[U-Boot] [PATCH v5 0/9] rockchip: Add gmac Ethernet support
From Simon:
This v3 patch is an update on Sjoerd's original v2 series from Feburary. I have dealt with the changes requested at the time, and adjusted the way that the speed change is handled.
Tested on firefly-rk3288, rock2.
Original cover letter: To add support I've taken a slightly different approach then some of the other boards with a designware IP block, by creating a new driver to take care of the platfrom glue which subclasses the main designware driver instead of adding the compatibility string the designware driver directly and doing the SoC specific setup in the board files. This seems quite a bit more elegant in a device model based world.
I've only tested this series on a Radxa Rock 2 board, it would be great if someone could test this on other boards with the designware IP especially for those with the reset GPIO in devicetree (e.g. some of the Allwinner boards).
Compared to the first one round the pinctrl related bits were dropped as RK3288 now has a full pinctrl driver. Furthermore the started hook in the designware driver was renamed to fix_mac_speed in line with what linux uses and moved to the dw_link_adjust function.
Changes in v5: - Changed the commit message for gmac - Added my Acked-by to few commits
Changes in v4: - Fix commit message to say 'rk3399'
Changes in v3: - Add a few new patches - Add comments for struct gmac_rk3288_platdata - Add new patch to adjust dw_adjust_link() to return an error - Add new patch to enable networking on evb-rk3399 - Add new patch to export the operation functions - Add new patch to split the link init into a separate function - Adjust binding to use r/tx-delay instead of r/tx_delay - Drop the 'net: designware: Add a fix_mac_speed hook' patch - Sort includes - Use debug() instead of printf() for error - Use function calls instead of fix_mac_speed() hook - Use new clk interface
Changes in v2: - Adjust to new hook name - Fix various coding style nits
Simon Glass (4): net: designware: Adjust dw_adjust_link() to return an error net: designware: Split the link init into a separate function net: designware: Export the operation functions rockchip: evb-rk3339: Enable DHCP
Sjoerd Simons (5): net: designware: Export various functions/struct to allow subclassing net: gmac_rockchip: Add Rockchip GMAC driver rockchip: Enable networking support on rock2 and firefly rockchip: Add PXE and DHCP to the default boot targets rockchip: Drop Ethernet from the TODO
configs/evb-rk3399_defconfig | 3 + configs/firefly-rk3288_defconfig | 4 + configs/rock2_defconfig | 4 + doc/README.rockchip | 1 - drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/designware.c | 57 ++++++++++---- drivers/net/designware.h | 13 ++++ drivers/net/gmac_rockchip.c | 154 ++++++++++++++++++++++++++++++++++++++ include/configs/rockchip-common.h | 4 +- 10 files changed, 230 insertions(+), 18 deletions(-) create mode 100644 drivers/net/gmac_rockchip.c
To allow other DM drivers to subclass the designware driver various functions and structures need to be exported. Export these.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Acked-by: Romain Perier romain.perier@collabora.com ---
Changes in v5: - Added Acked-by for Romain
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/net/designware.c | 6 +++--- drivers/net/designware.h | 4 ++++ 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 9e6d726184..6ef36bc8cb 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -628,7 +628,7 @@ static int designware_eth_bind(struct udevice *dev) return 0; }
-static int designware_eth_probe(struct udevice *dev) +int designware_eth_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct dw_eth_dev *priv = dev_get_priv(dev); @@ -678,7 +678,7 @@ static int designware_eth_remove(struct udevice *dev) return 0; }
-static const struct eth_ops designware_eth_ops = { +const struct eth_ops designware_eth_ops = { .start = designware_eth_start, .send = designware_eth_send, .recv = designware_eth_recv, @@ -687,7 +687,7 @@ static const struct eth_ops designware_eth_ops = { .write_hwaddr = designware_eth_write_hwaddr, };
-static int designware_eth_ofdata_to_platdata(struct udevice *dev) +int designware_eth_ofdata_to_platdata(struct udevice *dev) { struct dw_eth_pdata *dw_pdata = dev_get_platdata(dev); #ifdef CONFIG_DM_GPIO diff --git a/drivers/net/designware.h b/drivers/net/designware.h index d345c5b0c3..087ebef297 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -245,6 +245,10 @@ struct dw_eth_dev { };
#ifdef CONFIG_DM_ETH +int designware_eth_ofdata_to_platdata(struct udevice *dev); +int designware_eth_probe(struct udevice *dev); +extern const struct eth_ops designware_eth_ops; + struct dw_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3];
This function can fail, so return the error if there is one.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Acked-by: Romain Perier romain.perier@collabora.com ---
Changes in v5: - Add Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to adjust dw_adjust_link() to return an error
Changes in v2: None
drivers/net/designware.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 6ef36bc8cb..ebcef8beaa 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -230,14 +230,14 @@ static int _dw_write_hwaddr(struct dw_eth_dev *priv, u8 *mac_id) return 0; }
-static void dw_adjust_link(struct eth_mac_regs *mac_p, - struct phy_device *phydev) +static int dw_adjust_link(struct dw_eth_dev *priv, struct eth_mac_regs *mac_p, + struct phy_device *phydev) { u32 conf = readl(&mac_p->conf) | FRAMEBURSTENABLE | DISABLERXOWN;
if (!phydev->link) { printf("%s: No link.\n", phydev->dev->name); - return; + return 0; }
if (phydev->speed != 1000) @@ -256,6 +256,8 @@ static void dw_adjust_link(struct eth_mac_regs *mac_p, printf("Speed: %d, %s duplex%s\n", phydev->speed, (phydev->duplex) ? "full" : "half", (phydev->port == PORT_FIBRE) ? ", fiber mode" : ""); + + return 0; }
static void _dw_eth_halt(struct dw_eth_dev *priv) @@ -321,7 +323,9 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) return ret; }
- dw_adjust_link(mac_p, priv->phydev); + ret = dw_adjust_link(priv, mac_p, priv->phydev); + if (ret) + return ret;
if (!priv->phydev->link) return -EIO;
With rockchip we need to make adjustments after the link speed is set but before enabling received/transmit. In preparation for this, split these two pieces into separate functions.
Changes in v5: - Added Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to split the link init into a separate function
Changes in v2: None
drivers/net/designware.c | 26 ++++++++++++++++++++++++-- 1 file changed, 24 insertions(+), 2 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index ebcef8beaa..0c596a7aea 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -327,6 +327,13 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) if (ret) return ret;
+ return 0; +} + +static int designware_eth_enable(struct dw_eth_dev *priv) +{ + struct eth_mac_regs *mac_p = priv->mac_regs_p; + if (!priv->phydev->link) return -EIO;
@@ -484,7 +491,13 @@ static int dw_phy_init(struct dw_eth_dev *priv, void *dev) #ifndef CONFIG_DM_ETH static int dw_eth_init(struct eth_device *dev, bd_t *bis) { - return _dw_eth_init(dev->priv, dev->enetaddr); + int ret; + + ret = _dw_eth_init(dev->priv, dev->enetaddr); + if (!ret) + ret = designware_eth_enable(dev->priv); + + return ret; }
static int dw_eth_send(struct eth_device *dev, void *packet, int length) @@ -575,8 +588,17 @@ int designware_initialize(ulong base_addr, u32 interface) static int designware_eth_start(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); + struct dw_eth_dev *priv = dev_get_priv(dev); + int ret;
- return _dw_eth_init(dev->priv, pdata->enetaddr); + ret = _dw_eth_init(priv, pdata->enetaddr); + if (ret) + return ret; + ret = designware_eth_enable(priv); + if (ret) + return ret; + + return 0; }
static int designware_eth_send(struct udevice *dev, void *packet, int length)
Export all functions so that drivers can use them, or not, as the need arises.
Changes in v5: - Add Acked-by for Romain Changes in v4: None Changes in v3: - Add new patch to export the operation functions
Changes in v2: None
drivers/net/designware.c | 19 +++++++++---------- drivers/net/designware.h | 9 +++++++++ 2 files changed, 18 insertions(+), 10 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 0c596a7aea..f242fc6b3f 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -271,7 +271,7 @@ static void _dw_eth_halt(struct dw_eth_dev *priv) phy_shutdown(priv->phydev); }
-static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) +int designware_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) { struct eth_mac_regs *mac_p = priv->mac_regs_p; struct eth_dma_regs *dma_p = priv->dma_regs_p; @@ -330,7 +330,7 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) return 0; }
-static int designware_eth_enable(struct dw_eth_dev *priv) +int designware_eth_enable(struct dw_eth_dev *priv) { struct eth_mac_regs *mac_p = priv->mac_regs_p;
@@ -493,7 +493,7 @@ static int dw_eth_init(struct eth_device *dev, bd_t *bis) { int ret;
- ret = _dw_eth_init(dev->priv, dev->enetaddr); + ret = designware_eth_init(dev->priv, dev->enetaddr); if (!ret) ret = designware_eth_enable(dev->priv);
@@ -591,7 +591,7 @@ static int designware_eth_start(struct udevice *dev) struct dw_eth_dev *priv = dev_get_priv(dev); int ret;
- ret = _dw_eth_init(priv, pdata->enetaddr); + ret = designware_eth_init(priv, pdata->enetaddr); if (ret) return ret; ret = designware_eth_enable(priv); @@ -601,36 +601,35 @@ static int designware_eth_start(struct udevice *dev) return 0; }
-static int designware_eth_send(struct udevice *dev, void *packet, int length) +int designware_eth_send(struct udevice *dev, void *packet, int length) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_send(priv, packet, length); }
-static int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp) +int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_recv(priv, packetp); }
-static int designware_eth_free_pkt(struct udevice *dev, uchar *packet, - int length) +int designware_eth_free_pkt(struct udevice *dev, uchar *packet, int length) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_free_pkt(priv); }
-static void designware_eth_stop(struct udevice *dev) +void designware_eth_stop(struct udevice *dev) { struct dw_eth_dev *priv = dev_get_priv(dev);
return _dw_eth_halt(priv); }
-static int designware_eth_write_hwaddr(struct udevice *dev) +int designware_eth_write_hwaddr(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct dw_eth_dev *priv = dev_get_priv(dev); diff --git a/drivers/net/designware.h b/drivers/net/designware.h index 087ebef297..7992d0ebee 100644 --- a/drivers/net/designware.h +++ b/drivers/net/designware.h @@ -253,6 +253,15 @@ struct dw_eth_pdata { struct eth_pdata eth_pdata; u32 reset_delays[3]; }; + +int designware_eth_init(struct dw_eth_dev *priv, u8 *enetaddr); +int designware_eth_enable(struct dw_eth_dev *priv); +int designware_eth_send(struct udevice *dev, void *packet, int length); +int designware_eth_recv(struct udevice *dev, int flags, uchar **packetp); +int designware_eth_free_pkt(struct udevice *dev, uchar *packet, + int length); +void designware_eth_stop(struct udevice *dev); +int designware_eth_write_hwaddr(struct udevice *dev); #endif
#endif
Add a new driver for the GMAC ethernet interface present in Rockchip RK3288 SOCs. This driver subclasses the generic design-ware driver to add the glue needed specifically for Rockchip.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Acked-by: Romain Perier romain.perier@collabora.com ---
Changes in v5: - Rename the driver to gmac_rockchip as suggested by David Wu - Rewrote commit message (gmac_rk3288 -> gmac_rockchip) - Added Acked-by for Romain
Changes in v4: None Changes in v3: - Add comments for struct gmac_rk3288_platdata - Adjust binding to use r/tx-delay instead of r/tx_delay - Sort includes - Use debug() instead of printf() for error - Use function calls instead of fix_mac_speed() hook - Use new clk interface
drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/gmac_rockchip.c | 154 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 162 insertions(+) create mode 100644 drivers/net/gmac_rockchip.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index f25d3ffa9b..53837ed90a 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -215,4 +215,11 @@ config PIC32_ETH This driver implements 10/100 Mbps Ethernet and MAC layer for Microchip PIC32 microcontrollers.
+config GMAC_ROCKCHIP + bool "Rockchip Synopsys Designware Ethernet MAC" + depends on DM_ETH && ETH_DESIGNWARE + help + This driver provides Rockchip SoCs network support based on the + Synopsys Designware driver. + endif # NETDEVICES diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 9a7bfc6d5b..2493a48b88 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -34,6 +34,7 @@ obj-$(CONFIG_FTGMAC100) += ftgmac100.o obj-$(CONFIG_FTMAC110) += ftmac110.o obj-$(CONFIG_FTMAC100) += ftmac100.o obj-$(CONFIG_GRETH) += greth.o +obj-$(CONFIG_GMAC_ROCKCHIP) += gmac_rockchip.o obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o obj-$(CONFIG_LAN91C96) += lan91c96.o diff --git a/drivers/net/gmac_rockchip.c b/drivers/net/gmac_rockchip.c new file mode 100644 index 0000000000..5f833fa711 --- /dev/null +++ b/drivers/net/gmac_rockchip.c @@ -0,0 +1,154 @@ +/* + * (C) Copyright 2015 Sjoerd Simons sjoerd.simons@collabora.co.uk + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Rockchip GMAC ethernet IP driver for U-Boot + */ + +#include <common.h> +#include <dm.h> +#include <clk.h> +#include <phy.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/periph.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk3288.h> +#include <dm/pinctrl.h> +#include <dt-bindings/clock/rk3288-cru.h> +#include "designware.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Platform data for the gmac + * + * dw_eth_pdata: Required platform data for designware driver (must be first) + */ +struct gmac_rockchip_platdata { + struct dw_eth_pdata dw_eth_pdata; + int tx_delay; + int rx_delay; +}; + +static int gmac_rockchip_ofdata_to_platdata(struct udevice *dev) +{ + struct gmac_rockchip_platdata *pdata = dev_get_platdata(dev); + + pdata->tx_delay = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "tx-delay", 0x30); + pdata->rx_delay = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "rx-delay", 0x10); + + return designware_eth_ofdata_to_platdata(dev); +} + +static int gmac_rockchip_fix_mac_speed(struct dw_eth_dev *priv) +{ + struct rk3288_grf *grf; + int clk; + + switch (priv->phydev->speed) { + case 10: + clk = GMAC_CLK_SEL_2_5M; + break; + case 100: + clk = GMAC_CLK_SEL_25M; + break; + case 1000: + clk = GMAC_CLK_SEL_125M; + break; + default: + debug("Unknown phy speed: %d\n", priv->phydev->speed); + return -EINVAL; + } + + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con1, + GMAC_CLK_SEL_MASK << GMAC_CLK_SEL_SHIFT, + clk << GMAC_CLK_SEL_SHIFT); + + return 0; +} + +static int gmac_rockchip_probe(struct udevice *dev) +{ + struct gmac_rockchip_platdata *pdata = dev_get_platdata(dev); + struct rk3288_grf *grf; + struct clk clk; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + /* Since mac_clk is fed by an external clock we can use 0 here */ + ret = clk_set_rate(&clk, 0); + if (ret) + return ret; + + /* Set to RGMII mode */ + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con1, + RMII_MODE_MASK << RMII_MODE_SHIFT | + GMAC_PHY_INTF_SEL_MASK << GMAC_PHY_INTF_SEL_SHIFT, + GMAC_PHY_INTF_SEL_RGMII << GMAC_PHY_INTF_SEL_SHIFT); + + rk_clrsetreg(&grf->soc_con3, + RXCLK_DLY_ENA_GMAC_MASK << RXCLK_DLY_ENA_GMAC_SHIFT | + TXCLK_DLY_ENA_GMAC_MASK << TXCLK_DLY_ENA_GMAC_SHIFT | + CLK_RX_DL_CFG_GMAC_MASK << CLK_RX_DL_CFG_GMAC_SHIFT | + CLK_TX_DL_CFG_GMAC_MASK << CLK_TX_DL_CFG_GMAC_SHIFT, + RXCLK_DLY_ENA_GMAC_ENABLE << RXCLK_DLY_ENA_GMAC_SHIFT | + TXCLK_DLY_ENA_GMAC_ENABLE << TXCLK_DLY_ENA_GMAC_SHIFT | + pdata->rx_delay << CLK_RX_DL_CFG_GMAC_SHIFT | + pdata->tx_delay << CLK_TX_DL_CFG_GMAC_SHIFT); + + return designware_eth_probe(dev); +} + +static int gmac_rockchip_eth_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct dw_eth_dev *priv = dev_get_priv(dev); + int ret; + + ret = designware_eth_init(priv, pdata->enetaddr); + if (ret) + return ret; + ret = gmac_rockchip_fix_mac_speed(priv); + if (ret) + return ret; + ret = designware_eth_enable(priv); + if (ret) + return ret; + + return 0; +} + +const struct eth_ops gmac_rockchip_eth_ops = { + .start = gmac_rockchip_eth_start, + .send = designware_eth_send, + .recv = designware_eth_recv, + .free_pkt = designware_eth_free_pkt, + .stop = designware_eth_stop, + .write_hwaddr = designware_eth_write_hwaddr, +}; + +static const struct udevice_id rockchip_gmac_ids[] = { + { .compatible = "rockchip,rk3288-gmac" }, + { } +}; + +U_BOOT_DRIVER(eth_gmac_rockchip) = { + .name = "gmac_rockchip", + .id = UCLASS_ETH, + .of_match = rockchip_gmac_ids, + .ofdata_to_platdata = gmac_rockchip_ofdata_to_platdata, + .probe = gmac_rockchip_probe, + .ops = &gmac_rockchip_eth_ops, + .priv_auto_alloc_size = sizeof(struct dw_eth_dev), + .platdata_auto_alloc_size = sizeof(struct gmac_rockchip_platdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
Enable the various configuration option required to get the ethernet interface up and running on Radxa Rock2 and Firefly.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Acked-by: Romain Perier romain.perier@collabora.com ---
Changes in v5: - Added Acked-by for Romain Changes in v4: None Changes in v3: None Changes in v2: None
configs/firefly-rk3288_defconfig | 4 ++++ configs/rock2_defconfig | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 4910c80cd8..3431464a2f 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -44,6 +44,10 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_ROCKCHIP_DWMMC=y +CONFIG_DM_ETH=y +CONFIG_NETDEVICES=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 1883f07320..a57b3de042 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -43,6 +43,10 @@ CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_ROCKCHIP_DWMMC=y +CONFIG_DM_ETH=y +CONFIG_NETDEVICES=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set
This is the only RK3399 device without DHCP. Enable it so that we can use a common BOOT_TARGET_DEVICES setting. It is likely useful to be able to use USB networking, at least. Full networking can be enabled when a suitable platform needs it.
Changes in v5: None Changes in v4: - Fix commit message to say 'rk3399'
Changes in v3: - Add new patch to enable networking on evb-rk3399
Changes in v2: None
configs/evb-rk3399_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 40a8295417..be522fbd74 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -11,6 +11,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y
Now that at least on the firefly board we have network support, enable PXE and DHCP boot targets by default.
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/configs/rockchip-common.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 9ec71c4baa..be53e659ee 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -14,7 +14,9 @@ /* First try to boot from SD (index 0), then eMMC (index 1 */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ - func(MMC, mmc, 1) + func(MMC, mmc, 1) \ + func(PXE, pxe, na) \ + func(DHCP, dchp, na)
/* Enable gpt partition table */ #define CONFIG_CMD_GPT
Now that ethernet support works, it can be dropped from the rockchip TODO
Signed-off-by: Sjoerd Simons sjoerd.simons@collabora.co.uk Acked-by: Simon Glass sjg@chromium.org Acked-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Simon Glass <sjg at chromium.org> ---
Changes in v5: None Changes in v4: None Changes in v3: - Add a few new patches - Drop the 'net: designware: Add a fix_mac_speed hook' patch
doc/README.rockchip | 1 - 1 file changed, 1 deletion(-)
diff --git a/doc/README.rockchip b/doc/README.rockchip index 06ec80e523..43cafc7bd6 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -219,7 +219,6 @@ Immediate priorities are: - USB host - USB device - Run CPU at full speed (code exists but we only see ~60 DMIPS maximum) -- Ethernet - NAND flash - Support for other Rockchip parts - Boot U-Boot proper over USB OTG (at present only SPL works)
Romain Perier
