[U-Boot] [PATCH] arm: zynq: Label whole PL part as fpga_full region
This will simplify dt overlay structure for the whole PL.
arch/arm/dts/zynq-7000.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index 34fc6e5f8936..f993e19ef280 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -38,6 +38,14 @@ }; };
+ fpga_full: fpga-full { + compatible = "fpga-region"; + fpga-mgr = <&devcfg>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + }; + pmu@f8891000 { compatible = "arm,cortex-a9-pmu"; interrupts = <0 5 4>, <0 6 4>;
Hi Michal,
can you / did you send this to the kernel ML, too?
Reviewed-by: Moritz Fischer moritz.fischer@ettus.com
#size-cells = <1>;
ranges;
-- 1.9.1
Thanks,
Moritz
On 29.6.2017 19:38, Moritz Fischer wrote:
Hi Michal,
We need to send fpga manager driver first but yes we will do it.
Thanks, Michal
Michal Simek
Moritz Fischer
