[U-Boot] [PATCH] s3c2410_nand add missing functions for CONFIG_NAND_SPL
add missing functios nand_read_byte(), nand_write_buf(), nand_read_buf() for CONFIG_NAND_SPL config, also set nand->select_chip = NULL, since in nand_boot() we will check it to do a select_chip action. --- drivers/mtd/nand/s3c2410_nand.c | 39 +++++++++++++++++++++++++++++++++++++-- 1 files changed, 37 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/s3c2410_nand.c b/drivers/mtd/nand/s3c2410_nand.c index f2f3e72..fe61ab4 100644 --- a/drivers/mtd/nand/s3c2410_nand.c +++ b/drivers/mtd/nand/s3c2410_nand.c @@ -36,6 +36,32 @@ #define S3C2410_ADDR_NALE 4 #define S3C2410_ADDR_NCLE 8
+#ifdef CONFIG_NAND_SPL +static u_char nand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *this = mtd->priv; + return readb(this->IO_ADDR_R); +} + +static void nand_write_buf(struct mtd_info *mtd, const uint8_t *buf, int len) +{ + int i; + struct nand_chip *this = mtd->priv; + + for (i = 0; i < len; i++) + writeb(buf[i], this->IO_ADDR_W); +} + +static void nand_read_buf(struct mtd_info *mtd, u_char *buf, int len) +{ + int i; + struct nand_chip *this = mtd->priv; + + for (i = 0; i < len; i++) + buf[i] = readb(this->IO_ADDR_R); +} +#endif + static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *chip = mtd->priv; @@ -100,7 +126,7 @@ static int s3c2410_nand_correct_data(struct mtd_info *mtd, u_char *dat, read_ecc[2] == calc_ecc[2]) return 0;
- printf("s3c2410_nand_correct_data: not implemented\n"); + DEBUGN("s3c2410_nand_correct_data: not implemented\n"); return -1; } #endif @@ -130,8 +156,15 @@ int board_nand_init(struct nand_chip *nand) /* initialize nand_chip data structure */ nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)&nand_reg->NFDATA;
+ nand->select_chip = NULL; + /* read_buf and write_buf are default */ /* read_byte and write_byte are default */ +#ifdef CONFIG_NAND_SPL + nand->read_byte = nand_read_byte; + nand->write_buf = nand_write_buf; + nand->read_buf = nand_read_buf; +#endif
/* hwcontrol always must be implemented */ nand->cmd_ctrl = s3c2410_hwcontrol; @@ -142,7 +175,9 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.hwctl = s3c2410_nand_enable_hwecc; nand->ecc.calculate = s3c2410_nand_calculate_ecc; nand->ecc.correct = s3c2410_nand_correct_data; - nand->ecc.mode = NAND_ECC_HW3_512; + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; + nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; #else nand->ecc.mode = NAND_ECC_SOFT; #endif
Why do you need to write to the buffer in the NAND SPL? I don't think you need read_byte either.
-Scott
Hui Tang
Hui.Tang
Scott Wood
