Re: [U-Boot] UBI issues on SAMA5D31 NOR flash
Hello Andy,
Am 02.10.2014 10:16, schrieb Andy Pont:
Hello Heiko,
UBI error: vtbl_check: reserved_pebs 81, ubi->good_peb_count 80 UBI error: vtbl_check: too large reserved_pebs, good PEBs 80
Use of UBI is new to me so where are the PEBs configured?
Good question ... looking into vtbl_check(), the "reserved_pebs" value is read from the record in the volume table:
reserved_pebs = be32_to_cpu(vtbl[i].reserved_pebs);
"@reserved_pebs: how many physical eraseblocks are reserved for this volume"
I have changed the size of the partition as defined in U-Boot and also reduced the maximum image size when creating the UBI image and have found a combination that moves me on to the next error:
U-Boot> ubi part rootfs UBI: attaching mtd2 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 130944 bytes UBI: smallest flash I/O unit: 1 UBI: VID header offset: 64 (aligned 64) UBI: data offset: 128
- Warning: 1 protected sectors will not be erased!
UBI error: ubi_io_write: error -5 while writing 64 bytes to PEB 0:0, written 0 bytes
What says flinfo ? It seems you have protected sectors on your nor flash ... you must unprotect them before using it ...
UBI error: erase_worker: failed to erase PEB 0, error -5 UBI error: erase_worker: bad physical eraseblock 0 detected UBI warning: ubi_ro_mode: switch to read-only mode UBI error: do_work: work failed with error code -5 UBI error: autoresize: cannot auto-resize volume 0 UBI error: ubi_init: cannot attach mtd2 UBI error: ubi_init: UBI error: cannot initialize UBI, error -30 UBI init error 30
Hopefully this may be the last hurdle to overcome but somehow I think maybe not!
Cheer up!
bye, Heiko
Hello Heiko,
flinfo says that all sectors are read only as the flash device supports block locking and powers up with all sectors in their locked state.
The board configuration file includes CONFIG_SYS_FLASH_PROTECTION in order to allow the "protect off" command to work prior to manual updates of the flash content.
Cheer up!
I'll try! :-)
Regards,
Andy.
Andy Pont
Heiko Schocher
