[U-Boot] [PATCH 1/6 v2] powerpc/doc: Update the README.srio-pcie-boot-corenet
1. Misalignment will be found in the doc/README.srio-pcie-boot-corenet file when the tabs are set to 8 characters. And the standard for u-boot should be 8 character tabs! So this issue should be amended.
2. Add a NOTE for the ENV parameters of the Slave.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- changes for v2: - No
doc/README.srio-pcie-boot-corenet | 34 ++++++++++++++++++++-------------- 1 files changed, 20 insertions(+), 14 deletions(-)
diff --git a/doc/README.srio-pcie-boot-corenet b/doc/README.srio-pcie-boot-corenet index cd7e7ee..2b1f76b 100644 --- a/doc/README.srio-pcie-boot-corenet +++ b/doc/README.srio-pcie-boot-corenet @@ -21,13 +21,13 @@ Environment of the SRIO or PCIE boot: e) Slave's RCW should configure the SerDes for SRIO or PCIE boot port, set the boot location to SRIO or PCIE, and holdoff all the cores.
- ---------- ----------- ----------- - | | | | | | - | | | | | | + ----------- ----------- ----------- + | | | | | | + | | | | | | | NorFlash|<----->| Master |SRIO or PCIE | Slave |<---->[EEPROM] - | | | |<===========>| | - | | | | | | - ---------- ----------- ----------- + | | | |<===========>| | + | | | | | | + ----------- ----------- -----------
The example based on P4080DS platform: Two P4080DS platforms can be used to implement the boot from SRIO or PCIE. @@ -87,26 +87,32 @@ How to use this feature: Please refer to the examples given above.
2. U-Boot image's compilation. - For master, U-Boot image should be generated normally. + For master, U-Boot image should be generated normally.
- For example, master U-Boot image used on P4080DS should be compiled with + For example, master U-Boot image used on P4080DS should be compiled with
make P4080DS_config.
- For slave, U-Boot image should be generated specifically by + For slave, U-Boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
- For example, slave U-Boot image used on P4080DS should be compiled with + For example, slave U-Boot image used on P4080DS should be compiled with
make P4080DS_SRIO_PCIE_BOOT_config.
3. Necessary modifications based on a specific environment. - For a specific environment, the addresses of the slave's U-Boot image, - UCode, ENV stored in master's NorFlash, and any other configurations - can be modified in the file: - include/configs/corenet_ds.h. + For a specific environment, the addresses of the slave's U-Boot image, + UCode, ENV stored in master's NorFlash, and any other configurations + can be modified in the file: + include/configs/corenet_ds.h.
4. Set and save the environment variable "bootmaster" with "SRIO1", "SRIO2" or "PCIE1", "PCIE2", "PCIE3" for master, and then restart it in order to perform the role as a master for boot from SRIO or PCIE. + +NOTE: When the Slave's ENV parameters are stored in Master's NorFlash, + it can fetch them through PCIE or SRIO interface. But the ENV + parameters can not be modified by "saveenv" or other commands under + the Slave's u-boot environment, because the Slave can not erase, + write Master's NorFlash by PCIE or SRIO link.
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h.
Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE.
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- changes for v2: - Add the description for why the old macro should be modified and removed from the config_mpc85xx.h file.
README | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/cpu/mpc8xxx/srio.c | 4 ++-- arch/powerpc/include/asm/config_mpc85xx.h | 4 ---- drivers/pci/fsl_pci_init.c | 6 +++--- include/configs/P2041RDB.h | 1 + include/configs/P3041DS.h | 2 +- include/configs/P4080DS.h | 2 +- include/configs/P5020DS.h | 2 +- 9 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/README b/README index 0d37d56..b25976a 100644 --- a/README +++ b/README @@ -3862,6 +3862,9 @@ Low Level (hardware related) configuration options: - CONFIG_SRIO2: Board has SRIO 2 port available
+- CONFIG_SRIO_PCIE_BOOT_MASTER + Board can support master function for Boot from SRIO and PCIE + - CONFIG_SYS_SRIOn_MEM_VIRT: Virtual Address of SRIO port 'n' memory region
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 53713e3..9256449 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -564,7 +564,7 @@ skip_l2:
#ifdef CONFIG_SYS_SRIO srio_init(); -#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER char *s = getenv("bootmaster"); if (s) { if (!strcmp(s, "SRIO1")) { diff --git a/arch/powerpc/cpu/mpc8xxx/srio.c b/arch/powerpc/cpu/mpc8xxx/srio.c index 6e6f7dc..90d1065 100644 --- a/arch/powerpc/cpu/mpc8xxx/srio.c +++ b/arch/powerpc/cpu/mpc8xxx/srio.c @@ -24,7 +24,7 @@ #include <asm/fsl_srio.h> #include <asm/errno.h>
-#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER #define SRIO_PORT_ACCEPT_ALL 0x10000001 #define SRIO_IB_ATMU_AR 0x80f55000 #define SRIO_OB_ATMU_AR_MAINT 0x80077000 @@ -299,7 +299,7 @@ void srio_init(void) } }
-#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER void srio_boot_master(int port) { struct ccsr_rio *srio = (void *)CONFIG_SYS_FSL_SRIO_ADDR; diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 7267611..cfaa0e1 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -337,7 +337,6 @@ #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 -#define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 @@ -371,7 +370,6 @@ #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 -#define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 @@ -413,7 +411,6 @@ #define CONFIG_SYS_P4080_ERRATUM_SERDES_A005 #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 -#define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 @@ -449,7 +446,6 @@ #define CONFIG_SYS_FSL_ERRATUM_USB14 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 -#define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 77ac1f7..621c899 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -211,7 +211,7 @@ static int fsl_pci_setup_inbound_windows(struct pci_controller *hose, return 1; }
-#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER static void fsl_pcie_boot_master(pit_t *pi) { /* configure inbound window for slave's u-boot image */ @@ -388,7 +388,7 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) /* see if we are a PCIe or PCI controller */ pci_hose_read_config_byte(hose, dev, FSL_PCIE_CAP_ID, &pcie_cap);
-#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER /* boot from PCIE --master */ char *s = getenv("bootmaster"); char pcie[6]; @@ -624,7 +624,7 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, if (fsl_is_pci_agent(hose)) { fsl_pci_config_unlock(hose); hose->last_busno = hose->first_busno; -#ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER } else { /* boot from PCIE --master releases slave's core 0 */ char *s = getenv("bootmaster"); diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index bbc53ce..ebef17f 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -77,6 +77,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ +#define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_DPAA_RMAN /* RMan */
#define CONFIG_FSL_LAW /* Use common FSL init code */ diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index ce8f9b0..dd2b9c3 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -40,7 +40,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ - +#define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
#include "corenet_ds.h" diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 53979dd..48acee4 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -36,7 +36,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ - +#define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_ICS307_REFCLK_HZ 33333000 /* ICS307 ref clk freq */
#include "corenet_ds.h" diff --git a/include/configs/P5020DS.h b/include/configs/P5020DS.h index 778230d..d1e27c4 100644 --- a/include/configs/P5020DS.h +++ b/include/configs/P5020DS.h @@ -41,7 +41,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ - +#define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
Applied, thanks!
Andy
B4860QDS can support the feature of Boot from SRIO/PCIE, and the macro "CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature when building the u-boot image.
You can get some description about this macro in README file, and for more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet.
include/configs/B4860QDS.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index b09119a..81cd584 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -64,6 +64,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ +#define CONFIG_SRIO_PCIE_BOOT_MASTER #endif
Applied, thanks!
Andy
When a b4860qds board boots from SRIO or PCIE, it needs to finish these processes: 1. Set all the cores in holdoff status. 2. Set the boot location to one PCIE or SRIO interface by RCW. 3. Set a specific TLB entry for the boot process. 4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 5. Set a specific TLB entry in order to fetch ucode and ENV from master. 6. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 7. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet.
arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/b4860qds/tlb.c | 19 +++++++++++++++++++ boards.cfg | 1 + include/configs/B4860QDS.h | 32 +++++++++++++++++++++++++++----- 4 files changed, 48 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index baaa9fe..eb28768 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1845,6 +1845,7 @@ typedef struct ccsr_gur { #define FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT 25 #define FSL_CORENET2_RCWSR4_SRDS2_PRTCL 0x00ff0000 #define FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT 16 +#define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 #endif #define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL1 0x00800000 #define FSL_CORENET2_RCWSR5_SRDS_PLL_PD_S1_PLL2 0x00400000 diff --git a/board/freescale/b4860qds/tlb.c b/board/freescale/b4860qds/tlb.c index 6d634bf..9ea3c81 100644 --- a/board/freescale/b4860qds/tlb.c +++ b/board/freescale/b4860qds/tlb.c @@ -52,6 +52,15 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_1M, 1), +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) + /* + * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the + * space is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), #else SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -137,6 +146,16 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 16, BOOKE_PAGESZ_256M, 1), #endif +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE + /* + * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for + * fetching ucode and ENV from master + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 17, BOOKE_PAGESZ_1M, 1), +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 5d78064..61acc3f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -899,6 +899,7 @@ T4240QDS_SPIFLASH powerpc mpc85xx t4qds freesca B4860QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860 B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +B4860QDS_SRIO_PCIE_BOOT powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 B4420QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420 B4420QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 B4420QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 81cd584..00ee5ac 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -34,6 +34,15 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #endif
+#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + /* High Level Configuration Options */ #define CONFIG_BOOKE #define CONFIG_E6500 @@ -86,14 +95,15 @@ #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_SYS_NO_FLASH +#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) #define CONFIG_ENV_IS_NOWHERE +#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #endif
-#ifndef CONFIG_SYS_NO_FLASH #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_SPI_FLASH @@ -115,16 +125,18 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif
#ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); @@ -593,6 +605,16 @@ unsigned long get_board_ddr_clk(void); #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000
- Set all the cores in holdoff status.
- Set the boot location to one PCIE or SRIO interface by RCW.
- Set a specific TLB entry for the boot process.
- Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
- Set a specific TLB entry in order to fetch ucode and ENV from master.
- Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV.
- Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
Applied, thanks!
Andy
T4 can support the feature of Boot from SRIO/PCIE, and the macro "CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature when building the u-boot image.
include/configs/t4qds.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 2c665b8..a0c96f2 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -64,6 +64,7 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ +#define CONFIG_SRIO_PCIE_BOOT_MASTER
Applied, thanks!
Andy
When a T4 board boots from SRIO or PCIE, it needs to finish these processes: 1. Set all the cores in holdoff status. 2. Set the boot location to one PCIE or SRIO interface by RCW. 3. Set a specific TLB entry for the boot process. 4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 5. Set a specific TLB entry in order to fetch ucode and ENV from master. 6. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 7. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
arch/powerpc/include/asm/immap_85xx.h | 1 + board/freescale/t4qds/tlb.c | 19 ++++++++++++++++++ boards.cfg | 1 + include/configs/t4qds.h | 34 ++++++++++++++++++++++++++------ 4 files changed, 48 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index eb28768..af9a846 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1840,6 +1840,7 @@ typedef struct ccsr_gur { #define FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT 11 #define FSL_CORENET2_RCWSR4_SRDS4_PRTCL 0x000000f8 #define FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT 3 +#define FSL_CORENET_RCWSR6_BOOT_LOC 0x0f800000 #elif defined(CONFIG_PPC_B4860) || defined(CONFIG_PPC_B4420) #define FSL_CORENET2_RCWSR4_SRDS1_PRTCL 0xfe000000 #define FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT 25 diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c index 80eb511..2370332 100644 --- a/board/freescale/t4qds/tlb.c +++ b/board/freescale/t4qds/tlb.c @@ -55,6 +55,15 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_1M, 1), +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) + /* + * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the + * space is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), #else SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -130,6 +139,16 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 17, BOOKE_PAGESZ_4K, 1), +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE + /* + * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for + * fetching ucode and ENV from master + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 18, BOOKE_PAGESZ_1M, 1), +#endif
diff --git a/boards.cfg b/boards.cfg index 61acc3f..354738e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -896,6 +896,7 @@ stxssa_4M powerpc mpc85xx stxssa stx T4240QDS powerpc mpc85xx t4qds freescale T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +T4240QDS_SRIO_PCIE_BOOT powerpc mpc85xx t4qds freescale - T4240QDS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 B4860QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860 B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index a0c96f2..5077cf3 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -31,6 +31,15 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #endif
+#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + #define CONFIG_CMD_REGINFO
/* High Level Configuration Options */ @@ -71,14 +80,15 @@ #define CONFIG_ENV_OVERWRITE
-#ifndef CONFIG_SYS_NO_FLASH #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_SPI_FLASH @@ -100,18 +110,18 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - -
#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() @@ -625,6 +635,16 @@ unsigned long get_board_ddr_clk(void); #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000
Applied with fixes for build errors. I think this was just an issue of this patch arriving before the T4 consolidation patch, but please be careful.
Had to fix this line so it included PPC_T4240, for future reference
Thanks, Andy
Applied, thanks!
Andy
Andy Fleming
Liu Gang
