[U-Boot] [PATCH] am33xx: Remove serial_init in s_init for QSPI/NOR XIP boot
serial_init() reads global_data, since global_data is not yet initialized, this can cause unwanted behaviour leading to QSPI XIP boot hang. Also, since serial_init() is anyways called later from boar_init_f(), it does not make sense to do the same in s_init().
Tested on AM437x IDK EVM with QSPI XIP boot.
Signed-off-by: Vignesh R vigneshr@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index bd14326cf479..1633ddc6b096 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -273,12 +273,6 @@ void s_init(void) set_uart_mux_conf(); setup_clocks_for_console(); uart_soft_reset(); -#if defined(CONFIG_NOR_BOOT) || defined(CONFIG_QSPI_BOOT) - /* TODO: This does not work, gd is not available yet */ - gd->baudrate = CONFIG_BAUDRATE; - serial_init(); - gd->have_console = 1; -#endif #if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) /* Enable RTC32K clock */ rtc32k_enable();
serial_init();
-#endif #if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) /* Enable RTC32K clock */ rtc32k_enable(); -- 2.6.3
Signed-off-by: Vignesh R vigneshr@ti.com Reviewed-by: Simon Glass sjg@chromium.org
Vignesh R
