[U-Boot] [PATCH] SPEAr: Add ARM relocation support
Signed-off-by: Amit Virdi amit.virdi@st.com --- board/spear/common/spr_misc.c | 20 +------------------- 1 files changed, 1 insertions(+), 19 deletions(-)
diff --git a/board/spear/common/spr_misc.c b/board/spear/common/spr_misc.c index 0812c20..3ab278f 100644 --- a/board/spear/common/spr_misc.c +++ b/board/spear/common/spr_misc.c @@ -40,27 +40,9 @@ static struct chip_data chip_data;
int dram_init(void) { - struct xloader_table *xloader_tb = - (struct xloader_table *)XLOADER_TABLE_ADDRESS; - struct xloader_table_1_1 *table_1_1; - struct xloader_table_1_2 *table_1_2; - struct chip_data *chip = &chip_data; - + /* Store complete RAM size and return */ gd->ram_size = get_ram_size(PHYS_SDRAM_1, PHYS_SDRAM_1_MAXSIZE);
- if (XLOADER_TABLE_VERSION_1_1 == xloader_tb->table_version) { - table_1_1 = &xloader_tb->table.table_1_1; - chip->dramfreq = table_1_1->ddrfreq; - chip->dramtype = table_1_1->ddrtype; - - } else if (XLOADER_TABLE_VERSION_1_2 == xloader_tb->table_version) { - table_1_2 = &xloader_tb->table.table_1_2; - chip->dramfreq = table_1_2->ddrfreq; - chip->dramtype = table_1_2->ddrtype; - } else { - chip->dramfreq = -1; - } - return 0; }
Uh, are you sure the Subject correlates with the patch ?
M
- /* Store complete RAM size and return */ gd->ram_size = get_ram_size(PHYS_SDRAM_1, PHYS_SDRAM_1_MAXSIZE);
- } else {
On 2/17/2012 1:13 AM, Marek Vasut wrote:
Signed-off-by: Amit Virdiamit.virdi@st.com
M
Yeah. The fix is a part of the Relocation feature. For relocation, it is essential that dram_init stores RAM size and do nothing more i.e. no access to bss etc.
~Amit Virdi
- struct chip_data *chip =&chip_data;
table_1_1 =&xloader_tb->table.table_1_1;
table_1_2 =&xloader_tb->table.table_1_2;
- } else {
- return 0; }
M
Then name it "fix dram size reporting?". Also, you don't need dram_init at all if you only call get_dram_size() if I recall correctly, check arch/arm/lib/board.c, I might be mistaken. And maybe explain why you removed all the code in the changelog, it's not clear at all.
Thanks!
~Amit Virdi
} else {
Hello Marek,
M
Thanks for your suggestions. I got your point. I'll send V2 with correct subject and clear message.
Regards Amit Virdi
Thanks!
~Amit Virdi
} else {
Hello Marek,
M
Regards Amit Virdi
Good, thanks! :)
M
Thanks!
~Amit Virdi
} else {
Hi Amit,
M
So the subject *is* wrong: the patch does not add relocation support, it fixes it.
Also, please fix my e-mail address in the recipients list. Somemone has me as ...@aribaud.ne instead of "@aribaud.net", and did not notice it.
~Amit Virdi
Amicalement,
Ciao Albert,
On Fri, Feb 17, 2012 at 2:43 PM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Hi Amit,
M
Yes. I'll correct the subject and shall be sending V2.
Sure!!
Regards Amit Virdi
Albert ARIBAUD
Amit Virdi
Amit Virdi
