[U-Boot] [PATCH] arm, da850: staticize funtions
Make funtions static which are locally used in file and remove the declaration from header file.
Signed-off-by: Manish Badarkhe badarkhe.manish@gmail.com --- :100644 100644 a3bbbb8... b91e948... M arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c :100644 100644 7f9c3f6... 45a325c... M arch/arm/include/asm/arch-davinci/da850_lowlevel.h arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 6 +++--- arch/arm/include/asm/arch-davinci/da850_lowlevel.h | 3 --- 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c index a3bbbb8..b91e948 100644 --- a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c +++ b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c @@ -26,7 +26,7 @@ void davinci_enable_uart0(void) }
#if defined(CONFIG_SYS_DA850_PLL_INIT) -void da850_waitloop(unsigned long loopcnt) +static void da850_waitloop(unsigned long loopcnt) { unsigned long i;
@@ -34,7 +34,7 @@ void da850_waitloop(unsigned long loopcnt) asm(" NOP"); }
-int da850_pll_init(struct davinci_pllc_regs *reg, unsigned long pllmult) +static int da850_pll_init(struct davinci_pllc_regs *reg, unsigned long pllmult) { if (reg == davinci_pllc0_regs) /* Unlock PLL registers. */ @@ -160,7 +160,7 @@ int da850_pll_init(struct davinci_pllc_regs *reg, unsigned long pllmult) #endif /* CONFIG_SYS_DA850_PLL_INIT */
#if defined(CONFIG_SYS_DA850_DDR_INIT) -int da850_ddr_setup(void) +static int da850_ddr_setup(void) { unsigned long tmp;
diff --git a/arch/arm/include/asm/arch-davinci/da850_lowlevel.h b/arch/arm/include/asm/arch-davinci/da850_lowlevel.h index 7f9c3f6..45a325c 100644 --- a/arch/arm/include/asm/arch-davinci/da850_lowlevel.h +++ b/arch/arm/include/asm/arch-davinci/da850_lowlevel.h @@ -26,11 +26,8 @@ extern const int lpsc_size; #define dv_maskbits(addr, val) \ writel((readl(addr) & val), addr)
-void da850_waitloop(unsigned long loopcnt); -int da850_pll_init(struct davinci_pllc_regs *reg, unsigned long pllmult); void da850_lpc_transition(unsigned char pscnum, unsigned char module, unsigned char domain, unsigned char state); -int da850_ddr_setup(void); void da850_psc_init(void); void da850_pinmux_ctl(unsigned long offset, unsigned long mask, unsigned long value);
Applied to u-boot-ti/master, thanks!
Manish Badarkhe
