[PATCH] board: freescale: imx93_evk: Fix MMC environment offset boot conflict.
From 734bfa4e4556976fe85c741f13ae94161cae97e6 Mon Sep 17 00:00:00 2001
From: Ken Sloat ken.s@variscite.com Date: Tue, 11 Apr 2023 16:05:31 -0400
Currently, the imx93_evk is configured with CONFIG_ENV_IS_IN_MMC and the chosen environment offset in the config is 0x400000. Unless the user programs the associated fuses, this offset is the default secondary boot image offset used by the i.MX 93 ROM bootloader. With certain combinations of environmental variables, the CRC and beginning of the environment can potentially falsely appear as a valid boot image container header. If the expected "sw_version" offset within this mistaken boot image container is greater than the primary's, the ROM bootloader can skip booting of the primary image altogether and attempt to boot with the content of the environment data. This will then hang the system.
To fix this, move the environment from 0x400000 to 0x700000 reserving up to 3 MB at 0x400000 for any actual secondary user image container.
Signed-off-by: Ken Sloat ken.s@variscite.com --- configs/imx93_11x11_evk_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 4f8777161e..db94bbfdd1 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -7,7 +7,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x400000 +CONFIG_ENV_OFFSET=0x700000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000
Hi Peng,
I wanted to follow-up with you to see if you had time to review this patch.
Thanks
Sincerely, Ken Sloat
From: Ken Sloat Sent: Tuesday, April 11, 2023 4:40 PM To: peng.fan@nxp.com peng.fan@nxp.com; u-boot@lists.denx.de u-boot@lists.denx.de; Ken Sloat ken.s@variscite.com Cc: Nate Drude Nate.D@variscite.com Subject: [PATCH] board: freescale: imx93_evk: Fix MMC environment offset boot conflict.
On 4/12/2023 4:40 AM, Ken Sloat wrote:
From 734bfa4e4556976fe85c741f13ae94161cae97e6 Mon Sep 17 00:00:00 2001 From: Ken Sloat ken.s@variscite.com Date: Tue, 11 Apr 2023 16:05:31 -0400
Reviewed-by: Peng Fan peng.fan@nxp.com
From: Peng Fan peng.fan@oss.nxp.com Sent: Thursday, April 20, 2023 9:46 AM To: Ken Sloat ken.s@variscite.com; Peng Fan peng.fan@nxp.com; u-boot@lists.denx.de u-boot@lists.denx.de Cc: Nate Drude Nate.D@variscite.com Subject: Re: [PATCH] board: freescale: imx93_evk: Fix MMC environment offset boot conflict. Hi Stefano,
Looks like this may have been forgotten about? Just checking...
Thanks
Reviewed-by: Fabio Estevam festevam@denx.de
Signed-off-by: Ken Sloat ken.s@variscite.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Ken Sloat
Peng Fan
