[U-Boot][PATCH 0/2] Improve fpga cmd usage information
Current usage information is not read friendly specially when all the options are selected. This series fix some of the issues in the info, from one side aligment and overlapping issues and from the other the excess of verbosity on the loads command.
Ibai Erkiaga (2): fpga: fix alignment on fpga cmd usage info fpga: improve loads usage information
cmd/fpga.c | 45 ++++++++++++++++++--------------------------- 1 file changed, 18 insertions(+), 27 deletions(-)
The current implementation generates some alignment issues as well as some overlapping when all the fpga command options are enabled. The fix is intended to improve readability of the usage info.
Signed-off-by: Ibai Erkiaga ibai.erkiaga-elorza@amd.com
The current output looks like this: loadbp [dev] [address] [size] Load device from bitstream buffer with partial bitstream(Xilinx only) Load device from filesystem (FAT by default) (Xilinx only) loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> loadmk [dev] [address] Load device generated with mkimage For loadmk operating on FIT format uImage address must include subimage unit name in the form of addr:<subimg_uname>Load encrypted bitstream (Xilinx only) loads [dev] [address] [size] [auth-OCM-0/DDR-1/noauth-2] [enc-devkey(0)/userkey(1)/nenc(2) [Userkey address] Loads the secure bistreams(authenticated/encrypted/both
The new output lools like this: loadb [dev] [address] [size] Load device from bitstream buffer (Xilinx only) loadbp [dev] [address] [size] Load device from bitstream buffer with partial bitstream (Xilinx only) loadfs [dev] [address] [size] [blocksize] <interface> [<dev[:part]>] <filename> Load device from filesystem (FAT by default) (Xilinx only) loadmk [dev] [address] Load device generated with mkimage NOTE: loadmk operating on FIT format uImage address must include subimage unit name in the form of addr:<subimg_uname> loads [dev] [address] [size] [auth-OCM-0/DDR-1/noauth-2] [enc-devkey(0)/userkey(1)/nenc(2) [Userkey address] Loads the secure bistreams(authenticated/encrypted/both
--- cmd/fpga.c | 51 ++++++++++++++++++++++++--------------------------- 1 file changed, 24 insertions(+), 27 deletions(-)
diff --git a/cmd/fpga.c b/cmd/fpga.c index 93f14098ccb..cba38662958 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -411,46 +411,43 @@ U_BOOT_CMD(fpga, 6, 1, do_fpga_wrapper, "loadable FPGA image support", "[operation type] [device number] [image address] [image size]\n" "fpga operations:\n" - " dump\t[dev] [address] [size]\tLoad device to memory buffer\n" - " info\t[dev]\t\t\tlist known device information\n" - " load\t[dev] [address] [size]\tLoad device from memory buffer\n" + " dump\t[dev] [address] [size]\tLoad device to memory buffer\n" + " info\t[dev]\t\t\tList known device information\n" + " load\t[dev] [address] [size]\tLoad device from memory buffer\n" #if defined(CONFIG_CMD_FPGA_LOADP) - " loadp\t[dev] [address] [size]\t" + " loadp\t[dev] [address] [size]\t" "Load device from memory buffer with partial bitstream\n" #endif - " loadb\t[dev] [address] [size]\t" + " loadb\t[dev] [address] [size]\t" "Load device from bitstream buffer (Xilinx only)\n" #if defined(CONFIG_CMD_FPGA_LOADBP) - " loadbp\t[dev] [address] [size]\t" - "Load device from bitstream buffer with partial bitstream" + " loadbp\t[dev] [address] [size]\t" + "Load device from bitstream buffer with partial bitstream " "(Xilinx only)\n" #endif #if defined(CONFIG_CMD_FPGA_LOADFS) - "Load device from filesystem (FAT by default) (Xilinx only)\n" - " loadfs [dev] [address] [image size] [blocksize] <interface>\n" - " [<dev[:part]>] <filename>\n" + " loadfs\t[dev] [address] [size] [blocksize] <interface> [<dev[:part]>] <filename>\n" + "\tLoad device from filesystem (FAT by default) (Xilinx only)\n" #endif #if defined(CONFIG_CMD_FPGA_LOADMK) - " loadmk [dev] [address]\tLoad device generated with mkimage" + " loadmk\t[dev] [address]\t\tLoad device generated with mkimage\n" #if defined(CONFIG_FIT) - "\n" - "\tFor loadmk operating on FIT format uImage address must include\n" - "\tsubimage unit name in the form of addr:<subimg_uname>" + "\tNOTE: loadmk operating on FIT format uImage address must include\n" + "\tsubimage unit name in the form of addr:<subimg_uname>\n" #endif #endif #if defined(CONFIG_CMD_FPGA_LOAD_SECURE) - "Load encrypted bitstream (Xilinx only)\n" - " loads [dev] [address] [size] [auth-OCM-0/DDR-1/noauth-2]\n" - " [enc-devkey(0)/userkey(1)/nenc(2) [Userkey address]\n" - "Loads the secure bistreams(authenticated/encrypted/both\n" - "authenticated and encrypted) of [size] from [address].\n" - "The auth-OCM/DDR flag specifies to perform authentication\n" - "in OCM or in DDR. 0 for OCM, 1 for DDR, 2 for no authentication.\n" - "The enc flag specifies which key to be used for decryption\n" - "0-device key, 1-user key, 2-no encryption.\n" - "The optional Userkey address specifies from which address key\n" - "has to be used for decryption if user key is selected.\n" - "NOTE: the secure bitstream has to be created using Xilinx\n" - "bootgen tool only.\n" + " loads\t[dev] [address] [size] [auth-OCM-0/DDR-1/noauth-2]\n" + "\t[enc-devkey(0)/userkey(1)/nenc(2) [Userkey address]\n" + "\tLoads the secure bistreams(authenticated/encrypted/both\n" + "\tauthenticated and encrypted) of [size] from [address] (Xilinx only)\n" + "\t -The auth-OCM/DDR flag specifies to perform authentication\n" + "\tin OCM or in DDR. 0 for OCM, 1 for DDR, 2 for no authentication.\n" + "\t -The enc flag specifies which key to be used for decryption\n" + "\t0-device key, 1-user key, 2-no encryption.\n" + "\t -The optional Userkey address specifies from which address key\n" + "\thas to be used for decryption if user key is selected.\n" + "\tNOTE: the secure bitstream has to be created using Xilinx\n" + "\tbootgen tool only.\n" #endif );
Hello,
Am Wed, Jan 08, 2025 at 02:03:50PM +0000 schrieb Ibai Erkiaga:
Alignment could indeed improved. One question: the \t is dependent on the terminal, right? Would it be better to use spaces instead? That would also make the code more readable.
Greets Alex
#endif
"\n"
#endif ); -- 2.42.0.325.g3a06386e31
[AMD Official Use Only - AMD Internal Distribution Only]
Agree Alex,
I just used /t to stick as much as possible to the current implementation, but I'm open to change to white spaces if Michal thinks it's better.
Regards Ibai
________________________________ From: Alexander Dahl ada@thorsis.com Sent: 09 January 2025 07:52 To: Erkiaga Elorza, Ibai ibai.erkiaga-elorza@amd.com Cc: u-boot@lists.denx.de u-boot@lists.denx.de; Simek, Michal michal.simek@amd.com Subject: Re: [U-Boot][PATCH 1/2] fpga: fix alignment on fpga cmd usage info
Caution: This message originated from an External Source. Use proper caution when opening attachments, clicking links, or responding.
Hello,
Greets Alex
#endif
"\n"
Agree Alex,
Regards Ibai
*From:* Alexander Dahl ada@thorsis.com *Sent:* 09 January 2025 07:52 *To:* Erkiaga Elorza, Ibai ibai.erkiaga-elorza@amd.com *Cc:* u-boot@lists.denx.de u-boot@lists.denx.de; Simek, Michal michal.simek@amd.com *Subject:* Re: [U-Boot][PATCH 1/2] fpga: fix alignment on fpga cmd usage info Caution: This message originated from an External Source. Use proper caution when opening attachments, clicking links, or responding.
Hello,
Agree. Even other commands are using tabs using spaces would be better.
Thanks, Michal
this is not the full look. Full log looks like this. You can see that some of that lines are longer then 80 that's why they are on the next line. I think you should stay inside 80 chars per line. Second loadp is in front of loadb which looks weird.
There should be description about meaning of [] or <> in help message
[ ] should means optional parameter < > should means required parameter
Below all of them are optional which is not truth. It is correct in fpga info but not in fpga dump. It means I think when you are on this descriptions should be also fixed.
Also line fpga [operation type] [device number] [image address] [image size] is not covering all commands. It means you should consider if make sense to have this line.
Usage: fpga [operation type] [device number] [image address] [image size] fpga operations: dump [dev] [address] [size] Load device to memory buffer info [dev] List known device information load [dev] [address] [size] Load device from memory buffer loadp [dev] [address] [size] Load device from memory buffer with partial bitstream loadb [dev] [address] [size] Load device from bitstream buffer (Xilinx only) loadbp [dev] [address] [size] Load device from bitstream buffer with partial bitstream (Xilinx only) loadfs [dev] [address] [size] [blocksize] <interface> [<dev[:part]>] <filename> Load device from filesystem (FAT by default) (Xilinx only) loadmk [dev] [address] Load device generated with mkimage NOTE: loadmk operating on FIT format uImage address must include subimage unit name in the form of addr:<subimg_uname> loads [dev] [address] [size] [authflag] [encflag] [Userkey address] Load device from memory buffer with secure bistream (authenticated/encrypted/both)(Xilinx only) -authflag: 0 for OCM, 1 for DDR, 2 for no authentication (specifies where to perform authentication) -encflag: 0 for device key, 1 for user key, 2 for no encryption -Userkey address: specifies the address where user key is stored when user key is selected NOTE: the secure bitstream has to be created using Xilinx bootgen tool only.
Thanks, Michal
Current usage information for loads command is too verbose and long for a command usage prompt. This flag simplifies the text for readability purposes.
Signed-off-by: Ibai Erkiaga ibai.erkiaga-elorza@amd.com ---
The authentication and encryption flag naming is redundant with the description notes included. Use authflag and encflag names for the command pattern and use description lines for explanation.
New output looks like this: loads [dev] [address] [size] [authflag] [encflag] [Userkey address] Load device from memory buffer with secure bistream (authenticated/encrypted/both)(Xilinx only) -authflag: 0 for OCM, 1 for DDR, 2 for no authentication (specifies where to perform authentication) -encflag: 0 for device key, 1 for user key, 2 for no encryption -Userkey address: specifies the address where user key is stored when user key is selected NOTE: the secure bitstream has to be created using Xilinx bootgen tool only.
--- cmd/fpga.c | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/cmd/fpga.c b/cmd/fpga.c index cba38662958..cbcbe9c32f1 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -437,17 +437,11 @@ U_BOOT_CMD(fpga, 6, 1, do_fpga_wrapper, #endif #endif #if defined(CONFIG_CMD_FPGA_LOAD_SECURE) - " loads\t[dev] [address] [size] [auth-OCM-0/DDR-1/noauth-2]\n" - "\t[enc-devkey(0)/userkey(1)/nenc(2) [Userkey address]\n" - "\tLoads the secure bistreams(authenticated/encrypted/both\n" - "\tauthenticated and encrypted) of [size] from [address] (Xilinx only)\n" - "\t -The auth-OCM/DDR flag specifies to perform authentication\n" - "\tin OCM or in DDR. 0 for OCM, 1 for DDR, 2 for no authentication.\n" - "\t -The enc flag specifies which key to be used for decryption\n" - "\t0-device key, 1-user key, 2-no encryption.\n" - "\t -The optional Userkey address specifies from which address key\n" - "\thas to be used for decryption if user key is selected.\n" - "\tNOTE: the secure bitstream has to be created using Xilinx\n" - "\tbootgen tool only.\n" + " loads\t[dev] [address] [size] [authflag] [encflag] [Userkey address]\n" + "\tLoad device from memory buffer with secure bistream (authenticated/encrypted/both)(Xilinx only)\n" + "\t -authflag: 0 for OCM, 1 for DDR, 2 for no authentication (specifies where to perform authentication)\n" + "\t -encflag: 0 for device key, 1 for user key, 2 for no encryption\n" + "\t -Userkey address: specifies the address where user key is stored when user key is selected\n" + "\tNOTE: the secure bitstream has to be created using Xilinx bootgen tool only.\n" #endif );
#endif );"\tNOTE: the secure bitstream has to be created using Xilinx bootgen tool only.\n"
When you are on this one I can't see any reason to state that this is Xilinx only. Pretty much CONFIG_CMD_FPGA_LOAD_SECURE should depends on FPGA_XILINX and then you don't need to state it in help. The same is for that Kconfig symbol.
CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOAD_SECURE and LOADB should have own symbol too which also depends on FPGA_XILINX.
Then you can remove Xilinx only from help too.
Thanks, Michal
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4c4ad9d99799..89f0c162145c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1178,8 +1178,8 @@ config CMD_FPGA_LOADBP a partial bitstream.
config CMD_FPGA_LOADFS - bool "fpga loadfs - load bitstream from FAT filesystem (Xilinx only)" - depends on CMD_FPGA + bool "fpga loadfs - load bitstream from FAT filesystem" + depends on CMD_FPGA && FPGA_XILINX help Supports loading an FPGA device from a FAT filesystem.
@@ -1198,7 +1198,7 @@ config CMD_FPGA_LOADP
config CMD_FPGA_LOAD_SECURE bool "fpga loads - loads secure bitstreams" - depends on CMD_FPGA + depends on CMD_FPGA && FPGA_XILINX select FPGA_LOAD_SECURE help Enables the fpga loads command which is used to load secure
Alexander Dahl
Ibai Erkiaga
Michal Simek
