[U-Boot] [PATCH] arm: mvebu: theadorable: Add test for ctrl-c in PCIe PEX switch test
The check for the missing PEX switch can lead to an infinite loop, when the PCIe device is not found. It is helpful to enable the user to break out of this boot-loop, to enable booting to the prompt for test cases. This patch adds a 3 second delay in the error case before rebooting. The user can press Ctrl-C in this time to abort the boot-loop.
This patch also calls bootcount_inc() before rebooting in the error case. This is needed to increment the bootcounter, since this function is called earlier than the main bootcounter increment. Otherwise the bootcounter will not be incremented in the error case at all.
Signed-off-by: Stefan Roese sr@denx.de --- board/theadorable/theadorable.c | 32 ++++++++++++++++++++++++++++++-- 1 file changed, 30 insertions(+), 2 deletions(-)
diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 1169d67746..9e7623837b 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -1,11 +1,15 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2015-2016 Stefan Roese sr@denx.de + * Copyright (C) 2015-2019 Stefan Roese sr@denx.de */
#include <common.h> +#include <console.h> #include <i2c.h> #include <pci.h> +#if !defined(CONFIG_SPL_BUILD) +#include <bootcount.h> +#endif #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/cpu.h> @@ -42,6 +46,7 @@ DECLARE_GLOBAL_DATA_PTR; #define STM_I2C_BUS 1 #define STM_I2C_ADDR 0x27 #define REBOOT_DELAY 1000 /* reboot-delay in ms */ +#define ABORT_TIMEOUT 3000 /* 3 seconds reboot abort timeout */
/* DDR3 static configuration */ static MV_DRAM_MC_INIT ddr3_theadorable[MV_MAX_DDR3_STATIC_SIZE] = { @@ -238,7 +243,7 @@ int board_video_init(void) return mvebu_lcd_register_init(&lcd_info); }
-#ifdef CONFIG_BOARD_LATE_INIT +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_BOARD_LATE_INIT) int board_late_init(void) { pci_dev_t bdf; @@ -252,6 +257,7 @@ int board_late_init(void) */ bdf = pci_find_device(PCI_VENDOR_ID_PLX, 0x8619, 0); if (bdf == -1) { + unsigned long start_time = get_timer(0); u8 i2c_buf[8]; int ret;
@@ -259,6 +265,28 @@ int board_late_init(void) bootcount = bootcount_load(); printf("Failed to find PLX PEX-switch (bootcount=%ld)\n", bootcount); + + /* + * The user can exit this boot-loop in the error case by + * hitting Ctrl-C. So wait some time for this key here. + */ + printf("Continue booting with Ctrl-C, otherwise rebooting\n"); + do { + /* Handle control-c and timeouts */ + if (ctrlc()) { + printf("PEX error boot-loop aborted!\n"); + return 0; + } + } while (get_timer(start_time) < ABORT_TIMEOUT); + + + /* + * At this stage the bootcounter has not been incremented + * yet. We need to do this manually here to get an actually + * working bootcounter in this error case. + */ + bootcount_inc(); + if (bootcount > PEX_SWITCH_NOT_FOUNT_LIMIT) { printf("Issuing power-switch via uC!\n");
Stefan Roese
