL_POS) + +/* CDMAC Descriptor APP2: Receive LocalLink Footer Word 5, [3] p74 */ +#define CDMAC_BD_APP2_BCAST_FRAME (1 << 2) +#define CDMAC_BD_APP2_IPC_MCAST_FRAME (1 << 1) +#define CDMAC_BD_APP2_MAC_MCAST_FRAME (1 << 0) + +/* CDMAC Descriptor APP3: Receive LocalLink Footer Word 6, [3] p74 */ +#define CDMAC_BD_APP3_TLTPID_POS (16) +#define CDMAC_BD_APP3_TLTPID_MASK (0xFFFF << CDMAC_BD_APP3_TLTPID_POS) +#define CDMAC_BD_APP3_RXCSRAW_POS (0) +#define CDMAC_BD_APP3_RXCSRAW_MASK (0xFFFF << CDMAC_BD_APP3_RXCSRAW_POS) + +/* CDMAC Descriptor APP4: Receive LocalLink Footer Word 7, [3] p74 */ +#define CDMAC_BD_APP4_VLANTAG_POS (16) +#define CDMAC_BD_APP4_VLANTAG_MASK (0xFFFF << CDMAC_BD_APP4_VLANTAG_POS) +#define CDMAC_BD_APP4_RXBYTECNT_POS (0) +#define CDMAC_BD_APP4_RXBYTECNT_MASK (0x3FFF << CDMAC_BD_APP4_RXBYTECNT_POS) + + +/* + * SDMA Register Definition + * + * [1]: http://www.xilinx.com/support/documentation/ip_documentation/mpmc.pdf + * page 54, SDMA Register Summary + * page 160, SDMA Registers + * + * [2]: http://www.xilinx.com/support/documentation/user_guides/ug200.pdf + * page 244, DMA Controller -- Programming Interface and Registers + */ +struct sdma_ctrl { + /* Transmit Registers */ + u32 tx_nxtdesc_ptr; /* TX Next Description Pointer */ + u32 tx_curbuf_addr; /* TX Current Buffer Address */ + u32 tx_curbuf_length; /* TX Current Buffer Length */ + u32 tx_curdesc_ptr; /* TX Current Descriptor Pointer */ + u32 tx_taildesc_ptr; /* TX Tail Descriptor Pointer */ + u32 tx_chnl_ctrl; /* TX Channel Control */ + u32 tx_irq_reg; /* TX Interrupt Register */ + u32 tx_chnl_sts; /* TX Status Register */ + /* Receive Registers */ + u32 rx_nxtdesc_ptr; /* RX Next Descriptor Pointer */ + u32 rx_curbuf_addr; /* RX Current Buffer Address */ + u32 rx_curbuf_length; /* RX Current Buffer Length */ + u32 rx_curdesc_ptr; /* RX Current Descriptor Pointer */ + u32 rx_taildesc_ptr; /* RX Tail Descriptor Pointer */ + u32 rx_chnl_ctrl; /* RX Channel Control */ + u32 rx_irq_reg; /* RX Interrupt Register */ + u32 rx_chnl_sts; /* RX Status Register */ + /* Control Registers */ + u32 dma_control_reg; /* DMA Control Register */ +}; + +/* Rx/Tx Channel Control Register (*_chnl_ctrl), [1] p163, [2] p246/p252 */ +#define CHNL_CTRL_ITO_POS (24) +#define CHNL_CTRL_ITO_MASK (0xFF << CHNL_CTRL_ITO_POS) +#define CHNL_CTRL_IC_POS (16) +#define CHNL_CTRL_IC_MASK (0xFF << CHNL_CTRL_IC_POS) +#define CHNL_CTRL_MSBADDR_POS (12) +#define CHNL_CTRL_MSBADDR_MASK (0xF << CHNL_CTRL_MSBADDR_POS) +#define CHNL_CTRL_AME (1 << 11) +#define CHNL_CTRL_OBWC (1 << 10) +#define CHNL_CTRL_IOE (1 << 9) +#define CHNL_CTRL_LIC (1 << 8) +#define CHNL_CTRL_IE (1 << 7) +#define CHNL_CTRL_IEE (1 << 2) +#define CHNL_CTRL_IDE (1 << 1) +#define CHNL_CTRL_ICE (1 << 0) + +/* All interrupt enable bits */ +#define CHNL_CTRL_IRQ_MASK (CHNL_CTRL_IE | \ + CHNL_CTRL_IEE | \ + CHNL_CTRL_IDE | \ + CHNL_CTRL_ICE) + +/* Rx/Tx Interrupt Status Register (*_irq_reg), [1] p164, [2] p247/p253 */ +#define IRQ_REG_DTV_POS (24) +#define IRQ_REG_DTV_MASK (0xFF << IRQ_REG_DTV_POS) +#define IRQ_REG_CCV_POS (16) +#define IRQ_REG_CCV_MASK (0xFF << IRQ_REG_CCV_POS) +#define IRQ_REG_WRCQ_EMPTY (1 << 14) +#define IRQ_REG_CIC_POS (10) +#define IRQ_REG_CIC_MASK (0xF << IRQ_REG_CIC_POS) +#define IRQ_REG_DIC_POS (8) +#define IRQ_REG_DIC_MASK (3 << 8) +#define IRQ_REG_PLB_RD_NMI (1 << 4) +#define IRQ_REG_PLB_WR_NMI (1 << 3) +#define IRQ_REG_EI (1 << 2) +#define IRQ_REG_DI (1 << 1) +#define IRQ_REG_CI (1 << 0) + +/* All interrupt bits */ +#define IRQ_REG_IRQ_MASK (IRQ_REG_PLB_RD_NMI | \ + IRQ_REG_PLB_WR_NMI | \ + IRQ_REG_EI | IRQ_REG_DI | IRQ_REG_CI) + +/* Rx/Tx Channel Status Register (*_chnl_sts), [1] p165, [2] p249/p255 */ +#define CHNL_STS_ERROR_TAIL (1 << 21) +#define CHNL_STS_ERROR_CMP (1 << 20) +#define CHNL_STS_ERROR_ADDR (1 << 19) +#define CHNL_STS_ERROR_NXTP (1 << 18) +#define CHNL_STS_ERROR_CURP (1 << 17) +#define CHNL_STS_ERROR_BSYWR (1 << 16) +#define CHNL_STS_ERROR (1 << 7) +#define CHNL_STS_IOE (1 << 6) +#define CHNL_STS_SOE (1 << 5) +#define CHNL_STS_CMPLT (1 << 4) +#define CHNL_STS_SOP (1 << 3) +#define CHNL_STS_EOP (1 << 2) +#define CHNL_STS_EBUSY (1 << 1) + +/* DMA Control Register (dma_control_reg), [1] p166, [2] p256 */ +#define DMA_CONTROL_PLBED (1 << 5) +#define DMA_CONTROL_RXOCEID (1 << 4) +#define DMA_CONTROL_TXOCEID (1 << 3) +#define DMA_CONTROL_TPE (1 << 2) +#define DMA_CONTROL_RESET (1 << 0) + + +/* initialize both Rx/Tx buffer descriptors */ +void ll_temac_init_sdma(struct eth_device *dev); + +/* halt both Rx/Tx transfers */ +int ll_temac_halt_sdma(struct eth_device *dev); + +/* reset SDMA and IRQ, disable interrupts and errors */ +int ll_temac_reset_sdma(struct eth_device *dev); + +/* receive buffered data from SDMA (polling ISR) */ +int ll_temac_recv_sdma(struct eth_device *dev); + +/* send buffered data to SDMA */ +int ll_temac_send_sdma(struct eth_device *dev, + volatile void *buffer, int length); + + +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + +/* + * DMAC Register Index Enumeration + * + * [2]: http://www.xilinx.com/support/documentation/user_guides/ug200.pdf + * page 244, DMA Controller -- Programming Interface and Registers + */ +enum dmac_ctrl { + TX_NXTDESC_PTR = 0, + TX_CURBUF_ADDR, + TX_CURBUF_LENGTH, + TX_CURDESC_PTR, + TX_TAILDESC_PTR, + TX_CHNL_CTRL, + TX_IRQ_REG, + TX_CHNL_STS, + RX_NXTDESC_PTR, + RX_CURBUF_ADDR, + RX_CURBUF_LENGTH, + RX_CURDESC_PTR, + RX_TAILDESC_PTR, + RX_CHNL_CTRL, + RX_IRQ_REG, + RX_CHNL_STS, + DMA_CONTROL_REG +}; + + +/* initialize both Rx/Tx buffer descriptors */ +void ll_temac_init_dmac(struct eth_device *dev); + +/* halt both Rx/Tx transfers */ +int ll_temac_halt_dmac(struct eth_device *dev); + +/* reset SDMA and IRQ, disable interrupts and errors */ +int ll_temac_reset_dmac(struct eth_device *dev); + +/* receive buffered data from SDMA (polling ISR) */ +int ll_temac_recv_dmac(struct eth_device *dev); + +/* send buffered data to SDMA */ +int ll_temac_send_dmac(struct eth_device *dev, + volatile void *buffer, int length); + + +#endif /* CONFIG_XILINX_440 || CONFIG_XILINX_405 */ + +#endif /* _XILINX_LL_TEMAC_SDMA_ */ diff --git a/include/netdev.h b/include/netdev.h index 04d9f75..061c1f1 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -100,6 +100,8 @@ int xilinx_axiemac_initialize(bd_t *bis, unsigned long base_addr, unsigned long dma_addr); int xilinx_emaclite_initialize(bd_t *bis, unsigned long base_addr, int txpp, int rxpp); +int xilinx_ll_temac_initialize(bd_t *bis, unsigned long base_addr, + int mode, unsigned long ctrl);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board.
- Xilinx xps_ll_temac ethernet driver for u-boot
- supports SDMA or FIFO access
- Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu
- Copyright (C) 2008 - 2011 PetaLogix
- Copyright (C) 2011 Stepahn Linz linz@li-pro.net
- Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver
- Copyright (C) 2008 Nissin Systems Co.,Ltd.
- March 2008 created
- This program is free software; you can redistribute it and/or modify it
- under the terms of the GNU General Public License as published by the
- Free Software Foundation; either version 2 of the License, or (at your
- option) any later version.
+#undef ETH_HALTING
Why CONFIG_CMD_MII, the error says only CONFIG_MII
- Prior to PHY access, the MDIO clock must be setup. This driver will set
One newline
Can this global stuff be wrapped into the functions somehow? So it's not global.
- unsigned timeout = 2000;
Magic timeout ?
- while (timeout && (!(in_be32(®s->rdy) & mask)))
timeout--;
- if (!timeout)
- Undirect hostif write to ll_temac.
http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac. pdf + * page 67, Using the MII Management to Access PHY Registers
- struct temac_reg *regs = (struct temac_reg *)dev->iobase;
- out_be32(®s->lsw, (phy_data & LSW_REGDAT_MASK));
- out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMWD);
- out_be32(®s->lsw,
- out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMAI);
- xps_ll_temac_check_status(regs, RSE_MIIM_WR);
- Undirect hostif read to ll_temac.
u8 reg_addr)
- out_be32(®s->lsw,
- out_be32(®s->ctl, TEMAC_MIIMAI);
- xps_ll_temac_check_status(regs, RSE_MIIM_RR);
- return in_be32(®s->lsw) & LSW_REGDAT_MASK;
- Undirect write to ll_temac.
http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac. pdf + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +static void xps_ll_temac_indirect_set(struct eth_device *dev, u16 regn,
u32 reg_data)
- out_be32(®s->lsw, (reg_data & MLSW_MASK));
- out_be32(®s->ctl, CTL_WEN | (regn & CTL_ADDR_MASK));
- xps_ll_temac_check_status(regs, RSE_CFG_WR);
- Undirect read from ll_temac.
http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac. pdf + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +static u32 xps_ll_temac_indirect_get(struct eth_device *dev, u16 regn) +{
- out_be32(®s->ctl, (regn & CTL_ADDR_MASK));
- xps_ll_temac_check_status(regs, RSE_CFG_RR);
- return in_be32(®s->lsw) & MLSW_MASK;
- int j, result;
- debug("phy%d ", phy_addr);
- for (j = 0; j < 32; j++) {
- debug("\n");
+} +#endif
- int i;
- unsigned int temp, speed;
- struct ll_temac *ll_temac = dev->priv;
- struct phy_device *phydev;
- u32 supported = SUPPORTED_10baseT_Half |
- if (ll_temac->phyaddr == -1) {
break;
- /* interface - look at tsec */
- phydev = phy_connect(ll_temac->bus, ll_temac->phyaddr, dev, 0);
- phydev->supported &= supported;
- phydev->advertising = phydev->supported;
- ll_temac->phydev = phydev;
- phy_config(phydev);
- phy_startup(phydev);
- switch (phydev->speed) {
- case 1000:
break;
- case 100:
break;
- case 10:
break;
- default:
- temp = xps_ll_temac_indirect_get(dev, TEMAC_EMMC);
- temp &= ~EMMC_LSPD_MASK;
- temp |= speed;
- xps_ll_temac_indirect_set(dev, TEMAC_EMMC, temp);
- return 1;
- u32 val;
- /* set up unicast MAC address filter */
- val = ((dev->enetaddr[3] << 24) | (dev->enetaddr[2] << 16) |
- val &= UAW0_UADDR_MASK;
- xps_ll_temac_indirect_set(dev, TEMAC_UAW0, val);
- val = ((dev->enetaddr[5] << 8) | dev->enetaddr[4]);
- val &= UAW1_UADDR_MASK;
- xps_ll_temac_indirect_set(dev, TEMAC_UAW1, val);
- if (ll_temac->ctrlreset)
return -1;
- if (ll_temac->ctrlinit)
- xps_ll_temac_indirect_set(dev, TEMAC_MC,
- /* Promiscuous mode disable */
- xps_ll_temac_indirect_set(dev, TEMAC_AFM, 0);
- /* Enable Receiver - RX bit */
- xps_ll_temac_indirect_set(dev, TEMAC_RCW1, RCW1_RX);
- /* Enable Transmitter - TX bit */
- xps_ll_temac_indirect_set(dev, TEMAC_TC, TC_TX);
- /* Disable Receiver */
- xps_ll_temac_indirect_set(dev, TEMAC_RCW0, 0);
- /* Disable Transmitter */
- xps_ll_temac_indirect_set(dev, TEMAC_TC, 0);
- if (ll_temac->ctrlhalt)
+#endif +}
- int i;
- xps_ll_temac_init(dev, bis);
- printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\n",
+#if DEBUG
- for (i = 0; i < 32; i++)
- if (!xps_ll_temac_phy_ctrl(dev)) {
ll_temac_halt(dev);
return -1;
- struct eth_device *dev = eth_get_dev();
- *value = xps_ll_temac_hostif_get(dev, addr, reg);
- debug("%s 0x%x, 0x%x, 0x%x\n", __func__, addr, reg, *value);
- debug("%s 0x%x, 0x%x, 0x%x\n", __func__, addr, reg, value);
- xps_ll_temac_hostif_set(dev, addr, reg, value);
- debug("Just bus reset\n");
- bis: board information
- base_addr: LL TEMAC register bank
- ctrl_addr: LL TEMAC sub-controller register bank (FIFO or SDMA)
- mode: driver mode bit flags (see xilinx_ll_temac.h)
- struct eth_device *dev;
- struct ll_temac *ll_temac;
- dev = calloc(1, sizeof(*dev));
- if (dev == NULL)
return -1;
- dev->priv = calloc(1, sizeof(struct ll_temac));
- if (dev->priv == NULL) {
free(dev);
return -1;
- ll_temac = dev->priv;
- sprintf(dev->name, "Xlltem.%lx", base_addr);
- dev->iobase = base_addr;
- ll_temac->ctrladdr = ctrl_addr;
- ll_temac->rx_bp = rx_buffer;
- ll_temac->tx_bp = tx_buffer;
- ll_temac->rx_dp = &rx_descr;
- ll_temac->tx_dp = &tx_descr;
- ll_temac->phyaddr = CONFIG_PHY_ADDR;
+#else
- ll_temac->phyaddr = -1;
Maybe move this at the begining
#ifndef CONFIG_PHY_ADDR #define CONFIG_PHY_ADDR -1 #endif
- dev->init = ll_temac_init;
- dev->halt = ll_temac_halt;
- dev->write_hwaddr = ll_temac_addr_setup;
- if (mode & M_SDMA) {
if (mode & M_DCR) {
} else
- } else {
- eth_register(dev);
- miiphy_register(dev->name, ll_temac_miiphy_read, ll_temac_miiphy_write);
- ll_temac->bus = miiphy_get_dev_by_name(dev->name);
- ll_temac->bus->reset = ll_temac_bus_reset;
- return 1;
- private interface
+struct ll_temac {
- int ctrladdr;
- void (*ctrlinit) (struct eth_device*);
- int (*ctrlhalt) (struct eth_device*);
- int (*ctrlreset) (struct eth_device*);
- unsigned char *rx_bp;
- unsigned char *tx_bp;
- struct cdmac_bd *rx_dp;
- struct cdmac_bd *tx_dp;
- int phyaddr;
- struct mii_dev *bus;
- Driver mode bit flags
- FIXME: this should going up to include -- but where?
One newline
- TEMAC Memory and Register Definition
emac.pdf + * page 19, Memory and Register Descriptions
+struct temac_reg {
- /* direct soft registers (low part) */
- u32 raf; /* Reset and Address Filter */
- u32 tpf; /* Transmit Pause Frame */
- u32 ifgp; /* Transmit Inter Frame Gap Adjustment */
- u32 is; /* Interrupt Status */
- u32 ip; /* Interrupt Pending */
- u32 ie; /* Interrupt Enable */
- u32 ttag; /* Transmit VLAN Tag */
- u32 rtag; /* Receive VLAN Tag */
- /* hard TEMAC registers */
- u32 msw; /* Most Significant Word Data */
- u32 lsw; /* Least Significant Word Data */
- u32 ctl; /* Control */
- u32 rdy; /* Ready Status */
- /* direct soft registers (high part) */
- u32 uawl; /* Unicast Address Word Lower */
- u32 uawu; /* Unicast Address Word Upper */
- u32 tpid0; /* VLAN TPID Word 0 */
- u32 tpid1; /* VLAN TPID Word 1 */
- TEMAC Indirectly Addressable Register Index Enumeration
emac.pdf + * page 23, PLB Indirectly Addressable TEMAC Registers
+enum temac_ctrl {
- TEMAC_RCW0 = 0x200,
- TEMAC_RCW1 = 0x240,
- TEMAC_TC = 0x280,
- TEMAC_FCC = 0x2C0,
- TEMAC_EMMC = 0x300,
- TEMAC_PHYC = 0x320,
- TEMAC_MC = 0x340,
- TEMAC_UAW0 = 0x380,
- TEMAC_UAW1 = 0x384,
- TEMAC_MAW0 = 0x388,
- TEMAC_MAW1 = 0x38C,
- TEMAC_AFM = 0x390,
- TEMAC_TIS = 0x3A0,
- TEMAC_TIE = 0x3A4,
- TEMAC_MIIMWD = 0x3B0,
- TEMAC_MIIMAI = 0x3B4
- fMDC = ------------------- ---------> MC_CLKDIV = -------- - 1
- FIFO interface
- struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr;
- printf("FIFO: %d isr 0x%08x, ier 0x%08x, rdfr 0x%08x, "
+} +#endif
- out_be32(&fifo_ctrl->tdfr, LL_FIFO_TDFR_KEY);
- out_be32(&fifo_ctrl->rdfr, LL_FIFO_RDFR_KEY);
- out_be32(&fifo_ctrl->isr, ~0UL);
- out_be32(&fifo_ctrl->ier, 0);
- u32 i, len = 0;
- u32 *buf = (u32 *)&(ll_temac->rx_bp);
- if (in_be32(&fifo_ctrl->isr) & LL_FIFO_ISR_RC) {
+#ifdef DEBUG
debugll(dev, 1);
Do you need those parenthesis ?
- return len;
- u32 *buf = (u32 *)buffer;
- u32 i;
- for (i = 0; i < length; i += 4)
- out_be32(&fifo_ctrl->tlf, length);
- FIFO interface
- FIFO Register Definition
- Used for memory mapped access from and to (Rd/Td) the LocalLink (LL)
- [1]:
http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_fifo.p df + * page 10, Registers Definition
+struct fifo_ctrl {
- u32 isr; /* Interrupt Status Register (RW) */
- u32 ier; /* Interrupt Enable Register (RW) */
- u32 tdfr; /* Transmit Data FIFO Reset (WO) */
- u32 tdfv; /* Transmit Data FIFO Vacancy (RO) */
- u32 tdfd; /* Transmit Data FIFO 32bit wide Data write port (WO) */
- u32 tlf; /* Transmit Length FIFO (WO) */
- u32 rdfr; /* Receive Data FIFO Reset (WO) */
- u32 rdfo; /* Receive Data FIFO Occupancy (RO) */
- u32 rdfd; /* Receive Data FIFO 32bit wide Data read port (RO) */
- u32 rlf; /* Receive Length FIFO (RO) */
- u32 llr; /* LocalLink Reset (WO) */
Drop parenthesis around (0), please fix globally
Here too
- SDMA interface
- Indirect DCR access operations mi{ft}dcr_xilinx() espacialy
- for Xilinx PowerPC implementations on FPGA.
- FIXME: This part should going up to arch/powerpc -- but where?
- mtdcr(XILINX_INDIRECT_DCR_ADDRESS_REG, dcrn);
- return mfdcr(XILINX_INDIRECT_DCR_ACCESS_REG);
- mtdcr(XILINX_INDIRECT_DCR_ACCESS_REG, val);
+} +#endif
- int err;
- struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr;
- err = in_be32(&sdma_ctrl->tx_chnl_sts) & CHNL_STS_ERROR;
- err |= in_be32(&sdma_ctrl->rx_chnl_sts) & CHNL_STS_ERROR;
- return err;
- struct cdmac_bd *rx_dp = ll_temac->rx_dp;
- struct cdmac_bd *tx_dp = ll_temac->tx_dp;
- memset(tx_dp, 0, sizeof(*tx_dp));
- memset(rx_dp, 0, sizeof(*rx_dp));
- /* from LL TEMAC (Rx) */
- rx_dp->phys_buf_p = ll_temac->rx_bp;
- rx_dp->next_p = rx_dp;
- rx_dp->buf_len = PKTSIZE_ALIGN;
- flush_cache((u32)rx_dp, sizeof(*tx_dp));
- flush_cache((u32)rx_dp->phys_buf_p, PKTSIZE_ALIGN);
- out_be32(&sdma_ctrl->rx_curdesc_ptr, (u32)rx_dp);
- out_be32(&sdma_ctrl->rx_taildesc_ptr, (u32)rx_dp);
- out_be32(&sdma_ctrl->rx_nxtdesc_ptr, (u32)rx_dp); /* setup first fd */
- /* to LL TEMAC (Tx) */
- tx_dp->phys_buf_p = ll_temac->tx_bp;
- tx_dp->next_p = tx_dp;
- flush_cache((u32)tx_dp, sizeof(*tx_dp));
- out_be32(&sdma_ctrl->tx_curdesc_ptr, (u32)tx_dp);
- u32 timeout = 2000;
- out_be32(&sdma_ctrl->dma_control_reg, DMA_CONTROL_RESET);
- while (timeout && (in_be32(&sdma_ctrl->dma_control_reg)
timeout--;
- if (!timeout) {
return 1;
- u32 r;
- /* Soft reset the DMA. */
- if (ll_temac_halt_sdma(dev))
return 1;
- /* Now clear the interrupts. */
- r = in_be32(&sdma_ctrl->tx_chnl_ctrl);
- r &= ~CHNL_CTRL_IRQ_MASK;
- out_be32(&sdma_ctrl->tx_chnl_ctrl, r);
- r = in_be32(&sdma_ctrl->rx_chnl_ctrl);
- out_be32(&sdma_ctrl->rx_chnl_ctrl, r);
- /* Now ACK pending IRQs. */
- out_be32(&sdma_ctrl->tx_irq_reg, IRQ_REG_IRQ_MASK);
- out_be32(&sdma_ctrl->rx_irq_reg, IRQ_REG_IRQ_MASK);
- /* Set tail-ptr mode, disable errors for both channels. */
DMA_CONTROL_TPE |
overflows */
overflows */
- int length;
- if (ll_temac_dma_error(dev)) {
return -1;
- flush_cache((u32)rx_dp, sizeof(*rx_dp));
- if (!(rx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED))
* packets.
- length = rx_dp->sca.app[4] & CDMAC_BD_APP4_RXBYTECNT_MASK;
- if (length > 0)
- /* flip the buffer and re-enable the DMA. */
- flush_cache((u32)rx_dp->phys_buf_p, length);
- rx_dp->sca.stctrl = 0;
- rx_dp->sca.app[4] = 0;
- return length;
return -1;
- memcpy(ll_temac->tx_bp, (void *)buffer, length);
- flush_cache((u32)ll_temac->tx_bp, length);
- tx_dp->sca.stctrl = CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP |
- tx_dp->buf_len = length;
- out_be32(&sdma_ctrl->tx_taildesc_ptr, (u32)tx_dp); /* DMA start */
- do {
- } while (!(tx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED));
- int err;
- unsigned dmac_ctrl = ll_temac->ctrladdr;
- err = mifdcr_xilinx(dmac_ctrl + TX_CHNL_STS) & CHNL_STS_ERROR;
- err |= mifdcr_xilinx(dmac_ctrl + RX_CHNL_STS) & CHNL_STS_ERROR;
- return err;
- mitdcr_xilinx(dmac_ctrl + RX_CURDESC_PTR, (u32)rx_dp);
- mitdcr_xilinx(dmac_ctrl + RX_TAILDESC_PTR, (u32)rx_dp);
- mitdcr_xilinx(dmac_ctrl + RX_NXTDESC_PTR, (u32)rx_dp); /* setup first fd
- mitdcr_xilinx(dmac_ctrl + TX_CURDESC_PTR, (u32)rx_dp);
- mitdcr_xilinx(dmac_ctrl + DMA_CONTROL_REG, DMA_CONTROL_RESET);
- while (timeout && (mifdcr_xilinx(dmac_ctrl + DMA_CONTROL_REG)
timeout--;
- if (!timeout) {
return 1;
- u32 r;
- if (ll_temac_halt_dmac(dev))
return 1;
- r = mifdcr_xilinx(dmac_ctrl + TX_CHNL_CTRL);
- mitdcr_xilinx(dmac_ctrl + TX_CHNL_CTRL, r);
- r = mifdcr_xilinx(dmac_ctrl + RX_CHNL_CTRL);
- mitdcr_xilinx(dmac_ctrl + RX_CHNL_CTRL, r);
- mitdcr_xilinx(dmac_ctrl + TX_IRQ_REG, IRQ_REG_IRQ_MASK);
- mitdcr_xilinx(dmac_ctrl + RX_IRQ_REG, IRQ_REG_IRQ_MASK);
DMA_CONTROL_TPE |
overflows */
overflows */
- int length;
- if (ll_temac_dmac_error(dev)) {
return -1;
- if (!(rx_dp.sca.stctrl & CDMAC_BD_STCTRL_COMPLETED))
* packets.
- if (length > 0)
- return length;
return -1;
- mitdcr_xilinx(dmac_ctrl + TX_CURDESC_PTR, (u32)tx_dp);
- mitdcr_xilinx(dmac_ctrl + TX_TAILDESC_PTR, (u32)tx_dp); /* DMA start */
- do {
Maybe make functions used only in local scope static ?
- SDMA interface
- DMA Buffer Descriptor for CDMAC
- Used for data connection from and to (Rx/Tx) the LocalLink (LL) TEMAC
- overview:
- [1]:
- [2]:
- page 229, DMA Controller -- Descriptor Format
emac.pdf + * page 72, Transmit LocalLink Frame Format
- page 73, Receive LocalLink Frame Format
+struct cdmac_bd {
- struct cdmac_bd *next_p; /* Next Descriptor Pointer */
- u8 *phys_buf_p; /* Buffer Address */
- u32 buf_len; /* Buffer Length */
- union {
- } __attribute__ ((packed, aligned(1))) sca;
- SDMA Register Definition
- page 54, SDMA Register Summary
- page 160, SDMA Registers
- [2]:
- page 244, DMA Controller -- Programming Interface and Registers
+struct sdma_ctrl {
- /* Transmit Registers */
- u32 tx_nxtdesc_ptr; /* TX Next Description Pointer */
- u32 tx_curbuf_addr; /* TX Current Buffer Address */
- u32 tx_curbuf_length; /* TX Current Buffer Length */
- u32 tx_curdesc_ptr; /* TX Current Descriptor Pointer */
- u32 tx_taildesc_ptr; /* TX Tail Descriptor Pointer */
- u32 tx_chnl_ctrl; /* TX Channel Control */
- u32 tx_irq_reg; /* TX Interrupt Register */
- u32 tx_chnl_sts; /* TX Status Register */
- /* Receive Registers */
- u32 rx_nxtdesc_ptr; /* RX Next Descriptor Pointer */
- u32 rx_curbuf_addr; /* RX Current Buffer Address */
- u32 rx_curbuf_length; /* RX Current Buffer Length */
- u32 rx_curdesc_ptr; /* RX Current Descriptor Pointer */
- u32 rx_taildesc_ptr; /* RX Tail Descriptor Pointer */
- u32 rx_chnl_ctrl; /* RX Channel Control */
- u32 rx_irq_reg; /* RX Interrupt Register */
- u32 rx_chnl_sts; /* RX Status Register */
- /* Control Registers */
- u32 dma_control_reg; /* DMA Control Register */
CHNL_CTRL_IEE | \
CHNL_CTRL_IDE | \
CHNL_CTRL_ICE)
- DMAC Register Index Enumeration
- [2]:
+enum dmac_ctrl {
- TX_NXTDESC_PTR = 0,
- TX_CURBUF_ADDR,
- TX_CURBUF_LENGTH,
- TX_CURDESC_PTR,
- TX_TAILDESC_PTR,
- TX_CHNL_CTRL,
- TX_IRQ_REG,
- TX_CHNL_STS,
- RX_NXTDESC_PTR,
- RX_CURBUF_ADDR,
- RX_CURBUF_LENGTH,
- RX_CURDESC_PTR,
- RX_TAILDESC_PTR,
- RX_CHNL_CTRL,
- RX_IRQ_REG,
- RX_CHNL_STS,
- DMA_CONTROL_REG
M
Am Sonntag, den 27.11.2011, 12:09 +0100 schrieb Marek Vasut:
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used.
The driver uses and requires MII and PHYLIB.
Signed-off-by: Stephan Linz linz@li-pro.net
v4: Separate fifo and sdma code from driver core Split sdma code into separate DCR and XPS bus access code Add extensive register struct definitions and enumerations Add new callbacks into fifo an sdma code Prepare CDMAC buffer handling to be unique for every instance Separate Xilinx specific indirect DCR access, so we can move to arch Remove useless 'emac' parameter from indirect access helper functions Correct MDIO clock setup. Remove endless loops Common code beautifying
v3: Use helper functions for fifo mode Use helper functions for indirect accesses Code cleanup Add comments for MAGIC values Simplify code in fifo mode
v2: Remove helper function for access to temac Remove SDMA/FIFO/DCR macros and configure it in board Setup mac by write_hwaddr
drivers/net/Makefile | 2 + drivers/net/xilinx_ll_temac.c | 399 ++++++++++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac.h | 305 ++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac_fifo.c | 93 ++++++++ drivers/net/xilinx_ll_temac_fifo.h | 112 ++++++++++ drivers/net/xilinx_ll_temac_sdma.c | 413 ++++++++++++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac_sdma.h | 280 ++++++++++++++++++++++++ include/netdev.h | 2 + 8 files changed, 1606 insertions(+), 0 deletions(-) create mode 100644 drivers/net/xilinx_ll_temac.c create mode 100644 drivers/net/xilinx_ll_temac.h create mode 100644 drivers/net/xilinx_ll_temac_fifo.c create mode 100644 drivers/net/xilinx_ll_temac_fifo.h create mode 100644 drivers/net/xilinx_ll_temac_sdma.c create mode 100644 drivers/net/xilinx_ll_temac_sdma.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d3df82e..14d71a7 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -76,6 +76,8 @@ COBJS-$(CONFIG_ULI526X) += uli526x.o COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o COBJS-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +COBJS-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o \
xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c new file mode 100644 index 0000000..39f3a8b --- /dev/null +++ b/drivers/net/xilinx_ll_temac.c @@ -0,0 +1,399 @@ +/*
+#include <config.h> +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <asm/io.h> +#include <phy.h> +#include <miiphy.h>
+#undef ETH_HALTING
+#if !defined(CONFIG_MII) || !defined(CONFIG_CMD_MII) +# error "LL_TEMAC requires MII -- CONFIG_MII has to be defined!" +#endif
It follows the recommendations from doc/README.drivers.eth about line 175 - 185:
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, mii_read, mii_write); #endif
... only that I previously exclude the condition to an error. I've fixed the error string.
+#if !defined(CONFIG_PHYLIB) +# error "LL_TEMAC requires PHYLIB -- CONFIG_PHYLIB has to be defined!" +#endif
a + * safe default that should work with PLB bus speeds of up to 150 MHz and keep + * the MDIO clock below 2.5 MHz. If the user wishes faster access to the PHY + * then the clock divisor can be set to a different value by setting the + * correct bus speed value with CONFIG_XILINX_LL_TEMAC_CLK.
+#if !defined(CONFIG_XILINX_LL_TEMAC_CLK) +#define MDIO_CLOCK_DIV MC_CLKDIV_10(150000000) +#else +#define MDIO_CLOCK_DIV MC_CLKDIV_25(CONFIG_XILINX_LL_TEMAC_CLK) +#endif
One newline
fixed.
+/* Data buffer for LL TEMAC Rx and Tx direction */ +static unsigned char rx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); +static unsigned char tx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); +
+/* CDMAC buffer descriptor for LL TEMAC Rx and Tx buffer handling */ +static struct cdmac_bd rx_descr __attribute((aligned(DMAALIGN))); +static struct cdmac_bd tx_descr __attribute((aligned(DMAALIGN)));
Currently no. We need a proper DMA buffer allocation for Microblaze. If we have that, than we can move the DMA buffer and descriptor allocation into the init function.
But you are right. The current situation makes me not happy too. We can use the driver code never in parallel actions. Multiple Ethernet instances would share this global Rx/Tx buffers / structs. That is bad.
I will change this as fas as possible. As already said, we need a proper DMA buffer allocation ...
+static inline void xps_ll_temac_check_status(struct temac_reg *regs, u32 mask) +{
Magic timeout ?
We need to avoid endless loops, see below. Unfortunately the Xilinx documentation say we have to poll but not how long. So we try out as long as my gut feeling would think.
timeout--;
- if (!timeout)
+static void xps_ll_temac_hostif_set(struct eth_device *dev, u8 phy_addr,
u8 reg_addr, u16 phy_data)
- out_be32(®s->lsw,
((phy_addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) |
(reg_addr & LSW_REGAD_MASK));
+static u16 xps_ll_temac_hostif_get(struct eth_device *dev, u8 phy_addr,
u8 reg_addr)
- out_be32(®s->lsw,
u32 reg_data)
+#ifdef DEBUG +static inline void read_phy_reg(struct eth_device *dev, u8 phy_addr) +{
- int j, result;
result = xps_ll_temac_hostif_get(dev, phy_addr, j);
debug("%d: 0x%x ", j, result);
- debug("\n");
+} +#endif
+/* setting ll_temac and phy to proper setting */ +static int xps_ll_temac_phy_ctrl(struct eth_device *dev) +{
- int i;
SUPPORTED_10baseT_Full |
SUPPORTED_100baseT_Half |
SUPPORTED_100baseT_Full |
SUPPORTED_1000baseT_Half |
SUPPORTED_1000baseT_Full;
for (i = 31; i >= 0; i--) {
temp = xps_ll_temac_hostif_get(dev, i, 1);
if ((temp & 0x0ffff) != 0x0ffff) {
debug("phy %x result %x\n", i, temp);
ll_temac->phyaddr = i;
break;
- case 1000:
speed = EMMC_LSPD_1000;
break;
- case 100:
speed = EMMC_LSPD_100;
break;
- case 10:
speed = EMMC_LSPD_10;
break;
- default:
- temp |= speed;
- return 1;
+/* setup mac addr */ +static int ll_temac_addr_setup(struct eth_device *dev) +{
- u32 val;
(dev->enetaddr[1] << 8) | (dev->enetaddr[0]));
+static int xps_ll_temac_init(struct eth_device *dev, bd_t *bis) +{
if (ll_temac->ctrlreset(dev))
return -1;
ll_temac->ctrlinit(dev);
MC_MDIOEN | (MDIO_CLOCK_DIV & MC_CLKDIV_MASK));
+/* halt device */ +static void ll_temac_halt(struct eth_device *dev) +{ +#ifdef ETH_HALTING
ll_temac->ctrlhalt(dev);
+#endif +}
+static int ll_temac_init(struct eth_device *dev, bd_t *bis) +{ +#if DEBUG
- int i;
dev->name, 0, dev->iobase);
+#if DEBUG
read_phy_reg(dev, i);
ll_temac_halt(dev);
return -1;
+static int ll_temac_miiphy_read(const char *devname, unsigned char addr,
unsigned char reg, unsigned short *value)
+static int ll_temac_miiphy_write(const char *devname, unsigned char addr,
unsigned char reg, unsigned short value)
+static int ll_temac_bus_reset(struct mii_dev *bus) +{
int mode, unsigned long ctrl_addr)
- if (dev == NULL)
return -1;
free(dev);
return -1;
+#ifdef CONFIG_PHY_ADDR
+#else
yep
fixed.
if (mode & M_DCR) {
ll_temac->ctrlinit = ll_temac_init_dmac;
ll_temac->ctrlhalt = ll_temac_halt_dmac;
ll_temac->ctrlreset = ll_temac_reset_dmac;
dev->recv = ll_temac_recv_dmac;
dev->send = ll_temac_send_dmac;
} else
ll_temac->ctrlinit = ll_temac_init_sdma;
ll_temac->ctrlhalt = ll_temac_halt_sdma;
ll_temac->ctrlreset = ll_temac_reset_sdma;
dev->recv = ll_temac_recv_sdma;
dev->send = ll_temac_send_sdma;
- } else {
ll_temac->ctrlinit = NULL;
ll_temac->ctrlhalt = NULL;
ll_temac->ctrlreset = ll_temac_reset_fifo;
dev->recv = ll_temac_recv_fifo;
dev->send = ll_temac_send_fifo;
- return 1;
+} diff --git a/drivers/net/xilinx_ll_temac.h b/drivers/net/xilinx_ll_temac.h new file mode 100644 index 0000000..03dbb29 --- /dev/null +++ b/drivers/net/xilinx_ll_temac.h @@ -0,0 +1,305 @@ +/*
- private interface
+#ifndef _XILINX_LL_TEMAC_ +#define _XILINX_LL_TEMAC_
+#include <net.h> +#include <phy.h> +#include <miiphy.h> +#include <asm/byteorder.h>
+#include "xilinx_ll_temac_fifo.h" +#include "xilinx_ll_temac_sdma.h"
+struct ll_temac {
- int ctrladdr;
- int phyaddr;
+#define M_FIFO (0) /* use FIFO Ctrl */ +#define M_SDMA (1 << 0) /* use SDMA Ctrl */ +#define M_DCR (1 << 1) /* use DCR Bus */
One newline
fixed.
+struct temac_reg {
+enum temac_ctrl {
- TEMAC_TC = 0x280,
- TEMAC_MC = 0x340,
- FIFO interface
+} +#endif
- u32 i, len = 0;
+#ifdef DEBUG
debugll(dev, 1);
hm, not really, but I wanted to be strict -- fixed to: (uchar *)&ll_temac->rx_bp
- return len;
- u32 i;
- FIFO interface
- [1]:
+struct fifo_ctrl {
ok, fixed on all positions ...
Here too
dito
- SDMA interface
+} +#endif
- int err;
- return err;
timeout--;
- if (!timeout) {
return 1;
- u32 r;
return 1;
DMA_CONTROL_TPE |
overflows */
overflows */
- int length;
return -1;
* packets.
- if (length > 0)
- return length;
return -1;
- do {
Oops, forget timeout protection -- fixed.
- int err;
- return err;
timeout--;
- if (!timeout) {
return 1;
- u32 r;
return 1;
DMA_CONTROL_TPE |
overflows */
overflows */
- int length;
return -1;
* packets.
- if (length > 0)
- return length;
return -1;
- do {
That's so for ll_temac_dma_error() and ll_temac_dmac_error().
All other funcrions will be called from core driver code: ll_temac_init_*(), ll_temac_halt_*(), ll_temac_reset_*(), ll_temac_recv_*(), ll_temac_send_*().
- SDMA interface
- overview:
- [1]:
- [2]:
+struct cdmac_bd {
- union {
- [2]:
+struct sdma_ctrl {
CHNL_CTRL_IEE | \
CHNL_CTRL_IDE | \
CHNL_CTRL_ICE)
- [2]:
+enum dmac_ctrl {
- TX_CURBUF_ADDR,
- TX_CURBUF_LENGTH,
- TX_CURDESC_PTR,
- TX_TAILDESC_PTR,
- TX_CHNL_CTRL,
- TX_IRQ_REG,
- TX_CHNL_STS,
- RX_NXTDESC_PTR,
- RX_CURBUF_ADDR,
- RX_CURBUF_LENGTH,
- RX_CURDESC_PTR,
- RX_TAILDESC_PTR,
- RX_CHNL_CTRL,
- RX_IRQ_REG,
- RX_CHNL_STS,
- DMA_CONTROL_REG
M _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Stephan Linz,
Please run this through checkpatch, then fix all the issues, then resubmit. Thanks.
Am Sonntag, den 27.11.2011, 11:22 +0100 schrieb Stephan Linz:
Back to the discussion from August I have refactored the LL TEMAC driver. Just in version V4 it is ready to next review.
Note: To use the driver on Microblaze, you will need additional platform patches by Michal Simek:
- http://patchwork.ozlabs.org/patch/112535/
- http://patchwork.ozlabs.org/patch/112534/
- http://patchwork.ozlabs.org/patch/112532/
I will collect all related patches on a public bundle:
Oops: http://patchwork.ozlabs.org/bundle/rexut/net-ll_temac/
br, Stephan Linz _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Stephan Linz
