[U-Boot] [PATCH] T104xD4RDB: Fix PHY address for PHY connected to FM1@DTSEC3
On T1040D4RDB board, u-boot fails to connect port FM1@DTSEC3 to the Ethernet PHY because the wrong PHY address is used. Also, T1040D4RDB supports SGMII on one port only.
Signed-off-by: Codrin Ciubotariu codrin.ciubotariu@freescale.com --- include/configs/T104xRDB.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 5b61b56..e872507 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -742,7 +742,9 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #ifdef CONFIG_FMAN_ENET #if defined(CONFIG_T1040RDB) || defined(CONFIG_T1042RDB) #define CONFIG_SYS_SGMII1_PHY_ADDR 0x03 -#elif defined(CONFIG_T1040D4RDB) || defined(CONFIG_T1042D4RDB) +#elif defined(CONFIG_T1040D4RDB) +#define CONFIG_SYS_SGMII1_PHY_ADDR 0x01 +#elif defined(CONFIG_T1042D4RDB) #define CONFIG_SYS_SGMII1_PHY_ADDR 0x02 #define CONFIG_SYS_SGMII2_PHY_ADDR 0x03 #define CONFIG_SYS_SGMII3_PHY_ADDR 0x01
Applied to u-boot-mpc85xx, awaiting upstream. Thanks.
York
Codrin Ciubotariu
York Sun
