[U-Boot] Pull request - arm/zynq v3
Hi Albert,
please pull these 3 zynq patches to your arm tree. I have rebased the tree on the 2013.07 to remove that new nds32 patches.
There is still pending the arm: lds: Remove libgcc eabi exception handling tables patch. Have you considered to also add it?
v3: - Rebase on the v2013.07 because Albert didn't want to nds32 stuff
v2: - Changed email address, - There was incorrect rebase which I have fixed - correct sha1 now
Thanks. Michal
The following changes since commit 62c175fbb8a0f9a926c88294ea9f7e88eb898f6c:
Prepare v2013.07 (2013-07-23 07:58:13 -0400)
git://www.denx.de/git/u-boot-microblaze.git zynq
for you to fetch changes up to 037e0d25c6ee6367beca3062759993d10759dff2:
zynq: Enable axi ethernet and emaclite driver initialization (2013-08-19 09:32:00 +0200)
---------------------------------------------------------------- Michal Simek (3): zynq: Add new ddrc driver for ECC support zynq: slcr: Wait 100ms till clk is properly setup zynq: Enable axi ethernet and emaclite driver initialization
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/ddrc.c | 50 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/zynq/slcr.c | 2 +- arch/arm/include/asm/arch-zynq/hardware.h | 8 +++++ arch/arm/include/asm/arch-zynq/sys_proto.h | 1 + board/xilinx/zynq/board.c | 19 ++++++++++++ 6 files changed, 80 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/zynq/ddrc.c
Hi Michal,
On Mon, 19 Aug 2013 09:36:33 +0200, Michal Simek monstr@monstr.eu wrote:
Hi Albert,
v3:
v2:
Thanks. Michal
Applied to u-boot-arm/master, thanks!
Amicalement,
On 09/03/2013 02:12 PM, Albert ARIBAUD wrote:
Hi Michal,
Hi Albert,
v3:
v2:
Thanks. Michal
Thanks.
What about this patch "arm: lds: Remove libgcc eabi exception handling tables"?
Thanks, Michal
Hi Albert,
please pull these two patches to your arm next branch. It depends on "zynq: Use arch_cpu_init() instead of lowlevel_init()" (sha1: 262f08d6ea18a62f827b8ccb60f355ca2eaf6e2b) patch which you have in your branch that's why I have rebased them on the top.
Thanks, Michal
The following changes since commit c0e5dd88c438a41bf180dde0c2dc4c67dcd8058d:
Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master' (2013-11-05 20:50:39 +0100)
for you to fetch changes up to b5f05b063413245e3d29186739fb5db98d137dfd:
arm: zynq : Revert TZ_DDR_RAM to secure. (2013-11-06 09:24:06 +0100)
---------------------------------------------------------------- Michal Simek (1): arm: zynq: Do not remap OCM to high address
Radhey Shyam Pandey (1): arm: zynq : Revert TZ_DDR_RAM to secure.
arch/arm/cpu/armv7/zynq/cpu.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
Hi Michal,
On Wed, 06 Nov 2013 09:28:16 +0100, Michal Simek monstr@monstr.eu wrote:
Hi Albert,
Thanks, Michal
Is this really for 'next' and not 'master'? IOW, do you really mean it *not* to go into 2014.01?
Amicalement,
Hi Albert,
On 11/07/2013 10:50 AM, Albert ARIBAUD wrote:
Hi Michal,
Hi Albert,
Thanks, Michal
Every maintainer has different strategies for branches. But anyway, I want to add these patches/fixes to the 2014.01.
Thanks, Michal
Hi Michal,
Hi Albert,
Thanks, Michal
Amicalement,
Albert ARIBAUD
Michal Simek
