[U-Boot] [PATCH v2 1/1] usb: gadget: g_dnl: Sync internal SN variable with env
Since commit 842778a09104 ("usb: gadget: g_dnl: only set iSerialNumber if we have a serial#") "fastboot devices" stopped to show correct device serial number for TI boards, showing this line instead:
???????????? fastboot
This is because serial# env variable could be set after g_dnl gadget was initialized (e.g. by using env_set() in the board file).
To fix this, let's update internal serial number variable (g_dnl_serial) when "serial#" env var is changed.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Cc: Felipe Balbi felipe.balbi@linux.intel.com --- drivers/usb/gadget/g_dnl.c | 24 ++++++++++++++++++++++++ include/env_callback.h | 1 + 2 files changed, 25 insertions(+)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 0491a0eea9..1a9f075485 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -19,6 +19,8 @@ #include <dfu.h> #include <thor.h>
+#include <env_callback.h> + #include "gadget_chips.h" #include "composite.c"
@@ -202,6 +204,28 @@ static int g_dnl_get_bcd_device_number(struct usb_composite_dev *cdev) return g_dnl_get_board_bcd_device_number(gcnum); }
+/** + * Update internal serial number variable when the "serial#" env var changes. + * + * Handle all cases, including when flags == H_PROGRAMMATIC. + */ +static int on_serialno(const char *name, const char *value, enum env_op op, + int flags) +{ + switch (op) { + case env_op_create: + /* Fall through */ + case env_op_overwrite: + g_dnl_set_serialnumber((char *)value); + break; + default: + break; + } + + return 0; +} +U_BOOT_ENV_CALLBACK(serialno, on_serialno); + static int g_dnl_bind(struct usb_composite_dev *cdev) { struct usb_gadget *gadget = cdev->gadget; diff --git a/include/env_callback.h b/include/env_callback.h index 90b95b5e66..5c4a30c2de 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -72,6 +72,7 @@ SILENT_CALLBACK \ SPLASHIMAGE_CALLBACK \ "stdin:console,stdout:console,stderr:console," \ + "serial#:serialno," \ CONFIG_ENV_CALLBACK_LIST_STATIC
struct env_clbk_tbl {
On 1 September 2017 at 15:00, Sam Protsenko semen.protsenko@linaro.org wrote:
- Update internal serial number variable when the "serial#" env var changes.
- Handle all cases, including when flags == H_PROGRAMMATIC.
int flags)
switch (op) {
case env_op_create:
/* Fall through */
break;
default:
break;
2.14.1
Please ignore this patch. It doesn't handle the env_op_delete event. Will send v3 soon.
Sam Protsenko
