[U-Boot] [RFC PATCH] rockchip: tinker: Add boot from capability
We need to know from what device we are booting in order to save the enviroment in right place
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/dts/rk3288-tinker-s-u-boot.dtsi | 1 + arch/arm/mach-rockchip/rk3288/rk3288.c | 46 ++++++++++++++++++++ board/rockchip/tinker_rk3288/tinker-rk3288.c | 41 +++++++++++++++++ configs/tinker-rk3288_defconfig | 2 + configs/tinker-s-rk3288_defconfig | 2 + 5 files changed, 92 insertions(+)
diff --git a/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi b/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi index 538593359a..2193127514 100644 --- a/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi +++ b/arch/arm/dts/rk3288-tinker-s-u-boot.dtsi @@ -10,6 +10,7 @@ chosen { u-boot,spl-boot-order = \ "same-as-spl", &sdmmc, &emmc; + u-boot,spl-boot-device = "/dwmmc@ff0f0000"; }; };
diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index 987b4e0d58..002d1508e5 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -3,6 +3,8 @@ * Copyright (c) 2016 Rockchip Electronics Co., Ltd */ #include <common.h> +#include <spl.h> +#include <fdt_support.h> #include <dm.h> #include <env.h> #include <clk.h> @@ -26,6 +28,50 @@ const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_SD] = "/dwmmc@ff0c0000", };
+#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_TPL_BUILD) +const char *spl_decode_boot_device(u32 boot_device) +{ + int i; + static const struct { + u32 boot_device; + const char *ofpath; + } spl_boot_devices_tbl[] = { + { BOOT_DEVICE_MMC2, "/dwmmc@ff0f0000" }, + { BOOT_DEVICE_MMC1, "/dwmmc@ff0c0000" }, + }; + + for (i = 0; i < ARRAY_SIZE(spl_boot_devices_tbl); ++i) + if (spl_boot_devices_tbl[i].boot_device == boot_device) + return spl_boot_devices_tbl[i].ofpath; + + return NULL; +} + +void spl_perform_fixups(struct spl_image_info *spl_image) +{ + void *blob = (void *)gd->fdt_blob; + const char *boot_ofpath; + int chosen; + + if (!blob) + return; + + boot_ofpath = spl_decode_boot_device(spl_image->boot_device); + if (!boot_ofpath) { + pr_err("%s: could not map boot_device to ofpath\n", __func__); + return; + } + + chosen = fdt_find_or_add_subnode(blob, 0, "chosen"); + if (chosen < 0) { + pr_err("%s: could not find/create '/chosen'\n", __func__); + return; + } + fdt_setprop_string(blob, chosen, + "u-boot,spl-boot-device", boot_ofpath); +} +#endif + #ifdef CONFIG_SPL_BUILD static void configure_l2ctlr(void) { diff --git a/board/rockchip/tinker_rk3288/tinker-rk3288.c b/board/rockchip/tinker_rk3288/tinker-rk3288.c index 6c76c3c25c..66a7394d95 100644 --- a/board/rockchip/tinker_rk3288/tinker-rk3288.c +++ b/board/rockchip/tinker_rk3288/tinker-rk3288.c @@ -9,6 +9,34 @@ #include <i2c_eeprom.h> #include <netdev.h>
+static int tinker_boot_device = CONFIG_SYS_MMC_ENV_DEV; + +/* + * Select the boot device according to what was set in spl step + */ +static int setup_boottargets(void) +{ + const char *boot_device = + ofnode_get_chosen_prop("u-boot,spl-boot-device"); + + if (!boot_device) { + debug("%s: /chosen/u-boot,spl-boot-device not set\n", + __func__); + return -1; + } + debug("%s: booted from %s\n", __func__, boot_device); + + if (!strcmp(boot_device, "/dwmmc@ff0f0000")) { + /* eMMC boot device */ + tinker_boot_device = 1; + } else { + /* sdcard boot device */ + tinker_boot_device = 0; + } + + return 0; +} + static int get_ethaddr_from_eeprom(u8 *addr) { int ret; @@ -33,3 +61,16 @@ int rk3288_board_late_init(void)
return 0; } + +int misc_init_r(void) +{ + setup_boottargets(); + + return 0; +} + +int mmc_get_env_dev(void) +{ + debug("boot device %d\n", tinker_boot_device); + return tinker_boot_device; +} diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index c851a93f31..106e24e8ca 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -13,7 +13,9 @@ CONFIG_DEBUG_UART=y CONFIG_TPL_SYS_MALLOC_F_LEN=0x4000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_OF_LIBFDT=y # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_MISC_INIT_R=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index c851a93f31..106e24e8ca 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -13,7 +13,9 @@ CONFIG_DEBUG_UART=y CONFIG_TPL_SYS_MALLOC_F_LEN=0x4000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_OF_LIBFDT=y # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_MISC_INIT_R=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y
Hi Michael,
Please make sure board_spl_was_booted_from() works for rk3288, which
already work for rk3399, after that, we can move those functions from rk3399
only into common code to make everything work.
We are not going to add "spl-boot-device".
Thanks,
- Kever
}; };u-boot,spl-boot-device = "/dwmmc@ff0f0000";
- Copyright (c) 2016 Rockchip Electronics Co., Ltd
- int i;
- static const struct {
u32 boot_device;
const char *ofpath;
- } spl_boot_devices_tbl[] = {
- for (i = 0; i < ARRAY_SIZE(spl_boot_devices_tbl); ++i)
- return NULL;
- void *blob = (void *)gd->fdt_blob;
- const char *boot_ofpath;
- int chosen;
- if (!blob)
return;
- boot_ofpath = spl_decode_boot_device(spl_image->boot_device);
- if (!boot_ofpath) {
return;
- chosen = fdt_find_or_add_subnode(blob, 0, "chosen");
- if (chosen < 0) {
return;
- fdt_setprop_string(blob, chosen,
+} +#endif
- #ifdef CONFIG_SPL_BUILD static void configure_l2ctlr(void) {
- Select the boot device according to what was set in spl step
- const char *boot_device =
- if (!boot_device) {
__func__);
return -1;
- debug("%s: booted from %s\n", __func__, boot_device);
- if (!strcmp(boot_device, "/dwmmc@ff0f0000")) {
- } else {
- static int get_ethaddr_from_eeprom(u8 *addr) { int ret;
return 0; }
- setup_boottargets();
- debug("boot device %d\n", tinker_boot_device);
- return tinker_boot_device;
Hi Kever
On Tue, Nov 12, 2019 at 10:57 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Michael,
That implementation has no sense in my use case. You need fit image. I don't need any special change
Michael
Thanks,
- Kever
};u-boot,spl-boot-device = "/dwmmc@ff0f0000"; };
int i;
u32 boot_device;
const char *ofpath;
return NULL;
int chosen;
if (!blob)
return;
if (!boot_ofpath) {
return;
if (chosen < 0) {
return;
+} +#endif
if (!boot_device) {
__func__);
return -1;
} else {
Hi Kever
Let me more clear
On Tue, Nov 12, 2019 at 11:02 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi Kever
Hi Michael,
I don't re-allocate the dtb so the size in no-fit image is the same. I think that we can use some meta-tag for bootloader to store information from spl to second stage. You need to keep in the same size or you have -ENOSPACE. This can be generic but depends what the maintair think.
Michael
Michael
Thanks,
- Kever
int i;
u32 boot_device;
const char *ofpath;
return NULL;
int chosen;
if (!blob)
return;
if (!boot_ofpath) {
return;
if (chosen < 0) {
return;
+} +#endif
if (!boot_device) {
__func__);
return -1;
} else {
-- | Michael Nazzareno Trimarchi Amarula Solutions BV | | COO - Founder Cruquiuskade 47 | | +31(0)851119172 Amsterdam 1018 AM NL | | [`as] http://www.amarulasolutions.com |
On 2019/11/12 下午6:02, Michael Nazzareno Trimarchi wrote:
Hi Kever
Hi Michael,
I don't understand what you want to do.
The implementation is to get boot device from bootRom and convert it to the device in SPL dt,
why it has no sense?
Thanks,
- Kever
Michael
Thanks,
- Kever
int i;
u32 boot_device;
const char *ofpath;
return NULL;
int chosen;
if (!blob)
return;
if (!boot_ofpath) {
return;
if (chosen < 0) {
return;
+} +#endif
if (!boot_device) {
__func__);
return -1;
} else {
Hi Kever
Hi Kever
Hi Michael,
commit 75014470aec60580978962071972f2962695938d Author: Philipp Tomsich philipp.tomsich@theobroma-systems.com Date: Wed Sep 13 21:29:30 2017 +0200
spl: add a fdt_addr field to spl_image_info
When loading a full U-Boot with detached device-tree using the SPL FIT backend, we should store the address of the FDT loaded as part of the SPL image info: this allows us to fixup the FDT with additional info we may want to propagate onward.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org
The change rk3399 use is a detached device-tree. This not cover all the use case. I'm using some place holder to pass the information to next stage without detach it
Michael
Thanks,
- Kever
Michael
Thanks,
- Kever
int i;
u32 boot_device;
const char *ofpath;
return NULL;
int chosen;
if (!blob)
return;
if (!boot_ofpath) {
return;
if (chosen < 0) {
return;
+} +#endif
if (!boot_device) {
__func__);
return -1;
} else {
Hi
Drop it
+int mmc_get_env_dev(void) +{ + u32 bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + + if (bootdevice_brom_id == BROM_BOOTSOURCE_EMMC) + return 0; + + return 1; +}
THis is enough for tinker
Michael
On Wed, Nov 13, 2019 at 8:50 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi Kever
Hi Kever
Hi Michael,
spl: add a fdt_addr field to spl_image_info When loading a full U-Boot with detached device-tree using the SPL FIT backend, we should store the address of the FDT loaded as part of the SPL image info: this allows us to fixup the FDT with additional info we may want to propagate onward. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
Michael
Thanks,
- Kever
Michael
Thanks,
- Kever
int i;
u32 boot_device;
const char *ofpath;
return NULL;
int chosen;
if (!blob)
return;
if (!boot_ofpath) {
return;
if (chosen < 0) {
return;
+} +#endif
if (!boot_device) {
__func__);
return -1;
} else {
Kever Yang
Michael Trimarchi
