[U-Boot] [PATCH] dts: keep clock-names and clocks in SPL DTB if SPL_CLK is enabled
These two properties are necessary for SPL to get clocks from DT.
Note: For now, only clock look-up by index is supported (clk_get_by_index() function), so "clock-names" is never parsed in U-Boot. However, we may want to support something like clk_get_by_name() in the future, so let's keep "clock-names" as well as "clocks".
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
dts/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/dts/Kconfig b/dts/Kconfig index fb2d79e..d639be9 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -61,7 +61,9 @@ config DEFAULT_DEVICE_TREE config OF_SPL_REMOVE_PROPS string "List of device tree properties to drop for SPL" depends on SPL_OF_CONTROL + default "interrupt-parent" if SPL_PINCTRL_FULL && SPL_CLK default "clocks clock-names interrupt-parent" if SPL_PINCTRL_FULL + default "pinctrl-0 pinctrl-names interrupt-parent" if SPL_CLK default "pinctrl-0 pinctrl-names clocks clock-names interrupt-parent" help Since SPL normally runs in a reduced memory space, the device tree
Simon,
Any comment on this patch?
2016-02-03 20:51 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
-- 1.9.1
On 3 February 2016 at 04:51, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Applied to u-boot-dm, thanks!
Masahiro Yamada
