[U-Boot] [PATCH 13/22] ppc4xx: remove PMC405 board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 - board/esd/pmc405/Kconfig | 12 -- board/esd/pmc405/MAINTAINERS | 6 - board/esd/pmc405/Makefile | 13 -- board/esd/pmc405/pmc405.c | 142 ----------------- configs/PMC405_defconfig | 3 - doc/README.scrapyard | 1 + include/configs/PMC405.h | 318 --------------------------------------- 8 files changed, 1 insertion(+), 498 deletions(-) delete mode 100644 board/esd/pmc405/Kconfig delete mode 100644 board/esd/pmc405/MAINTAINERS delete mode 100644 board/esd/pmc405/Makefile delete mode 100644 board/esd/pmc405/pmc405.c delete mode 100644 configs/PMC405_defconfig delete mode 100644 include/configs/PMC405.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index 0e8cbf3..eddaee1 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -128,9 +128,6 @@ config TARGET_CPCI405DT config TARGET_PLU405 bool "Support PLU405"
-config TARGET_PMC405 - bool "Support PMC405" - config TARGET_PMC405DE bool "Support PMC405DE"
@@ -224,7 +221,6 @@ source "board/dave/PPChameleonEVB/Kconfig" source "board/esd/cpci2dp/Kconfig" source "board/esd/cpci405/Kconfig" source "board/esd/plu405/Kconfig" -source "board/esd/pmc405/Kconfig" source "board/esd/pmc405de/Kconfig" source "board/esd/pmc440/Kconfig" source "board/esd/voh405/Kconfig" diff --git a/board/esd/pmc405/Kconfig b/board/esd/pmc405/Kconfig deleted file mode 100644 index 3738c68..0000000 --- a/board/esd/pmc405/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_PMC405 - -config SYS_BOARD - default "pmc405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "PMC405" - -endif diff --git a/board/esd/pmc405/MAINTAINERS b/board/esd/pmc405/MAINTAINERS deleted file mode 100644 index 148a596..0000000 --- a/board/esd/pmc405/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -PMC405 BOARD -M: Matthias Fuchs matthias.fuchs@esd-electronics.com -S: Maintained -F: board/esd/pmc405/ -F: include/configs/PMC405.h -F: configs/PMC405_defconfig diff --git a/board/esd/pmc405/Makefile b/board/esd/pmc405/Makefile deleted file mode 100644 index ad98207..0000000 --- a/board/esd/pmc405/Makefile +++ /dev/null @@ -1,13 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# Objects for Xilinx JTAG programming (CPLD) -CPLD = ../common/xilinx_jtag/lenval.o \ - ../common/xilinx_jtag/micro.o \ - ../common/xilinx_jtag/ports.o - -obj-y = pmc405.o ../common/misc.o ../common/cmd_loadpci.o $(CPLD) diff --git a/board/esd/pmc405/pmc405.c b/board/esd/pmc405/pmc405.c deleted file mode 100644 index e67ff30..0000000 --- a/board/esd/pmc405/pmc405.c +++ /dev/null @@ -1,142 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Stefan Roese, DENX Software Engineering, sr@denx.de. - * - * (C) Copyright 2005-2009 - * Matthias Fuchs, esd gmbh germany, matthias.fuchs@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <command.h> -#include <malloc.h> - -DECLARE_GLOBAL_DATA_PTR; - -extern void lxt971_no_sleep(void); - -int board_early_init_f (void) -{ - /* - * IRQ 0-15 405GP internally generated; active high; level sensitive - * IRQ 16 405GP internally generated; active low; level sensitive - * IRQ 17-24 RESERVED - * IRQ 25 (EXT IRQ 0) CAN0; active low; level sensitive - * IRQ 26 (EXT IRQ 1) SER0 ; active low; level sensitive - * IRQ 27 (EXT IRQ 2) SER1; active low; level sensitive - * IRQ 28 (EXT IRQ 3) FPGA 0; active low; level sensitive - * IRQ 29 (EXT IRQ 4) FPGA 1; active low; level sensitive - * IRQ 30 (EXT IRQ 5) PCI INTA; active low; level sensitive - * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive - */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0ER, 0x00000000); /* disable all ints */ - mtdcr(UIC0CR, 0x00000000); /* set all to be non-critical*/ - mtdcr(UIC0PR, 0xFFFFFF81); /* set int polarities */ - mtdcr(UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr(UIC0VCR, 0x00000001); /* set vect base=0, INT0 highest priority */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - /* - * EBC Configuration Register: - * set ready timeout to 512 ebc-clks -> ca. 15 us - */ - mtebc (EBC0_CFG, 0xa8400000); - - /* - * Setup GPIO pins - */ - mtdcr(CPC0_CR0, mfdcr(CPC0_CR0) | ((CONFIG_SYS_FPGA_INIT | - CONFIG_SYS_FPGA_DONE | - CONFIG_SYS_XEREADY | - CONFIG_SYS_NONMONARCH | - CONFIG_SYS_REV1_2) << 5)); - - if (!(in_be32((void *)GPIO0_IR) & CONFIG_SYS_REV1_2)) { - /* rev 1.2 boards */ - mtdcr(CPC0_CR0, mfdcr(CPC0_CR0) | ((CONFIG_SYS_INTA_FAKE | - CONFIG_SYS_SELF_RST) << 5)); - } - - out_be32((void *)GPIO0_OR, CONFIG_SYS_VPEN); - /* setup for output */ - out_be32((void *)GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | - CONFIG_SYS_FPGA_DATA | CONFIG_SYS_XEREADY | CONFIG_SYS_VPEN); - - /* - * - check if rev1_2 is low, then: - * - set/reset CONFIG_SYS_INTA_FAKE/CONFIG_SYS_SELF_RST - * in TCR to assert INTA# or SELFRST# - */ - return 0; -} - -int misc_init_r (void) -{ - /* adjust flash start and offset */ - gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; - gd->bd->bi_flashoffset = 0; - - /* deassert EREADY# */ - out_be32((void *)GPIO0_OR, - in_be32((void *)GPIO0_OR) | CONFIG_SYS_XEREADY); - return (0); -} - -ushort pmc405_pci_subsys_deviceid(void) -{ - ulong val; - - val = in_be32((void *)GPIO0_IR); - if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ - /* check monarch# signal */ - if (val & CONFIG_SYS_NONMONARCH) - return CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH; - return CONFIG_SYS_PCI_SUBSYS_DEVICEID_MONARCH; - } - return CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH; -} - -/* - * Check Board Identity - */ -int checkboard (void) -{ - ulong val; - char str[64]; - int i = getenv_f("serial#", str, sizeof(str)); - - puts ("Board: "); - - if (i == -1) - puts ("### No HW ID - assuming PMC405"); - else - puts(str); - - val = in_be32((void *)GPIO0_IR); - if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ - puts(" rev1.2 ("); - if (val & CONFIG_SYS_NONMONARCH) /* monarch# signal */ - puts("non-"); - puts("monarch)"); - } else - puts(" <=rev1.1"); - - putc ('\n'); - - return 0; -} - -void reset_phy(void) -{ -#ifdef CONFIG_LXT971_NO_SLEEP - - /* - * Disable sleep mode in LXT971 - */ - lxt971_no_sleep(); -#endif -} diff --git a/configs/PMC405_defconfig b/configs/PMC405_defconfig deleted file mode 100644 index d82117c..0000000 --- a/configs/PMC405_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_PMC405=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index a41d942..24a5d93 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,7 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +PMC405 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu PCI405 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu OCRTC ppc4xx 405gpr - - Matthias Fuchs matthias.fuchs@esd.eu HUB405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu diff --git a/include/configs/PMC405.h b/include/configs/PMC405.h deleted file mode 100644 index c68d9a6..0000000 --- a/include/configs/PMC405.h +++ /dev/null @@ -1,318 +0,0 @@ -/* - * (C) Copyright 2001-2004 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - */ - -#define CONFIG_405GP 1 /* This is a PPC405 CPU */ -#define CONFIG_PMC405 1 /* ...on a PMC405 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFF80000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33330000 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -/* Only interrupt boot if space is pressed. */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#define CFG_BOOTM_LEN 0x1000000 /* support booting of huge images */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#undef CONFIG_HAS_ETH1 - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BSP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_ELF -#define CONFIG_CMD_DATE -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII -#define CONFIG_CMD_I2C -#define CONFIG_CMD_PING -#define CONFIG_CMD_UNIVERSE -#define CONFIG_CMD_EEPROM - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible */ -#define CONFIG_SYS_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Sz */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console info */ - -#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock */ -#define CONFIG_SYS_BASE_BAUD 806400 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_LOOPW 1 /* enable loopw command */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -#define CONFIG_SYS_RX_ETH_BUFFER 16 - -/* - * PCI stuff - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config */ - -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH 0x0408 /* PCI Device ID */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_MONARCH 0x0409 /* PCI Device ID */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID pmc405_pci_subsys_deviceid() - -#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* Processor/PPC */ - -#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CONFIG_SYS_PCI_PTM2LA 0xef000000 /* point to internal regs */ -#define CONFIG_SYS_PCI_PTM2MS 0xff000001 /* 16MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI 0x00000000 /* Host: use this pci address */ - -#define CONFIG_PCI_4xx_PTM_OVERWRITE 1 /* overwrite PTMx settings by env */ - -/* - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (~(CONFIG_SYS_TEXT_BASE) + 1) -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* 128 kB for malloc() */ - -#define CONFIG_PRAM 0 /* use pram variable to overwrite */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * FLASH organization - */ -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#define CONFIG_SYS_FLASH_INCREMENT 0x01000000 - -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* don't use hardware protection */ -#define CONFIG_SYS_FLASH_AUTOPROTECT_LIST {{0xfff80000, 0x80000}} -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (faster) */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, \ - CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_INCREMENT} -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on fli */ - -/* - * Environment Variable setup - */ -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ - -/* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_OFFSET 0x000 -#define CONFIG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars */ - -#define CONFIG_SYS_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE 242 /* NVRAM size */ - -/* - * I2C EEPROM (CAT24WC16) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 100000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT24W16 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24W16 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ - -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/* - * External Bus Controller (EBC) Setup - */ -#define FLASH0_BA 0xFF000000 /* FLASH 0 Base Address */ -#define FLASH1_BA 0xFE000000 /* FLASH 1 Base Address */ -#define CAN_BA 0xF0000000 /* CAN Base Addres */ -#define RTC_BA 0xF0000500 /* RTC Base Address */ -#define NVRAM_BA 0xF0200000 /* NVRAM Base Address */ - -/* Memory Bank 0 (Flash Bank 0) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -/* BAS=0xFF0,BS=16MB,BU=R/W,BW=16bit */ -#define CONFIG_SYS_EBC_PB0CR (FLASH0_BA | 0x9A000) - -/* Memory Bank 1 (Flash Bank 1) initialization */ -#define CONFIG_SYS_EBC_PB1AP 0x92015480 -/* BAS=0xFE0,BS=16MB,BU=R/W,BW=16bit*/ -#define CONFIG_SYS_EBC_PB1CR (FLASH1_BA | 0x9A000) - -/* Memory Bank 2 (CAN0, 1, RTC) initialization */ -/* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ -#define CONFIG_SYS_EBC_PB2AP 0x03000440 -/* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ -#define CONFIG_SYS_EBC_PB2CR (CAN_BA | 0x18000) - -/* Memory Bank 3 -> unused */ - -/* Memory Bank 4 (NVRAM) initialization */ -/* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ -#define CONFIG_SYS_EBC_PB4AP 0x03000440 -/* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ -#define CONFIG_SYS_EBC_PB4CR (NVRAM_BA | 0x18000) - -/* - * FPGA stuff - */ -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* JTAG TMS pin (output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* JTAG TCK pin (output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* JTAG TDO pin (output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* unused (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* JTAG TDI pin (input) */ - -/* pass Ethernet MAC to VxWorks */ -#define CONFIG_SYS_VXWORKS_MAC_PTR 0x00000000 - -/* - * GPIOs - */ -#define CONFIG_SYS_VPEN (0x80000000 >> 3) /* GPIO3 */ -#define CONFIG_SYS_NONMONARCH (0x80000000 >> 14) /* GPIO14 */ -#define CONFIG_SYS_XEREADY (0x80000000 >> 15) /* GPIO15 */ -#define CONFIG_SYS_INTA_FAKE (0x80000000 >> 19) /* GPIO19 */ -#define CONFIG_SYS_SELF_RST (0x80000000 >> 21) /* GPIO21 */ -#define CONFIG_SYS_REV1_2 (0x80000000 >> 23) /* GPIO23 */ - -/* - * Definitions for initial stack pointer and data area (in data cache) - */ - -/* use on chip memory (OCM) for temperary stack until sdram is tested */ -#define CONFIG_SYS_TEMP_STACK_OCM 1 - -/* On Chip Memory location */ -#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 -#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 - -/* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR - -/* End of used area in RAM */ -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_OF_LIBFDT -#define CONFIG_OF_BOARD_SETUP - -#endif /* __CONFIG_H */
Matthias Fuchs
