[U-Boot] [PATCH] ppc4xx: Add GDsys CompactCenter board support.
Board support for the Guntermann & Drunck CompactCenter and DevCon-Center. Based on the AMCC Canyonlands board support by Stefan Roese.
Signed-off-by: Dirk Eibach eibach@gdsys.de --- MAINTAINERS | 2 + MAKEALL | 2 + Makefile | 8 + board/gdsys/compactcenter/Makefile | 52 ++++ board/gdsys/compactcenter/bootstrap.c | 196 +++++++++++++ board/gdsys/compactcenter/compactcenter.c | 326 ++++++++++++++++++++++ board/gdsys/compactcenter/config.mk | 41 +++ board/gdsys/compactcenter/init.S | 87 ++++++ board/gdsys/compactcenter/u-boot.lds | 144 ++++++++++ include/configs/compactcenter.h | 425 +++++++++++++++++++++++++++++ 10 files changed, 1283 insertions(+), 0 deletions(-) create mode 100644 board/gdsys/compactcenter/Makefile create mode 100644 board/gdsys/compactcenter/bootstrap.c create mode 100644 board/gdsys/compactcenter/compactcenter.c create mode 100644 board/gdsys/compactcenter/config.mk create mode 100644 board/gdsys/compactcenter/init.S create mode 100644 board/gdsys/compactcenter/u-boot.lds create mode 100644 include/configs/compactcenter.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0041112..ea87863 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -135,6 +135,8 @@ Jon Diekema jon.diekema@smiths-aerospace.com
+ compactcenter PPC460EX + devconcenter PPC460EX gdppc440etx PPC440EP/GR neo PPC405EP
diff --git a/MAKEALL b/MAKEALL index 41f1445..84b04ce 100755 --- a/MAKEALL +++ b/MAKEALL @@ -183,6 +183,7 @@ LIST_4xx=" \ canyonlands \ canyonlands_nand \ CMS700 \ + compactcenter \ CPCI2DP \ CPCI405 \ CPCI4052 \ @@ -193,6 +194,7 @@ LIST_4xx=" \ csb272 \ csb472 \ DASA_SIM \ + devconcenter \ DP405 \ DU405 \ DU440 \ diff --git a/Makefile b/Makefile index 2a06440..5dba5a8 100644 --- a/Makefile +++ b/Makefile @@ -1299,6 +1299,14 @@ CATcenter_33_config: unconfig CMS700_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cms700 esd
+# Compact-Center & DevCon-Center use different U-Boot images +compactcenter_config \ +devconcenter_config: unconfig + @mkdir -p $(obj)include + @echo "#define CONFIG_$$(echo $(subst ,,$(@:_config=)) | \ + tr '[:lower:]' '[:upper:]')" >$(obj)include/config.h + @$(MKCONFIG) -n $@ -a compactcenter ppc ppc4xx compactcenter gdsys + CPCI2DP_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci2dp esd
diff --git a/board/gdsys/compactcenter/Makefile b/board/gdsys/compactcenter/Makefile new file mode 100644 index 0000000..2aeead6 --- /dev/null +++ b/board/gdsys/compactcenter/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2008 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o +COBJS += bootstrap.o +SOBJS := init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/gdsys/compactcenter/bootstrap.c b/board/gdsys/compactcenter/bootstrap.c new file mode 100644 index 0000000..cd638c2 --- /dev/null +++ b/board/gdsys/compactcenter/bootstrap.c @@ -0,0 +1,196 @@ +/* + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <asm/io.h> + +/* + * NOR and NAND boot options change bytes 5, 6, 8, 9, 11. The + * values are independent of the rest of the clock settings. + */ + +#define NAND_COMPATIBLE 0x01 +#define NOR_COMPATIBLE 0x02 + +#define I2C_EEPROM_ADDR 0x54 + +static char *config_labels[] = { + "CPU: 600 PLB: 200 OPB: 100 EBC: 100", + "CPU: 800 PLB: 200 OPB: 100 EBC: 100", + "CPU:1000 PLB: 200 OPB: 100 EBC: 100", + "CPU:1066 PLB: 266 OPB: 88 EBC: 88", + NULL +}; + +static u8 boot_configs[][17] = { + { + (NAND_COMPATIBLE | NOR_COMPATIBLE), + 0x86, 0x80, 0xce, 0x1f, 0x79, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + }, + { + (NAND_COMPATIBLE | NOR_COMPATIBLE), + 0x86, 0x80, 0xba, 0x14, 0x99, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + }, + { + (NAND_COMPATIBLE | NOR_COMPATIBLE), + 0x86, 0x82, 0x96, 0x19, 0xb9, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + }, + { + (NAND_COMPATIBLE | NOR_COMPATIBLE), + 0x86, 0x80, 0xb3, 0x01, 0x9d, 0x80, 0x00, 0xa0, 0x40, 0x08, + 0x23, 0x50, 0x0d, 0x05, 0x00, 0x00 + }, + { + 0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 + } +}; + +/* + * Bytes 5,6,8,9,11 change for NAND boot + */ +#if 0 +/* + * Values for 512 page size NAND chips, not used anymore, just + * keep them here for reference + */ +static u8 nand_boot[] = { + 0x90, 0x01, 0xa0, 0x68, 0x58 +}; +#else +/* + * Values for 2k page size NAND chips + */ +static u8 nand_boot[] = { + 0x90, 0x01, 0xa0, 0xe8, 0x58 +}; +#endif + +static int do_bootstrap(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + u8 *buf, b_nand; + int x, y, nbytes, selcfg; + extern char console_buffer[]; + + if (argc < 2) { + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + if ((strcmp(argv[1], "nor") != 0) && + (strcmp(argv[1], "nand") != 0)) { + printf("Unsupported boot-device - only nor|nand support\n"); + return 1; + } + + /* set the nand flag based on provided input */ + if ((strcmp(argv[1], "nand") == 0)) + b_nand = 1; + else + b_nand = 0; + + printf("Available configurations: \n\n"); + + if (b_nand) { + for (x = 0, y = 0; boot_configs[x][0] != 0; x++) { + /* filter on nand compatible */ + if (boot_configs[x][0] & NAND_COMPATIBLE) { + printf(" %d - %s\n", (y+1), config_labels[x]); + y++; + } + } + } else { + for (x = 0, y = 0; boot_configs[x][0] != 0; x++) { + /* filter on nor compatible */ + if (boot_configs[x][0] & NOR_COMPATIBLE) { + printf(" %d - %s\n", (y+1), config_labels[x]); + y++; + } + } + } + + do { + nbytes = readline(" Selection [1-x / quit]: "); + + if (nbytes) { + if (strcmp(console_buffer, "quit") == 0) + return 0; + selcfg = simple_strtol(console_buffer, NULL, 10); + if ((selcfg < 1) || (selcfg > y)) + nbytes = 0; + } + } while (nbytes == 0); + + + y = (selcfg - 1); + + for (x = 0; boot_configs[x][0] != 0; x++) { + if (b_nand) { + if (boot_configs[x][0] & NAND_COMPATIBLE) { + if (y > 0) + y--; + else if (y < 1) + break; + } + } else { + if (boot_configs[x][0] & NOR_COMPATIBLE) { + if (y > 0) + y--; + else if (y < 1) + break; + } + } + } + + buf = &boot_configs[x][1]; + + if (b_nand) { + buf[5] = nand_boot[0]; + buf[6] = nand_boot[1]; + buf[8] = nand_boot[2]; + buf[9] = nand_boot[3]; + buf[11] = nand_boot[4]; + } + + if (i2c_write(I2C_EEPROM_ADDR, 0, 1, buf, 16) != 0) + printf("Error writing to EEPROM at address 0x%x\n", + I2C_EEPROM_ADDR); + udelay(CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS * 1000); + + printf("Done\n"); + printf("Please power-cycle the board for the changes to take effect\n"); + + return 0; +} + +U_BOOT_CMD( + bootstrap, 2, 0, do_bootstrap, + "bootstrap - program the I2C bootstrap EEPROM\n", + "<nand|nor> - strap to boot from NAND or NOR flash\n" + ); diff --git a/board/gdsys/compactcenter/compactcenter.c b/board/gdsys/compactcenter/compactcenter.c new file mode 100644 index 0000000..9f1e49d --- /dev/null +++ b/board/gdsys/compactcenter/compactcenter.c @@ -0,0 +1,326 @@ +/* + * (C) Copyright 2009 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * Based on board/amcc/canyonlands/canyonlands.c + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <ppc440.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <i2c.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/mmu.h> +#include <asm/4xx_pcie.h> +#include <asm/gpio.h> + +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +DECLARE_GLOBAL_DATA_PTR; + +#define CONFIG_SYS_BCSR3_PCIE 0x10 + +int board_early_init_f(void) +{ + u32 pvr = get_pvr(); + + /* + * Setup the interrupt controller polarities, triggers, etc. + */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + mtdcr(uic0er, 0x00000000); /* disable all */ + mtdcr(uic0cr, 0x00000005); /* ATI & UIC1 crit are critical */ + mtdcr(uic0pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic0tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic0vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic0sr, 0xffffffff); /* clear all */ + + mtdcr(uic1sr, 0xffffffff); /* clear all */ + mtdcr(uic1er, 0x00000000); /* disable all */ + mtdcr(uic1cr, 0x00000000); /* all non-critical */ + mtdcr(uic1pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic1tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic1vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic1sr, 0xffffffff); /* clear all */ + + mtdcr(uic2sr, 0xffffffff); /* clear all */ + mtdcr(uic2er, 0x00000000); /* disable all */ + mtdcr(uic2cr, 0x00000000); /* all non-critical */ + mtdcr(uic2pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic2tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic2vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic2sr, 0xffffffff); /* clear all */ + + mtdcr(uic3sr, 0xffffffff); /* clear all */ + mtdcr(uic3er, 0x00000000); /* disable all */ + mtdcr(uic3cr, 0x00000000); /* all non-critical */ + mtdcr(uic3pr, 0xffffffff); /* per ref-board manual */ + mtdcr(uic3tr, 0x00000000); /* per ref-board manual */ + mtdcr(uic3vr, 0x00000000); /* int31 highest, base=0x000 */ + mtdcr(uic3sr, 0xffffffff); /* clear all */ + + /* + * Configure PFC (Pin Function Control) registers + * enable GPIO 49-63 + * UART0: 4 pins + */ + mtsdr(SDR0_PFC0, 0x00007fff); + mtsdr(SDR0_PFC1, 0x00040000); + + /* Enable PCI host functionality in SDR0_PCI0 */ + mtsdr(SDR0_PCI0, 0xe0000000); + + mtsdr(SDR0_SRST1, 0); /* Pull AHB out of reset default=1 */ + + /* Setup PLB4-AHB bridge based on the system address map */ + mtdcr(AHB_TOP, 0x8000004B); + mtdcr(AHB_BOT, 0x8000004B); + + if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA)) { + /* + * Configure USB-STP pins as alternate and not GPIO + * It seems to be neccessary to configure the STP pins as GPIO + * input at powerup (perhaps while USB reset is asserted). So + * we configure those pins to their "real" function now. + */ + gpio_config(16, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + gpio_config(19, GPIO_OUT, GPIO_ALT1, GPIO_OUT_1); + } + + /* Trigger board component reset */ + out_le16((void *)CONFIG_SYS_IO_BASE, 0xffff); + out_le16((void *)CONFIG_SYS_IO_BASE + 0x100, 0xffff); + udelay(50); + out_le16((void *)CONFIG_SYS_IO_BASE, 0xffbf); + out_le16((void *)CONFIG_SYS_IO_BASE + 0x100, 0xffbf); + udelay(50); + out_le16((void *)CONFIG_SYS_IO_BASE, 0xffff); + out_le16((void *)CONFIG_SYS_IO_BASE + 0x100, 0xffff); + + return 0; +} + +int get_cpu_num(void) +{ + int cpu = NA_OR_UNKNOWN_CPU; + + return cpu; +} + +int checkboard(void) +{ + char *s = getenv("serial#"); + +#ifdef CONFIG_DEVCONCENTER + printf("Board: DevCon-Center"); +#else + printf("Board: CompactCenter"); +#endif + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + putc('\n'); + + return 0; +} + +/* + * pci_target_init + * + * The bootstrap configuration provides default settings for the pci + * inbound map (PIM). But the bootstrap config choices are limited and + * may not be sufficient for a given board. + */ +#if defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) +void pci_target_init(struct pci_controller *hose) +{ + /* + * Disable everything + */ + out_le32((void *)PCIX0_PIM0SA, 0); /* disable */ + out_le32((void *)PCIX0_PIM1SA, 0); /* disable */ + out_le32((void *)PCIX0_PIM2SA, 0); /* disable */ + out_le32((void *)PCIX0_EROMBA, 0); /* disable expansion rom */ + + /* + * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 + * strapping options to not support sizes such as 128/256 MB. + */ + out_le32((void *)PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); + out_le32((void *)PCIX0_PIM0LAH, 0); + out_le32((void *)PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1); + out_le32((void *)PCIX0_BAR0, 0); + + /* + * Program the board's subsystem id/vendor id + */ + out_le16((void *)PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); + out_le16((void *)PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID); + + out_le16((void *)PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY); +} +#endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */ + +#if defined(CONFIG_PCI) +/* + * is_pci_host + * + * This routine is called to determine if a pci scan should be + * performed. With various hardware environments (especially cPCI and + * PPMC) it's insufficient to depend on the state of the arbiter enable + * bit in the strap register, or generic host/adapter assumptions. + * + * Rather than hard-code a bad assumption in the general 440 code, the + * 440 pci code requires the board to decide at runtime. + * + * Return 0 for adapter mode, non-zero for host (monarch) mode. + */ +int is_pci_host(struct pci_controller *hose) +{ + /* Board is always configured as host. */ + return 1; +} +#endif /* CONFIG_PCI */ + +int board_early_init_r(void) +{ + /* + * CompactCenter has 64MBytes, DevCon-Center 128MBytes of NOR FLASH + * (Spansion 29GL512), but the boot EBC mapping only supports a maximum + * of 16MBytes (4.ff00.0000 - 4.ffff.ffff). + * To solve this problem, the FLASH has to get remapped to another + * EBC address which accepts bigger regions: + * + * 0xfn00.0000 -> 4.cn00.0000 + */ + + u32 bxcr_bw = (CONFIG_SYS_FLASH_SIZE == 128 << 20) ? + EBC_BXCR_BS_128MB : EBC_BXCR_BS_64MB; + + /* Remap the NOR FLASH to 0xcn00.0000 ... 0xcfff.ffff */ + mtebc(pb0cr, CONFIG_SYS_FLASH_BASE_PHYS_L + | bxcr_bw + | EBC_BXCR_BU_RW + | EBC_BXCR_BW_16BIT); + + /* Remove TLB entry of boot EBC mapping */ + remove_tlb(CONFIG_SYS_BOOT_BASE_ADDR, 16 << 20); + + /* Add TLB entry for 0xfn00.0000 -> 0x4.cn00.0000 */ + program_tlb(CONFIG_SYS_FLASH_BASE_PHYS, CONFIG_SYS_FLASH_BASE, + CONFIG_SYS_FLASH_SIZE, TLB_WORD2_I_ENABLE); + + /* + * Now accessing of the whole 64Mbytes of NOR FLASH at virtual address + * 0xfc00.0000 is possible + */ + + /* + * Clear potential errors resulting from auto-calibration. + * If not done, then we could get an interrupt later on when + * exceptions are enabled. + */ + set_mcsr(get_mcsr()); + + return 0; +} + +int misc_init_r(void) +{ + u32 sdr0_srst1 = 0; + u32 eth_cfg; + u32 pvr = get_pvr(); + + /* + * Set EMAC mode/configuration (GMII, SGMII, RGMII...). + * This is board specific, so let's do it here. + */ + mfsdr(SDR0_ETH_CFG, eth_cfg); + /* disable SGMII mode */ + eth_cfg &= ~(SDR0_ETH_CFG_SGMII2_ENABLE | + SDR0_ETH_CFG_SGMII1_ENABLE | + SDR0_ETH_CFG_SGMII0_ENABLE); + /* Set the for 2 RGMII mode */ + /* GMC0 EMAC4_0, GMC0 EMAC4_1, RGMII Bridge 0 */ + eth_cfg &= ~SDR0_ETH_CFG_GMC0_BRIDGE_SEL; + if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA)) + eth_cfg |= SDR0_ETH_CFG_GMC1_BRIDGE_SEL; + else + eth_cfg &= ~SDR0_ETH_CFG_GMC1_BRIDGE_SEL; + mtsdr(SDR0_ETH_CFG, eth_cfg); + + /* + * The AHB Bridge core is held in reset after power-on or reset + * so enable it now + */ + mfsdr(SDR0_SRST1, sdr0_srst1); + sdr0_srst1 &= ~SDR0_SRST1_AHB; + mtsdr(SDR0_SRST1, sdr0_srst1); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + int rc; + int i; + u32 bxcr; + u32 ranges[EBC_NUM_BANKS * 4]; + u32 *p = ranges; + + ft_cpu_setup(blob, bd); + + /* Fixup NOR mapping */ + *p++ = 0; /* chip select number */ + *p++ = 0; /* always 0 */ + *p++ = CONFIG_SYS_FLASH_BASE_PHYS_L; /* we fixed up this address */ + *p++ = gd->bd->bi_flashsize; + + for (i = 1; i < EBC_NUM_BANKS; i++) { + mtdcr(ebccfga, EBC_BXCR(i)); + bxcr = mfdcr(ebccfgd); + + if ((bxcr & EBC_BXCR_BU_MASK) != EBC_BXCR_BU_NONE) { + *p++ = i; + *p++ = 0; + *p++ = bxcr & EBC_BXCR_BAS_MASK; + *p++ = EBC_BXCR_BANK_SIZE(bxcr); + } + } + + rc = fdt_find_and_setprop(blob, "/plb/opb/ebc", "ranges", ranges, + (p - ranges) * sizeof(u32), 1); + if (rc) { + printf("Unable to update property EBC mappings, err=%s\n", + fdt_strerror(rc)); + } + + fdt_find_and_setprop(blob, "/plb/pciex@d00000000", "status", + "disabled", sizeof("disabled"), 1); + + fdt_find_and_setprop(blob, "/plb/sata@bffd1000", "status", + "disabled", sizeof("disabled"), 1); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/board/gdsys/compactcenter/config.mk b/board/gdsys/compactcenter/config.mk new file mode 100644 index 0000000..56e397d --- /dev/null +++ b/board/gdsys/compactcenter/config.mk @@ -0,0 +1,41 @@ +# +# (C) Copyright 2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +# G&D CompactCenter +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +TEXT_BASE = 0xFFFA0000 +endif + +PLATFORM_CPPFLAGS += -DCONFIG_440=1 + +ifeq ($(debug),1) +PLATFORM_CPPFLAGS += -DDEBUG +endif + +ifeq ($(dbcr),1) +PLATFORM_CPPFLAGS += -DCONFIG_SYS_INIT_DBCR=0x8cff0000 +endif diff --git a/board/gdsys/compactcenter/init.S b/board/gdsys/compactcenter/init.S new file mode 100644 index 0000000..ab19ca1 --- /dev/null +++ b/board/gdsys/compactcenter/init.S @@ -0,0 +1,87 @@ +/* + * (C) Copyright 2009 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * Based on board/amcc/canyonlands/init.S + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <ppc_asm.tmpl> +#include <config.h> +#include <asm-ppc/mmu.h> + +/************************************************************************** + * TLB TABLE + * + * This table is used by the cpu boot code to setup the initial tlb + * entries. Rather than make broad assumptions in the cpu source tree, + * this table lets each board set things up however they like. + * + * Pointer to the table is returned in r1 + * + *************************************************************************/ + .section .bootpg,"ax" + .globl tlbtab + +tlbtab: + tlbtab_start + + /* + * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to + * use the speed up boot process. It is patched after relocation to + * enable SA_I + */ + tlbentry(CONFIG_SYS_BOOT_BASE_ADDR, SZ_16M, CONFIG_SYS_BOOT_BASE_ADDR, 4, AC_R|AC_W|AC_X|SA_G) /* TLB 0 */ + + /* + * TLB entries for SDRAM are not needed on this platform. + * They are dynamically generated in the SPD DDR(2) detection + * routine. + */ + +#ifdef CONFIG_SYS_INIT_RAM_DCACHE + /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ + tlbentry(CONFIG_SYS_INIT_RAM_ADDR, SZ_4K, CONFIG_SYS_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G) +#endif + + tlbentry(CONFIG_SYS_PCI_BASE, SZ_256M, 0x00000000, 0xC, AC_R|AC_W|SA_G|SA_I) + tlbentry(CONFIG_SYS_PCI_MEMBASE, SZ_256M, 0x20000000, 0xC, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for NVRAM */ + tlbentry(CONFIG_SYS_NVRAM_BASE, SZ_1M, CONFIG_SYS_NVRAM_BASE, 4, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for UART */ + tlbentry(CONFIG_SYS_UART_BASE, SZ_16K, CONFIG_SYS_UART_BASE, 4, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for IO */ + tlbentry(CONFIG_SYS_IO_BASE, SZ_16K, CONFIG_SYS_IO_BASE, 4, AC_R|AC_W|SA_G|SA_I) + + /* TLB-entry for OCM */ + tlbentry(CONFIG_SYS_OCM_BASE, SZ_1M, 0x00000000, 4, AC_R|AC_W|AC_X|SA_I) + + /* TLB-entry for Local Configuration registers => peripherals */ + tlbentry(CONFIG_SYS_LOCAL_CONF_REGS, SZ_16M, CONFIG_SYS_LOCAL_CONF_REGS, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + + /* AHB: Internal USB Peripherals (USB, SATA) */ + tlbentry(CONFIG_SYS_AHB_BASE, SZ_1M, 0xbff00000, 4, AC_R|AC_W|AC_X|SA_G|SA_I) + + tlbtab_end diff --git a/board/gdsys/compactcenter/u-boot.lds b/board/gdsys/compactcenter/u-boot.lds new file mode 100644 index 0000000..0c95d5c --- /dev/null +++ b/board/gdsys/compactcenter/u-boot.lds @@ -0,0 +1,144 @@ +/* + * (C) Copyright 2008 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + .resetvec 0xFFFFFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xFFFFF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + board/gdsys/compactcenter/init.o (.text) + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + } + + _end = . ; + PROVIDE (end = .); +} diff --git a/include/configs/compactcenter.h b/include/configs/compactcenter.h new file mode 100644 index 0000000..ebee2c7 --- /dev/null +++ b/include/configs/compactcenter.h @@ -0,0 +1,425 @@ +/* + * (C) Copyright 2009 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * Based on include/configs/canyonlands.h + * (C) Copyright 2008 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/************************************************************************ + * compactcenter.h - configuration for CompactCenter (460EX) + ***********************************************************************/ +#ifndef __CONFIG_H +#define __CONFIG_H + +/*----------------------------------------------------------------------- + * High Level Configuration Options + *----------------------------------------------------------------------*/ +/* + * This config file is used for Canyonlands and DevCon-Center + */ +#define CONFIG_460EX 1 /* Specific PPC460EX */ +#ifdef CONFIG_DEVCONCENTER +#define CONFIG_HOSTNAME devconcenter +#define CONFIG_IDENT_STRING " devconcenter 0.02" +#else +#define CONFIG_HOSTNAME compactcenter +#define CONFIG_IDENT_STRING " compactcenter 0.02" +#endif +#define CONFIG_440 1 +#define CONFIG_4xx 1 /* ... PPC4xx family */ + +/* + * Include common defines/options for all AMCC eval boards + */ +#include "amcc-common.h" + +#define CONFIG_SYS_CLK_FREQ 66666667 /* external freq to pll */ + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ +#define CONFIG_BOARD_EARLY_INIT_R 1 /* Call board_early_init_r */ +#define CONFIG_MISC_INIT_R 1 /* Call misc_init_r */ +#define CONFIG_BOARD_TYPES 1 /* support board types */ +#define CONFIG_FIT +#define CFG_ALT_MEMTEST + +/*----------------------------------------------------------------------- + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + *----------------------------------------------------------------------*/ +#define CONFIG_SYS_PCI_MEMBASE 0x80000000 /* mapped PCI memory */ +#define CONFIG_SYS_PCI_BASE 0xd0000000 /* internal PCI regs */ +#define CONFIG_SYS_PCI_TARGBASE CONFIG_SYS_PCI_MEMBASE + +/* EBC stuff */ +#ifdef CONFIG_DEVCONCENTER /* Devcon-Center has 128 MB of flash */ +#define CONFIG_SYS_FLASH_BASE 0xF8000000 /* later mapped to this addr */ +#define CONFIG_SYS_FLASH_SIZE (128 << 20) +#else +#define CONFIG_SYS_FLASH_BASE 0xFC000000 /* later mapped to this addr */ +#define CONFIG_SYS_FLASH_SIZE (64 << 20) +#endif + +#define CONFIG_SYS_NVRAM_BASE 0xE0000000 +#define CONFIG_SYS_UART_BASE 0xE0100000 +#define CONFIG_SYS_IO_BASE 0xE0200000 + +#define CONFIG_SYS_BOOT_BASE_ADDR 0xFF000000 /* EBC Boot Space: 0xFF000000 */ +#define CONFIG_SYS_FLASH_BASE_PHYS_H 0x4 +#ifdef CONFIG_DEVCONCENTER /* Devcon-Center has 128 MB of flash */ +#define CONFIG_SYS_FLASH_BASE_PHYS_L 0xC8000000 +#else +#define CONFIG_SYS_FLASH_BASE_PHYS_L 0xCC000000 +#endif +#define CONFIG_SYS_FLASH_BASE_PHYS (((u64)CONFIG_SYS_FLASH_BASE_PHYS_H << 32) | \ + (u64)CONFIG_SYS_FLASH_BASE_PHYS_L) + +#define CONFIG_SYS_OCM_BASE 0xE3000000 /* OCM: 64k */ +#define CONFIG_SYS_SRAM_BASE 0xE8000000 /* SRAM: 256k */ +#define CONFIG_SYS_LOCAL_CONF_REGS 0xEF000000 + +#define CONFIG_SYS_PERIPHERAL_BASE 0xEF600000 /* internal peripherals */ + +#define CONFIG_SYS_AHB_BASE 0xE2000000 /* internal AHB peripherals */ + +/*----------------------------------------------------------------------- + * Initial RAM & stack pointer (placed in OCM) + *----------------------------------------------------------------------*/ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ +#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Serial Port + *----------------------------------------------------------------------*/ +#undef CONFIG_UART1_CONSOLE /* define this if you want console on UART1 */ + +/*----------------------------------------------------------------------- + * Environment + *----------------------------------------------------------------------*/ +/* + * Define here the location of the environment variables (FLASH). + */ +#define CONFIG_ENV_IS_IN_FLASH 1 /* use FLASH for environment vars */ + +/*----------------------------------------------------------------------- + * FLASH related + *----------------------------------------------------------------------*/ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ +#define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CONFIG_SYS_FLASH_CFI_AMD_RESET 1 /* Use AMD (Spansion) reset cmd */ + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE} +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#ifdef CONFIG_DEVCONCENTER +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* max number of sectors on one chip */ +#else +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ +#endif + +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ + +#ifdef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#endif /* CONFIG_ENV_IS_IN_FLASH */ + +/*------------------------------------------------------------------------------ + * DDR SDRAM + *----------------------------------------------------------------------------*/ + +#define CONFIG_AUTOCALIB "silent\0" /* default is non-verbose */ + +#define CONFIG_PPC4xx_DDR_AUTOCALIBRATION /* IBM DDR autocalibration */ +#define DEBUG_PPC4xx_DDR_AUTOCALIBRATION /* dynamic DDR autocal debug */ +#undef CONFIG_PPC4xx_DDR_METHOD_A + +/* DDR1/2 SDRAM Device Control Register Data Values */ +/* Memory Queue */ +#define CONFIG_SYS_SDRAM_R0BAS 0x0000f800 +#define CONFIG_SYS_SDRAM_R1BAS 0x00000000 +#define CONFIG_SYS_SDRAM_R2BAS 0x00000000 +#define CONFIG_SYS_SDRAM_R3BAS 0x00000000 +#define CONFIG_SYS_SDRAM_PLBADDULL 0x00000000 +#define CONFIG_SYS_SDRAM_PLBADDUHB 0x00000008 +#define CONFIG_SYS_SDRAM_CONF1LL 0x80001C80 +#define CONFIG_SYS_SDRAM_CONF1HB 0x80001C80 +#define CONFIG_SYS_SDRAM_CONFPATHB 0x10a68000 + +/* SDRAM Controller */ +#define CONFIG_SYS_SDRAM0_MB0CF 0x00000201 +#define CONFIG_SYS_SDRAM0_MB1CF 0x00000000 +#define CONFIG_SYS_SDRAM0_MB2CF 0x00000000 +#define CONFIG_SYS_SDRAM0_MB3CF 0x00000000 +#define CONFIG_SYS_SDRAM0_MCOPT1 0x05122000 +#define CONFIG_SYS_SDRAM0_MCOPT2 0x00000000 +#define CONFIG_SYS_SDRAM0_MODT0 0x00000000 +#define CONFIG_SYS_SDRAM0_MODT1 0x00000000 +#define CONFIG_SYS_SDRAM0_MODT2 0x00000000 +#define CONFIG_SYS_SDRAM0_MODT3 0x00000000 +#define CONFIG_SYS_SDRAM0_CODT 0x00000020 +#define CONFIG_SYS_SDRAM0_RTR 0x06180000 +#define CONFIG_SYS_SDRAM0_INITPLR0 0xA8380000 +#define CONFIG_SYS_SDRAM0_INITPLR1 0x81900400 +#define CONFIG_SYS_SDRAM0_INITPLR2 0x81020000 +#define CONFIG_SYS_SDRAM0_INITPLR3 0x81030000 +#define CONFIG_SYS_SDRAM0_INITPLR4 0x81010000 +#define CONFIG_SYS_SDRAM0_INITPLR5 0xE4000542 +#define CONFIG_SYS_SDRAM0_INITPLR6 0x81900400 +#define CONFIG_SYS_SDRAM0_INITPLR7 0x8A880000 +#define CONFIG_SYS_SDRAM0_INITPLR8 0x8A880000 +#define CONFIG_SYS_SDRAM0_INITPLR9 0x8A880000 +#define CONFIG_SYS_SDRAM0_INITPLR10 0x8A880000 +#define CONFIG_SYS_SDRAM0_INITPLR11 0x81000442 +#define CONFIG_SYS_SDRAM0_INITPLR12 0x81010380 +#define CONFIG_SYS_SDRAM0_INITPLR13 0x81010000 +#define CONFIG_SYS_SDRAM0_INITPLR14 0x00000000 +#define CONFIG_SYS_SDRAM0_INITPLR15 0x00000000 +#define CONFIG_SYS_SDRAM0_RQDC 0x80000038 +#define CONFIG_SYS_SDRAM0_RFDC 0x003F0000 +#define CONFIG_SYS_SDRAM0_RDCC 0x80000000 +#define CONFIG_SYS_SDRAM0_DLCR 0x00000000 +#define CONFIG_SYS_SDRAM0_CLKTR 0x40000000 +#define CONFIG_SYS_SDRAM0_WRDTR 0x84000800 +#define CONFIG_SYS_SDRAM0_SDTR1 0x80201000 +#define CONFIG_SYS_SDRAM0_SDTR2 0x32204232 +#define CONFIG_SYS_SDRAM0_SDTR3 0x090B0D15 +#define CONFIG_SYS_SDRAM0_MMODE 0x00000442 +#define CONFIG_SYS_SDRAM0_MEMODE 0x00000000 + +#define CONFIG_SYS_MBYTES_SDRAM 256 /* 256MB */ + +/*----------------------------------------------------------------------- + * I2C + *----------------------------------------------------------------------*/ +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed */ + +#define CONFIG_SYS_I2C_MULTI_EEPROMS +#define CONFIG_SYS_I2C_EEPROM_ADDR (0xa8>>1) +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 + +/* I2C SYSMON */ +#define CONFIG_DTT_LM63 1 /* National LM63 */ +#define CONFIG_DTT_SENSORS { 0 } /* Sensor addresses */ +#define CONFIG_DTT_PWM_LOOKUPTABLE \ + { { 40, 10 }, { 50, 20 }, { 60, 40 } } +#define CONFIG_DTT_TACH_LIMIT 0xa10 + +/* RTC configuration */ +#define CONFIG_RTC_DS1337 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/*----------------------------------------------------------------------- + * Ethernet + *----------------------------------------------------------------------*/ +#define CONFIG_IBM_EMAC4_V4 1 + +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 + +#define CONFIG_PHY_ADDR 2 /* PHY address, See schematics */ +#define CONFIG_PHY1_ADDR 3 + +#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#define CONFIG_PHY_DYNAMIC_ANEG 1 + +/*----------------------------------------------------------------------- + * USB-OHCI + *----------------------------------------------------------------------*/ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#undef CONFIG_SYS_OHCI_BE_CONTROLLER /* 460EX has little endian descriptors */ +#define CONFIG_SYS_OHCI_SWAP_REG_ACCESS /* 460EX has little endian register */ +#define CONFIG_SYS_OHCI_USE_NPS /* force NoPowerSwitching mode */ +#define CONFIG_SYS_USB_OHCI_REGS_BASE (CONFIG_SYS_AHB_BASE | 0xd0000) +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "ppc440" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 + +/* + * Default environment variables + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_AMCC_DEF_ENV \ + CONFIG_AMCC_DEF_ENV_POWERPC \ + CONFIG_AMCC_DEF_ENV_NOR_UPD \ + "kernel_addr=fc000000\0" \ + "fdt_addr=fc1e0000\0" \ + "ramdisk_addr=fc200000\0" \ + "pciconfighost=1\0" \ + "pcie_mode=RP:RP\0" \ + "" + +/* + * Commands additional to the ones defined in amcc-common.h + */ +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DTT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_PCI +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_USB + +/* Partitions */ +#define CONFIG_MAC_PARTITION +#define CONFIG_DOS_PARTITION +#define CONFIG_ISO_PARTITION + +/*----------------------------------------------------------------------- + * PCI stuff + *----------------------------------------------------------------------*/ +/* General PCI */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_PCI_CONFIG_HOST_BRIDGE +#define CONFIG_PCI_DISABLE_PCIE + +/* Board-specific PCI */ +#define CONFIG_SYS_PCI_TARGET_INIT /* let board init pci target */ +#undef CONFIG_SYS_PCI_MASTER_INIT + +#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1014 /* IBM */ +#define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0xcafe /* Whatever */ + + +/*----------------------------------------------------------------------- + * External Bus Controller (EBC) Setup + *----------------------------------------------------------------------*/ + +/* + * CompactCenter has 64MBytes of NOR FLASH (Spansion 29GL512), but the + * boot EBC mapping only supports a maximum of 16MBytes + * (4.ff00.0000 - 4.ffff.ffff). + * To solve this problem, the FLASH has to get remapped to another + * EBC address which accepts bigger regions: + * + * 0xfc00.0000 -> 4.cc00.0000 + */ + + +/* Memory Bank 0 (NOR-FLASH) initialization */ +#define CONFIG_SYS_EBC_PB0AP 0x10055e00 +#define CONFIG_SYS_EBC_PB0CR (CONFIG_SYS_BOOT_BASE_ADDR | 0x9a000) + +/* Memory Bank 1 (NVRAM) initialization */ +#define CONFIG_SYS_EBC_PB1AP 0x02815480 +#define CONFIG_SYS_EBC_PB1CR (CONFIG_SYS_NVRAM_BASE | 0x18000) /* BAS=NVRAM,BS=1MB,BU=R/W,BW=8bit*/ + +/* Memory Bank 2 (UART) initialization */ +#define CONFIG_SYS_EBC_PB2AP 0x02815480 +#define CONFIG_SYS_EBC_PB2CR (CONFIG_SYS_UART_BASE | 0x1A000) /* BAS=UART,BS=1MB,BU=R/W,BW=16bit*/ + +/* Memory Bank 3 (IO) initialization */ +#define CONFIG_SYS_EBC_PB3AP 0x02815480 +#define CONFIG_SYS_EBC_PB3CR (CONFIG_SYS_IO_BASE | 0x1A000) /* BAS=IO,BS=1MB,BU=R/W,BW=16bit*/ + +/* + * PPC4xx GPIO Configuration + */ +/* 460EX: Use USB configuration */ +#define CONFIG_SYS_4xx_GPIO_TABLE { /* Out GPIO Alternate1 Alternate2 Alternate3 */ \ +{ \ +/* GPIO Core 0 */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO0 GMC1TxD(0) USB2HostD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO1 GMC1TxD(1) USB2HostD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO2 GMC1TxD(2) USB2HostD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO3 GMC1TxD(3) USB2HostD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO4 GMC1TxD(4) USB2HostD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO5 GMC1TxD(5) USB2HostD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO6 GMC1TxD(6) USB2HostD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO7 GMC1TxD(7) USB2HostD(7) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO8 GMC1RxD(0) USB2OTGD(0) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO9 GMC1RxD(1) USB2OTGD(1) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO10 GMC1RxD(2) USB2OTGD(2) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO11 GMC1RxD(3) USB2OTGD(3) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO12 GMC1RxD(4) USB2OTGD(4) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO13 GMC1RxD(5) USB2OTGD(5) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO14 GMC1RxD(6) USB2OTGD(6) */ \ +{GPIO0_BASE, GPIO_BI , GPIO_ALT1, GPIO_OUT_0}, /* GPIO15 GMC1RxD(7) USB2OTGD(7) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_SEL, GPIO_OUT_0}, /* GPIO16 GMC1TxER USB2HostStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO17 GMC1CD USB2HostNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO18 GMC1RxER USB2HostDir */ \ +{GPIO0_BASE, GPIO_IN, GPIO_SEL, GPIO_OUT_0}, /* GPIO19 GMC1TxEN USB2OTGStop */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO20 GMC1CRS USB2OTGNext */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO21 GMC1RxDV USB2OTGDir */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO22 NFRDY */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO23 NFREN */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO24 NFWEN */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO25 NFCLE */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO26 NFALE */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO27 IRQ(0) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO28 IRQ(1) */ \ +{GPIO0_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO29 IRQ(2) */ \ +{GPIO0_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO30 PerPar0 DMAReq2 IRQ(7)*/ \ +{GPIO0_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO31 PerPar1 DMAAck2 IRQ(8)*/ \ +}, \ +{ \ +/* GPIO Core 1 */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO32 PerPar2 EOT2/TC2 IRQ(9)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO33 PerPar3 DMAReq3 IRQ(4)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT3, GPIO_OUT_1}, /* GPIO34 UART0_DCD_N UART1_DSR_CTS_N UART2_SOUT*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO35 UART0_8PIN_DSR_N UART1_RTS_DTR_N UART2_SIN*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO36 UART0_8PIN_CTS_N DMAAck3 UART3_SIN*/ \ +{GPIO1_BASE, GPIO_BI , GPIO_ALT2, GPIO_OUT_0}, /* GPIO37 UART0_RTS_N EOT3/TC3 UART3_SOUT*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT2, GPIO_OUT_1}, /* GPIO38 UART0_DTR_N UART1_SOUT */ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT2, GPIO_OUT_0}, /* GPIO39 UART0_RI_N UART1_SIN */ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT1, GPIO_OUT_0}, /* GPIO40 IRQ(3) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO41 CS(1) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO42 CS(2) */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO43 CS(3) DMAReq1 IRQ(10)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO44 CS(4) DMAAck1 IRQ(11)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_ALT3, GPIO_OUT_0}, /* GPIO45 CS(5) EOT/TC1 IRQ(12)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO46 PerAddr(5) DMAReq0 IRQ(13)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO47 PerAddr(6) DMAAck0 IRQ(14)*/ \ +{GPIO1_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_0}, /* GPIO48 PerAddr(7) EOT/TC0 IRQ(15)*/ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO49 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO50 USB_SERVICE_SUSPEND_N */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO51 SPI_CSS_N */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO52 FPGA_PROGRAM_UC_N */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO53 FPGA_INIT_UC_N */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO54 WD_STROBE */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO55 LED_2_OUT */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO56 LED_1_OUT */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO57 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO58 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO59 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO60 Unselect via TraceSelect Bit */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_0}, /* GPIO61 STARTUP_FINISHED_N */ \ +{GPIO1_BASE, GPIO_OUT, GPIO_SEL , GPIO_OUT_1}, /* GPIO62 STARTUP_FINISHED */ \ +{GPIO1_BASE, GPIO_IN , GPIO_SEL , GPIO_OUT_0}, /* GPIO63 SERVICE_PORT_ACTIVE */ \ +} \ +} + +#endif /* __CONFIG_H */
Dear Dirk Eibach,
- Bytes 5,6,8,9,11 change for NAND boot
+#if 0 +/*
- Values for 512 page size NAND chips, not used anymore, just
- keep them here for reference
- 0x90, 0x01, 0xa0, 0x68, 0x58
+}; +#else
Please do not add dead code.
- Values for 2k page size NAND chips
- 0x90, 0x01, 0xa0, 0xe8, 0x58
+}; +#endif
- /* set the nand flag based on provided input */
- if ((strcmp(argv[1], "nand") == 0))
b_nand = 1;
- else
b_nand = 0;
Consider changing this into:
if ((strcmp(argv[1], "nand") == 0)) b_nand = NAND_COMPATIBLE; else b_nand = NOR_COMPATIBLE;
(and probably chose a diferent name for the variable then).
Then you could simplify this into:
- printf("Available configurations: \n\n");
- if (b_nand) {
y++;
- } else {
y++;
for (x = 0, y = 0; boot_configs[x][0] != 0; x++) { if (boot_configs[x][0] & b_nand) { printf(" %d - %s\n", (y+1), config_labels[x]); y++; } }
- for (x = 0; boot_configs[x][0] != 0; x++) {
if (b_nand) {
if (y > 0)
y--;
else if (y < 1)
break;
} else {
if (y > 0)
y--;
else if (y < 1)
break;
Ditto here.
+tlbtab:
- tlbtab_start
* enable SA_I
- tlbentry(CONFIG_SYS_BOOT_BASE_ADDR, SZ_16M, CONFIG_SYS_BOOT_BASE_ADDR, 4, AC_R|AC_W|AC_X|SA_G) /* TLB 0 */
Line way too long.
* routine.
- /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */
- tlbentry(CONFIG_SYS_INIT_RAM_ADDR, SZ_4K, CONFIG_SYS_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G)
Ditto. Please fix everywhere.
- Base addresses -- Note these are effective addresses where the
- actual resources get mapped (not physical addresses)
More too long lines in this file.
Dirk Eibach
