[U-Boot] universal_c210: fix compiler error and compiler warning
This patch fix following errors
universal.c: In function 'init_pmic_lcd': universal.c:340: warning: implicit declaration of function 'get_pmic' universal.c:340: warning: initialization makes pointer from integer without a cast universal.c: In function 'lcd_power_on': universal.c:431: warning: initialization makes pointer from integer without a cast universal.c: At top level: universal.c:335: warning: 'init_pmic_lcd' defined but not used
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Cc: Donghwa Lee dh09.lee@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com --- board/samsung/universal_c210/universal.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 3d508be..4869798 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -55,6 +55,8 @@ static int get_hwrev(void) return board_rev & 0xFF; }
+static void init_pmic_lcd(void); + int power_init_board(void) { int ret; @@ -63,6 +65,8 @@ int power_init_board(void) if (ret) return ret;
+ init_pmic_lcd(); + return 0; }
@@ -337,7 +341,7 @@ static void init_pmic_lcd(void) unsigned char val; int ret = 0;
- struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8998_PMIC");
if (pmic_probe(p)) return; @@ -428,7 +432,7 @@ static void reset_lcd(void)
static void lcd_power_on(void) { - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8998_PMIC");
Dear Minkyu Kang,
In message 50C58623.3090308@samsung.com you wrote: ...
This is unrelated to your patch - but what if pmic_get() returns NULL?
pmic_probe() will crashif you pass it a NULL pointer...
Hi Wolfgang,
Dear Minkyu Kang,
The PMIC 2.0 uses malloc to allocate pmic structure.
The fix, which has been proposed would work for old pmic.
In the new one PMIC 2.0, we require to test return pointer from pmic_get() (similar to all malloc allocations):
struct pmic *p = pmic_get("MAX8998_PMIC"); if (!p) return -ENODEV;
Dear Wolfgang,
On 10/12/12 18:32, Lukasz Majewski wrote:
Hi Wolfgang,
Dear Minkyu Kang,
I will fix it by another patch.
Thanks. Minkyu Kang.
Dear Lukasz Majewski,
...and malloc() can fail.
So this code here needs fixing. This is what I wanted to point out.
- int power_init_board(void) { int ret;
- init_pmic_lcd();
- return 0; }
Tested-by: Piotr Wilczek p.wilczek@samsung.com
applied to u-boot-samsung/resolve
Lukasz Majewski
Minkyu Kang
Piotr Wilczek
