[PATCH v2 1/5] power: regulator: Trigger probe of regulators which are always-on or boot-on
In case a regulator DT node contains regulator-always-on or regulator-boot-on property, make sure the regulator gets correctly configured by U-Boot on start up. Unconditionally probe such regulator drivers. This is a preparatory patch for introduction of .regulator_post_probe() which would trigger the regulator configuration.
Parsing of regulator-always-on and regulator-boot-on DT property has been moved to regulator_post_bind() as the information is required early, the rest of the DT parsing has been kept in regulator_pre_probe() to avoid slowing down the boot process.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ben Wolsieffer benwolsieffer@gmail.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Chris Morgan macromorgan@hotmail.com Cc: Dragan Simic dsimic@manjaro.org Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Kever Yang kever.yang@rock-chips.com Cc: Kostya Porotchkin kostap@marvell.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sam Day me@samcday.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Svyatoslav Ryhel clamor95@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Tom Rini trini@konsulko.com Cc: Volodymyr Babchuk Volodymyr_Babchuk@epam.com Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: - Rebase on current u-boot/next - Update test cases to handle already started regulators correctly --- drivers/power/regulator/regulator-uclass.c | 22 +++++++++++++++------- test/dm/panel.c | 2 +- test/dm/regulator.c | 4 ++-- 3 files changed, 18 insertions(+), 10 deletions(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 88a8525b3c4..e2f703702e3 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -433,6 +433,8 @@ static int regulator_post_bind(struct udevice *dev) const char *property = "regulator-name";
uc_pdata = dev_get_uclass_plat(dev); + uc_pdata->always_on = dev_read_bool(dev, "regulator-always-on"); + uc_pdata->boot_on = dev_read_bool(dev, "regulator-boot-on");
/* Regulator's mandatory constraint */ uc_pdata->name = dev_read_string(dev, property); @@ -444,13 +446,21 @@ static int regulator_post_bind(struct udevice *dev) return -EINVAL; }
- if (regulator_name_is_unique(dev, uc_pdata->name)) - return 0; + if (!regulator_name_is_unique(dev, uc_pdata->name)) { + debug("'%s' of dev: '%s', has nonunique value: '%s\n", + property, dev->name, uc_pdata->name); + return -EINVAL; + }
- debug("'%s' of dev: '%s', has nonunique value: '%s\n", - property, dev->name, uc_pdata->name); + /* + * In case the regulator has regulator-always-on or + * regulator-boot-on DT property, trigger probe() to + * configure its default state during startup. + */ + if (uc_pdata->always_on && uc_pdata->boot_on) + dev_or_flags(dev, DM_FLAG_PROBE_AFTER_BIND);
- return -EINVAL; + return 0; }
static int regulator_pre_probe(struct udevice *dev) @@ -473,8 +483,6 @@ static int regulator_pre_probe(struct udevice *dev) -ENODATA); uc_pdata->max_uA = dev_read_u32_default(dev, "regulator-max-microamp", -ENODATA); - uc_pdata->always_on = dev_read_bool(dev, "regulator-always-on"); - uc_pdata->boot_on = dev_read_bool(dev, "regulator-boot-on"); uc_pdata->ramp_delay = dev_read_u32_default(dev, "regulator-ramp-delay", 0); uc_pdata->force_off = dev_read_bool(dev, "regulator-force-boot-off"); diff --git a/test/dm/panel.c b/test/dm/panel.c index ce835c96ed0..ec85a9b1e6e 100644 --- a/test/dm/panel.c +++ b/test/dm/panel.c @@ -33,7 +33,7 @@ static int dm_test_panel(struct unit_test_state *uts) ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); ut_asserteq(false, enable); - ut_asserteq(false, regulator_get_enable(reg)); + ut_asserteq(true, regulator_get_enable(reg));
ut_assertok(panel_enable_backlight(dev)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, diff --git a/test/dm/regulator.c b/test/dm/regulator.c index 532bbd82376..449748ad52f 100644 --- a/test/dm/regulator.c +++ b/test/dm/regulator.c @@ -186,7 +186,7 @@ int dm_test_power_regulator_set_enable_if_allowed(struct unit_test_state *uts)
/* Get BUCK1 - always on regulator */ platname = regulator_names[BUCK1][PLATNAME]; - ut_assertok(regulator_autoset_by_name(platname, &dev_autoset)); + ut_asserteq(-EALREADY, regulator_autoset_by_name(platname, &dev_autoset)); ut_assertok(regulator_get_by_platname(platname, &dev));
/* Try disabling always-on regulator */ @@ -288,7 +288,7 @@ static int dm_test_power_regulator_autoset(struct unit_test_state *uts) * Expected output state: uV=1200000; uA=200000; output enabled */ platname = regulator_names[BUCK1][PLATNAME]; - ut_assertok(regulator_autoset_by_name(platname, &dev_autoset)); + ut_asserteq(-EALREADY, regulator_autoset_by_name(platname, &dev_autoset));
/* Check, that the returned device is proper */ ut_assertok(regulator_get_by_platname(platname, &dev));
Turn regulators_enable_boot_on() and regulators_enable_boot_off() into empty functions. Implement matching functionality in regulator_post_probe() instead. The regulator_post_probe() is called for all regulators after they probe, and regulators that have regulator-always-on or regulator-boot-on DT properties now always probe due to DM_FLAG_PROBE_AFTER_BIND being set on such regulators in regulator_post_bind().
Finally, fold regulator_unset() functionality into regulator_autoset().
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ben Wolsieffer benwolsieffer@gmail.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Chris Morgan macromorgan@hotmail.com Cc: Dragan Simic dsimic@manjaro.org Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Kever Yang kever.yang@rock-chips.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sam Day me@samcday.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Svyatoslav Ryhel clamor95@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Tom Rini trini@konsulko.com Cc: Volodymyr Babchuk Volodymyr_Babchuk@epam.com Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: Rebase on current u-boot/next --- drivers/power/regulator/regulator-uclass.c | 60 +++++++--------------- 1 file changed, 19 insertions(+), 41 deletions(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index e2f703702e3..14cf3159203 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -308,6 +308,11 @@ int regulator_autoset(struct udevice *dev) return ret; }
+ if (uc_pdata->force_off) { + ret = regulator_set_enable(dev, false); + goto out; + } + if (!uc_pdata->always_on && !uc_pdata->boot_on) { ret = -EMEDIUMTYPE; goto out; @@ -512,56 +517,28 @@ static int regulator_pre_probe(struct udevice *dev) return 0; }
-int regulators_enable_boot_on(bool verbose) +static int regulator_post_probe(struct udevice *dev) { - struct udevice *dev; - struct uclass *uc; int ret;
- ret = uclass_get(UCLASS_REGULATOR, &uc); - if (ret) + ret = regulator_autoset(dev); + if (ret && ret != -EMEDIUMTYPE && ret != -EALREADY && ret != ENOSYS) return ret; - for (uclass_first_device(UCLASS_REGULATOR, &dev); - dev; - uclass_next_device(&dev)) { - ret = regulator_autoset(dev); - if (ret == -EMEDIUMTYPE || ret == -EALREADY) { - ret = 0; - continue; - } - if (verbose) - regulator_show(dev, ret); - if (ret == -ENOSYS) - ret = 0; - }
- return ret; + if (_DEBUG) + regulator_show(dev, ret); + + return 0; }
-int regulators_enable_boot_off(bool verbose) +int regulators_enable_boot_on(bool verbose) { - struct udevice *dev; - struct uclass *uc; - int ret; - - ret = uclass_get(UCLASS_REGULATOR, &uc); - if (ret) - return ret; - for (uclass_first_device(UCLASS_REGULATOR, &dev); - dev; - uclass_next_device(&dev)) { - ret = regulator_unset(dev); - if (ret == -EMEDIUMTYPE) { - ret = 0; - continue; - } - if (verbose) - regulator_show(dev, ret); - if (ret == -ENOSYS) - ret = 0; - } + return 0; +}
- return ret; +int regulators_enable_boot_off(bool verbose) +{ + return 0; }
UCLASS_DRIVER(regulator) = { @@ -569,5 +546,6 @@ UCLASS_DRIVER(regulator) = { .name = "regulator", .post_bind = regulator_post_bind, .pre_probe = regulator_pre_probe, + .post_probe = regulator_post_probe, .per_device_plat_auto = sizeof(struct dm_regulator_uclass_plat), };
In case the DT regulator node does not contain 'regulator-max-microvolt' property and does not contain 'regulator-state-mem' subnode (like the test.dts regul1_scmi: reg@1 {} regulator node), then regulator_pre_probe() will parse this regulator node and set uc_pdata->suspend_on = true and uc_pdata->suspend_uV = uc_pdata->max_uV, where uc_pdata->max_uV is set to -ENODATA because "regulator-max-microvolt" is missing, and therefore uc_pdata->suspend_uV is also -ENODATA. In case regulator_autoset() is used afterward, it will attempt to call regulator_set_suspend_value() with uV = uc_pdata->suspend_uV = -ENODATA and fail with -EINVAL. Check for this case in regulator_set_suspend_value() and immediately return 0, because there is no way to set meaningful suspend voltage, so do nothing and retain the existing settings of the regulator.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ben Wolsieffer benwolsieffer@gmail.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Chris Morgan macromorgan@hotmail.com Cc: Dragan Simic dsimic@manjaro.org Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Kever Yang kever.yang@rock-chips.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sam Day me@samcday.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Svyatoslav Ryhel clamor95@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Tom Rini trini@konsulko.com Cc: Volodymyr Babchuk Volodymyr_Babchuk@epam.com Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: New patch --- drivers/power/regulator/regulator-uclass.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 14cf3159203..3c05fdf1966 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -85,6 +85,10 @@ int regulator_set_suspend_value(struct udevice *dev, int uV) const struct dm_regulator_ops *ops = dev_get_driver_ops(dev); struct dm_regulator_uclass_plat *uc_pdata;
+ /* Regulator did not set limits, assume already configured. */ + if (uV == -ENODATA) + return 0; + uc_pdata = dev_get_uclass_plat(dev); if (uc_pdata->min_uV != -ENODATA && uV < uc_pdata->min_uV) return -EINVAL;
Hi Marek,
I sent a different fix for this some time ago, please check it out:
https://patchwork.ozlabs.org/patch/1964571/
Regards, Jonas
V2: New patch
- /* Regulator did not set limits, assume already configured. */
- if (uV == -ENODATA)
- uc_pdata = dev_get_uclass_plat(dev); if (uc_pdata->min_uV != -ENODATA && uV < uc_pdata->min_uV) return -EINVAL;
On 9/25/24 8:29 AM, Jonas Karlman wrote:
Hi Marek,
That one will work too, yes.
This function is never called, drop it.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ben Wolsieffer benwolsieffer@gmail.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Chris Morgan macromorgan@hotmail.com Cc: Dragan Simic dsimic@manjaro.org Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Kever Yang kever.yang@rock-chips.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sam Day me@samcday.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Svyatoslav Ryhel clamor95@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Tom Rini trini@konsulko.com Cc: Volodymyr Babchuk Volodymyr_Babchuk@epam.com Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: Rebase on current u-boot/next --- drivers/power/regulator/regulator-uclass.c | 11 ----------- include/power/regulator.h | 14 +------------- 2 files changed, 1 insertion(+), 24 deletions(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 3c05fdf1966..34c2a36ec44 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -343,17 +343,6 @@ out: return ret; }
-int regulator_unset(struct udevice *dev) -{ - struct dm_regulator_uclass_plat *uc_pdata; - - uc_pdata = dev_get_uclass_plat(dev); - if (uc_pdata && uc_pdata->force_off) - return regulator_set_enable(dev, false); - - return -EMEDIUMTYPE; -} - static void regulator_show(struct udevice *dev, int ret) { struct dm_regulator_uclass_plat *uc_pdata; diff --git a/include/power/regulator.h b/include/power/regulator.h index bb07a814c79..5363483d02a 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -430,7 +430,7 @@ int regulators_enable_boot_on(bool verbose); * * This disables all regulators which are marked to be off at boot time. * - * This effectively calls regulator_unset() for every regulator. + * This effectively does nothing. */ int regulators_enable_boot_off(bool verbose);
@@ -453,18 +453,6 @@ int regulators_enable_boot_off(bool verbose); */ int regulator_autoset(struct udevice *dev);
-/** - * regulator_unset: turn off a regulator - * - * The setup depends on constraints found in device's uclass's platform data - * (struct dm_regulator_uclass_platdata): - * - * - Disable - will set - if 'force_off' is set to true, - * - * The function returns on the first-encountered error. - */ -int regulator_unset(struct udevice *dev); - /** * regulator_autoset_by_name: setup the regulator given by its uclass's * platform data name field. The setup depends on constraints found in device's
Both regulators_enable_boot_on/off() are unused and superseded by regulator uclass regulator_post_probe(). Remove both functions.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Ben Wolsieffer benwolsieffer@gmail.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Chris Morgan macromorgan@hotmail.com Cc: Dragan Simic dsimic@manjaro.org Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Kever Yang kever.yang@rock-chips.com Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Max Krummenacher max.krummenacher@toradex.com Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Quentin Schulz quentin.schulz@cherry.de Cc: Sam Day me@samcday.com Cc: Simon Glass sjg@chromium.org Cc: Sumit Garg sumit.garg@linaro.org Cc: Svyatoslav Ryhel clamor95@gmail.com Cc: Thierry Reding treding@nvidia.com Cc: Tom Rini trini@konsulko.com Cc: Volodymyr Babchuk Volodymyr_Babchuk@epam.com Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: Rebase on current u-boot/next --- arch/arm/mach-rockchip/board.c | 8 ------ arch/arm/mach-snapdragon/board.c | 1 - arch/arm/mach-tegra/board2.c | 3 --- board/Marvell/octeontx2_cn913x/board.c | 5 ---- .../amlogic/odroid-go-ultra/odroid-go-ultra.c | 2 -- board/dhelectronics/dh_imx6/dh_imx6.c | 2 -- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 2 -- board/dhelectronics/dh_stm32mp1/board.c | 2 -- board/engicam/stm32mp1/stm32mp1.c | 3 --- board/google/veyron/veyron.c | 4 --- board/samsung/common/exynos5-dt.c | 4 --- board/st/stm32mp1/stm32mp1.c | 2 -- drivers/power/regulator/regulator-uclass.c | 10 -------- include/power/regulator.h | 25 ------------------- 14 files changed, 73 deletions(-)
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index 0fdf9365b41..3fadf7e4122 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -202,14 +202,6 @@ int board_late_init(void)
int board_init(void) { - int ret; - -#ifdef CONFIG_DM_REGULATOR - ret = regulators_enable_boot_on(false); - if (ret) - debug("%s: Cannot enable boot on regulator\n", __func__); -#endif - return 0; }
diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index 0af297470a6..2ab2ceb5138 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -237,7 +237,6 @@ void __weak qcom_board_init(void)
int board_init(void) { - regulators_enable_boot_on(false); show_psci_version(); qcom_of_fixup_nodes(); qcom_board_init(); diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 7971e3b68d5..5c5838629b2 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -187,9 +187,6 @@ int board_init(void) warmboot_prepare_code(TEGRA_LP0_ADDR, TEGRA_LP0_SIZE); #endif
- /* Set up boot-on regulators */ - regulators_enable_boot_on(_DEBUG); - return nvidia_board_init(); }
diff --git a/board/Marvell/octeontx2_cn913x/board.c b/board/Marvell/octeontx2_cn913x/board.c index 3d20cfb2fab..3ffe15d42b8 100644 --- a/board/Marvell/octeontx2_cn913x/board.c +++ b/board/Marvell/octeontx2_cn913x/board.c @@ -23,11 +23,6 @@ int board_early_init_f(void)
int board_early_init_r(void) { - if (CONFIG_IS_ENABLED(DM_REGULATOR)) { - /* Check if any existing regulator should be turned down */ - regulators_enable_boot_off(false); - } - return 0; }
diff --git a/board/amlogic/odroid-go-ultra/odroid-go-ultra.c b/board/amlogic/odroid-go-ultra/odroid-go-ultra.c index 8f3f2045d74..f9412071737 100644 --- a/board/amlogic/odroid-go-ultra/odroid-go-ultra.c +++ b/board/amlogic/odroid-go-ultra/odroid-go-ultra.c @@ -16,7 +16,5 @@ int mmc_get_env_dev(void)
int board_init(void) { - regulators_enable_boot_on(_DEBUG); - return 0; } diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index ada44e01424..f2b14bf701a 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -128,8 +128,6 @@ int board_init(void)
setup_fec_clock();
diff --git a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c index a389ab3c2d9..78aae412350 100644 --- a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c +++ b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c @@ -112,8 +112,6 @@ int dh_setup_mac_address(void)
diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 4f4f537fee5..24c5f37c12f 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -622,8 +622,6 @@ static void board_init_regulator_av96(void) static void board_init_regulator(void) { board_init_regulator_av96(); - - regulators_enable_boot_on(_DEBUG); } #else static inline int board_get_regulator_buck3_nvm_uv_av96(int *uv) diff --git a/board/engicam/stm32mp1/stm32mp1.c b/board/engicam/stm32mp1/stm32mp1.c index bc2af66d8e9..56557d56429 100644 --- a/board/engicam/stm32mp1/stm32mp1.c +++ b/board/engicam/stm32mp1/stm32mp1.c @@ -37,9 +37,6 @@ int checkboard(void) /* board dependent setup after realloc */ int board_init(void) { - if (IS_ENABLED(CONFIG_DM_REGULATOR)) - regulators_enable_boot_on(_DEBUG); - return 0; }
diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index bd8ce633772..674f19ba03c 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -57,10 +57,6 @@ static int veyron_init(void) if (ret) return log_msg_ret("s33", ret);
- ret = regulators_enable_boot_on(false); - if (ret) - return log_msg_ret("boo", ret); - return 0; } #endif diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 56862bcb34d..68edd1ec282 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -88,10 +88,6 @@ int exynos_power_init(void) if (ret == -ENODEV) return 0;
- ret = regulators_enable_boot_on(false); - if (ret) - return ret; - ret = exynos_set_regulator("vdd_mif", 1100000); if (ret) return ret; diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 97532a8156f..d5e5e776d2a 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -665,8 +665,6 @@ int board_init(void) if (board_is_stm32mp15x_dk2()) board_stm32mp15x_dk2_init();
- regulators_enable_boot_on(_DEBUG); - /* * sysconf initialisation done only when U-Boot is running in secure * done in TF-A for TFABOOT. diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 34c2a36ec44..c491ba91017 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -524,16 +524,6 @@ static int regulator_post_probe(struct udevice *dev) return 0; }
-int regulators_enable_boot_on(bool verbose) -{ - return 0; -} - -int regulators_enable_boot_off(bool verbose) -{ - return 0; -} - UCLASS_DRIVER(regulator) = { .id = UCLASS_REGULATOR, .name = "regulator", diff --git a/include/power/regulator.h b/include/power/regulator.h index 5363483d02a..8a914dfc74f 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -414,26 +414,6 @@ int regulator_get_mode(struct udevice *dev); */ int regulator_set_mode(struct udevice *dev, int mode_id);
-/** - * regulators_enable_boot_on() - enable regulators needed for boot - * - * This enables all regulators which are marked to be on at boot time. This - * only works for regulators which don't have a range for voltage/current, - * since in that case it is not possible to know which value to use. - * - * This effectively calls regulator_autoset() for every regulator. - */ -int regulators_enable_boot_on(bool verbose); - -/** - * regulators_enable_boot_off() - disable regulators needed for boot - * - * This disables all regulators which are marked to be off at boot time. - * - * This effectively does nothing. - */ -int regulators_enable_boot_off(bool verbose); - /** * regulator_autoset: setup the voltage/current on a regulator * @@ -617,11 +597,6 @@ static inline int regulator_set_mode(struct udevice *dev, int mode_id) return -ENOSYS; }
-static inline int regulators_enable_boot_on(bool verbose) -{ - return -ENOSYS; -} - static inline int regulator_autoset(struct udevice *dev) { return -ENOSYS;
Hi Marek,
[snip]
- if (uc_pdata->always_on && uc_pdata->boot_on)
This check for always_on _and_ boot_on does not fully match the commit message, comment or the old behavior of regulators_enable_boot_on() where any always_on _or_ boot_on would trigger autoset().
Regards, Jonas
- return -EINVAL;
[snip]
On 9/26/24 5:05 PM, Jonas Karlman wrote:
Hi Marek,
[snip]
This should be ORR, thanks for spotting this, fixed in V3.
Jonas Karlman
