Re: [PATCH 4/4] rockchip: rk3308: fix same-as-spl boot order
On 2023/7/15 18:19, Pegorer Massimo wrote:
Boot devices defined in rk3308.c and in rk3308.dtsi do not match, causing 'same-as-spl' feature not to work. Update DTS definitions, aligning to Linux kernel DTS and to other Rockchip DTS files, i.e. from dwmmc to mmc.
Add rk3308-rock-pi-s.dtb in dtb-y targets for CONFIG_ROCKCHIP_RK3308.
Signed-off-by: Massimo Pegorer massimo.pegorer@vimar.com
It would be better to sync the dtsi from mainline kernel, this patch is fine for it's the
same with the mainline kernel after change.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/dts/Makefile | 3 ++- arch/arm/dts/rk3308.dtsi | 6 +++--- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 17f506a8fa..14c957d237 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -119,7 +119,8 @@ dtb-$(CONFIG_ROCKCHIP_RK3288) += \
dtb-$(CONFIG_ROCKCHIP_RK3308) += \ rk3308-evb.dtb \
- rk3308-roc-cc.dtb
rk3308-roc-cc.dtb \
dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \
diff --git a/arch/arm/dts/rk3308.dtsi b/arch/arm/dts/rk3308.dtsi index a5c0b72ae0..9a152a8a90 100644 --- a/arch/arm/dts/rk3308.dtsi +++ b/arch/arm/dts/rk3308.dtsi @@ -584,7 +584,7 @@ status = "disabled"; };
- sdmmc: dwmmc@ff480000 {
- sdmmc: mmc@ff480000 { compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xff480000 0x0 0x4000>; max-frequency = <150000000>;
@@ -599,7 +599,7 @@ status = "disabled"; };
- emmc: dwmmc@ff490000 {
- emmc: mmc@ff490000 { compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xff490000 0x0 0x4000>; max-frequency = <150000000>;
@@ -612,7 +612,7 @@ status = "disabled"; };
- sdio: dwmmc@ff4a0000 {
- sdio: mmc@ff4a0000 { compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xff4a0000 0x0 0x4000>; max-frequency = <150000000>;
Kever Yang
