[U-Boot] [PATCH] spl: use different BOARD_INIT MACRO for spl and tpl
SPL and TPL may not always need spl_board_init() at the same time.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
common/spl/Kconfig | 7 +++++++ common/spl/spl.c | 2 +- 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 7aae826..3e6f526 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -754,6 +754,13 @@ config TPL
if TPL
+config TPL_BOARD_INIT + bool "Call board-specific initialization in TPL" + help + If this option is enabled, U-Boot will call the function + spl_board_init() from board_init_r(). This function should be + provided by the board. + config TPL_LDSCRIPT string "Linker script for the TPL stage" depends on TPL diff --git a/common/spl/spl.c b/common/spl/spl.c index ac2c6ca..ec6ac69 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -395,7 +395,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) timer_init(); #endif
-#ifdef CONFIG_SPL_BOARD_INIT +#if CONFIG_IS_ENABLED(BOARD_INIT) spl_board_init(); #endif
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Dr. Philipp Tomsich
Kever Yang
