[GIT PULL] u-boot-riscv/next
Hi Tom,
The following changes since commit fdefb4e194c65777fa11479119adaa71651f41d4:
Merge tag 'efi-next-20231217' of https://source.denx.de/u-boot/custodians/u-boot-efi into next (2023-12-17 09:11:06 -0500)
https://source.denx.de/u-boot/custodians/u-boot-riscv.git next
for you to fetch changes up to 44a792c99498f5a9d3526019779d66585978c491:
riscv: sifive: unmatched: migrate to text environment (2023-12-18 11:09:01 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/18996 ---------------------------------------------------------------- - VisionFive2: Enable CONFIG_SYSRESET - StarFive: Modify starfive timer driver - AMD/Xilinx: Add MicroBlaze V support - Unmatched: Migrate to text environment ---------------------------------------------------------------- Jaehoon Chung (2): riscv: dts: jh7110: Add a gpio-restart node configs: visionfive2: Enable CONFIG_SYSRESET config
Kuan Lim Lee (1): timer: starfive: Add Starfive timer support
Michal Simek (1): riscv: Add support for AMD/Xilinx MicroBlaze V
Yong-Xuan Wang (1): riscv: sifive: unmatched: migrate to text environment
arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 2 + arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi | 5 ++ arch/riscv/dts/xilinx-mbv32.dts | 106 +++++++++++++++++++++++ board/sifive/unmatched/unmatched.env | 19 ++++ board/xilinx/Kconfig | 3 +- board/xilinx/common/board.c | 5 ++ board/xilinx/mbv/Kconfig | 28 ++++++ board/xilinx/mbv/MAINTAINERS | 7 ++ board/xilinx/mbv/Makefile | 5 ++ board/xilinx/mbv/board.c | 11 +++ configs/sifive_unmatched_defconfig | 2 +- configs/starfive_visionfive2_defconfig | 1 + configs/xilinx_mbv32_defconfig | 30 +++++++ configs/xilinx_mbv32_smode_defconfig | 32 +++++++ drivers/timer/starfive-timer.c | 16 ++-- include/configs/sifive-unmatched.h | 37 -------- include/configs/xilinx_mbv.h | 6 ++ 18 files changed, 273 insertions(+), 46 deletions(-) create mode 100644 arch/riscv/dts/xilinx-mbv32.dts create mode 100644 board/sifive/unmatched/unmatched.env create mode 100644 board/xilinx/mbv/Kconfig create mode 100644 board/xilinx/mbv/MAINTAINERS create mode 100644 board/xilinx/mbv/Makefile create mode 100644 board/xilinx/mbv/board.c create mode 100644 configs/xilinx_mbv32_defconfig create mode 100644 configs/xilinx_mbv32_smode_defconfig create mode 100644 include/configs/xilinx_mbv.h
Best regards, Leo
On Mon, Dec 18, 2023 at 07:44:15PM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
