[PATCH v2 0/1] sunxi: Add support for FriendlyARM NanoPi R1S H5
Hi Andre,
Please don't include not-yet-merged parts in here. Make a verbatim copy of the version in Linus' tree.
Okay, I remove the not-yet-merged parts in dts.
who is reading the MAC address out of the EEPROM, and how does it land in the kernel (if it lands there)?
There is a rtl8153 usb network card on this machine, and it will randomly generate a mac address when it bootup. I think the mac address on the eeprom is for this rtl8153 usb network card.
So why is CONFIG_MACPWR missing from the defconfig?
This is my mistake, I'm very sorry about that.
Thanks, Chukun
Chukun Pan (1): sunxi: Add support for FriendlyARM NanoPi R1S H5
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts | 195 +++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/nanopi_r1s_h5_defconfig | 14 ++ 4 files changed, 215 insertions(+) create mode 100644 arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts create mode 100644 configs/nanopi_r1s_h5_defconfig
This adds support for the NanoPi R1S H5 board.
Allwinner H5 SoC 512MB DDR3 RAM 10/100/1000M Ethernet x 2 RTL8189ETV WiFi 802.11b/g/n USB 2.0 host port (A) MicroSD Slot Reset button Serial Debug Port WAN - LAN - SYS LED
The dts file is taken from Linux 5.14 tag.
Signed-off-by: Chukun Pan amadeus@jmu.edu.cn --- Changes for v2: - Remove not-yet-merged parts in dts - Add missing CONFIG_MACPWR option
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9e44817a40..e278480c1c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -632,6 +632,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-libretech-all-h5-cc.dtb \ sun50i-h5-nanopi-neo2.dtb \ sun50i-h5-nanopi-neo-plus2.dtb \ + sun50i-h5-nanopi-r1s-h5.dtb \ sun50i-h5-orangepi-zero-plus.dtb \ sun50i-h5-orangepi-pc2.dtb \ sun50i-h5-orangepi-prime.dtb \ diff --git a/arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts b/arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts new file mode 100644 index 0000000000..55bcdf8d1a --- /dev/null +++ b/arch/arm/dts/sun50i-h5-nanopi-r1s-h5.dts @@ -0,0 +1,195 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2021 Chukun Pan amadeus@jmu.edu.cn + * + * Based on sun50i-h5-nanopi-neo-plus2.dts, which is: + * Copyright (C) 2017 Antony Antony antony@phenome.org + * Copyright (C) 2016 ARM Ltd. + */ + +/dts-v1/; +#include "sun50i-h5.dtsi" +#include "sun50i-h5-cpu-opp.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> + +/ { + model = "FriendlyARM NanoPi R1S H5"; + compatible = "friendlyarm,nanopi-r1s-h5", "allwinner,sun50i-h5"; + + aliases { + ethernet0 = &emac; + ethernet1 = &rtl8189etv; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + function = LED_FUNCTION_LAN; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pio 0 9 GPIO_ACTIVE_HIGH>; + }; + + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + led-2 { + function = LED_FUNCTION_WAN; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pio 6 11 GPIO_ACTIVE_HIGH>; + }; + }; + + r-gpio-keys { + compatible = "gpio-keys"; + + reset { + label = "reset"; + linux,code = <KEY_RESTART>; + gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>; + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; + }; + + vdd_cpux: gpio-regulator { + compatible = "regulator-gpio"; + regulator-name = "vdd-cpux"; + regulator-type = "voltage"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1300000>; + regulator-ramp-delay = <50>; /* 4ms */ + gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; + gpios-states = <0x1>; + states = <1100000 0x0>, <1300000 0x1>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + post-power-on-delay-ms = <200>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_cpux>; +}; + +&ehci1 { + status = "okay"; +}; + +&ehci2 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii-id"; + status = "okay"; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + +&i2c0 { + status = "okay"; + + eeprom@51 { + compatible = "microchip,24c02"; + reg = <0x51>; + pagesize = <16>; + }; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8189etv: sdio_wifi@1 { + reg = <1>; + }; +}; + +&ohci1 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pa_pins>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + /* USB Type-A port's VBUS is always on */ + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 4fc26077b2..6cb36d8209 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -358,6 +358,11 @@ M: Jelle van der Waa jelle@vdwaa.nl S: Maintained F: configs/nanopi_neo_air_defconfig
+NANOPI-R1S-H5 BOARD +M: Chukun Pan amadeus@jmu.edu.cn +S: Maintained +F: configs/nanopi_r1s_h5_defconfig + NANOPI-A64 BOARD M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi_r1s_h5_defconfig b/configs/nanopi_r1s_h5_defconfig new file mode 100644 index 0000000000..27cf172d72 --- /dev/null +++ b/configs/nanopi_r1s_h5_defconfig @@ -0,0 +1,14 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-r1s-h5" +CONFIG_SPL=y +CONFIG_MACH_SUN50I_H5=y +CONFIG_DRAM_CLK=672 +CONFIG_DRAM_ZQ=3881977 +# CONFIG_DRAM_ODT_EN is not set +CONFIG_MACPWR="PD6" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
On Sun, 10 Oct 2021 21:36:56 +0800 Chukun Pan amadeus@jmu.edu.cn wrote:
Hi Andre,
Well, fair enough, but how does this MAC address end up in the USB MAC? I guess this misses some code, but IIUC Chen-Yu pointed you to the solution already in the Linux thread.
Many thanks for the quick turnaround, that looks alright now. I will push it as part of the sunxi PR for v2022.01.
Thanks, Chukun
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
Andre Przywara
Chukun Pan
