[PATCH v1] imx: bootaux fix elf loading
This reverts the arch/arm/mach-imx/imx_bootaux.c changes of commit 805b3cac1e0c. The loader function name was changed so that it does not clash with the generically available function in lib/elf.c.
imx-bootaux loads an elf file linked for an auxilary core. Thus the loader function requires address translation from the auxilary core's address space to where those are mapped into U-Boot's address space.
So the elf loader is specific and must not be replaced with a generic loader which doesn't provide the address translation functionality.
Fixes commit 805b3cac1e0c ("lib: elf: Move the generic elf loading/validating functions to lib")
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com
arch/arm/mach-imx/imx_bootaux.c | 67 ++++++++++++++++++++++++++++++++- 1 file changed, 66 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx_bootaux.c b/arch/arm/mach-imx/imx_bootaux.c index e1fc4b3e19a..30fb45d48c2 100644 --- a/arch/arm/mach-imx/imx_bootaux.c +++ b/arch/arm/mach-imx/imx_bootaux.c @@ -14,6 +14,71 @@ #include <linux/compiler.h> #include <cpu_func.h>
+#ifndef CONFIG_IMX8M +const __weak struct rproc_att hostmap[] = { }; + +static const struct rproc_att *get_host_mapping(unsigned long auxcore) +{ + const struct rproc_att *mmap = hostmap; + + while (mmap && mmap->size) { + if (mmap->da <= auxcore && + mmap->da + mmap->size > auxcore) + return mmap; + mmap++; + } + + return NULL; +} + +/* + * A very simple elf loader for the auxilary core, assumes the image + * is valid, returns the entry point address. + * Translates load addresses in the elf file to the U-Boot address space. + */ +static unsigned long load_elf_image_m_core_phdr(unsigned long addr) +{ + Elf32_Ehdr *ehdr; /* ELF header structure pointer */ + Elf32_Phdr *phdr; /* Program header structure pointer */ + int i; + + ehdr = (Elf32_Ehdr *)addr; + phdr = (Elf32_Phdr *)(addr + ehdr->e_phoff); + + /* Load each program header */ + for (i = 0; i < ehdr->e_phnum; ++i, ++phdr) { + const struct rproc_att *mmap = get_host_mapping(phdr->p_paddr); + void *dst, *src; + + if (phdr->p_type != PT_LOAD) + continue; + + if (!mmap) { + printf("Invalid aux core address: %08x", + phdr->p_paddr); + return 0; + } + + dst = (void *)(phdr->p_paddr - mmap->da) + mmap->sa; + src = (void *)addr + phdr->p_offset; + + debug("Loading phdr %i to 0x%p (%i bytes)\n", + i, dst, phdr->p_filesz); + + if (phdr->p_filesz) + memcpy(dst, src, phdr->p_filesz); + if (phdr->p_filesz != phdr->p_memsz) + memset(dst + phdr->p_filesz, 0x00, + phdr->p_memsz - phdr->p_filesz); + flush_cache((unsigned long)dst & + ~(CONFIG_SYS_CACHELINE_SIZE - 1), + ALIGN(phdr->p_filesz, CONFIG_SYS_CACHELINE_SIZE)); + } + + return ehdr->e_entry; +} +#endif + int arch_auxiliary_core_up(u32 core_id, ulong addr) { ulong stack, pc; @@ -31,7 +96,7 @@ int arch_auxiliary_core_up(u32 core_id, ulong addr) */ if (valid_elf_image(addr)) { stack = 0x0; - pc = load_elf_image_phdr(addr); + pc = load_elf_image_m_core_phdr(addr); if (!pc) return CMD_RET_FAILURE;
Acked-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com
return mmap;
mmap++;
return NULL;
- A very simple elf loader for the auxilary core, assumes the image
- is valid, returns the entry point address.
- Translates load addresses in the elf file to the U-Boot address space.
int i;
void *dst, *src;
continue;
if (!mmap) {
phdr->p_paddr);
if (phdr->p_filesz)
+} +#endif
-- 2.20.1
This reverts the arch/arm/mach-imx/imx_bootaux.c changes of commit 805b3cac1e0c. The loader function name was changed so that it does not clash with the generically available function in lib/elf.c. imx-bootaux loads an elf file linked for an auxilary core. Thus the loader function requires address translation from the auxilary core's address space to where those are mapped into U-Boot's address space. So the elf loader is specific and must not be replaced with a generic loader which doesn't provide the address translation functionality. Fixes commit 805b3cac1e0c ("lib: elf: Move the generic elf loading/validating functions to lib") Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com
Best regards, Stefano Babic
Max Krummenacher
Oleksandr Suvorov
sbabic@denx.de
