[U-Boot] [PATCH 0/9] mkenvimage: v10/v11 diff split into several patches
First, thanks for having mainlined mkenvimage :)
These patches mainly address Wolfgang's remarks. There are a couple others.
I first intended to submit a v11 patch but since the v10 was merged into u-boot's master branch, I splitted the changes into 9 patches against it.
Regards, David.
David Wagner (9): Strip mkenvimage mkenvimage: correct and clarify comments and error messages mkenvimage: Correct the includes and add a missing one mkenvimage: More error handling mkenvimage: Read from stdin if the filename is "-" mkenvimage: Use mmap() when reading from a regular file mkenvimage: Don't try to detect comments in the input file mkenvimage: Really set the redundant byte when applicable mkenvimage: Default to stdout if the output argument is absent or "-"
tools/Makefile | 1 + tools/mkenvimage.c | 128 +++++++++++++++++++++++++++++----------------------- 2 files changed, 72 insertions(+), 57 deletions(-)
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/Makefile | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/tools/Makefile b/tools/Makefile index a5f989a..64bcc4d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -194,6 +194,7 @@ $(obj)xway-swap-bytes$(SFX): $(obj)xway-swap-bytes.o
$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(HOSTSTRIP) $@
$(obj)mkimage$(SFX): $(obj)aisimage.o \ $(obj)crc32.o \
Dear David Wagner,
In message 1322080098-3151-2-git-send-email-david.wagner@free-electrons.com you wrote:
Applied, thanks.
Also, don't split error messages over several lines as per a coding style exception making them easier to grep.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 39 ++++++++++++++------------------------- 1 files changed, 14 insertions(+), 25 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 9c32f4a..da54658 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -41,12 +41,9 @@
static void usage(const char *exec_name) { - fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " - "-s <environment partition size> -o <output> <input file>\n" + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] -s <environment partition size> -o <output> <input file>\n" "\n" - "This tool takes a key=value input file (same as would a " - "`printenv' show) and generates the corresponding environment " - "image, ready to be flashed.\n" + "This tool takes a key=value input file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed.\n" "\n" "\tThe input file is in format:\n" "\t\tkey1=value1\n" @@ -54,8 +51,7 @@ static void usage(const char *exec_name) "\t\t...\n" "\t-r : the environment has multiple copies in flash\n" "\t-b : the target is big endian (default is little endian)\n" - "\t-p <byte> : fill the image with <byte> bytes instead of " - "0xff bytes\n" + "\t-p <byte> : fill the image with <byte> bytes instead of 0xff bytes\n" "\n" "If the input file is "-", data is read from standard input\n", exec_name); @@ -89,8 +85,7 @@ int main(int argc, char **argv) case 'o': bin_filename = strdup(optarg); if (!bin_filename) { - fprintf(stderr, "Can't strdup() the output " - "filename\n"); + fprintf(stderr, "Can't strdup() the output filename\n"); return EXIT_FAILURE; } break; @@ -115,22 +110,21 @@ int main(int argc, char **argv)
/* Check datasize and allocate the data */ if (datasize == 0) { - fprintf(stderr, - "Please specify the size of the envrionnment " - "partition.\n"); + fprintf(stderr, "Please specify the size of the environment partition.\n"); usage(argv[0]); return EXIT_FAILURE; }
dataptr = malloc(datasize * sizeof(*dataptr)); if (!dataptr) { - fprintf(stderr, "Can't alloc dataptr.\n"); + fprintf(stderr, "Can't alloc %d bytes for dataptr.\n", + datasize); return EXIT_FAILURE; }
/* * envptr points to the beginning of the actual environment (after the - * crc and possible `redundant' bit + * crc and possible `redundant' byte */ envsize = datasize - (CRC_SIZE + redundant); envptr = dataptr + CRC_SIZE + redundant; @@ -166,8 +160,8 @@ int main(int argc, char **argv) /* ... and check it */ ret = fstat(txt_fd, &txt_file_stat); if (ret == -1) { - fprintf(stderr, "Can't stat() on "%s": " - "%s\n", txt_filename, strerror(errno)); + fprintf(stderr, "Can't stat() on "%s": %s\n", + txt_filename, strerror(errno)); return EXIT_FAILURE; }
@@ -181,13 +175,9 @@ int main(int argc, char **argv) } ret = close(txt_fd); } - /* - * The right test to do is "=>" (not ">") because of the additionnal - * ending \0. See below. - */ - if (filesize >= envsize) { - fprintf(stderr, "The input file is larger than the " - "envrionnment partition size\n"); + /* The +1 is for the additionnal ending \0. See below. */ + if (filesize + 1 > envsize) { + fprintf(stderr, "The input file is larger than the environment partition size\n"); return EXIT_FAILURE; }
@@ -236,8 +226,7 @@ int main(int argc, char **argv) * check the env size again to make sure we have room for two \0 */ if (ep >= envsize) { - fprintf(stderr, "The environment file is too large for " - "the target environment storage\n"); + fprintf(stderr, "The environment file is too large for the target environment storage\n"); return EXIT_FAILURE; } envptr[ep] = '\0';
This version is rebased on top of 'next' (it didn't apply anymore, after Horst Kronstorfer's patches).
tools/mkenvimage.c | 35 +++++++++++++++++------------------ 1 files changed, 17 insertions(+), 18 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 753d9e6..5f7d6ea 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -42,12 +42,9 @@
static void usage(const char *exec_name) { - fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " - "-s <environment partition size> -o <output> <input file>\n" + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] -s <environment partition size> -o <output> <input file>\n" "\n" - "This tool takes a key=value input file (same as would a " - "`printenv' show) and generates the corresponding environment " - "image, ready to be flashed.\n" + "This tool takes a key=value input file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed.\n" "\n" "\tThe input file is in format:\n" "\t\tkey1=value1\n" @@ -55,8 +52,7 @@ static void usage(const char *exec_name) "\t\t...\n" "\t-r : the environment has multiple copies in flash\n" "\t-b : the target is big endian (default is little endian)\n" - "\t-p <byte> : fill the image with <byte> bytes instead of " - "0xff bytes\n" + "\t-p <byte> : fill the image with <byte> bytes instead of 0xff bytes\n" "\t-V : print version information and exit\n" "\n" "If the input file is "-", data is read from standard input\n", @@ -94,8 +90,7 @@ int main(int argc, char **argv) case 'o': bin_filename = strdup(optarg); if (!bin_filename) { - fprintf(stderr, "Can't strdup() the output " - "filename\n"); + fprintf(stderr, "Can't strdup() the output filename\n"); return EXIT_FAILURE; } break; @@ -128,22 +123,21 @@ int main(int argc, char **argv)
/* Check datasize and allocate the data */ if (datasize == 0) { - fprintf(stderr, - "Please specify the size of the environment " - "partition.\n"); + fprintf(stderr, "Please specify the size of the environment partition.\n"); usage(argv[0]); return EXIT_FAILURE; }
/* * envptr points to the beginning of the actual environment (after the - * crc and possible `redundant' bit + * crc and possible `redundant' byte */ envsize = datasize - (CRC_SIZE + redundant); envptr = dataptr + CRC_SIZE + redundant; @@ -179,8 +173,8 @@ int main(int argc, char **argv) /* ... and check it */ ret = fstat(txt_fd, &txt_file_stat); if (ret == -1) { - fprintf(stderr, "Can't stat() on "%s": " - "%s\n", txt_filename, strerror(errno)); + fprintf(stderr, "Can't stat() on "%s": %s\n", + txt_filename, strerror(errno)); return EXIT_FAILURE; }
@@ -194,6 +188,7 @@ int main(int argc, char **argv) } ret = close(txt_fd); } +<<<<<<< HEAD /* * The right test to do is "=>" (not ">") because of the additional * ending \0. See below. @@ -201,6 +196,11 @@ int main(int argc, char **argv) if (filesize >= envsize) { fprintf(stderr, "The input file is larger than the " "environment partition size\n"); +======= + /* The +1 is for the additionnal ending \0. See below. */ + if (filesize + 1 > envsize) { + fprintf(stderr, "The input file is larger than the environment partition size\n"); +>>>>>>> mkenvimage: correct and clarify comments and error messages return EXIT_FAILURE; }
@@ -249,8 +249,7 @@ int main(int argc, char **argv) * check the env size again to make sure we have room for two \0 */ if (ep >= envsize) { - fprintf(stderr, "The environment file is too large for " - "the target environment storage\n"); + fprintf(stderr, "The environment file is too large for the target environment storage\n"); return EXIT_FAILURE; } envptr[ep] = '\0';
Le Wed, 21 Dec 2011 01:58:25 +0100, David Wagner david.wagner@free-electrons.com a écrit :
- /* The +1 is for the additionnal ending \0. See below. */
- if (filesize + 1 > envsize) {
Seems like your forgot to resolve some conflicts. A compile test would have detected those issues.
Regards,
Thomas
Regards,
Thomas
Ow. right...
However, I will first wait for Horst's patch 3/4 (print program basename instead of whole path in usage()) to be applied because even after correcting my mistake, it won't compile (patch 4/4, which have been applied on 'next', depends on 3/4).
Regards, David.
compiler.h and u-boot/crc.h need to be included from U-Boot's headers.
stdlib.h was missing.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index da54658..6af0d56 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -28,14 +28,15 @@ #include <errno.h> #include <fcntl.h> #include <stdio.h> +#include <stdlib.h> #include <stdint.h> #include <string.h> #include <unistd.h> -#include <compiler.h> +#include "compiler.h" #include <sys/types.h> #include <sys/stat.h>
-#include <u-boot/crc.h> +#include "u-boot/crc.h"
#define CRC_SIZE sizeof(uint32_t)
tools/mkenvimage.c | 15 +++------------ 1 files changed, 3 insertions(+), 12 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 5f7d6ea..b8b5c3a 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -28,14 +28,15 @@ #include <errno.h> #include <fcntl.h> #include <stdio.h> +#include <stdlib.h> #include <stdint.h> #include <string.h> #include <unistd.h> -#include <compiler.h> +#include "compiler.h" #include <sys/types.h> #include <sys/stat.h>
-#include <u-boot/crc.h> +#include "u-boot/crc.h" #include <version.h>
#define CRC_SIZE sizeof(uint32_t) @@ -188,19 +189,9 @@ int main(int argc, char **argv) } ret = close(txt_fd); } -<<<<<<< HEAD - /* - * The right test to do is "=>" (not ">") because of the additional - * ending \0. See below. - */ - if (filesize >= envsize) { - fprintf(stderr, "The input file is larger than the " - "environment partition size\n"); -======= /* The +1 is for the additionnal ending \0. See below. */ if (filesize + 1 > envsize) { fprintf(stderr, "The input file is larger than the environment partition size\n"); ->>>>>>> mkenvimage: correct and clarify comments and error messages return EXIT_FAILURE; }
Dear David Wagner,
In message 1324429120-10141-1-git-send-email-david.wagner@free-electrons.com you wrote:
Please rebase against current master and resubmit. Thanks.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 41 +++++++++++++++-------------------------- 1 files changed, 15 insertions(+), 26 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index c5ed373..7d33143 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -45,12 +45,9 @@
static void usage(const char *exec_name) { - fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " - "-s <environment partition size> -o <output> <input file>\n" + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] -s <environment partition size> -o <output> <input file>\n" "\n" - "This tool takes a key=value input file (same as would a " - "`printenv' show) and generates the corresponding environment " - "image, ready to be flashed.\n" + "This tool takes a key=value input file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed.\n" "\n" "\tThe input file is in format:\n" "\t\tkey1=value1\n" @@ -58,8 +55,7 @@ static void usage(const char *exec_name) "\t\t...\n" "\t-r : the environment has multiple copies in flash\n" "\t-b : the target is big endian (default is little endian)\n" - "\t-p <byte> : fill the image with <byte> bytes instead of " - "0xff bytes\n" + "\t-p <byte> : fill the image with <byte> bytes instead of 0xff bytes\n" "\t-V : print version information and exit\n" "\n" "If the input file is "-", data is read from standard input\n", @@ -100,8 +96,7 @@ int main(int argc, char **argv) case 'o': bin_filename = strdup(optarg); if (!bin_filename) { - fprintf(stderr, "Can't strdup() the output " - "filename\n"); + fprintf(stderr, "Can't strdup() the output filename\n"); return EXIT_FAILURE; } break; @@ -118,7 +113,7 @@ int main(int argc, char **argv) usage(prg); return EXIT_SUCCESS; case 'V': - printf("%s version %s\n", prg, PLAIN_VERSION); + printf("%s version %s\n", argv[0], PLAIN_VERSION); return EXIT_SUCCESS; case ':': fprintf(stderr, "Missing argument for option -%c\n", @@ -134,22 +129,21 @@ int main(int argc, char **argv)
/* Check datasize and allocate the data */ if (datasize == 0) { - fprintf(stderr, - "Please specify the size of the environment " - "partition.\n"); + fprintf(stderr, "Please specify the size of the environment partition.\n"); usage(prg); return EXIT_FAILURE; }
/* * envptr points to the beginning of the actual environment (after the - * crc and possible `redundant' bit + * crc and possible `redundant' byte */ envsize = datasize - (CRC_SIZE + redundant); envptr = dataptr + CRC_SIZE + redundant; @@ -185,8 +179,8 @@ int main(int argc, char **argv) /* ... and check it */ ret = fstat(txt_fd, &txt_file_stat); if (ret == -1) { - fprintf(stderr, "Can't stat() on "%s": " - "%s\n", txt_filename, strerror(errno)); + fprintf(stderr, "Can't stat() on "%s": %s\n", + txt_filename, strerror(errno)); return EXIT_FAILURE; }
@@ -200,13 +194,9 @@ int main(int argc, char **argv) } ret = close(txt_fd); } - /* - * The right test to do is "=>" (not ">") because of the additional - * ending \0. See below. - */ - if (filesize >= envsize) { - fprintf(stderr, "The input file is larger than the " - "environment partition size\n"); + /* The +1 is for the additionnal ending \0. See below. */ + if (filesize + 1 > envsize) { + fprintf(stderr, "The input file is larger than the environment partition size\n"); return EXIT_FAILURE; }
@@ -255,8 +245,7 @@ int main(int argc, char **argv) * check the env size again to make sure we have room for two \0 */ if (ep >= envsize) { - fprintf(stderr, "The environment file is too large for " - "the target environment storage\n"); + fprintf(stderr, "The environment file is too large for the target environment storage\n"); return EXIT_FAILURE; } envptr[ep] = '\0';
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 7d33143..bc18736 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -31,14 +31,15 @@ #include <errno.h> #include <fcntl.h> #include <stdio.h> +#include <stdlib.h> #include <stdint.h> #include <string.h> #include <unistd.h> -#include <compiler.h> +#include "compiler.h" #include <sys/types.h> #include <sys/stat.h>
these are fine
i don't think this is necessary -mike
compiler.h needs to be included from U-Boot's headers. Also, group U-Boot-specific includes together
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index c95f7f5..810a89e 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -31,13 +31,14 @@ #include <errno.h> #include <fcntl.h> #include <stdio.h> +#include <stdlib.h> #include <stdint.h> #include <string.h> #include <unistd.h> -#include <compiler.h> #include <sys/types.h> #include <sys/stat.h>
+#include "compiler.h" #include <u-boot/crc.h> #include <version.h>
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Verbosly fail if the target environment size or the padding byte are badly formated.
Verbosly fail if something bad happens when reading from standard input.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 32 ++++++++++++++++++++++++++++++-- 1 files changed, 30 insertions(+), 2 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index bc18736..eb9a8f2 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -93,7 +93,17 @@ int main(int argc, char **argv) switch (option) { case 's': datasize = strtol(optarg, NULL, 0); - break; + if (!errno) + break; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", + optarg); + else + fprintf(stderr, "Error while parsing %s: %s\n", + optarg, strerror(errno)); + + return EXIT_FAILURE; case 'o': bin_filename = strdup(optarg); if (!bin_filename) { @@ -109,7 +119,17 @@ int main(int argc, char **argv) break; case 'p': padbyte = strtol(optarg, NULL, 0); - break; + if (!errno) + break; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", + optarg); + else + fprintf(stderr, "Error while parsing %s: %s\n", + optarg, strerror(errno)); + + return EXIT_FAILURE; case 'h': usage(prg); return EXIT_SUCCESS; @@ -166,7 +186,15 @@ int main(int argc, char **argv)
do { filebuf = realloc(filebuf, readlen); + if (!filebuf) { + fprintf(stderr, "Can't realloc memory for the input file buffer\n"); + return EXIT_FAILURE; + } readbytes = read(txt_fd, filebuf + filesize, readlen); + if (errno) { + fprintf(stderr, "Error while reading stdin: %s\n", strerror(errno)); + return EXIT_FAILURE; + } filesize += readbytes; } while (readbytes == readlen);
break;
if (!errno)
break;
optarg);
else
seems like this should be a local xstrol() helper -mike
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 30 ++++++++++++++++++++++++++++-- 1 files changed, 28 insertions(+), 2 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 810a89e..9f2490e 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -63,6 +63,23 @@ static void usage(const char *exec_name) exec_name); }
+long int xstrtol(char *s) +{ + long int tmp; + + tmp = strtol(s, NULL, 0); + if (!errno) + return tmp; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", s); + else + fprintf(stderr, "Error while parsing %s: %s\n", s, + strerror(errno)); + + exit(EXIT_FAILURE); +} + int main(int argc, char **argv) { uint32_t crc, targetendian_crc; @@ -92,7 +109,7 @@ int main(int argc, char **argv) while ((option = getopt(argc, argv, ":s:o:rbp:hV")) != -1) { switch (option) { case 's': - datasize = strtol(optarg, NULL, 0); + datasize = xstrtol(optarg); break; case 'o': bin_filename = strdup(optarg); @@ -108,7 +125,7 @@ int main(int argc, char **argv) bigendian = 1; break; case 'p': - padbyte = strtol(optarg, NULL, 0); + padbyte = xstrtol(optarg); break; case 'h': usage(prg); @@ -166,7 +183,16 @@ int main(int argc, char **argv)
do { filebuf = realloc(filebuf, readlen); + if (!filebuf) { + fprintf(stderr, "Can't realloc memory for the input file buffer\n"); + return EXIT_FAILURE; + } readbytes = read(txt_fd, filebuf + filesize, readlen); + if (errno) { + fprintf(stderr, "Error while reading stdin: %s\n", + strerror(errno)); + return EXIT_FAILURE; + } filesize += readbytes; } while (readbytes == readlen);
const
- long int tmp;
- tmp = strtol(s, NULL, 0);
- if (!errno)
return tmp;
you should manually clear errno before calling strtol. it'll set the value, but won't clear it. -mike
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 31 +++++++++++++++++++++++++++++-- 1 files changed, 29 insertions(+), 2 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 810a89e..cc1deec 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -63,6 +63,24 @@ static void usage(const char *exec_name) exec_name); }
+long int xstrtol(const char *s) +{ + long int tmp; + + errno = 0; + tmp = strtol(s, NULL, 0); + if (!errno) + return tmp; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", s); + else + fprintf(stderr, "Error while parsing %s: %s\n", s, + strerror(errno)); + + exit(EXIT_FAILURE); +} + int main(int argc, char **argv) { uint32_t crc, targetendian_crc; @@ -92,7 +110,7 @@ int main(int argc, char **argv) while ((option = getopt(argc, argv, ":s:o:rbp:hV")) != -1) { switch (option) { case 's': - datasize = strtol(optarg, NULL, 0); + datasize = xstrtol(optarg); break; case 'o': bin_filename = strdup(optarg); @@ -108,7 +126,7 @@ int main(int argc, char **argv) bigendian = 1; break; case 'p': - padbyte = strtol(optarg, NULL, 0); + padbyte = xstrtol(optarg); break; case 'h': usage(prg); @@ -166,7 +184,16 @@ int main(int argc, char **argv)
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 26 +++++++++++++------------- 1 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index eb9a8f2..6db2b21 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -173,15 +173,9 @@ int main(int argc, char **argv) memset(envptr, padbyte, envsize);
/* Open the input file ... */ - if (optind >= argc) { - fprintf(stderr, "Please specify an input filename\n"); - return EXIT_FAILURE; - } - - txt_filename = argv[optind]; - if (strcmp(txt_filename, "-") == 0) { + if (optind >= argc || strcmp(argv[optind], "-") == 0) { int readbytes = 0; - int readlen = sizeof(*envptr) * 2048; + int readlen = sizeof(*envptr) * 4096; txt_fd = STDIN_FILENO;
do { @@ -199,6 +193,7 @@ int main(int argc, char **argv) } while (readbytes == readlen);
} else { + txt_filename = argv[optind]; txt_fd = open(txt_filename, O_RDONLY); if (txt_fd == -1) { fprintf(stderr, "Can't open "%s": %s\n", @@ -288,11 +283,16 @@ int main(int argc, char **argv)
memcpy(dataptr, &targetendian_crc, sizeof(uint32_t));
- bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); - if (bin_fd == -1) { - fprintf(stderr, "Can't open output file "%s": %s\n", - bin_filename, strerror(errno)); - return EXIT_FAILURE; + if (!bin_filename || strcmp(bin_filename, "-") == 0) { + bin_fd = STDOUT_FILENO; + } else { + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | + S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } }
if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) !=
S_IWGRP);
this should prob be open() -mike
S_IWGRP);
What is wrong with creat() ? from 'man 2 creat': creat() is equivalent to open() with flags equal to O_CREAT|O_WRONLY|O_TRUNC. We want to create the file if it doesn't exist and truncate it if it does.
The only issue I can think of is that no additional flag can be passed to creat(); fcntl can alter some of them. But will we need any ?
Regards, David.
S_IWGRP);
nothings wrong with it per-say ... just unusual ;). if you really want to keep it, then it's fine. -mike
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 15 +++++++++------ 1 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 6db2b21..58f1d0b 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -38,6 +38,7 @@ #include "compiler.h" #include <sys/types.h> #include <sys/stat.h> +#include <sys/mman.h>
#include "u-boot/crc.h" #include <version.h> @@ -209,14 +210,16 @@ int main(int argc, char **argv) }
filesize = txt_file_stat.st_size; - /* Read the raw input file and transform it */ - filebuf = malloc(sizeof(*envptr) * filesize); - ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); - if (ret != sizeof(*envptr) * filesize) { - fprintf(stderr, "Can't read the whole input file\n"); + + filebuf = mmap(NULL, sizeof(*envptr) * filesize, PROT_READ, + MAP_PRIVATE, txt_fd, 0); + ret = close(txt_fd); + if (filebuf == MAP_FAILED) { + fprintf(stderr, "mmap (%ld bytes) failed: %s\n", + sizeof(*envptr) * filesize, + strerror(errno)); return EXIT_FAILURE; } - ret = close(txt_fd); } /* The +1 is for the additionnal ending \0. See below. */ if (filesize + 1 > envsize) {
}strerror(errno)); return EXIT_FAILURE;
seems like the mmap() failure shouldn't be fatal. just have it fallback to the normal read()/write() logic. -mike
Fall back to read() if it fails.
I let an error message be printed when mmap fails, as the user may want to know why.
tools/mkenvimage.c | 25 +++++++++++++++++++------ 1 files changed, 19 insertions(+), 6 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 20e53b8..ca32df7 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -37,6 +37,7 @@ #include <unistd.h> #include <sys/types.h> #include <sys/stat.h> +#include <sys/mman.h>
#include "compiler.h" #include <u-boot/crc.h> @@ -210,12 +211,24 @@ int main(int argc, char **argv) }
filesize = txt_file_stat.st_size; - /* Read the raw input file and transform it */ - filebuf = malloc(sizeof(*envptr) * filesize); - ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); - if (ret != sizeof(*envptr) * filesize) { - fprintf(stderr, "Can't read the whole input file\n"); - return EXIT_FAILURE; + + filebuf = mmap(NULL, sizeof(*envptr) * filesize, PROT_READ, + MAP_PRIVATE, txt_fd, 0); + if (filebuf == MAP_FAILED) { + fprintf(stderr, "mmap (%ld bytes) failed: %s\n", + sizeof(*envptr) * filesize, + strerror(errno)); + fprintf(stderr, "Falling back to read()\n"); + + filebuf = malloc(sizeof(*envptr) * filesize); + ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); + if (ret != sizeof(*envptr) * filesize) { + fprintf(stderr, "Can't read the whole input file (%ld bytes): %s\n", + sizeof(*envptr) * filesize, + strerror(errno)); + + return EXIT_FAILURE; + } } ret = close(txt_fd); }
Remove this feature since it seems impossible to reliably detect them.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 8 -------- 1 files changed, 0 insertions(+), 8 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 58f1d0b..a3d4e27 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -249,14 +249,6 @@ int main(int argc, char **argv) /* End of a variable */ envptr[ep++] = '\0'; } - } else if (filebuf[fp] == '#') { - if (fp != 0 && filebuf[fp-1] == '\n') { - /* This line is a comment, let's skip it */ - while (fp < txt_file_stat.st_size && fp++ && - filebuf[fp] != '\n'); - } else { - envptr[ep++] = filebuf[fp]; - } } else { envptr[ep++] = filebuf[fp]; }
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index a3d4e27..c1e6cad 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -276,7 +276,9 @@ int main(int argc, char **argv) crc = crc32(0, envptr, envsize); targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc);
- memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + memcpy(dataptr, &targetendian_crc, sizeof(targetendian_crc)); + if (redundant) + dataptr[sizeof(targetendian_crc)] = 1;
if (!bin_filename || strcmp(bin_filename, "-") == 0) { bin_fd = STDOUT_FILENO;
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 6af0d56..b6e7f14 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -82,7 +82,17 @@ int main(int argc, char **argv) switch (option) { case 's': datasize = strtol(optarg, NULL, 0); - break; + if (!errno) + break; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", + optarg); + else + fprintf(stderr, "Error while parsing %s: %s\n", + optarg, strerror(errno)); + + return EXIT_FAILURE; case 'o': bin_filename = strdup(optarg); if (!bin_filename) { @@ -98,7 +108,17 @@ int main(int argc, char **argv) break; case 'p': padbyte = strtol(optarg, NULL, 0); - break; + if (!errno) + break; + + if (errno == ERANGE) + fprintf(stderr, "Bad integer format: %s\n", + optarg); + else + fprintf(stderr, "Error while parsing %s: %s\n", + optarg, strerror(errno)); + + return EXIT_FAILURE; case 'h': usage(argv[0]); return EXIT_SUCCESS; @@ -147,7 +167,15 @@ int main(int argc, char **argv)
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 11 +++-------- 1 files changed, 3 insertions(+), 8 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index b6e7f14..86a4e05 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -154,15 +154,9 @@ int main(int argc, char **argv) memset(envptr, padbyte, envsize);
do { @@ -180,6 +174,7 @@ int main(int argc, char **argv) } while (readbytes == readlen);
This 2nd version is a meld of the 1st version and patch 9
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index b6e7f14..ab67c1a 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -154,15 +154,9 @@ int main(int argc, char **argv) memset(envptr, padbyte, envsize);
} else { + txt_filename = argv[optind]; txt_fd = open(txt_filename, O_RDONLY); if (txt_fd == -1) { fprintf(stderr, "Can't open "%s": %s\n", @@ -269,11 +264,16 @@ int main(int argc, char **argv)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 86a4e05..74b296e 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -35,6 +35,7 @@ #include "compiler.h" #include <sys/types.h> #include <sys/stat.h> +#include <sys/mman.h>
@@ -190,14 +191,16 @@ int main(int argc, char **argv) }
filesize = txt_file_stat.st_size; - /* Read the raw input file and transform it */ - filebuf = malloc(sizeof(*envptr) * filesize); - ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); - if (ret != sizeof(*envptr) * filesize) { - fprintf(stderr, "Can't read the whole input file\n"); + + filebuf = mmap(NULL, sizeof(*envptr) * filesize, PROT_READ, + MAP_PRIVATE, txt_fd, 0); + ret = close(txt_fd); + if (filebuf == MAP_FAILED) { + fprintf(stderr, "mmap (%d bytes) failed: %s\n", + sizeof(*envptr) * filesize, + strerror(errno)); return EXIT_FAILURE; } - ret = close(txt_fd); } /* The +1 is for the additionnal ending \0. See below. */ if (filesize + 1 > envsize) {
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 74b296e..8d84c85 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -230,14 +230,6 @@ int main(int argc, char **argv) /* End of a variable */ envptr[ep++] = '\0'; } - } else if (filebuf[fp] == '#') { - if (fp != 0 && filebuf[fp-1] == '\n') { - /* This line is a comment, let's skip it */ - while (fp < txt_file_stat.st_size && fp++ && - filebuf[fp] != '\n'); - } else { - envptr[ep++] = filebuf[fp]; - } } else { envptr[ep++] = filebuf[fp]; }
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 8d84c85..fa6eb6e 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -257,7 +257,9 @@ int main(int argc, char **argv) crc = crc32(0, envptr, envsize); targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc);
- memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + memcpy(dataptr, &targetendian_crc, sizeof(targetendian_crc)); + if (redundant) + *(dataptr + sizeof(targetendian_crc)) = 1;
bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); if (bin_fd == -1) {
- if (redundant)
dataptr[sizeof(targetendian_crc)] = 1; -mike
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 221e9de..4e69056 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -257,7 +257,9 @@ int main(int argc, char **argv) crc = crc32(0, envptr, envsize); targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc);
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/mkenvimage.c | 14 +++++++++----- 1 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index fa6eb6e..8ba63d2 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -261,11 +261,15 @@ int main(int argc, char **argv) if (redundant) *(dataptr + sizeof(targetendian_crc)) = 1;
- bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); - if (bin_fd == -1) { - fprintf(stderr, "Can't open output file "%s": %s\n", - bin_filename, strerror(errno)); - return EXIT_FAILURE; + if (!bin_filename || strcmp(bin_filename, "-") == 0) { + bin_fd = STDOUT_FILENO; + } else { + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } }
squash this into the first stdin patch ? [PATCH 5/9] mkenvimage: Read from stdin if the filename is "-" -mike
Done, you can ignore this patch.
David.
don't see anything wrong with the latest patchset now, thanks! -mike
I re-sent 2 patches that didn't apply anymore on top of next (v2 2/10 and v2 3/10) ; the others should be fine.
I also sent one more patch ([PATCH 09/10] Correctly handle input files beginning with several newlines)
Could you please apply them ? I have one more patch in line that adds Cygwin support, still to be tested.
Thanks!
David.
See Thomas's answer : there are not resolved conflicts in your last patch. Solve them, and I will take care of the patchset. However, I do not know if it can go into the release (Wolfgang will decide about it).
Best regards, Stefano Babic
Dear David Wagner,
In message 1322080098-3151-1-git-send-email-david.wagner@free-electrons.com you wrote:
Sorry, but this patch series has become a mess; we have the original 1-9 series, then a v2 1-10, then v3 1-8, and even a v4 1-8, with htese later series all being sparse ones. Sonce the number of patches changed several times, it's totally unclear to me which would be the correct series to apply.
Please rebase and post a cleaned up complete series. Thanks.
All right, I'll send a "v5" for all the patches.
Best regards, David.
participants (5)
David Wagner
Mike Frysinger
Stefano Babic
Thomas Petazzoni
